root/radiance/ray/src/util/makedist.c
Revision: 2.3
Committed: Mon Aug 2 14:35:13 1993 UTC (30 years, 9 months ago) by greg
Changes since 2.2: +3 -0 lines
Added conditional declaration of atof()
1 /* Copyright (c) 1991 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * makedist.c - program to make a source distribution.
9 *
10 * 8/18/86
11 *
12 * Program uses angular coordinates as follows:
13 *
14 * alpha - degrees measured from x1 axis.
15 * beta - degress of projection into x2x3 plane,
16 * measured from x2 axis towards x3 axis.
17 *
18 * Default axes are (x1,x2,x3) = (x,y,z).
19 */
20
21 #include <stdio.h>
22
23 #include "random.h"
24
25 #include "setscan.h"
26
27 #ifndef BSD
28 #define vfork fork
29 #endif
30
31 #define FTINY 1e-7
32
33 #define PI 3.14159265358979324
34
35 #define atorad(a) ((PI/180.0) * (a))
36
37 char *rtargv[128] = {"rtrace", "-h"};
38 int rtargc = 2;
39
40 #define passarg(s) (rtargv[rtargc++] = s)
41
42 #ifdef DCL_ATOF
43 extern double atof();
44 #endif
45 /* default angles */
46 ANGLE alpha[181] = {10, 25, 40, 55, 70, 85, AEND};
47 ANGLE beta[361] = {0,30,60,90,120,150,180,210,240,270,300,330,AEND};
48
49 /* coordinate system */
50 double axis[3][3] = {{1,0,0},{0,1,0},{0,0,1}};
51
52 double targetw = 1.0; /* target width */
53 double targeth = 1.0; /* target height */
54 double targetd = 1.0; /* target distance */
55 double targetp[3] = {0,0,0}; /* target center */
56 int xres = 16; /* x sample resolution */
57 int yres = 16; /* y sample resolution */
58
59 int userformat = 1; /* output 1=nice,0=plain,-1=raw */
60 int header = 1; /* print header? */
61
62 char *progname; /* program name */
63
64
65 main(argc, argv)
66 int argc;
67 char *argv[];
68 {
69 int i;
70
71 progname = argv[0];
72
73 for (i = 1; i < argc && argv[i][0] == '-'; i++)
74 switch (argv[i][1]) {
75 case 't': /* target */
76 switch (argv[i][2]) {
77 case 'w': /* width */
78 targetw = atof(argv[++i]);
79 break;
80 case 'h': /* height */
81 targeth = atof(argv[++i]);
82 break;
83 case 'd': /* distance */
84 targetd = atof(argv[++i]);
85 break;
86 case 'c': /* center */
87 targetp[0] = atof(argv[++i]);
88 targetp[1] = atof(argv[++i]);
89 targetp[2] = atof(argv[++i]);
90 break;
91 default:
92 goto badopt;
93 }
94 break;
95 case 'a':
96 if (!strcmp(argv[i], "-alpha")) {
97 if (setscan(alpha, argv[++i]) < 0) {
98 fprintf(stderr,
99 "%s: bad alpha spec: %s\n",
100 progname, argv[i]);
101 exit(1);
102 }
103 } else
104 switch (argv[i][2]) {
105 case 'd': /* ambient divisions */
106 case 's': /* ambient samples */
107 case 'r': /* ambient resolution */
108 case 'a': /* ambient accuracy */
109 case 'b': /* ambient bounces */
110 case 'i': /* include */
111 case 'e': /* exclude */
112 case 'f': /* file */
113 passarg(argv[i]);
114 passarg(argv[++i]);
115 break;
116 case 'v': /* ambient value */
117 passarg(argv[i]);
118 passarg(argv[++i]);
119 passarg(argv[++i]);
120 passarg(argv[++i]);
121 break;
122 default:
123 goto badopt;
124 }
125 break;
126 case 'b':
127 if (!strcmp(argv[i], "-beta")) {
128 if (setscan(beta, argv[++i]) < 0) {
