1 |
/* Copyright (c) 1996 Regents of the University of California */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ LBL"; |
5 |
#endif |
6 |
7 |
8 |
* Parallel network process handling routines |
9 |
10 |
11 |
#include <stdio.h> |
12 |
#include <sys/types.h> |
13 |
#include <signal.h> |
14 |
#include <fcntl.h> |
15 |
#include "netproc.h" |
16 |
#include "vfork.h" |
17 |
/* Remote shell location */ |
18 |
#ifdef sgi |
19 |
#define RSH "/usr/bsd/rsh" |
20 |
#endif |
21 |
#ifdef _AUX_SOURCE |
22 |
#define RSH "/usr/bin/remsh" |
23 |
#endif |
24 |
#ifndef RSH |
25 |
#define RSH "/usr/ucb/rsh" |
26 |
#endif |
27 |
/* select call compatibility stuff */ |
28 |
#ifndef FD_SETSIZE |
29 |
#include <sys/param.h> |
30 |
#define FD_SETSIZE NOFILE /* maximum # select file descriptors */ |
31 |
#endif |
32 |
#ifndef FD_SET |
33 |
#ifndef NFDBITS |
34 |
#define NFDBITS (8*sizeof(int)) /* number of bits per fd_mask */ |
35 |
#endif |
36 |
#define FD_SET(n, p) ((p)->fds_bits[(n)/NFDBITS] |= (1 << ((n) % NFDBITS))) |
37 |
#define FD_CLR(n, p) ((p)->fds_bits[(n)/NFDBITS] &= ~(1 << ((n) % NFDBITS))) |
38 |
#define FD_ISSET(n, p) ((p)->fds_bits[(n)/NFDBITS] & (1 << ((n) % NFDBITS))) |
39 |
#ifndef BSD |
40 |
#define bzero(d,n) (void)memset(d,0,n) |
41 |
#endif |
42 |
#define FD_ZERO(p) bzero((char *)(p), sizeof(*(p))) |
43 |
#endif |
44 |
45 |
PSERVER *pslist = NULL; /* global process server list */ |
46 |
47 |
static PROC *pindex[FD_SETSIZE]; /* process index table */ |
48 |
49 |
static char ourhost[64]; /* this host name */ |
50 |
static char ourdir[128]; /* our working directory */ |
51 |
static char ouruser[32]; /* our user name */ |
52 |
static char *ourshell; /* our user's shell */ |
53 |
54 |
static fd_set errdesc; /* error file descriptors */ |
55 |
static int maxfd; /* maximum assigned descriptor */ |
56 |
57 |
extern char *malloc(), *realloc(); |
58 |
extern char *getenv(); |
59 |
60 |
61 |
PSERVER * |
62 |
addpserver(host, dir, usr, np) /* add a new process server */ |
63 |
char *host, *dir, *usr; |
64 |
int np; |
65 |
66 |
register PSERVER *ps; |
67 |
/* allocate the struct */ |
68 |
if (np < 1) |
69 |
return(NULL); |
70 |
ps = (PSERVER *)malloc(sizeof(PSERVER)+(np-1)*sizeof(PROC)); |
71 |
if (ps == NULL) |
72 |
return(NULL); |
73 |
if (!ourhost[0]) { /* initialize */ |
74 |
char dirtmp[128]; |
75 |
register char *cp; |
76 |
register int len; |
77 |
78 |
strcpy(ourhost, myhostname()); |
79 |
getcwd(dirtmp, sizeof(dirtmp)); |
80 |
if ((cp = getenv("HOME")) != NULL) { |
81 |
if (!strcmp(cp, dirtmp)) |
82 |
ourdir[0] = '\0'; |
83 |
else if (!strncmp(cp, dirtmp, len=strlen(cp)) && |
84 |
dirtmp[len] == '/') |
85 |
strcpy(ourdir, dirtmp+len+1); |
86 |
else |
87 |
strcpy(ourdir, dirtmp); |
88 |
} else |
89 |
90 |
if ((cp = getenv("USER")) != NULL) |
91 |
strcpy(ouruser, cp); |
92 |
if ((ourshell = getenv("SHELL")) == NULL) |
93 |
ourshell = "/bin/sh"; |
94 |
FD_ZERO(&errdesc); |
95 |
maxfd = -1; |
96 |
97 |
/* assign host, directory, user */ |
98 |
if (host == NULL || !strcmp(host, ourhost) || |
99 |
!strcmp(host, LHOSTNAME)) |
100 |
ps->hostname[0] = '\0'; |
101 |
else |
102 |
strcpy(ps->hostname, host); |
103 |
if (dir == NULL) |
104 |
strcpy(ps->directory, ourdir); |
105 |
else |
106 |
strcpy(ps->directory, dir); |
107 |
if (usr == NULL || !strcmp(usr, ouruser)) |
108 |
ps->username[0] = '\0'; |
109 |
else |
110 |
strcpy(ps->username, usr); |
111 |
/* clear process slots */ |
112 |
ps->nprocs = np; |
113 |
while (np--) { |
114 |
