root/Development/ray/src/util/ltpict.pl
Revision: 2.1
Committed: Tue Apr 15 22:36:25 2014 UTC (11 years, 6 months ago) by greg
1 #!/usr/bin/perl
2
3 # Make a four-view picture of the photometry of a luminaire
4 #
5 # This is inspired by objpict.pl that renders four-view
6 # images of objects that are not light sources.
7 #
8 # Written by Axel Jacobs <[email protected]>
9
10 use strict;
11 use warnings;
12
13 use File::Temp qw/ tempdir /;
14 my $td = tempdir( CLEANUP => 1 );
15
16 my $res = 1024; # Default output image dimensions. Same as objpict.
17 my $tiny = 0.01;
18 my $maxsize = 0.001; # max luminaire size after scaling
19 my $is_ies = 0;
20
21 my $ies = "$td/dist.ies";
22 my $lumi = "$td/lumi.rad"; # Fitting given on cmd line, or generated by ies2rad
23 my $lumi2 = "$td/lumi2.rad"; # Fitting scaled to size
24 my $mat = "$td/lt.mat";
25 my $room1 = "$td/room1.rad";
26 my $room2 = "$td/room2.rad";
27 my $room3 = "$td/room3.rad";
28 my $room4 = "$td/room4.rad";
29 my $oct1 = "$td/lt1.oct";
30 my $oct2 = "$td/lt2.oct";
31 my $oct3 = "$td/lt3.oct";
32 my $oct4 = "$td/lt4.oct";
33
34 # Parse command line arguments
35 while (@ARGV) {
36 $_ = $ARGV[0];
37 if (m/-i/) { # File is an IES file, not a Radiance luminaire
38 $is_ies = 1;
39 } elsif (m/-d/) { # Resolution of the output HDR image
40 $res = $ARGV[1];
41 shift @ARGV;
42 } elsif (m/^-\w/) { # Oops! Illegal option
43 die("ltpict: bad option '$_'\n");
44 } else {
45 last; # No more options. What's left is the actual file name.
46 }
47 shift @ARGV;
48 }
49
50 if ($is_ies == 0) {
51 # Input file is a Radiance luminaire
52 $lumi = $ARGV[0];
53 } else {
54 # Input file is IES photometry
55 system "ies2rad -p $td -o lumi $ARGV[0]";
56 }
57
58 my $res2 = $res / 2; # Each rendering is half the size of final composite
59
60 # Scale luminaire and center at origin
61 my $dimstr = `getbbox -h $lumi`;
62 chomp $dimstr;
63 # Values returned by getbbox are indented and delimited with multiple spaces.
64 $dimstr =~ s/^\s+//; # remove leading spaces
65 my @dims = split(/\s+/, $dimstr); # convert to array
66
67 # Find largest axes-aligned dimension
68 my @diffs = ($dims[1]-$dims[0], $dims[3]-$dims[2], $dims[5]-$dims[4]);
69 @diffs = reverse sort { $a <=> $b } @diffs;
70 my $size = $diffs[0];
71
72 # Move luminaire so centre is at origin, and scale
73 my $xtrans = -1.0 * ($dims[0] + $dims[1]) / 2;
74 my $ytrans = -1.0 * ($dims[2] + $dims[3]) / 2;
75 my $ztrans = -1.0 * ($dims[4] + $dims[5]) / 2;
76 my $scale = $maxsize / $size;
77
78 open(FH, ">$lumi2") or
79 die("ltpict: Cannot write to temporary file $lumi");
80 print FH "!xform -t $xtrans $ytrans $ztrans -s $scale $lumi";
81 close FH;
82
83
84 # Material for the room
85 open(FH, ">$mat") or
86 die("ltpict: Cannot write to temporary file $mat");
87 print FH "void plastic wall_mat 0 0 5 .5 .5 .5 0 0";
88 close FH;
89
90
91 # Different 'room' geometry for different views
92 my $o = 0.1; # Offset
93
94 # C0-C180
95 open(FH, ">$room1") or
96 die("ltpict: Cannot write to temporary file $room1");
97 print FH "wall_mat polygon box.4620 0 0 12 -$o -5 5 -$o 5 5 -$o 5 -5 -$o -5 -5";
98 close(FH);
99
100 # C90-C270
101 open(FH, ">$room2") or
102 die("ltpict: Cannot write to temporary file $room2");
103 print FH "wall_mat polygon box.1540 0 0 12 5 $o -5 5 $o 5 -5 $o 5 -5 $o -5";
104 close(FH);
105
106 # Lower hemisphere
107 open(FH, ">$room3") or
108 die("ltpict: Cannot write to temporary file $room3");
109 print FH "wall_mat bubble lower 0 0 4 0 0 $dims[4] 5";
110 close(FH);
111
112 # Upper hemisphere
113 open(FH, ">$room4") or
114 die("ltpict: Cannot write to temporary file $room4");
115 print FH "wall_mat bubble upper 0 0 4 0 0 $dims[5] 5";
116 close(FH);
117
118
119 # Call bbox again, for the translated and scaled luminaire.
120 $dimstr = `getbbox -h $lumi2`;
121 chomp $dimstr;
122 # Values returned by getbbox are indented and delimited with multiple spaces.
123 $dimstr =~ s/^\s+//; # remove leading spaces
124 @dims = split(/\s+/, $dimstr); # convert to array
125
126 # Define the four views
127 my $vw1 = "-vtl -vp 4.5 0 0 -vd -1 0 0 -vh 10 -vv 10";
128 my $vw2 = "-vtl -vp 0 -4.5 0 -vd 0 1 0 -vh 10 -vv 10";
129 my $zcent3 = $dims[4] - $tiny;
130 my $vw3 = "-vta -vp 0 0 $zcent3 -vd 0 0 -1 -vu 0 1 0 -vh 180 -vv 180";
131 my $zcent4 = $dims[5] + $tiny;
132 my $vw4 = "-vta -vp 0 0 $zcent4 -vd 0 0 1 -vu 0 1 0 -vh 180 -vv 180";
133
134 system "oconv $mat $room1 $lumi2 > $oct1";
135 system "oconv $mat $room2 $lumi2 > $oct2";
136 system "oconv $mat $room3 $lumi2 > $oct3";
137 system "oconv $mat $room4 $lumi2 > $oct4";
138
139 # Render four different views of the objects
140 my $rpict_cmd = "rpict -ab 0 -ds 0 -dv -av 0 0 0 -x $res2 -y $res2";
141 system "$rpict_cmd $vw1 $oct1 > $td/right.hdr";
142 system "$rpict_cmd $vw2 $oct2 > $td/front.hdr";
143 system "$rpict_cmd $vw3 $oct3 > $td/down.hdr";
144 system "$rpict_cmd $vw4 $oct4 > $td/up.hdr";
145
146 # Compose the four views into one image
147 my $vtl = "$td/vtl.hdr"; # The two parallel views
148 my $vta = "$td/vta.hdr"; # The two fisheye views
149
150 # Auto-expose right/front and down/up pairs separately
151 my $pcond_cmd = "pcond -l";
152 system "pcompos -a 2 $td/right.hdr $td/front.hdr > $td/rf.hdr";
153 system "$pcond_cmd $td/rf.hdr > $vtl";
154 system "pcompos -a 2 $td/down.hdr $td/up.hdr > $td/du.hdr";
155 system "$pcond_cmd $td/du.hdr > $vta";
156
157 # Combine top two images with bottom row. Output HDR.
158 exec "pcompos -a 1 $vtl $vta";
159
160 #EOF