129 fprintf(stderr,
130 "%s: bad beta spec: %s\n",
131 progname, argv[i]);
132 exit(1);
133 }
134 } else
135 goto badopt;
136 break;
137 case 'x':
138 switch (argv[i][2]) {
139 case '\0': /* x resolution */
140 xres = atoi(argv[++i]);
141 break;
142 case '1':
143 case '2': /* axis spec */
144 case '3':
145 axis[argv[i][2]-'1'][0] = atof(argv[i+1]);
146 axis[argv[i][2]-'1'][1] = atof(argv[i+2]);
147 axis[argv[i][2]-'1'][2] = atof(argv[i+3]);
148 i += 3;
149 break;
150 default:
151 goto badopt;
152 }
153 break;
154 case 'y': /* y resolution */
155 yres = atoi(argv[++i]);
156 break;
157 case 'l':
158 switch (argv[i][2]) {
159 case 'w': /* limit weight */
160 case 'r': /* limit recursion */
161 passarg(argv[i]);
162 passarg(argv[++i]);
163 break;
164 default:
165 goto badopt;
166 }
167 break;
168 case 'u': /* user friendly format */
169 userformat = 1;
170 break;
171 case 'o': /* custom format */
172 passarg(argv[i]);
173 userformat = -1;
174 break;
175 case 'd':
176 switch (argv[i][2]) {
177 case '\0': /* data format */
178 userformat = 0;
179 break;
180 case 'j': /* direct jitter */
181 case 't': /* direct threshold */
182 case 'c': /* direct certainty */
183 passarg(argv[i]);
184 passarg(argv[++i]);
185 break;
186 default:
187 goto badopt;
188 }
189 break;
190 case 'h': /* no header */
191 header = 0;
192 break;
193 default:;
194 badopt:
195 fprintf(stderr, "%s: bad option: %s\n",
196 progname, argv[i]);
197 exit(1);
198 }
199
200 if (userformat >= 0) { /* we cook */
201 passarg("-ov");
202 passarg("-fff");
203 } else /* raw */
204 passarg("-ffa");
205
206 if (i != argc-1) {
207 fprintf(stderr, "%s: single octree required\n", progname);
208 exit(1);
209 }
210
211 passarg(argv[i]);
212 passarg(NULL);
213
214 fixaxes();
215
216 if (header)
217 if (userformat > 0)
218 printf("Alpha\tBeta\tRadiance\n");
219 else {
220 printargs(argc, argv, stdout);
221 putchar('\n');
222 }
223
224 if (doscan() == -1)
225 exit(1);
226
227 exit(0);
228 }
229
230
231 printargs(ac, av, fp) /* print arguments to a file */
232 int ac;
233 char **av;
234 FILE *fp;
235 {
236 while (ac-- > 0) {
237 fputs(*av++, fp);
238 putc(' ', fp);
239 }
240 putc('\n', fp);
241 }
242
243
244 fixaxes() /* make sure axes are OK */
245 {
246 extern double normalize(), fdot();
247 double d;
248 register int i;
249
250 for (i = 0; i < 3; i++)
251 if (normalize(axis[i]) == 0.0)
252 goto axerr;
253
254 for (i = 0; i < 3; i++) {
255 d = fdot(axis[i], axis[(i+1)%3]);
256 if (d > FTINY || d < -FTINY)
257 goto axerr;
258 }
259 return;
260 axerr:
261 fprintf(stderr, "%s: bad axis specification\n", progname);
262 exit(1);
263 }
264
265
266 doscan() /* do scan for target */
267 {
268 FILE *fopen(), *scanstart();
269 double readsample();
270 FILE *fp;
271 ANGLE *a, *b;
272
273 fp = scanstart(); /* returns in child if not raw */
274 for (a = alpha; *a != AEND; a++) /* read data */
275 for (b = beta; *b != AEND; b++)
276 if (userformat > 0)
277 printf("%d\t%d\t%e\n", *a, *b, readsample(fp));
278 else
279 printf("%e\n", readsample(fp));
280 return(scanend(fp));
281 }
