root/Development/ray/src/util/netproc.c
Mon Mar 15 21:31:50 2010 UTC (15 years, 7 months ago) by greg
CVS Tags: HEAD, rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0, rad5R1, rad5R2, rad5R3, rad5R4, rad6R0
Changes since 2.16: +8 -6 lines
Changed behavior so no change to remote user directory if full path given
Mon Sep 20 16:26:58 2004 UTC (21 years, 1 month ago) by greg
Fri Mar 26 21:36:19 2004 UTC (21 years, 7 months ago) by schorsch
Changes since 2.14: +43 -27 lines
Continued ANSIfication.
Tue Nov 11 16:24:06 2003 UTC (22 years ago) by greg
Mon Nov 10 16:52:24 2003 UTC (22 years ago) by greg
Changes since 2.12: +1 -2 lines
Diff to previous 2.12
Mon Oct 27 10:32:06 2003 UTC (22 years ago) by schorsch
Changes since 2.11: +7 -7 lines
Mon Jun 30 14:59:13 2003 UTC (22 years, 4 months ago) by schorsch
Changes since 2.10: +7 -5 lines
Wed Apr 23 00:52:34 2003 UTC (22 years, 6 months ago) by greg
Sat Feb 22 02:07:30 2003 UTC (22 years, 8 months ago) by greg
Changes since 2.8: +3 -7 lines
Tue Oct 28 14:01:39 1997 UTC (28 years ago) by gregl
Changes since 2.7: +1 -21 lines
created selcall.h include file for select(2) compatibility
Thu Oct 16 13:48:49 1997 UTC (28 years ago) by gregl
added ifdef for INCL_SEL_H since not every system has it
Thu Sep 18 16:10:19 1997 UTC (28 years, 1 month ago) by gregl
added include of sys/select.h for AIX machines
Mon Jun 24 10:06:40 1996 UTC (29 years, 4 months ago) by greg
Changes since 2.4: +4 -4 lines
added conditional use of getwd()
Mon Mar 4 09:22:50 1996 UTC (29 years, 8 months ago) by greg
Changes since 2.3: +5 -4 lines
changed getcwd() call to getwd()
Tue Feb 20 15:55:01 1996 UTC (29 years, 8 months ago) by greg
Changes since 2.2: +13 -15 lines
added RSH variable to rename or replace remote shell execution
Wed Feb 7 16:42:45 1996 UTC (29 years, 9 months ago) by greg
moved host name stuff to lib routine
Thu Jan 18 11:24:53 1996 UTC (29 years, 9 months ago) by greg
Diff to selected 2.12