ps->proc[np].com = NULL; |
115 |
ps->proc[np].pid = -1; |
116 |
ps->proc[np].efd = -1; |
117 |
ps->proc[np].errs = NULL; |
118 |
ps->proc[np].elen = 0; |
119 |
ps->proc[np].cf = NULL; |
120 |
121 |
/* insert in our list */ |
122 |
ps->next = pslist; |
123 |
pslist = ps; |
124 |
/* check for signs of life */ |
125 |
if (!pserverOK(ps)) { |
126 |
delpserver(ps); /* failure -- abort */ |
127 |
return(NULL); |
128 |
129 |
return(ps); |
130 |
131 |
132 |
133 |
delpserver(ps) /* delete a process server */ |
134 |
PSERVER *ps; |
135 |
136 |
PSERVER pstart; |
137 |
register PSERVER *psp; |
138 |
register int i; |
139 |
/* find server in our list */ |
140 |
pstart.next = pslist; |
141 |
for (psp = &pstart; ps != psp->next; psp = psp->next) |
142 |
if (psp->next == NULL) |
143 |
return; /* not in our list! */ |
144 |
/* kill any running jobs */ |
145 |
for (i = 0; i < ps->nprocs; i++) |
146 |
if (ps->proc[i].com != NULL) { |
147 |
kill(SIGTERM, ps->proc[i].pid); |
148 |
wait4job(ps, ps->proc[i].pid); |
149 |
150 |
/* remove server from list */ |
151 |
psp->next = ps->next; |
152 |
pslist = pstart.next; |
153 |
free((char *)ps); /* free associated memory */ |
154 |
155 |
156 |
157 |
PSERVER * |
158 |
findjob(pnp) /* find out where process is running */ |
159 |
register int *pnp; /* modified */ |
160 |
161 |
162 |
register int i; |
163 |
164 |
for (ps = pslist; ps != NULL; ps = ps->next) |
165 |
166 |
if (ps->proc[i].pid == *pnp) { |
167 |
*pnp = i; |
168 |
return(ps); |
169 |
170 |
return(NULL); /* not found */ |
171 |
172 |
173 |
174 |
int |
175 |
startjob(ps, command, compf) /* start a job on a process server */ |
176 |
177 |
char *command; |
178 |
int (*compf)(); |
179 |
180 |
char *av[12]; |
181 |
int pfd[2], pid; |
182 |
register int i; |
183 |
184 |
if (ps == NULL) { /* find a server */ |
185 |
186 |
if ((i = startjob(ps, command, compf)) != -1) |
187 |
return(i); /* got one */ |
188 |
return(-1); /* no slots anywhere */ |
189 |
190 |
191 |
if (ps->proc[i].com == NULL) |
192 |
break; |
193 |
if (i >= ps->nprocs) |
194 |
return(-1); /* out of process slots */ |
195 |
/* open pipe */ |
196 |
if (pipe(pfd) < 0) { |
197 |
perror("cannot open pipe"); |
198 |
exit(1); |
199 |
200 |
/* start child process */ |
201 |
if ((pid = vfork()) == 0) { |
202 |
close(pfd[0]); /* connect stderr to pipe */ |
203 |
if (pfd[1] != 2) { |
204 |
dup2(pfd[1], 2); |
205 |
close(pfd[1]); |
206 |
207 |
if (ps->hostname[0]) { /* rsh command */ |
208 |
av[i=0] = RSH; |
209 |
av[++i] = ps->hostname; |
210 |
av[++i] = "-n"; /* no stdin */ |
211 |
if (ps->username[0]) { |
212 |
av[++i] = "-l"; |
213 |
av[++i] = ps->username; |
214 |
215 |
if (ps->directory[0]) { |
216 |
av[++i] = "cd"; |
217 |
av[++i] = ps->directory; |
218 |
av[++i] = ";"; |
219 |
220 |
av[++i] = command; |
221 |
av[++i] = NULL; |
222 |
} else { /* shell command */ |
223 |
av[0] = ourshell; |
224 |
av[1] = "-c"; |
225 |
av[2] = command; |
226 |
av[3] = NULL; |
227 |
228 |
execv(av[0], av); |
229 |
_exit(1); |
230 |
231 |
if (pid == -1) { |
232 |
perror("fork failed"); |
233 |
exit(1); |
234 |
235 |
ps->proc[i].com = command; /* assign process slot */ |
236 |
ps->proc[i].cf = compf; |
237 |
ps->proc[i].pid = pid; |
238 |
close(pfd[1]); /* get piped stderr file descriptor */ |
239 |
ps->proc[i].efd = pfd[0]; |
240 |
fcntl(pfd[0], F_SETFD, 1); /* set close on exec flag */ |
241 |
pindex[pfd[0]] = ps->proc + i; /* assign error fd index */ |
242 |
FD_SET(pfd[0], &errdesc); /* add to select call parameter */ |
