root/Development/ray/src/util/ltview.pl
Revision: 2.2
Committed: Wed Apr 16 20:32:00 2014 UTC (11 years, 8 months ago) by greg
CVS Tags: rad6R0, rad5R4, rad5R3, rad5R2, rad5R1, rad5R0, rad4R2P2, rad4R2P1, rad4R2, HEAD
Changes since 2.1: +77 -84 lines
Error occurred while calculating annotation data.
Axel updates to ltview and ltpict
1 #!/usr/bin/perl
2 #
3 # Make an interactive preview of a luminaire
4 #
5 # This script is based on Radiance's objview.pl plus
6 # Rob Guglielmetti's ltview extension to his objview.rb
7 #
8 # Written by Axel Jacobs <[email protected]>
9
10 use strict;
11 use warnings;
12 use Math::Trig;
13 use File::Temp qw/ tempdir /;
14
15 my $td = tempdir( CLEANUP => 1 );
16 my $oct = "$td/ltview.oct";
17 my $room = "$td/room.rad";
18 my $box; # Overall box dimensions
19 my $rif = "$td/ltview.rif";
20 my $lumi = "$td/lumi.rad"; # Fitting as given on cmd line, or generated by ies2rad
21 my $lumi2 = "$td/lumi2.rad"; # Fitting centred at origin
22 my $raddev = "x11"; # Default output device. Overwrite with -o
23 my $is_ies = 0; # Input file is IES photometry, not a Radiance luminaire
24
25 while (@ARGV) {
26 $_ = $ARGV[0];
27 if (m/-i/) {
28 $is_ies = 1;
29 } elsif (m/-o/) { # output device (rvu -devices)
30 $raddev = $ARGV[1];
31 shift @ARGV;
32 } elsif (m/-b/) {
33 $box = $ARGV[1]; # Box dimensions
34 shift @ARGV;
35 } elsif (m/^-\w/) {
36 die("ltview: Bad option: '$_'\n");
37 } else {
38 last;
39 }
40 shift @ARGV;
41 }
42
43 # We need exactly one Radiance luminaires or IES file
44 if ( !$#ARGV == 0 ) {
45 die("ltview: Need one Radiance luminaire or IES file.\n");
46 } elsif ( $is_ies == 0 ) {
47
48 # Input file is a Radiance luminaire
49 $lumi = $ARGV[0];
50 } else {
51
52 # Input file is IES photometry
53 system qq[ ies2rad -p $td -o lumi "$ARGV[0]" ];
54 }
55
56 # Work out centre of luminaire
57 my $dimstr = `getbbox -h "$lumi"`;
58 chomp $dimstr;
59
60 # Values returned by getbbox are indented and delimited with multiple spaces.
61 $dimstr =~ s/^\s+//; # remove leading spaces
62 my @dims = split( /\s+/, $dimstr ); # convert to array
63
64 # Find largest axes-aligned luminaire dimension
65 # The box will be ten times as large, unless overwritten with -b option.
66 my @diffs = reverse sort { $a <=> $b }
67 ( $dims[1] - $dims[0], $dims[3] - $dims[2], $dims[5] - $dims[4] );
68 my $lsize = $diffs[0];
69
70 # Centre fitting at origin
71 my $xtrans = -1.0 * ( $dims[0] + $dims[1] ) / 2;
72 my $ytrans = -1.0 * ( $dims[2] + $dims[3] ) / 2;
73 my $ztrans = -1.0 * ( $dims[4] + $dims[5] ) / 2;
74 system qq[ xform -t $xtrans $ytrans $ztrans "$lumi" > $lumi2 ];
75
76 # Make the enclosing box
77 my $b2;
78 if ( defined $box ) {
79
80 # Room dimensions are giving explicitly.
81 $b2 = $box / 2;
82 } else {
83
84 # Box dimensions are ten times largest luminaire bbox dimensions.
85 $b2 = $lsize * 10.0 / 2.0;
86 }
87
88 open( FH, ">$room" )
89 or die("ltview: Can't write to temporary file '$room'\n");
90 print FH <<EndOfRoom;
91 void plastic wall_mat 0 0 5 .2 .2 .2 0 0
92
93 # Don't generate -y face so we can look into the box
94 #wall_mat polygon box.1540 0 0 12 $b2 -$b2 -$b2 $b2 -$b2 $b2 -$b2 -$b2 $b2 -$b2 -$b2 -$b2
95 wall_mat polygon box.4620 0 0 12 -$b2 -$b2 $b2 -$b2 $b2 $b2 -$b2 $b2 -$b2 -$b2 -$b2 -$b2
96 wall_mat polygon box.2310 0 0 12 -$b2 $b2 -$b2 $b2 $b2 -$b2 $b2 -$b2 -$b2 -$b2 -$b2 -$b2
97 wall_mat polygon box.3267 0 0 12 $b2 $b2 -$b2 -$b2 $b2 -$b2 -$b2 $b2 $b2 $b2 $b2 $b2
98 wall_mat polygon box.5137 0 0 12 $b2 -$b2 $b2 $b2 -$b2 -$b2 $b2 $b2 -$b2 $b2 $b2 $b2
99 wall_mat polygon box.6457 0 0 12 -$b2 $b2 $b2 -$b2 -$b2 $b2 $b2 -$b2 $b2 $b2 $b2 $b2
100 EndOfRoom
101 close(FH);
102
103 my $scene = "$room $lumi2";
104
105 # Make this work under Windoze
106 if ( $^O =~ /MSWin32/ ) {
107 $scene =~ s{\\}{/}g;
108 $oct =~ s{\\}{/}g;
109 $raddev = "qt";
110 }
111
112 # Tweak scene bounding box so we get a nice view covering all of the box, without
113 # having a wasteful black border around it. Must work for arbitrary box dims.
114 my $zone = 1.1 * $b2 * ( 1 + 1 / tan( 22.5 * pi / 180 ) );
115
116 open( FH, ">$rif" )
117 or die("ltview: Can't write to temporary file '$rif'\n");
118 print FH <<EndOfRif;
119 scene= $scene
120 ZONE= Interior -$zone $zone -$zone $zone -$zone $zone
121 UP= Z
122 view= y
123 OCTREE= $oct
124 oconv= -f
125 render= -av 0 0 0
126 INDIRECT= 0
127 QUALITY= Med
128 DETAIL= Low
129 VARIABILITY= Med
130 EndOfRif
131 close(FH);
132
133 exec "rad -o $raddev $rif";
134
135 #EOF
