1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: makedist.c,v 2.4 2003/02/22 02:07:30 greg Exp $"; |
3 |
#endif |
4 |
5 |
* makedist.c - program to make a source distribution. |
6 |
7 |
* 8/18/86 |
8 |
9 |
* Program uses angular coordinates as follows: |
10 |
11 |
* alpha - degrees measured from x1 axis. |
12 |
* beta - degress of projection into x2x3 plane, |
13 |
* measured from x2 axis towards x3 axis. |
14 |
15 |
* Default axes are (x1,x2,x3) = (x,y,z). |
16 |
17 |
18 |
#include <stdlib.h> |
19 |
#include <unistd.h> |
20 |
#include <stdio.h> |
21 |
#include <string.h> |
22 |
#include <sys/types.h> |
23 |
#include <sys/wait.h> |
24 |
25 |
#include "rtmath.h" |
26 |
#include "random.h" |
27 |
#include "setscan.h" |
28 |
29 |
#ifndef BSD |
30 |
#define vfork fork |
31 |
#endif |
32 |
33 |
#define atorad(a) ((PI/180.0) * (a)) |
34 |
35 |
char *rtargv[128] = {"rtrace", "-h"}; |
36 |
int rtargc = 2; |
37 |
38 |
#define passarg(s) (rtargv[rtargc++] = s) |
39 |
40 |
ANGLE alpha[181] = {10, 25, 40, 55, 70, 85, AEND}; |
41 |
ANGLE beta[361] = {0,30,60,90,120,150,180,210,240,270,300,330,AEND}; |
42 |
43 |
/* coordinate system */ |
44 |
double axis[3][3] = {{1,0,0},{0,1,0},{0,0,1}}; |
45 |
46 |
double targetw = 1.0; /* target width */ |
47 |
double targeth = 1.0; /* target height */ |
48 |
double targetd = 1.0; /* target distance */ |
49 |
double targetp[3] = {0,0,0}; /* target center */ |
50 |
int xres = 16; /* x sample resolution */ |
51 |
int yres = 16; /* y sample resolution */ |
52 |
53 |
int userformat = 1; /* output 1=nice,0=plain,-1=raw */ |
54 |
int header = 1; /* print header? */ |
55 |
56 |
char *progname; /* program name */ |
57 |
58 |
static void printargs(int ac, char **av, FILE *fp); |
59 |
static void fixaxes(void); |
60 |
static int doscan(void); |
61 |
static FILE * scanstart(void); |
62 |
static int scanend(FILE *fp); |
63 |
static void sendsamples(FILE *fp); |
64 |
static void writesample(FILE *fp, ANGLE a, ANGLE b); |
65 |
static double readsample(FILE *fp); |
66 |
67 |
68 |
int |
69 |
main( |
70 |
int argc, |
71 |
char *argv[] |
72 |
73 |
74 |
int i; |
75 |
76 |
progname = argv[0]; |
77 |
78 |
for (i = 1; i < argc && argv[i][0] == '-'; i++) |
79 |
switch (argv[i][1]) { |
80 |
case 't': /* target */ |
81 |
switch (argv[i][2]) { |
82 |
case 'w': /* width */ |
83 |
targetw = atof(argv[++i]); |
84 |
break; |
85 |
case 'h': /* height */ |
86 |
targeth = atof(argv[++i]); |
87 |
break; |
88 |
case 'd': /* distance */ |
89 |
targetd = atof(argv[++i]); |
90 |
break; |
91 |
case 'c': /* center */ |
92 |
targetp[0] = atof(argv[++i]); |
93 |
targetp[1] = atof(argv[++i]); |
94 |
targetp[2] = atof(argv[++i]); |
95 |
break; |
96 |
default: |
97 |
goto badopt; |
98 |
99 |
break; |
100 |
case 'a': |
101 |
if (!strcmp(argv[i], "-alpha")) { |
102 |
if (setscan(alpha, argv[++i]) < 0) { |
103 |
fprintf(stderr, |
104 |
"%s: bad alpha spec: %s\n", |
105 |
progname, argv[i]); |
106 |
exit(1); |
107 |
108 |
} else |
109 |
110 |
case 'd': /* ambient divisions */ |
111 |
case 's': /* ambient samples */ |
112 |
case 'r': /* ambient resolution */ |
113 |
case 'a': /* ambient accuracy */ |
114 |
case 'b': /* ambient bounces */ |
115 |
case 'i': /* include */ |
116 |
case 'e': /* exclude */ |
117 |
case 'f': /* file */ |
118 |
passarg(argv[i]); |
119 |
passarg(argv[++i]); |
120 |
break; |
121 |
case 'v': /* ambient value */ |
122 |
passarg(argv[i]); |
123 |
124 |
125 |
126 |
break; |
127 |
default: |
128 |
goto badopt; |
129 |
130 |
break; |
131 |
case 'b': |
132 |
