1 |
greg |
1.1 |
#ifndef lint |
2 |
greg |
2.4 |
static const char RCSid[] = "$Id$"; |
3 |
greg |
1.1 |
#endif |
4 |
5 |
* makedist.c - program to make a source distribution. |
6 |
7 |
* 8/18/86 |
8 |
9 |
* Program uses angular coordinates as follows: |
10 |
11 |
* alpha - degrees measured from x1 axis. |
12 |
* beta - degress of projection into x2x3 plane, |
13 |
* measured from x2 axis towards x3 axis. |
14 |
15 |
* Default axes are (x1,x2,x3) = (x,y,z). |
16 |
17 |
18 |
#include <stdio.h> |
19 |
20 |
greg |
2.4 |
#include <stdlib.h> |
21 |
22 |
greg |
1.1 |
#include "random.h" |
23 |
24 |
greg |
1.2 |
#include "setscan.h" |
25 |
greg |
1.1 |
26 |
greg |
1.3 |
#ifndef BSD |
27 |
#define vfork fork |
28 |
#endif |
29 |
greg |
1.1 |
30 |
#define FTINY 1e-7 |
31 |
32 |
#define PI 3.14159265358979324 |
33 |
34 |
#define atorad(a) ((PI/180.0) * (a)) |
35 |
36 |
char *rtargv[128] = {"rtrace", "-h"}; |
37 |
int rtargc = 2; |
38 |
39 |
#define passarg(s) (rtargv[rtargc++] = s) |
40 |
41 |
ANGLE alpha[181] = {10, 25, 40, 55, 70, 85, AEND}; |
42 |
ANGLE beta[361] = {0,30,60,90,120,150,180,210,240,270,300,330,AEND}; |
43 |
44 |
/* coordinate system */ |
45 |
double axis[3][3] = {{1,0,0},{0,1,0},{0,0,1}}; |
46 |
47 |
double targetw = 1.0; /* target width */ |
48 |
double targeth = 1.0; /* target height */ |
49 |
double targetd = 1.0; /* target distance */ |
50 |
double targetp[3] = {0,0,0}; /* target center */ |
51 |
int xres = 16; /* x sample resolution */ |
52 |
int yres = 16; /* y sample resolution */ |
53 |
54 |
int userformat = 1; /* output 1=nice,0=plain,-1=raw */ |
55 |
int header = 1; /* print header? */ |
56 |
57 |
char *progname; /* program name */ |
58 |
59 |
60 |
main(argc, argv) |
61 |
int argc; |
62 |
char *argv[]; |
63 |
64 |
int i; |
65 |
66 |
progname = argv[0]; |
67 |
68 |
for (i = 1; i < argc && argv[i][0] == '-'; i++) |
69 |
switch (argv[i][1]) { |
70 |
case 't': /* target */ |
71 |
switch (argv[i][2]) { |
72 |
case 'w': /* width */ |
73 |
targetw = atof(argv[++i]); |
74 |
break; |
75 |
case 'h': /* height */ |
76 |
targeth = atof(argv[++i]); |
77 |
break; |
78 |
case 'd': /* distance */ |
79 |
targetd = atof(argv[++i]); |
80 |
break; |
81 |
case 'c': /* center */ |
82 |
targetp[0] = atof(argv[++i]); |
83 |
targetp[1] = atof(argv[++i]); |
84 |
targetp[2] = atof(argv[++i]); |
85 |
break; |
86 |
default: |
87 |
goto badopt; |
88 |
89 |
break; |
90 |
case 'a': |
91 |
if (!strcmp(argv[i], "-alpha")) { |
92 |
if (setscan(alpha, argv[++i]) < 0) { |
93 |
fprintf(stderr, |
94 |
"%s: bad alpha spec: %s\n", |
95 |
progname, argv[i]); |
96 |
exit(1); |
97 |
98 |
} else |
99 |
100 |
case 'd': /* ambient divisions */ |
101 |
case 's': /* ambient samples */ |
102 |
case 'r': /* ambient resolution */ |
103 |
case 'a': /* ambient accuracy */ |
104 |
case 'b': /* ambient bounces */ |
105 |
case 'i': /* include */ |
106 |
case 'e': /* exclude */ |
107 |
case 'f': /* file */ |
108 |
passarg(argv[i]); |
109 |
passarg(argv[++i]); |
110 |
break; |
111 |
case 'v': /* ambient value */ |
112 |
passarg(argv[i]); |
113 |
114 |
115 |
116 |
break; |
117 |
default: |
118 |
goto badopt; |
119 |
120 |
break; |
121 |
case 'b': |
122 |
if (!strcmp(argv[i], "-beta")) { |
123 |
if (setscan(beta, argv[++i]) < 0) { |
124 |
fprintf(stderr, |
125 |
"%s: bad beta spec: %s\n", |
126 |
127 |
exit(1); |
128 |
129 |
} else |
130 |
