root/Development/ray/src/util/makedist.c
Revision: 2.6
Committed: Fri Nov 5 03:31:39 2004 UTC (21 years, 1 month ago) by greg
State: FILE REMOVED
# User Rev Content
1 greg 1.1 #ifndef lint
2 greg 2.6 static const char RCSid[] = "$Id: makedist.c,v 2.5 2004/03/26 21:36:19 schorsch Exp $";
3 greg 1.1 #endif
4     /*
5     * makedist.c - program to make a source distribution.
6     *
7     * 8/18/86
8     *
9     * Program uses angular coordinates as follows:
10     *
11     * alpha - degrees measured from x1 axis.
12     * beta - degress of projection into x2x3 plane,
13     * measured from x2 axis towards x3 axis.
14     *
15     * Default axes are (x1,x2,x3) = (x,y,z).
16     */
17
18 greg 2.4 #include <stdlib.h>
19 schorsch 2.5 #include <unistd.h>
20     #include <stdio.h>
21     #include <string.h>
22     #include <sys/types.h>
23     #include <sys/wait.h>
24 greg 2.4
25 schorsch 2.5 #include "rtmath.h"
26 greg 1.1 #include "random.h"
27 greg 1.2 #include "setscan.h"
28 greg 1.1
29 greg 1.3 #ifndef BSD
30     #define vfork fork
31     #endif
32 greg 1.1
33     #define atorad(a) ((PI/180.0) * (a))
34
35     char *rtargv[128] = {"rtrace", "-h"};
36     int rtargc = 2;
37
38     #define passarg(s) (rtargv[rtargc++] = s)
39
40     ANGLE alpha[181] = {10, 25, 40, 55, 70, 85, AEND};
41     ANGLE beta[361] = {0,30,60,90,120,150,180,210,240,270,300,330,AEND};
42
43     /* coordinate system */
44     double axis[3][3] = {{1,0,0},{0,1,0},{0,0,1}};
45
46     double targetw = 1.0; /* target width */
47     double targeth = 1.0; /* target height */
48     double targetd = 1.0; /* target distance */
49     double targetp[3] = {0,0,0}; /* target center */
50     int xres = 16; /* x sample resolution */
51     int yres = 16; /* y sample resolution */
52
53     int userformat = 1; /* output 1=nice,0=plain,-1=raw */
54     int header = 1; /* print header? */
55
56     char *progname; /* program name */
57
58 schorsch 2.5 static void printargs(int ac, char **av, FILE *fp);
59     static void fixaxes(void);
60     static int doscan(void);
61     static FILE * scanstart(void);
62     static int scanend(FILE *fp);
63     static void sendsamples(FILE *fp);
64     static void writesample(FILE *fp, ANGLE a, ANGLE b);
65     static double readsample(FILE *fp);
66
67 greg 1.1
68 schorsch 2.5 int
69     main(
70     int argc,
71     char *argv[]
72     )
73 greg 1.1 {
74     int i;
75
76     progname = argv[0];
77
78     for (i = 1; i < argc && argv[i][0] == '-'; i++)
79     switch (argv[i][1]) {
80     case 't': /* target */
81     switch (argv[i][2]) {
82     case 'w': /* width */
83     targetw = atof(argv[++i]);
84     break;
85     case 'h': /* height */
86     targeth = atof(argv[++i]);
87     break;
88     case 'd': /* distance */
89     targetd = atof(argv[++i]);
90     break;
91     case 'c': /* center */
92     targetp[0] = atof(argv[++i]);
93     targetp[1] = atof(argv[++i]);
94     targetp[2] = atof(argv[++i]);
95     break;
96     default:
97     goto badopt;
98     }
99     break;
100     case 'a':
101     if (!strcmp(argv[i], "-alpha")) {
102     if (setscan(alpha, argv[++i]) < 0) {
103     fprintf(stderr,
104     "%s: bad alpha spec: %s\n",
105     progname, argv[i]);
106     exit(1);
107     }
108     } else
109     switch (argv[i][2]) {
110     case 'd': /* ambient divisions */
111     case 's': /* ambient samples */
112     case 'r': /* ambient resolution */
113     case 'a': /* ambient accuracy */
114     case 'b': /* ambient bounces */
115     case 'i': /* include */
116     case 'e': /* exclude */
117     case 'f': /* file */
118     passarg(argv[i]);
119     passarg(argv[++i]);
120     break;
121     case 'v': /* ambient value */
122     passarg(argv[i]);
123     passarg(argv[++i]);
124     passarg(argv[++i]);
125     passarg(argv[++i]);
126     break;