if (!strcmp(argv[i], "-beta")) { |
133 |
if (setscan(beta, argv[++i]) < 0) { |
134 |
fprintf(stderr, |
135 |
"%s: bad beta spec: %s\n", |
136 |
137 |
exit(1); |
138 |
139 |
} else |
140 |
goto badopt; |
141 |
break; |
142 |
case 'x': |
143 |
144 |
case '\0': /* x resolution */ |
145 |
xres = atoi(argv[++i]); |
146 |
break; |
147 |
case '1': |
148 |
case '2': /* axis spec */ |
149 |
case '3': |
150 |
axis[argv[i][2]-'1'][0] = atof(argv[i+1]); |
151 |
axis[argv[i][2]-'1'][1] = atof(argv[i+2]); |
152 |
axis[argv[i][2]-'1'][2] = atof(argv[i+3]); |
153 |
i += 3; |
154 |
break; |
155 |
default: |
156 |
goto badopt; |
157 |
158 |
break; |
159 |
case 'y': /* y resolution */ |
160 |
yres = atoi(argv[++i]); |
161 |
break; |
162 |
case 'l': |
163 |
164 |
case 'w': /* limit weight */ |
165 |
case 'r': /* limit recursion */ |
166 |
passarg(argv[i]); |
167 |
168 |
break; |
169 |
default: |
170 |
goto badopt; |
171 |
172 |
break; |
173 |
case 'u': /* user friendly format */ |
174 |
userformat = 1; |
175 |
break; |
176 |
case 'o': /* custom format */ |
177 |
passarg(argv[i]); |
178 |
userformat = -1; |
179 |
break; |
180 |
case 'd': |
181 |
182 |
case '\0': /* data format */ |
183 |
userformat = 0; |
184 |
break; |
185 |
case 'j': /* direct jitter */ |
186 |
case 't': /* direct threshold */ |
187 |
case 'c': /* direct certainty */ |
188 |
passarg(argv[i]); |
189 |
190 |
break; |
191 |
default: |
192 |
goto badopt; |
193 |
194 |
break; |
195 |
case 'h': /* no header */ |
196 |
header = 0; |
197 |
break; |
198 |
default:; |
199 |
badopt: |
200 |
fprintf(stderr, "%s: bad option: %s\n", |
201 |
202 |
exit(1); |
203 |
204 |
205 |
if (userformat >= 0) { /* we cook */ |
206 |
passarg("-ov"); |
207 |
passarg("-fff"); |
208 |
} else /* raw */ |
209 |
passarg("-ffa"); |
210 |
211 |
if (i != argc-1) { |
212 |
fprintf(stderr, "%s: single octree required\n", progname); |
213 |
exit(1); |
214 |
215 |
216 |
passarg(argv[i]); |
217 |
passarg(NULL); |
218 |
219 |
fixaxes(); |
220 |
221 |
if (header) { |
222 |
if (userformat > 0) { |
223 |
printf("Alpha\tBeta\tRadiance\n"); |
224 |
} else { |
225 |
printargs(argc, argv, stdout); |
226 |
putchar('\n'); |
227 |
228 |
229 |
230 |
if (doscan() == -1) |
231 |
exit(1); |
232 |
233 |
exit(0); |
234 |
235 |
236 |
237 |
static void |
238 |
printargs( /* print arguments to a file */ |
239 |
int ac, |
240 |
char **av, |
241 |
FILE *fp |
242 |
243 |
244 |
while (ac-- > 0) { |
245 |
fputs(*av++, fp); |
246 |
putc(' ', fp); |
247 |
248 |
putc('\n', fp); |
249 |
250 |
251 |
252 |
static void |
253 |
fixaxes(void) /* make sure axes are OK */ |
254 |
255 |
double d; |
256 |
register int i; |
257 |
258 |
for (i = 0; i < 3; i++) |
259 |
if (normalize(axis[i]) == 0.0) |
260 |
goto axerr; |
261 |
262 |
for (i = 0; i < 3; i++) { |
263 |
d = fdot(axis[i], axis[(i+1)%3]); |
264 |
if (d > FTINY || d < -FTINY) |
265 |
goto axerr; |
266 |
267 |
return; |
268 |
axerr: |
269 |
fprintf(stderr, "%s: bad axis specification\n", progname); |
270 |
exit(1); |
271 |
272 |
273 |
274 |
static int |
275 |
doscan(void) /* do scan for target */ |
276 |
277 |
FILE *fopen(), *scanstart(); |
278 |
double readsample(); |
279 |
FILE *fp; |
280 |
ANGLE *a, *b; |
281 |
282 |
fp = scanstart(); /* returns in child if not raw */ |
283 |
for (a = alpha; *a != AEND; a++) /* read data */ |
284 |
for (b = beta; *b != AEND; b++) |
285 |
if (userformat > 0) |
286 |
printf("%d\t%d\t%e\n", *a, *b, readsample(fp)); |
287 |
else |
288 |
printf("%e\n", readsample(fp)); |
289 |
return(scanend(fp)); |
290 |
