root/radiance/ray/src/util/makedist.c
Revision: 2.4
Committed: Sat Feb 22 02:07:30 2003 UTC (22 years, 2 months ago) by greg
Changes since 2.3: +3 -8 lines
5 * makedist.c - program to make a source distribution.
6 *
7 * 8/18/86
8 *
9 * Program uses angular coordinates as follows:
10 *
11 * alpha - degrees measured from x1 axis.
12 * beta - degress of projection into x2x3 plane,
13 * measured from x2 axis towards x3 axis.
14 *
15 * Default axes are (x1,x2,x3) = (x,y,z).
16 */
17
18 #include <stdio.h>
19
20 #include <stdlib.h>
21
22 #include "random.h"
23
24 #include "setscan.h"
25
26 #ifndef BSD
27 #define vfork fork
28 #endif
29
30 #define FTINY 1e-7
31
32 #define PI 3.14159265358979324
33
34 #define atorad(a) ((PI/180.0) * (a))
35
36 char *rtargv[128] = {"rtrace", "-h"};
37 int rtargc = 2;
38
39 #define passarg(s) (rtargv[rtargc++] = s)
40
41 ANGLE alpha[181] = {10, 25, 40, 55, 70, 85, AEND};
42 ANGLE beta[361] = {0,30,60,90,120,150,180,210,240,270,300,330,AEND};
43
44 /* coordinate system */
45 double axis[3][3] = {{1,0,0},{0,1,0},{0,0,1}};
46
47 double targetw = 1.0; /* target width */
48 double targeth = 1.0; /* target height */
49 double targetd = 1.0; /* target distance */
50 double targetp[3] = {0,0,0}; /* target center */
51 int xres = 16; /* x sample resolution */
52 int yres = 16; /* y sample resolution */
53
54 int userformat = 1; /* output 1=nice,0=plain,-1=raw */
55 int header = 1; /* print header? */
56
57 char *progname; /* program name */
58
59
60 main(argc, argv)
61 int argc;
62 char *argv[];
63 {
64 int i;
65
66 progname = argv[0];
67
68 for (i = 1; i < argc && argv[i][0] == '-'; i++)
69 switch (argv[i][1]) {
70 case 't': /* target */
71 switch (argv[i][2]) {
72 case 'w': /* width */
73 targetw = atof(argv[++i]);
74 break;
75 case 'h': /* height */
76 targeth = atof(argv[++i]);
77 break;
78 case 'd': /* distance */
79 targetd = atof(argv[++i]);
80 break;
81 case 'c': /* center */
82 targetp[0] = atof(argv[++i]);
83 targetp[1] = atof(argv[++i]);
84 targetp[2] = atof(argv[++i]);
85 break;
86 default:
87 goto badopt;
88 }
89 break;
90 case 'a':
91 if (!strcmp(argv[i], "-alpha")) {
92 if (setscan(alpha, argv[++i]) < 0) {
93 fprintf(stderr,
94 "%s: bad alpha spec: %s\n",
95 progname, argv[i]);
96 exit(1);
97 }
98 } else
99 switch (argv[i][2]) {
100 case 'd': /* ambient divisions */
101 case 's': /* ambient samples */
102 case 'r': /* ambient resolution */
103 case 'a': /* ambient accuracy */
104 case 'b': /* ambient bounces */
105 case 'i': /* include */
106 case 'e': /* exclude */
107 case 'f': /* file */
108 passarg(argv[i]);
109 passarg(argv[++i]);
110 break;
111 case 'v': /* ambient value */
112 passarg(argv[i]);
113 passarg(argv[++i]);
114 passarg(argv[++i]);
115 passarg(argv[++i]);
116 break;
117 default:
118 goto badopt;
119 }
120 break;
121 case 'b':
122 if (!strcmp(argv[i], "-beta")) {
123 if (setscan(beta, argv[++i]) < 0) {
124 fprintf(stderr,
125 "%s: bad beta spec: %s\n",
126 progname, argv[i]);
127 exit(1);
128 }
129 } else