127     default:
128     goto badopt;
129     }
130     break;
131     case 'b':
132     if (!strcmp(argv[i], "-beta")) {
133     if (setscan(beta, argv[++i]) < 0) {
134     fprintf(stderr,
135     "%s: bad beta spec: %s\n",
136     progname, argv[i]);
137     exit(1);
138     }
139     } else
140     goto badopt;
141     break;
142     case 'x':
143     switch (argv[i][2]) {
144     case '\0': /* x resolution */
145     xres = atoi(argv[++i]);
146     break;
147     case '1':
148     case '2': /* axis spec */
149     case '3':
150     axis[argv[i][2]-'1'][0] = atof(argv[i+1]);
151     axis[argv[i][2]-'1'][1] = atof(argv[i+2]);
152     axis[argv[i][2]-'1'][2] = atof(argv[i+3]);
153     i += 3;
154     break;
155     default:
156     goto badopt;
157     }
158     break;
159     case 'y': /* y resolution */
160     yres = atoi(argv[++i]);
161     break;
162     case 'l':
163     switch (argv[i][2]) {
164     case 'w': /* limit weight */
165     case 'r': /* limit recursion */
166     passarg(argv[i]);
167     passarg(argv[++i]);
168     break;
169     default:
170     goto badopt;
171     }
172     break;
173     case 'u': /* user friendly format */
174     userformat = 1;
175     break;
176     case 'o': /* custom format */
177     passarg(argv[i]);
178     userformat = -1;
179     break;
180     case 'd':
181     switch (argv[i][2]) {
182     case '\0': /* data format */
183     userformat = 0;
184     break;
185     case 'j': /* direct jitter */
186     case 't': /* direct threshold */
187     case 'c': /* direct certainty */
188     passarg(argv[i]);
189     passarg(argv[++i]);
190     break;
191     default:
192     goto badopt;
193     }
194     break;
195     case 'h': /* no header */
196     header = 0;
197     break;
198     default:;
199     badopt:
200     fprintf(stderr, "%s: bad option: %s\n",
201     progname, argv[i]);
202     exit(1);
203     }
204
205     if (userformat >= 0) { /* we cook */
206     passarg("-ov");
207     passarg("-fff");
208     } else /* raw */
209     passarg("-ffa");
210
211     if (i != argc-1) {
212     fprintf(stderr, "%s: single octree required\n", progname);
213     exit(1);
214     }
215
216     passarg(argv[i]);
217     passarg(NULL);
218
219     fixaxes();
220
221 schorsch 2.5 if (header) {
222     if (userformat > 0) {
223 greg 1.1 printf("Alpha\tBeta\tRadiance\n");
224 schorsch 2.5 } else {
225 greg 1.1 printargs(argc, argv, stdout);
226     putchar('\n');
227     }
228 schorsch 2.5 }
229 greg 1.1
230     if (doscan() == -1)
231     exit(1);
232
233     exit(0);
234     }
235
236
237 schorsch 2.5 static void
238     printargs( /* print arguments to a file */
239     int ac,
240     char **av,
241     FILE *fp
242     )
243 greg 1.1 {
244     while (ac-- > 0) {
245     fputs(*av++, fp);
246     putc(' ', fp);
247     }
248     putc('\n', fp);
249     }
250
251
252 schorsch 2.5 static void
253     fixaxes(void) /* make sure axes are OK */
254 greg 1.1 {
255     double d;
256     register int i;
257
258     for (i = 0; i < 3; i++)
259     if (normalize(axis[i]) == 0.0)
260     goto axerr;
261
262     for (i = 0; i < 3; i++) {
263     d = fdot(axis[i], axis[(i+1)%3]);
264     if (d > FTINY || d < -FTINY)
265     goto axerr;
266     }
267     return;
268     axerr:
269     fprintf(stderr, "%s: bad axis specification\n", progname);
270     exit(1);
271     }
272
273
274 schorsch 2.5 static int
275     doscan(void) /* do scan for target */
276 greg 1.1 {
277     FILE *fopen(), *scanstart();
278     double readsample();
279     FILE *fp;
280     ANGLE *a, *b;
281
282     fp = scanstart(); /* returns in child if not raw */
283     for (a = alpha; *a != AEND; a++) /* read data */
284     for (b = beta; *b != AEND; b++)
285     if (userformat > 0)
286     printf("%d\t%d\t%e\n", *a, *b, readsample(fp));
287     else