goto badopt; |
131 |
break; |
132 |
case 'x': |
133 |
134 |
case '\0': /* x resolution */ |
135 |
xres = atoi(argv[++i]); |
136 |
break; |
137 |
case '1': |
138 |
case '2': /* axis spec */ |
139 |
case '3': |
140 |
axis[argv[i][2]-'1'][0] = atof(argv[i+1]); |
141 |
axis[argv[i][2]-'1'][1] = atof(argv[i+2]); |
142 |
axis[argv[i][2]-'1'][2] = atof(argv[i+3]); |
143 |
i += 3; |
144 |
break; |
145 |
default: |
146 |
goto badopt; |
147 |
148 |
break; |
149 |
case 'y': /* y resolution */ |
150 |
yres = atoi(argv[++i]); |
151 |
break; |
152 |
case 'l': |
153 |
154 |
case 'w': /* limit weight */ |
155 |
case 'r': /* limit recursion */ |
156 |
passarg(argv[i]); |
157 |
158 |
break; |
159 |
default: |
160 |
goto badopt; |
161 |
162 |
break; |
163 |
case 'u': /* user friendly format */ |
164 |
userformat = 1; |
165 |
break; |
166 |
case 'o': /* custom format */ |
167 |
passarg(argv[i]); |
168 |
userformat = -1; |
169 |
break; |
170 |
case 'd': |
171 |
172 |
case '\0': /* data format */ |
173 |
userformat = 0; |
174 |
break; |
175 |
case 'j': /* direct jitter */ |
176 |
case 't': /* direct threshold */ |
177 |
case 'c': /* direct certainty */ |
178 |
passarg(argv[i]); |
179 |
180 |
break; |
181 |
default: |
182 |
goto badopt; |
183 |
184 |
break; |
185 |
case 'h': /* no header */ |
186 |
header = 0; |
187 |
break; |
188 |
default:; |
189 |
badopt: |
190 |
fprintf(stderr, "%s: bad option: %s\n", |
191 |
192 |
exit(1); |
193 |
194 |
195 |
if (userformat >= 0) { /* we cook */ |
196 |
passarg("-ov"); |
197 |
passarg("-fff"); |
198 |
} else /* raw */ |
199 |
passarg("-ffa"); |
200 |
201 |
if (i != argc-1) { |
202 |
fprintf(stderr, "%s: single octree required\n", progname); |
203 |
exit(1); |
204 |
205 |
206 |
passarg(argv[i]); |
207 |
passarg(NULL); |
208 |
209 |
fixaxes(); |
210 |
211 |
if (header) |
212 |
if (userformat > 0) |
213 |
printf("Alpha\tBeta\tRadiance\n"); |
214 |
else { |
215 |
printargs(argc, argv, stdout); |
216 |
putchar('\n'); |
217 |
218 |
219 |
if (doscan() == -1) |
220 |
exit(1); |
221 |
222 |
exit(0); |
223 |
224 |
225 |
226 |
printargs(ac, av, fp) /* print arguments to a file */ |
227 |
int ac; |
228 |
char **av; |
229 |
FILE *fp; |
230 |
231 |
while (ac-- > 0) { |
232 |
fputs(*av++, fp); |
233 |
putc(' ', fp); |
234 |
235 |
putc('\n', fp); |
236 |
237 |
238 |
239 |
fixaxes() /* make sure axes are OK */ |
240 |
241 |
extern double normalize(), fdot(); |
242 |
double d; |
243 |
register int i; |
244 |
245 |
for (i = 0; i < 3; i++) |
246 |
if (normalize(axis[i]) == 0.0) |
247 |
goto axerr; |
248 |
249 |
for (i = 0; i < 3; i++) { |
250 |
d = fdot(axis[i], axis[(i+1)%3]); |
251 |
if (d > FTINY || d < -FTINY) |
252 |
goto axerr; |
253 |
254 |
return; |
255 |
axerr: |
256 |
fprintf(stderr, "%s: bad axis specification\n", progname); |
257 |
exit(1); |
258 |
259 |
260 |
261 |
doscan() /* do scan for target */ |
262 |
263 |
FILE *fopen(), *scanstart(); |
264 |
double readsample(); |
265 |
FILE *fp; |
266 |
ANGLE *a, *b; |
267 |
268 |
fp = scanstart(); /* returns in child if not raw */ |
269 |
for (a = alpha; *a != AEND; a++) /* read data */ |
270 |
for (b = beta; *b != AEND; b++) |
271 |
272 |
printf("%d\t%d\t%e\n", *a, *b, readsample(fp)); |
273 |
else |
274 |
printf("%e\n", readsample(fp)); |
275 |
return(scanend(fp)); |
276 |
277 |
278 |
279 |
FILE * |
280 |
scanstart() /* open scanner pipeline */ |
