root/radiance/ray/src/util/ltview.pl
Revision: 2.2
Committed: Wed Apr 16 20:32:00 2014 UTC (11 years, 4 months ago) by greg
CVS Tags: rad5R4, rad5R2, rad5R3, rad5R0, rad5R1, rad4R2, rad6R0, rad4R2P1, rad4R2P2, HEAD
Changes since 2.1: +77 -84 lines
Axel updates to ltview and ltpict
# User Rev Content
1 greg 2.1 #!/usr/bin/perl
2     #
3     # Make an interactive preview of a luminaire
4     #
5     # This script is based on Radiance's objview.pl plus
6     # Rob Guglielmetti's ltview extension to his objview.rb
7     #
8     # Written by Axel Jacobs <[email protected]>
9
10     use strict;
11     use warnings;
12     use Math::Trig;
13     use File::Temp qw/ tempdir /;
14
15 greg 2.2 my $td = tempdir( CLEANUP => 1 );
16     my $oct = "$td/ltview.oct";
17     my $room = "$td/room.rad";
18     my $box; # Overall box dimensions
19     my $rif = "$td/ltview.rif";
20     my $lumi = "$td/lumi.rad"; # Fitting as given on cmd line, or generated by ies2rad
21     my $lumi2 = "$td/lumi2.rad"; # Fitting centred at origin
22     my $raddev = "x11"; # Default output device. Overwrite with -o
23     my $is_ies = 0; # Input file is IES photometry, not a Radiance luminaire
24 greg 2.1
25     while (@ARGV) {
26 greg 2.2 $_ = $ARGV[0];
27     if (m/-i/) {
28     $is_ies = 1;
29     } elsif (m/-o/) { # output device (rvu -devices)
30     $raddev = $ARGV[1];
31     shift @ARGV;
32     } elsif (m/-b/) {
33     $box = $ARGV[1]; # Box dimensions
34     shift @ARGV;
35     } elsif (m/^-\w/) {
36     die("ltview: Bad option: '$_'\n");
37     } else {
38     last;
39     }
40     shift @ARGV;
41 greg 2.1 }
42
43     # We need exactly one Radiance luminaires or IES file
44 greg 2.2 if ( !$#ARGV == 0 ) {
45     die("ltview: Need one Radiance luminaire or IES file.\n");
46     } elsif ( $is_ies == 0 ) {
47 greg 2.1
48 greg 2.2 # Input file is a Radiance luminaire
49     $lumi = $ARGV[0];
50 greg 2.1 } else {
51 greg 2.2
52     # Input file is IES photometry
53     system qq[ ies2rad -p $td -o lumi "$ARGV[0]" ];
54 greg 2.1 }
55
56 greg 2.2 # Work out centre of luminaire
57     my $dimstr = `getbbox -h "$lumi"`;
58     chomp $dimstr;
59
60     # Values returned by getbbox are indented and delimited with multiple spaces.
61     $dimstr =~ s/^\s+//; # remove leading spaces
62     my @dims = split( /\s+/, $dimstr ); # convert to array
63
64     # Find largest axes-aligned luminaire dimension
65     # The box will be ten times as large, unless overwritten with -b option.
66     my @diffs = reverse sort { $a <=> $b }
67     ( $dims[1] - $dims[0], $dims[3] - $dims[2], $dims[5] - $dims[4] );
68     my $lsize = $diffs[0];
69
70     # Centre fitting at origin
71     my $xtrans = -1.0 * ( $dims[0] + $dims[1] ) / 2;
72     my $ytrans = -1.0 * ( $dims[2] + $dims[3] ) / 2;
73     my $ztrans = -1.0 * ( $dims[4] + $dims[5] ) / 2;
74     system qq[ xform -t $xtrans $ytrans $ztrans "$lumi" > $lumi2 ];
75 greg 2.1
76 greg 2.2 # Make the enclosing box
77 greg 2.1 my $b2;
78 greg 2.2 if ( defined $box ) {
79 greg 2.1
80 greg 2.2 # Room dimensions are giving explicitly.
81     $b2 = $box / 2;
82 greg 2.1 } else {
83
84 greg 2.2 # Box dimensions are ten times largest luminaire bbox dimensions.
85     $b2 = $lsize * 10.0 / 2.0;
86 greg 2.1 }
87
88 greg 2.2 open( FH, ">$room" )
89     or die("ltview: Can't write to temporary file '$room'\n");
90 greg 2.1 print FH <<EndOfRoom;
91 greg 2.2 void plastic wall_mat 0 0 5 .2 .2 .2 0 0
92
93     # Don't generate -y face so we can look into the box
94 greg 2.1 #wall_mat polygon box.1540 0 0 12 $b2 -$b2 -$b2 $b2 -$b2 $b2 -$b2 -$b2 $b2 -$b2 -$b2 -$b2
95     wall_mat polygon box.4620 0 0 12 -$b2 -$b2 $b2 -$b2 $b2 $b2 -$b2 $b2 -$b2 -$b2 -$b2 -$b2
96     wall_mat polygon box.2310 0 0 12 -$b2 $b2 -$b2 $b2 $b2 -$b2 $b2 -$b2 -$b2 -$b2 -$b2 -$b2
97     wall_mat polygon box.3267 0 0 12 $b2 $b2 -$b2 -$b2 $b2 -$b2 -$b2 $b2 $b2 $b2 $b2 $b2
98     wall_mat polygon box.5137 0 0 12 $b2 -$b2 $b2 $b2 -$b2 -$b2 $b2 $b2 -$b2 $b2 $b2 $b2
99     wall_mat polygon box.6457 0 0 12 -$b2 $b2 $b2 -$b2 -$b2 $b2 $b2 -$b2 $b2 $b2 $b2 $b2
100     EndOfRoom
101     close(FH);
102
103 greg 2.2 my $scene = "$room $lumi2";
104
105 greg 2.1 # Make this work under Windoze
106     if ( $^O =~ /MSWin32/ ) {
107 greg 2.2 $scene =~ s{\\}{/}g;
108     $oct =~ s{\\}{/}g;
109     $raddev = "qt";
110 greg 2.1 }
111
112 greg 2.2 # Tweak scene bounding box so we get a nice view covering all of the box, without
113 greg 2.1 # having a wasteful black border around it. Must work for arbitrary box dims.
114 greg 2.2 my $zone = 1.1 * $b2 * ( 1 + 1 / tan( 22.5 * pi / 180 ) );
115 greg 2.1
116 greg 2.2 open( FH, ">$rif" )
117     or die("ltview: Can't write to temporary file '$rif'\n");
118 greg 2.1 print FH <<EndOfRif;
119     scene= $scene
120     ZONE= Interior -$zone $zone -$zone $zone -$zone $zone
121     UP= Z
122     view= y
123     OCTREE= $oct
124     oconv= -f
125 greg 2.2 render= -av 0 0 0
126     INDIRECT= 0
127     QUALITY= Med
128     DETAIL= Low
129     VARIABILITY= Med
130 greg 2.1 EndOfRif
131     close(FH);
132
133 greg 2.2 exec "rad -o $raddev $rif";
134 greg 2.1
135     #EOF
