root/radiance/ray/src/util/makedist.c
Revision: 2.1
Committed: Tue Nov 12 17:19:04 1991 UTC (33 years, 7 months ago) by greg
1 /* Copyright (c) 1991 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * makedist.c - program to make a source distribution.
9 *
10 * 8/18/86
11 *
12 * Program uses angular coordinates as follows:
13 *
14 * alpha - degrees measured from x1 axis.
15 * beta - degress of projection into x2x3 plane,
16 * measured from x2 axis towards x3 axis.
17 *
18 * Default axes are (x1,x2,x3) = (x,y,z).
19 */
20
21 #include <stdio.h>
22
23 #include "random.h"
24
25 #include "setscan.h"
26
27 #ifndef BSD
28 #define vfork fork
29 #endif
30
31 #define FTINY 1e-7
32
33 #define PI 3.14159265358979324
34
35 #define atorad(a) ((PI/180.0) * (a))
36
37 char *rtargv[128] = {"rtrace", "-h"};
38 int rtargc = 2;
39
40 #define passarg(s) (rtargv[rtargc++] = s)
41
42 /* default angles */
43 ANGLE alpha[181] = {10, 25, 40, 55, 70, 85, AEND};
44 ANGLE beta[361] = {0,30,60,90,120,150,180,210,240,270,300,330,AEND};
45
46 /* coordinate system */
47 double axis[3][3] = {{1,0,0},{0,1,0},{0,0,1}};
48
49 double targetw = 1.0; /* target width */
50 double targeth = 1.0; /* target height */
51 double targetd = 1.0; /* target distance */
52 double targetp[3] = {0,0,0}; /* target center */
53 int xres = 16; /* x sample resolution */
54 int yres = 16; /* y sample resolution */
55
56 int userformat = 1; /* output 1=nice,0=plain,-1=raw */
57 int header = 1; /* print header? */
58
59 char *progname; /* program name */
60
61
62 main(argc, argv)
63 int argc;
64 char *argv[];
65 {
66 double atof();
67 int i;
68
69 progname = argv[0];
70
71 for (i = 1; i < argc && argv[i][0] == '-'; i++)
72 switch (argv[i][1]) {
73 case 't': /* target */
74 switch (argv[i][2]) {
75 case 'w': /* width */
76 targetw = atof(argv[++i]);
77 break;
78 case 'h': /* height */
79 targeth = atof(argv[++i]);
80 break;
81 case 'd': /* distance */
82 targetd = atof(argv[++i]);
83 break;
84 case 'c': /* center */
85 targetp[0] = atof(argv[++i]);
86 targetp[1] = atof(argv[++i]);
87 targetp[2] = atof(argv[++i]);
88 break;
89 default:
90 goto badopt;
91 }
92 break;
93 case 'a':
94 if (!strcmp(argv[i], "-alpha")) {
95 if (setscan(alpha, argv[++i]) < 0) {
96 fprintf(stderr,
97 "%s: bad alpha spec: %s\n",
98 progname, argv[i]);
99 exit(1);
100 }
101 } else
102 switch (argv[i][2]) {
103 case 'd': /* ambient divisions */
104 case 's': /* ambient samples */
105 case 'r': /* ambient resolution */
106 case 'a': /* ambient accuracy */
107 case 'b': /* ambient bounces */
108 case 'i': /* include */
109 case 'e': /* exclude */
110 case 'f': /* file */
111 passarg(argv[i]);
112 passarg(argv[++i]);
113 break;
114 case 'v': /* ambient value */
115 passarg(argv[i]);
116 passarg(argv[++i]);
117 passarg(argv[++i]);
118 passarg(argv[++i]);
119 break;
120 default:
121 goto badopt;
122 }
123 break;
124 case 'b':
125 if (!strcmp(argv[i], "-beta")) {
126 if (setscan(beta, argv[++i]) < 0) {
127 fprintf(stderr,
128 "%s: bad beta spec: %s\n",
129 progname, argv[i]);