288     printf("%e\n", readsample(fp));
289     return(scanend(fp));
290     }
291
292
293 schorsch 2.5 static FILE *
294     scanstart(void) /* open scanner pipeline */
295 greg 1.1 {
296     int status;
297     char *fgets();
298     int p1[2], p2[2];
299     int pid;
300     FILE *fp;
301
302     fflush(stdout); /* empty output buffer */
303     if (pipe(p1) < 0) /* get pipe1 */
304     goto err;
305     if ((pid = fork()) == 0) { /* if child1 */
306     close(p1[1]);
307     if (p1[0] != 0) { /* connect pipe1 to stdin */
308     dup2(p1[0], 0);
309     close(p1[0]);
310     }
311     if (userformat >= 0) { /* if processing output */
312     if (pipe(p2) < 0) /* get pipe2 */
313     goto err;
314     if ((pid = vfork()) == 0) { /* if child2 */
315     close(p2[0]);
316     if (p2[1] != 1) { /* pipe2 to stdout */
317     dup2(p2[1], 1);
318     close(p2[1]);
319     }
320     execvp(rtargv[0], rtargv); /* rtrace */
321     goto err;
322     }
323     if (pid == -1)
324     goto err;
325     close(p2[1]);
326     if ((fp = fdopen(p2[0], "r")) == NULL)
327     goto err;
328     return(fp);
329     } else { /* if running raw */
330     execvp(rtargv[0], rtargv); /* rtrace */
331     goto err;
332     }
333     }
334     if (pid == -1)
335     goto err;
336     close(p1[0]);
337     if ((fp = fdopen(p1[1], "w")) == NULL)
338     goto err;
339     sendsamples(fp); /* parent writes output to pipe1 */
340     fclose(fp);
341     if (wait(&status) != -1) /* wait for child1 */
342     _exit(status);
343     err:
344     perror(progname);
345     _exit(1);
346     }
347
348
349 schorsch 2.5 static int
350     scanend( /* done with scanner input */
351     FILE *fp
352     )
353 greg 1.1 {
354     int status;
355
356     fclose(fp);
357     if (wait(&status) == -1) { /* wait for child2 */
358     perror(progname);
359     exit(1);
360     }
361     return(status ? -1 : 0);
362     }
363
364
365 schorsch 2.5 static void
366     sendsamples( /* send our samples to fp */
367     FILE *fp
368     )
369 greg 1.1 {
370     ANGLE *a, *b;
371
372     for (a = alpha; *a != AEND; a++)
373     for (b = beta; *b != AEND; b++)
374     writesample(fp, *a, *b);
375     }
376
377
378 schorsch 2.5 static void
379     writesample( /* write out sample ray grid */
380     FILE *fp,
381     ANGLE a,
382     ANGLE b
383     )
384 greg 1.1 {
385     double sin(), cos();
386     float sp[6];
387     double dv[3];
388     double xpos, ypos;
389     int i, j, k;
390     /* get direction in their system */
391     dv[0] = -cos(atorad(a));
392     dv[1] = dv[2] = -sin(atorad(a));
393     dv[1] *= cos(atorad(b));
394     dv[2] *= sin(atorad(b));
395     /* do sample grid in our system */
396     for (j = 0; j < yres; j++) {
397     for (i = 0; i < xres; i++) {
398     xpos = ((i + frandom())/xres - 0.5) * targetw;
399     ypos = ((j + frandom())/yres - 0.5) * targeth;
400     for (k = 0; k < 3; k++) {
401     sp[k] = targetp[k];
402     sp[k] += xpos*axis[2][k];
403     sp[k] += ypos*axis[1][k];
404     sp[k+3] = dv[0]*axis[0][k] +
405     dv[1]*axis[1][k] +
406     dv[2]*axis[2][k];
407     sp[k] -= sp[k+3]*targetd;
408     }
409     if (fwrite(sp, sizeof(*sp), 6, fp) != 6) {
410     fprintf(stderr, "%s: data write error\n",
411     progname);
412     _exit(1);
413     }
414     }
415     }
416     }
417
418
419 schorsch 2.5 static double
420     readsample( /* read in sample ray grid */
421     FILE *fp
422     )
423 greg 1.1 {
424     float col[3];
425     double sum;
426     int i;
427
428     sum = 0.0;
429     i = xres*yres;
430     while (i--) {
431     if (fread(col, sizeof(*col), 3, fp) != 3) {
432     fprintf(stderr, "%s: data read error\n", progname);
433     exit(1);
434     }
435     sum += .3*col[0] + .59*col[1] + .11*col[2];
436     }
437     return(sum / (xres*yres));
438     }