281 |
282 |
int status; |
283 |
char *fgets(); |
284 |
int p1[2], p2[2]; |
285 |
int pid; |
286 |
FILE *fp; |
287 |
288 |
fflush(stdout); /* empty output buffer */ |
289 |
if (pipe(p1) < 0) /* get pipe1 */ |
290 |
goto err; |
291 |
if ((pid = fork()) == 0) { /* if child1 */ |
292 |
close(p1[1]); |
293 |
if (p1[0] != 0) { /* connect pipe1 to stdin */ |
294 |
dup2(p1[0], 0); |
295 |
close(p1[0]); |
296 |
297 |
if (userformat >= 0) { /* if processing output */ |
298 |
if (pipe(p2) < 0) /* get pipe2 */ |
299 |
goto err; |
300 |
if ((pid = vfork()) == 0) { /* if child2 */ |
301 |
close(p2[0]); |
302 |
if (p2[1] != 1) { /* pipe2 to stdout */ |
303 |
dup2(p2[1], 1); |
304 |
close(p2[1]); |
305 |
306 |
execvp(rtargv[0], rtargv); /* rtrace */ |
307 |
goto err; |
308 |
309 |
if (pid == -1) |
310 |
goto err; |
311 |
close(p2[1]); |
312 |
if ((fp = fdopen(p2[0], "r")) == NULL) |
313 |
goto err; |
314 |
return(fp); |
315 |
} else { /* if running raw */ |
316 |
317 |
goto err; |
318 |
319 |
320 |
if (pid == -1) |
321 |
goto err; |
322 |
close(p1[0]); |
323 |
if ((fp = fdopen(p1[1], "w")) == NULL) |
324 |
goto err; |
325 |
sendsamples(fp); /* parent writes output to pipe1 */ |
326 |
fclose(fp); |
327 |
if (wait(&status) != -1) /* wait for child1 */ |
328 |
_exit(status); |
329 |
err: |
330 |
perror(progname); |
331 |
_exit(1); |
332 |
333 |
334 |
335 |
scanend(fp) /* done with scanner input */ |
336 |
FILE *fp; |
337 |
338 |
int status; |
339 |
340 |
fclose(fp); |
341 |
if (wait(&status) == -1) { /* wait for child2 */ |
342 |
perror(progname); |
343 |
exit(1); |
344 |
345 |
return(status ? -1 : 0); |
346 |
347 |
348 |
349 |
sendsamples(fp) /* send our samples to fp */ |
350 |
FILE *fp; |
351 |
352 |
ANGLE *a, *b; |
353 |
354 |
for (a = alpha; *a != AEND; a++) |
355 |
356 |
writesample(fp, *a, *b); |
357 |
358 |
359 |
360 |
writesample(fp, a, b) /* write out sample ray grid */ |
361 |
FILE *fp; |
362 |
ANGLE a, b; |
363 |
364 |
double sin(), cos(); |
365 |
float sp[6]; |
366 |
double dv[3]; |
367 |
double xpos, ypos; |
368 |
int i, j, k; |
369 |
/* get direction in their system */ |
370 |
dv[0] = -cos(atorad(a)); |
371 |
dv[1] = dv[2] = -sin(atorad(a)); |
372 |
dv[1] *= cos(atorad(b)); |
373 |
dv[2] *= sin(atorad(b)); |
374 |
/* do sample grid in our system */ |
375 |
for (j = 0; j < yres; j++) { |
376 |
for (i = 0; i < xres; i++) { |
377 |
xpos = ((i + frandom())/xres - 0.5) * targetw; |
378 |
ypos = ((j + frandom())/yres - 0.5) * targeth; |
379 |
for (k = 0; k < 3; k++) { |
380 |
sp[k] = targetp[k]; |
381 |
sp[k] += xpos*axis[2][k]; |
382 |
sp[k] += ypos*axis[1][k]; |
383 |
sp[k+3] = dv[0]*axis[0][k] + |
384 |
dv[1]*axis[1][k] + |
385 |
dv[2]*axis[2][k]; |
386 |
sp[k] -= sp[k+3]*targetd; |
387 |
388 |
if (fwrite(sp, sizeof(*sp), 6, fp) != 6) { |
389 |
fprintf(stderr, "%s: data write error\n", |
390 |
progname); |
391 |
_exit(1); |
392 |
393 |
394 |
395 |
396 |
397 |
398 |
double |
399 |
readsample(fp) /* read in sample ray grid */ |
400 |
FILE *fp; |
401 |
402 |
float col[3]; |
403 |
double sum; |
404 |
int i; |
405 |
406 |
sum = 0.0; |
407 |
i = xres*yres; |
408 |
while (i--) { |
409 |
if (fread(col, sizeof(*col), 3, fp) != 3) { |
410 |
fprintf(stderr, "%s: data read error\n", progname); |
411 |
exit(1); |
412 |
413 |
sum += .3*col[0] + .59*col[1] + .11*col[2]; |
414 |
415 |
return(sum / (xres*yres)); |
416 |