282
283
284 FILE *
285 scanstart() /* open scanner pipeline */
286 {
287 int status;
288 char *fgets();
289 int p1[2], p2[2];
290 int pid;
291 FILE *fp;
292
293 fflush(stdout); /* empty output buffer */
294 if (pipe(p1) < 0) /* get pipe1 */
295 goto err;
296 if ((pid = fork()) == 0) { /* if child1 */
297 close(p1[1]);
298 if (p1[0] != 0) { /* connect pipe1 to stdin */
299 dup2(p1[0], 0);
300 close(p1[0]);
301 }
302 if (userformat >= 0) { /* if processing output */
303 if (pipe(p2) < 0) /* get pipe2 */
304 goto err;
305 if ((pid = vfork()) == 0) { /* if child2 */
306 close(p2[0]);
307 if (p2[1] != 1) { /* pipe2 to stdout */
308 dup2(p2[1], 1);
309 close(p2[1]);
310 }
311 execvp(rtargv[0], rtargv); /* rtrace */
312 goto err;
313 }
314 if (pid == -1)
315 goto err;
316 close(p2[1]);
317 if ((fp = fdopen(p2[0], "r")) == NULL)
318 goto err;
319 return(fp);
320 } else { /* if running raw */
321 execvp(rtargv[0], rtargv); /* rtrace */
322 goto err;
323 }
324 }
325 if (pid == -1)
326 goto err;
327 close(p1[0]);
328 if ((fp = fdopen(p1[1], "w")) == NULL)
329 goto err;
330 sendsamples(fp); /* parent writes output to pipe1 */
331 fclose(fp);
332 if (wait(&status) != -1) /* wait for child1 */
333 _exit(status);
334 err:
335 perror(progname);
336 _exit(1);
337 }
338
339
340 scanend(fp) /* done with scanner input */
341 FILE *fp;
342 {
343 int status;
344
345 fclose(fp);
346 if (wait(&status) == -1) { /* wait for child2 */
347 perror(progname);
348 exit(1);
349 }
350 return(status ? -1 : 0);
351 }
352
353
354 sendsamples(fp) /* send our samples to fp */
355 FILE *fp;
356 {
357 ANGLE *a, *b;
358
359 for (a = alpha; *a != AEND; a++)
360 for (b = beta; *b != AEND; b++)
361 writesample(fp, *a, *b);
362 }
363
364
365 writesample(fp, a, b) /* write out sample ray grid */
366 FILE *fp;
367 ANGLE a, b;
368 {
369 double sin(), cos();
370 float sp[6];
371 double dv[3];
372 double xpos, ypos;
373 int i, j, k;
374 /* get direction in their system */
375 dv[0] = -cos(atorad(a));
376 dv[1] = dv[2] = -sin(atorad(a));
377 dv[1] *= cos(atorad(b));
378 dv[2] *= sin(atorad(b));
379 /* do sample grid in our system */
380 for (j = 0; j < yres; j++) {
381 for (i = 0; i < xres; i++) {
382 xpos = ((i + frandom())/xres - 0.5) * targetw;
383 ypos = ((j + frandom())/yres - 0.5) * targeth;
384 for (k = 0; k < 3; k++) {
385 sp[k] = targetp[k];
386 sp[k] += xpos*axis[2][k];
387 sp[k] += ypos*axis[1][k];
388 sp[k+3] = dv[0]*axis[0][k] +
389 dv[1]*axis[1][k] +
390 dv[2]*axis[2][k];
391 sp[k] -= sp[k+3]*targetd;
392 }
393 if (fwrite(sp, sizeof(*sp), 6, fp) != 6) {
394 fprintf(stderr, "%s: data write error\n",
395 progname);
396 _exit(1);
397 }
398 }
399 }
400 }
401
402
403 double
404 readsample(fp) /* read in sample ray grid */
405 FILE *fp;
406 {
407 float col[3];
408 double sum;
409 int i;
410
411 sum = 0.0;
412 i = xres*yres;
413 while (i--) {
414 if (fread(col, sizeof(*col), 3, fp) != 3) {
415 fprintf(stderr, "%s: data read error\n", progname);
416 exit(1);
417 }
418 sum += .3*col[0] + .59*col[1] + .11*col[2];
419 }
420 return(sum / (xres*yres));
421 }
