--- ray/src/util/ltpict.pl 2014/04/15 22:36:25 2.1 +++ ray/src/util/ltpict.pl 2014/04/16 20:32:00 2.2 @@ -13,14 +13,14 @@ use warnings; use File::Temp qw/ tempdir /; my $td = tempdir( CLEANUP => 1 ); -my $res = 1024; # Default output image dimensions. Same as objpict. +my $res = 1024; # Default output image dimensions. Same as objpict. my $tiny = 0.01; -my $maxsize = 0.001; # max luminaire size after scaling +my $maxsize = 0.001; # max luminaire size after scaling my $is_ies = 0; my $ies = "$td/dist.ies"; -my $lumi = "$td/lumi.rad"; # Fitting given on cmd line, or generated by ies2rad -my $lumi2 = "$td/lumi2.rad"; # Fitting scaled to size +my $lumi = "$td/lumi.rad"; # Fitting given on cmd line, or generated by ies2rad +my $lumi2 = "$td/lumi2.rad"; # Fitting scaled to size my $mat = "$td/lt.mat"; my $room1 = "$td/room1.rad"; my $room2 = "$td/room2.rad"; @@ -33,104 +33,107 @@ my $oct4 = "$td/lt4.oct"; # Parse command line arguments while (@ARGV) { - $_ = $ARGV[0]; - if (m/-i/) { # File is an IES file, not a Radiance luminaire - $is_ies = 1; - } elsif (m/-d/) { # Resolution of the output HDR image - $res = $ARGV[1]; - shift @ARGV; - } elsif (m/^-\w/) { # Oops! Illegal option + $_ = $ARGV[0]; + if (m/-i/) { # File is an IES file, not a Radiance luminaire + $is_ies = 1; + } elsif (m/-d/) { # Resolution of the output HDR image + $res = $ARGV[1]; + shift @ARGV; + } elsif (m/^-\w/) { # Oops! Illegal option die("ltpict: bad option '$_'\n"); } else { - last; # No more options. What's left is the actual file name. - } + last; # No more options. What's left is the actual file name. + } shift @ARGV; } -if ($is_ies == 0) { - # Input file is a Radiance luminaire - $lumi = $ARGV[0]; +# We need exactly one Radiance luminaires or IES file +if ( !$#ARGV == 0 ) { + die("ltpict: Need one Radiance luminaire or IES file.\n"); +} elsif ( $is_ies == 0 ) { + + # Input file is a Radiance luminaire + $lumi = $ARGV[0]; } else { - # Input file is IES photometry - system "ies2rad -p $td -o lumi $ARGV[0]"; + + # Input file is IES photometry + system qq[ ies2rad -p $td -o lumi "$ARGV[0]" ]; } my $res2 = $res / 2; # Each rendering is half the size of final composite # Scale luminaire and center at origin -my $dimstr = `getbbox -h $lumi`; +my $dimstr = `getbbox -h "$lumi"`; chomp $dimstr; + # Values returned by getbbox are indented and delimited with multiple spaces. -$dimstr =~ s/^\s+//; # remove leading spaces -my @dims = split(/\s+/, $dimstr); # convert to array +$dimstr =~ s/^\s+//; # remove leading spaces +my @dims = split( /\s+/, $dimstr ); # convert to array # Find largest axes-aligned dimension -my @diffs = ($dims[1]-$dims[0], $dims[3]-$dims[2], $dims[5]-$dims[4]); +my @diffs = ( $dims[1] - $dims[0], $dims[3] - $dims[2], $dims[5] - $dims[4] ); @diffs = reverse sort { $a <=> $b } @diffs; my $size = $diffs[0]; # Move luminaire so centre is at origin, and scale -my $xtrans = -1.0 * ($dims[0] + $dims[1]) / 2; -my $ytrans = -1.0 * ($dims[2] + $dims[3]) / 2; -my $ztrans = -1.0 * ($dims[4] + $dims[5]) / 2; -my $scale = $maxsize / $size; +my $xtrans = -1.0 * ( $dims[0] + $dims[1] ) / 2; +my $ytrans = -1.0 * ( $dims[2] + $dims[3] ) / 2; +my $ztrans = -1.0 * ( $dims[4] + $dims[5] ) / 2; +my $scale = $maxsize / $size; +system qq[ xform -t $xtrans $ytrans $ztrans "$lumi" > $lumi2 ]; -open(FH, ">$lumi2") or - die("ltpict: Cannot write to temporary file $lumi"); -print FH "!xform -t $xtrans $ytrans $ztrans -s $scale $lumi"; -close FH; - - # Material for the room -open(FH, ">$mat") or - die("ltpict: Cannot write to temporary file $mat"); +open( FH, ">$mat" ) + or die("ltpict: Cannot write to temporary file $mat"); print FH "void plastic wall_mat 0 0 5 .5 .5 .5 0 0"; close FH; - # Different 'room' geometry for different views -my $o = 0.1; # Offset +my $o = 0.1; # Offset # C0-C180 -open(FH, ">$room1") or - die("ltpict: Cannot write to temporary file $room1"); -print FH "wall_mat polygon box.4620 0 0 12 -$o -5 5 -$o 5 5 -$o 5 -5 -$o -5 -5"; +open( FH, ">$room1" ) + or die("ltpict: Cannot write to temporary file $room1"); +print FH + "wall_mat polygon box.4620 0 0 12 -$o -5 5 -$o 5 5 -$o 5 -5 -$o -5 -5"; close(FH); # C90-C270 -open(FH, ">$room2") or - die("ltpict: Cannot write to temporary file $room2"); -print FH "wall_mat polygon box.1540 0 0 12 5 $o -5 5 $o 5 -5 $o 5 -5 $o -5"; +open( FH, ">$room2" ) + or die("ltpict: Cannot write to temporary file $room2"); +print FH + "wall_mat polygon box.1540 0 0 12 5 $o -5 5 $o 5 -5 $o 5 -5 $o -5"; close(FH); # Lower hemisphere -open(FH, ">$room3") or - die("ltpict: Cannot write to temporary file $room3"); +open( FH, ">$room3" ) + or die("ltpict: Cannot write to temporary file $room3"); print FH "wall_mat bubble lower 0 0 4 0 0 $dims[4] 5"; close(FH); # Upper hemisphere -open(FH, ">$room4") or - die("ltpict: Cannot write to temporary file $room4"); +open( FH, ">$room4" ) + or die("ltpict: Cannot write to temporary file $room4"); print FH "wall_mat bubble upper 0 0 4 0 0 $dims[5] 5"; close(FH); - # Call bbox again, for the translated and scaled luminaire. $dimstr = `getbbox -h $lumi2`; chomp $dimstr; + # Values returned by getbbox are indented and delimited with multiple spaces. -$dimstr =~ s/^\s+//; # remove leading spaces -@dims = split(/\s+/, $dimstr); # convert to array +$dimstr =~ s/^\s+//; # remove leading spaces +@dims = split( /\s+/, $dimstr ); # convert to array # Define the four views -my $vw1 = "-vtl -vp 4.5 0 0 -vd -1 0 0 -vh 10 -vv 10"; -my $vw2 = "-vtl -vp 0 -4.5 0 -vd 0 1 0 -vh 10 -vv 10"; +my $vw1 = "-vtl -vp 4.5 0 0 -vd -1 0 0 -vh 10 -vv 10"; +my $vw2 = "-vtl -vp 0 -4.5 0 -vd 0 1 0 -vh 10 -vv 10"; my $zcent3 = $dims[4] - $tiny; -my $vw3 = "-vta -vp 0 0 $zcent3 -vd 0 0 -1 -vu 0 1 0 -vh 180 -vv 180"; +my $vw3 = "-vta -vp 0 0 $zcent3 -vd 0 0 -1 -vu 0 1 0 -vh 180 -vv 180"; my $zcent4 = $dims[5] + $tiny; -my $vw4 = "-vta -vp 0 0 $zcent4 -vd 0 0 1 -vu 0 1 0 -vh 180 -vv 180"; +my $vw4 = "-vta -vp 0 0 $zcent4 -vd 0 0 1 -vu 0 1 0 -vh 180 -vv 180"; +# Compile octrees system "oconv $mat $room1 $lumi2 > $oct1"; system "oconv $mat $room2 $lumi2 > $oct2"; system "oconv $mat $room3 $lumi2 > $oct3"; @@ -144,8 +147,8 @@ system "$rpict_cmd $vw3 $oct3 > $td/down.hdr"; system "$rpict_cmd $vw4 $oct4 > $td/up.hdr"; # Compose the four views into one image -my $vtl = "$td/vtl.hdr"; # The two parallel views -my $vta = "$td/vta.hdr"; # The two fisheye views +my $vtl = "$td/vtl.hdr"; # The two parallel views +my $vta = "$td/vta.hdr"; # The two fisheye views # Auto-expose right/front and down/up pairs separately my $pcond_cmd = "pcond -l";