130 exit(1);
131 }
132 } else
133 goto badopt;
134 break;
135 case 'x':
136 switch (argv[i][2]) {
137 case '\0': /* x resolution */
138 xres = atoi(argv[++i]);
139 break;
140 case '1':
141 case '2': /* axis spec */
142 case '3':
143 axis[argv[i][2]-'1'][0] = atof(argv[i+1]);
144 axis[argv[i][2]-'1'][1] = atof(argv[i+2]);
145 axis[argv[i][2]-'1'][2] = atof(argv[i+3]);
146 i += 3;
147 break;
148 default:
149 goto badopt;
150 }
151 break;
152 case 'y': /* y resolution */
153 yres = atoi(argv[++i]);
154 break;
155 case 'l':
156 switch (argv[i][2]) {
157 case 'w': /* limit weight */
158 case 'r': /* limit recursion */
159 passarg(argv[i]);
160 passarg(argv[++i]);
161 break;
162 default:
163 goto badopt;
164 }
165 break;
166 case 'u': /* user friendly format */
167 userformat = 1;
168 break;
169 case 'o': /* custom format */
170 passarg(argv[i]);
171 userformat = -1;
172 break;
173 case 'd':
174 switch (argv[i][2]) {
175 case '\0': /* data format */
176 userformat = 0;
177 break;
178 case 'j': /* direct jitter */
179 case 't': /* direct threshold */
180 case 'c': /* direct certainty */
181 passarg(argv[i]);
182 passarg(argv[++i]);
183 break;
184 default:
185 goto badopt;
186 }
187 break;
188 case 'h': /* no header */
189 header = 0;
190 break;
191 default:;
192 badopt:
193 fprintf(stderr, "%s: bad option: %s\n",
194 progname, argv[i]);
195 exit(1);
196 }
197
198 if (userformat >= 0) { /* we cook */
199 passarg("-ov");
200 passarg("-fff");
201 } else /* raw */
202 passarg("-ffa");
203
204 if (i != argc-1) {
205 fprintf(stderr, "%s: single octree required\n", progname);
206 exit(1);
207 }
208
209 passarg(argv[i]);
210 passarg(NULL);
211
212 fixaxes();
213
214 if (header)
215 if (userformat > 0)
216 printf("Alpha\tBeta\tRadiance\n");
217 else {
218 printargs(argc, argv, stdout);
219 putchar('\n');
220 }
221
222 if (doscan() == -1)
223 exit(1);
224
225 exit(0);
226 }
227
228
229 printargs(ac, av, fp) /* print arguments to a file */
230 int ac;
231 char **av;
232 FILE *fp;
233 {
234 while (ac-- > 0) {
235 fputs(*av++, fp);
236 putc(' ', fp);
237 }
238 putc('\n', fp);
239 }
240
241
242 fixaxes() /* make sure axes are OK */
243 {
244 extern double normalize(), fdot();
245 double d;
246 register int i;
247
248 for (i = 0; i < 3; i++)
249 if (normalize(axis[i]) == 0.0)
250 goto axerr;
251
252 for (i = 0; i < 3; i++) {
253 d = fdot(axis[i], axis[(i+1)%3]);
254 if (d > FTINY || d < -FTINY)
255 goto axerr;
256 }
257 return;
258 axerr:
259 fprintf(stderr, "%s: bad axis specification\n", progname);
260 exit(1);
261 }
262
263
264 doscan() /* do scan for target */
265 {
266 FILE *fopen(), *scanstart();
267 double readsample();
268 FILE *fp;
269 ANGLE *a, *b;
270
271 fp = scanstart(); /* returns in child if not raw */
272 for (a = alpha; *a != AEND; a++) /* read data */
273 for (b = beta; *b != AEND; b++)
274 if (userformat > 0)
275 printf("%d\t%d\t%e\n", *a, *b, readsample(fp));
276 else
277 printf("%e\n", readsample(fp));
278 return(scanend(fp));
279 }
280
281
282 FILE *