291 |
292 |
293 |
static FILE * |
294 |
scanstart(void) /* open scanner pipeline */ |
295 |
296 |
int status; |
297 |
char *fgets(); |
298 |
int p1[2], p2[2]; |
299 |
int pid; |
300 |
FILE *fp; |
301 |
302 |
fflush(stdout); /* empty output buffer */ |
303 |
if (pipe(p1) < 0) /* get pipe1 */ |
304 |
goto err; |
305 |
if ((pid = fork()) == 0) { /* if child1 */ |
306 |
close(p1[1]); |
307 |
if (p1[0] != 0) { /* connect pipe1 to stdin */ |
308 |
dup2(p1[0], 0); |
309 |
close(p1[0]); |
310 |
311 |
if (userformat >= 0) { /* if processing output */ |
312 |
if (pipe(p2) < 0) /* get pipe2 */ |
313 |
goto err; |
314 |
if ((pid = vfork()) == 0) { /* if child2 */ |
315 |
close(p2[0]); |
316 |
if (p2[1] != 1) { /* pipe2 to stdout */ |
317 |
dup2(p2[1], 1); |
318 |
close(p2[1]); |
319 |
320 |
execvp(rtargv[0], rtargv); /* rtrace */ |
321 |
goto err; |
322 |
323 |
if (pid == -1) |
324 |
goto err; |
325 |
close(p2[1]); |
326 |
if ((fp = fdopen(p2[0], "r")) == NULL) |
327 |
goto err; |
328 |
return(fp); |
329 |
} else { /* if running raw */ |
330 |
331 |
goto err; |
332 |
333 |
334 |
if (pid == -1) |
335 |
goto err; |
336 |
close(p1[0]); |
337 |
if ((fp = fdopen(p1[1], "w")) == NULL) |
338 |
goto err; |
339 |
sendsamples(fp); /* parent writes output to pipe1 */ |
340 |
fclose(fp); |
341 |
if (wait(&status) != -1) /* wait for child1 */ |
342 |
_exit(status); |
343 |
err: |
344 |
perror(progname); |
345 |
_exit(1); |
346 |
347 |
348 |
349 |
static int |
350 |
scanend( /* done with scanner input */ |
351 |
FILE *fp |
352 |
353 |
354 |
int status; |
355 |
356 |
fclose(fp); |
357 |
if (wait(&status) == -1) { /* wait for child2 */ |
358 |
perror(progname); |
359 |
exit(1); |
360 |
361 |
return(status ? -1 : 0); |
362 |
363 |
364 |
365 |
static void |
366 |
sendsamples( /* send our samples to fp */ |
367 |
FILE *fp |
368 |
369 |
370 |
ANGLE *a, *b; |
371 |
372 |
for (a = alpha; *a != AEND; a++) |
373 |
374 |
writesample(fp, *a, *b); |
375 |
376 |
377 |
378 |
static void |
379 |
writesample( /* write out sample ray grid */ |
380 |
FILE *fp, |
381 |
ANGLE a, |
382 |
ANGLE b |
383 |
384 |
385 |
double sin(), cos(); |
386 |
float sp[6]; |
387 |
double dv[3]; |
388 |
double xpos, ypos; |
389 |
int i, j, k; |
390 |
/* get direction in their system */ |
391 |
dv[0] = -cos(atorad(a)); |
392 |
dv[1] = dv[2] = -sin(atorad(a)); |
393 |
dv[1] *= cos(atorad(b)); |
394 |
dv[2] *= sin(atorad(b)); |
395 |
/* do sample grid in our system */ |
396 |
for (j = 0; j < yres; j++) { |
397 |
for (i = 0; i < xres; i++) { |
398 |
xpos = ((i + frandom())/xres - 0.5) * targetw; |
399 |
ypos = ((j + frandom())/yres - 0.5) * targeth; |
400 |
for (k = 0; k < 3; k++) { |
401 |
sp[k] = targetp[k]; |
402 |
sp[k] += xpos*axis[2][k]; |
403 |
sp[k] += ypos*axis[1][k]; |
404 |
sp[k+3] = dv[0]*axis[0][k] + |
405 |
dv[1]*axis[1][k] + |
406 |
dv[2]*axis[2][k]; |
407 |
sp[k] -= sp[k+3]*targetd; |
408 |
409 |
if (fwrite(sp, sizeof(*sp), 6, fp) != 6) { |
410 |
fprintf(stderr, "%s: data write error\n", |
411 |
progname); |
412 |
_exit(1); |
413 |
414 |
415 |
416 |
417 |
418 |
419 |
static double |
420 |
readsample( /* read in sample ray grid */ |
421 |
FILE *fp |
422 |
423 |
424 |
float col[3]; |
425 |
double sum; |
426 |
int i; |
427 |
428 |
sum = 0.0; |
429 |
i = xres*yres; |
430 |
while (i--) { |
431 |
if (fread(col, sizeof(*col), 3, fp) != 3) { |
432 |
fprintf(stderr, "%s: data read error\n", progname); |
433 |
exit(1); |
434 |
435 |
sum += .3*col[0] + .59*col[1] + .11*col[2]; |
436 |
437 |
return(sum / (xres*yres)); |
438 |