130 goto badopt;
131 break;
132 case 'x':
133 switch (argv[i][2]) {
134 case '\0': /* x resolution */
135 xres = atoi(argv[++i]);
136 break;
137 case '1':
138 case '2': /* axis spec */
139 case '3':
140 axis[argv[i][2]-'1'][0] = atof(argv[i+1]);
141 axis[argv[i][2]-'1'][1] = atof(argv[i+2]);
142 axis[argv[i][2]-'1'][2] = atof(argv[i+3]);
143 i += 3;
144 break;
145 default:
146 goto badopt;
147 }
148 break;
149 case 'y': /* y resolution */
150 yres = atoi(argv[++i]);
151 break;
152 case 'l':
153 switch (argv[i][2]) {
154 case 'w': /* limit weight */
155 case 'r': /* limit recursion */
156 passarg(argv[i]);
157 passarg(argv[++i]);
158 break;
159 default:
160 goto badopt;
161 }
162 break;
163 case 'u': /* user friendly format */
164 userformat = 1;
165 break;
166 case 'o': /* custom format */
167 passarg(argv[i]);
168 userformat = -1;
169 break;
170 case 'd':
171 switch (argv[i][2]) {
172 case '\0': /* data format */
173 userformat = 0;
174 break;
175 case 'j': /* direct jitter */
176 case 't': /* direct threshold */
177 case 'c': /* direct certainty */
178 passarg(argv[i]);
179 passarg(argv[++i]);
180 break;
181 default:
182 goto badopt;
183 }
184 break;
185 case 'h': /* no header */
186 header = 0;
187 break;
188 default:;
189 badopt:
190 fprintf(stderr, "%s: bad option: %s\n",
191 progname, argv[i]);
192 exit(1);
193 }
194
195 if (userformat >= 0) { /* we cook */
196 passarg("-ov");
197 passarg("-fff");
198 } else /* raw */
199 passarg("-ffa");
200
201 if (i != argc-1) {
202 fprintf(stderr, "%s: single octree required\n", progname);
203 exit(1);
204 }
205
206 passarg(argv[i]);
207 passarg(NULL);
208
209 fixaxes();
210
211 if (header)
212 if (userformat > 0)
213 printf("Alpha\tBeta\tRadiance\n");
214 else {
215 printargs(argc, argv, stdout);
216 putchar('\n');
217 }
218
219 if (doscan() == -1)
220 exit(1);
221
222 exit(0);
223 }
224
225
226 printargs(ac, av, fp) /* print arguments to a file */
227 int ac;
228 char **av;
229 FILE *fp;
230 {
231 while (ac-- > 0) {
232 fputs(*av++, fp);
233 putc(' ', fp);
234 }
235 putc('\n', fp);
236 }
237
238
239 fixaxes() /* make sure axes are OK */
240 {
241 extern double normalize(), fdot();
242 double d;
243 register int i;
244
245 for (i = 0; i < 3; i++)
246 if (normalize(axis[i]) == 0.0)
247 goto axerr;
248
249 for (i = 0; i < 3; i++) {
250 d = fdot(axis[i], axis[(i+1)%3]);
251 if (d > FTINY || d < -FTINY)
252 goto axerr;
253 }
254 return;
255 axerr:
256 fprintf(stderr, "%s: bad axis specification\n", progname);
257 exit(1);
258 }
259
260
261 doscan() /* do scan for target */
262 {
263 FILE *fopen(), *scanstart();
264 double readsample();
265 FILE *fp;
266 ANGLE *a, *b;
267
268 fp = scanstart(); /* returns in child if not raw */
269 for (a = alpha; *a != AEND; a++) /* read data */
270 for (b = beta; *b != AEND; b++)
271 if (userformat > 0)
272 printf("%d\t%d\t%e\n", *a, *b, readsample(fp));
273 else
274 printf("%e\n", readsample(fp));
275 return(scanend(fp));
276 }
277
278
279 FILE *
280 scanstart() /* open scanner pipeline */