243 |
if (pfd[0] > maxfd) |
244 |
maxfd = pfd[0]; |
245 |
return(pid); /* return to parent process */ |
246 |
247 |
248 |
249 |
static int |
250 |
readerrs(fd) /* read error output from fd */ |
251 |
int fd; |
252 |
253 |
char errbuf[BUFSIZ]; |
254 |
int nr; |
255 |
register PROC *pp; |
256 |
/* look up associated process */ |
257 |
if ((pp = pindex[fd]) == NULL) |
258 |
abort(); /* serious consistency error */ |
259 |
nr = read(fd, errbuf, BUFSIZ-1); |
260 |
if (nr < 0) { |
261 |
perror("read error"); |
262 |
exit(1); |
263 |
264 |
if (nr == 0) /* stream closed (process finished) */ |
265 |
return(0); |
266 |
errbuf[nr] = '\0'; /* add to error buffer */ |
267 |
if (pp->elen == 0) |
268 |
pp->errs = (char *)malloc(nr+1); |
269 |
else |
270 |
pp->errs = (char *)realloc(pp->errs, pp->elen+nr+1); |
271 |
if (pp->errs == NULL) { |
272 |
perror("malloc failed"); |
273 |
exit(1); |
274 |
275 |
strcpy(pp->errs+pp->elen, errbuf); |
276 |
pp->elen += nr; |
277 |
return(nr); |
278 |
279 |
280 |
281 |
static |
282 |
wait4end() /* read error streams until someone is done */ |
283 |
284 |
fd_set readfds, excepfds; |
285 |
register int i; |
286 |
/* find end of descriptor set */ |
287 |
for ( ; maxfd >= 0; maxfd--) |
288 |
if (FD_ISSET(maxfd, &errdesc)) |
289 |
break; |
290 |
if (maxfd < 0) |
291 |
return; /* nothing to read */ |
292 |
readfds = excepfds = errdesc; |
293 |
while (select(maxfd+1, &readfds, NULL, &excepfds, NULL) > 0) |
294 |
for (i = 0; i <= maxfd; i++) /* get pending i/o */ |
295 |
if (FD_ISSET(i, &readfds) || FD_ISSET(i, &excepfds)) |
296 |
if (readerrs(i) == 0) |
297 |
return; /* finished process */ |
298 |
perror("select call failed"); |
299 |
exit(1); |
300 |
301 |
302 |
303 |
static int |
304 |
finishjob(ps, pn, status) /* clean up finished process */ |
305 |
PSERVER *ps; |
306 |
int pn; |
307 |
int status; |
308 |
309 |
310 |
311 |
pp = ps->proc + pn; |
312 |
if (pp->cf != NULL) /* client cleanup */ |
313 |
status = (*pp->cf)(ps, pn, status); |
314 |
close(pp->efd); /* close error stream */ |
315 |
pindex[pp->efd] = NULL; |
316 |
FD_CLR(pp->efd, &errdesc); |
317 |
free((char *)pp->errs); |
318 |
pp->com = NULL; /* clear settings */ |
319 |
pp->pid = -1; |
320 |
pp->efd = -1; |
321 |
pp->errs = NULL; |
322 |
pp->elen = 0; |
323 |
pp->cf = NULL; |
324 |
return(status); |
325 |
326 |
327 |
328 |
int |
329 |
wait4job(ps, pid) /* wait for process to finish */ |
330 |
PSERVER *ps; |
331 |
int pid; |
332 |
333 |
int status, psn, psn2; |
334 |
PSERVER *ps2; |
335 |
336 |
if (pid == -1) { /* wait for first job */ |
337 |
if (ps != NULL) { |
338 |
for (psn = ps->nprocs; psn--; ) |
339 |
if (ps->proc[psn].com != NULL) |
340 |
break; |
341 |
if (psn < 0) |
342 |
return(-1); /* no processes this server */ |
343 |
344 |
do { |
345 |
wait4end(); /* wait for something to end */ |
346 |
if ((psn2 = wait(&status)) == -1) |
347 |
return(-1); /* none left */ |
348 |
ps2 = findjob(&psn2); |
349 |
if (ps2 != NULL) /* clean up job if ours */ |
350 |
status = finishjob(ps2, psn2, status); |
351 |
} while (ps2 == NULL || (ps != NULL && ps2 != ps)); |
352 |
return(status); /* return job status */ |
353 |
354 |
psn = pid; /* else find specific job */ |
355 |
ps2 = findjob(&psn); /* find process slot */ |
356 |
if (ps2 == NULL || (ps != NULL && ps2 != ps)) |
357 |
return(-1); /* inconsistent target */ |
358 |
ps = ps2; |
359 |
do { |
360 |
361 |
362 |
363 |
364 |
365 |
366 |
} while (ps2 != ps || psn2 != psn); |
367 |
368 |
