--- ray/src/util/netproc.c 1996/01/18 11:24:53 2.1 +++ ray/src/util/netproc.c 1997/10/28 14:01:39 2.8 @@ -9,51 +9,27 @@ static char SCCSid[] = "$SunId$ LBL"; */ #include -#include #include #include +#include "selcall.h" #include "netproc.h" +#include "paths.h" #include "vfork.h" - /* Remote shell location */ -#ifdef sgi -#define RSH "/usr/bsd/rsh" -#endif -#ifdef _AUX_SOURCE -#define RSH "/usr/bin/remsh" -#endif -#ifndef RSH -#define RSH "/usr/ucb/rsh" -#endif - /* select call compatibility stuff */ -#ifndef FD_SETSIZE -#include -#define FD_SETSIZE NOFILE /* maximum # select file descriptors */ -#endif -#ifndef FD_SET -#ifndef NFDBITS -#define NFDBITS (8*sizeof(int)) /* number of bits per fd_mask */ -#endif -#define FD_SET(n, p) ((p)->fds_bits[(n)/NFDBITS] |= (1 << ((n) % NFDBITS))) -#define FD_CLR(n, p) ((p)->fds_bits[(n)/NFDBITS] &= ~(1 << ((n) % NFDBITS))) -#define FD_ISSET(n, p) ((p)->fds_bits[(n)/NFDBITS] & (1 << ((n) % NFDBITS))) -#ifndef BSD -#define bzero(d,n) (void)memset(d,0,n) -#endif -#define FD_ZERO(p) bzero((char *)(p), sizeof(*(p))) -#endif PSERVER *pslist = NULL; /* global process server list */ static PROC *pindex[FD_SETSIZE]; /* process index table */ static char ourhost[64]; /* this host name */ -static char ourdir[128]; /* our working directory */ +static char ourdir[MAXPATH]; /* our working directory */ static char ouruser[32]; /* our user name */ static char *ourshell; /* our user's shell */ static fd_set errdesc; /* error file descriptors */ static int maxfd; /* maximum assigned descriptor */ +extern char *remsh; /* externally defined remote shell program */ + extern char *malloc(), *realloc(); extern char *getenv(); @@ -71,12 +47,12 @@ int np; if (ps == NULL) return(NULL); if (!ourhost[0]) { /* initialize */ - char dirtmp[128]; + char dirtmp[MAXPATH]; register char *cp; register int len; - gethostname(ourhost, sizeof(ourhost)); - getcwd(dirtmp, sizeof(dirtmp)); + strcpy(ourhost, myhostname()); + getwd(dirtmp); if ((cp = getenv("HOME")) != NULL) { if (!strcmp(cp, dirtmp)) ourdir[0] = '\0'; @@ -177,7 +153,8 @@ register PSERVER *ps; char *command; int (*compf)(); { - char *av[12]; + char udirt[MAXPATH]; + char *av[16]; int pfd[2], pid; register int i; @@ -205,14 +182,19 @@ int (*compf)(); close(pfd[1]); } if (ps->hostname[0]) { /* rsh command */ - av[i=0] = RSH; + av[i=0] = remsh; av[++i] = ps->hostname; - av[++i] = "-n"; /* no stdin */ - if (ps->username[0]) { + av[++i] = "-n"; /* no stdin */ + if (ps->username[0]) { /* different user */ av[++i] = "-l"; av[++i] = ps->username; + av[++i] = "cd"; + udirt[0] = '~'; + strcpy(udirt+1, ouruser); + av[++i] = udirt; + av[++i] = ";"; } - if (ps->directory[0]) { + if (ps->directory[0]) { /* change directory */ av[++i] = "cd"; av[++i] = ps->directory; av[++i] = ";";