281 {
282 int status;
283 char *fgets();
284 int p1[2], p2[2];
285 int pid;
286 FILE *fp;
287
288 fflush(stdout); /* empty output buffer */
289 if (pipe(p1) < 0) /* get pipe1 */
290 goto err;
291 if ((pid = fork()) == 0) { /* if child1 */
292 close(p1[1]);
293 if (p1[0] != 0) { /* connect pipe1 to stdin */
294 dup2(p1[0], 0);
295 close(p1[0]);
296 }
297 if (userformat >= 0) { /* if processing output */
298 if (pipe(p2) < 0) /* get pipe2 */
299 goto err;
300 if ((pid = vfork()) == 0) { /* if child2 */
301 close(p2[0]);
302 if (p2[1] != 1) { /* pipe2 to stdout */
303 dup2(p2[1], 1);
304 close(p2[1]);
305 }
306 execvp(rtargv[0], rtargv); /* rtrace */
307 goto err;
308 }
309 if (pid == -1)
310 goto err;
311 close(p2[1]);
312 if ((fp = fdopen(p2[0], "r")) == NULL)
313 goto err;
314 return(fp);
315 } else { /* if running raw */
316 execvp(rtargv[0], rtargv); /* rtrace */
317 goto err;
318 }
319 }
320 if (pid == -1)
321 goto err;
322 close(p1[0]);
323 if ((fp = fdopen(p1[1], "w")) == NULL)
324 goto err;
325 sendsamples(fp); /* parent writes output to pipe1 */
326 fclose(fp);
327 if (wait(&status) != -1) /* wait for child1 */
328 _exit(status);
329 err:
330 perror(progname);
331 _exit(1);
332 }
333
334
335 scanend(fp) /* done with scanner input */
336 FILE *fp;
337 {
338 int status;
339
340 fclose(fp);
341 if (wait(&status) == -1) { /* wait for child2 */
342 perror(progname);
343 exit(1);
344 }
345 return(status ? -1 : 0);
346 }
347
348
349 sendsamples(fp) /* send our samples to fp */
350 FILE *fp;
351 {
352 ANGLE *a, *b;
353
354 for (a = alpha; *a != AEND; a++)
355 for (b = beta; *b != AEND; b++)
356 writesample(fp, *a, *b);
357 }
358
359
360 writesample(fp, a, b) /* write out sample ray grid */
361 FILE *fp;
362 ANGLE a, b;
363 {
364 double sin(), cos();
365 float sp[6];
366 double dv[3];
367 double xpos, ypos;
368 int i, j, k;
369 /* get direction in their system */
370 dv[0] = -cos(atorad(a));
371 dv[1] = dv[2] = -sin(atorad(a));
372 dv[1] *= cos(atorad(b));
373 dv[2] *= sin(atorad(b));
374 /* do sample grid in our system */
375 for (j = 0; j < yres; j++) {
376 for (i = 0; i < xres; i++) {
377 xpos = ((i + frandom())/xres - 0.5) * targetw;
378 ypos = ((j + frandom())/yres - 0.5) * targeth;
379 for (k = 0; k < 3; k++) {
380 sp[k] = targetp[k];
381 sp[k] += xpos*axis[2][k];
382 sp[k] += ypos*axis[1][k];
383 sp[k+3] = dv[0]*axis[0][k] +
384 dv[1]*axis[1][k] +
385 dv[2]*axis[2][k];
386 sp[k] -= sp[k+3]*targetd;
387 }
388 if (fwrite(sp, sizeof(*sp), 6, fp) != 6) {
389 fprintf(stderr, "%s: data write error\n",
390 progname);
391 _exit(1);
392 }
393 }
394 }
395 }
396
397
398 double
399 readsample(fp) /* read in sample ray grid */
400 FILE *fp;
401 {
402 float col[3];
403 double sum;
404 int i;
405
406 sum = 0.0;
407 i = xres*yres;
408 while (i--) {
409 if (fread(col, sizeof(*col), 3, fp) != 3) {
410 fprintf(stderr, "%s: data read error\n", progname);
411 exit(1);
412 }
413 sum += .3*col[0] + .59*col[1] + .11*col[2];
414 }
415 return(sum / (xres*yres));
416 }