283 scanstart() /* open scanner pipeline */
284 {
285 int status;
286 char *fgets();
287 int p1[2], p2[2];
288 int pid;
289 FILE *fp;
290
291 fflush(stdout); /* empty output buffer */
292 if (pipe(p1) < 0) /* get pipe1 */
293 goto err;
294 if ((pid = fork()) == 0) { /* if child1 */
295 close(p1[1]);
296 if (p1[0] != 0) { /* connect pipe1 to stdin */
297 dup2(p1[0], 0);
298 close(p1[0]);
299 }
300 if (userformat >= 0) { /* if processing output */
301 if (pipe(p2) < 0) /* get pipe2 */
302 goto err;
303 if ((pid = vfork()) == 0) { /* if child2 */
304 close(p2[0]);
305 if (p2[1] != 1) { /* pipe2 to stdout */
306 dup2(p2[1], 1);
307 close(p2[1]);
308 }
309 execvp(rtargv[0], rtargv); /* rtrace */
310 goto err;
311 }
312 if (pid == -1)
313 goto err;
314 close(p2[1]);
315 if ((fp = fdopen(p2[0], "r")) == NULL)
316 goto err;
317 return(fp);
318 } else { /* if running raw */
319 execvp(rtargv[0], rtargv); /* rtrace */
320 goto err;
321 }
322 }
323 if (pid == -1)
324 goto err;
325 close(p1[0]);
326 if ((fp = fdopen(p1[1], "w")) == NULL)
327 goto err;
328 sendsamples(fp); /* parent writes output to pipe1 */
329 fclose(fp);
330 if (wait(&status) != -1) /* wait for child1 */
331 _exit(status);
332 err:
333 perror(progname);
334 _exit(1);
335 }
336
337
338 scanend(fp) /* done with scanner input */
339 FILE *fp;
340 {
341 int status;
342
343 fclose(fp);
344 if (wait(&status) == -1) { /* wait for child2 */
345 perror(progname);
346 exit(1);
347 }
348 return(status ? -1 : 0);
349 }
350
351
352 sendsamples(fp) /* send our samples to fp */
353 FILE *fp;
354 {
355 ANGLE *a, *b;
356
357 for (a = alpha; *a != AEND; a++)
358 for (b = beta; *b != AEND; b++)
359 writesample(fp, *a, *b);
360 }
361
362
363 writesample(fp, a, b) /* write out sample ray grid */
364 FILE *fp;
365 ANGLE a, b;
366 {
367 double sin(), cos();
368 float sp[6];
369 double dv[3];
370 double xpos, ypos;
371 int i, j, k;
372 /* get direction in their system */
373 dv[0] = -cos(atorad(a));
374 dv[1] = dv[2] = -sin(atorad(a));
375 dv[1] *= cos(atorad(b));
376 dv[2] *= sin(atorad(b));
377 /* do sample grid in our system */
378 for (j = 0; j < yres; j++) {
379 for (i = 0; i < xres; i++) {
380 xpos = ((i + frandom())/xres - 0.5) * targetw;
381 ypos = ((j + frandom())/yres - 0.5) * targeth;
382 for (k = 0; k < 3; k++) {
383 sp[k] = targetp[k];
384 sp[k] += xpos*axis[2][k];
385 sp[k] += ypos*axis[1][k];
386 sp[k+3] = dv[0]*axis[0][k] +
387 dv[1]*axis[1][k] +
388 dv[2]*axis[2][k];
389 sp[k] -= sp[k+3]*targetd;
390 }
391 if (fwrite(sp, sizeof(*sp), 6, fp) != 6) {
392 fprintf(stderr, "%s: data write error\n",
393 progname);
394 _exit(1);
395 }
396 }
397 }
398 }
399
400
401 double
402 readsample(fp) /* read in sample ray grid */
403 FILE *fp;
404 {
405 float col[3];
406 double sum;
407 int i;
408
409 sum = 0.0;
410 i = xres*yres;
411 while (i--) {
412 if (fread(col, sizeof(*col), 3, fp) != 3) {
413 fprintf(stderr, "%s: data read error\n", progname);
414 exit(1);
415 }
416 sum += .3*col[0] + .59*col[1] + .11*col[2];
417 }
418 return(sum / (xres*yres));
419 }
