root/Development/ray/src/util/ltpict.pl
Revision: 2.2
Committed: Wed Apr 16 20:32:00 2014 UTC (11 years, 4 months ago) by greg
CVS Tags: rad5R4, rad5R2, rad5R3, rad5R0, rad5R1, rad4R2, rad6R0, rad4R2P1, rad4R2P2, HEAD
Changes since 2.1: +58 -55 lines
Axel updates to ltview and ltpict
# User Rev Content
1 greg 2.1 #!/usr/bin/perl
2
3     # Make a four-view picture of the photometry of a luminaire
4     #
5     # This is inspired by objpict.pl that renders four-view
6     # images of objects that are not light sources.
7     #
8     # Written by Axel Jacobs <[email protected]>
9
10     use strict;
11     use warnings;
12
13     use File::Temp qw/ tempdir /;
14     my $td = tempdir( CLEANUP => 1 );
15
16 greg 2.2 my $res = 1024; # Default output image dimensions. Same as objpict.
17 greg 2.1 my $tiny = 0.01;
18 greg 2.2 my $maxsize = 0.001; # max luminaire size after scaling
19 greg 2.1 my $is_ies = 0;
20
21     my $ies = "$td/dist.ies";
22 greg 2.2 my $lumi = "$td/lumi.rad"; # Fitting given on cmd line, or generated by ies2rad
23     my $lumi2 = "$td/lumi2.rad"; # Fitting scaled to size
24 greg 2.1 my $mat = "$td/lt.mat";
25     my $room1 = "$td/room1.rad";
26     my $room2 = "$td/room2.rad";
27     my $room3 = "$td/room3.rad";
28     my $room4 = "$td/room4.rad";
29     my $oct1 = "$td/lt1.oct";
30     my $oct2 = "$td/lt2.oct";
31     my $oct3 = "$td/lt3.oct";
32     my $oct4 = "$td/lt4.oct";
33
34     # Parse command line arguments
35     while (@ARGV) {
36 greg 2.2 $_ = $ARGV[0];
37     if (m/-i/) { # File is an IES file, not a Radiance luminaire
38     $is_ies = 1;
39     } elsif (m/-d/) { # Resolution of the output HDR image
40     $res = $ARGV[1];
41     shift @ARGV;
42     } elsif (m/^-\w/) { # Oops! Illegal option
43 greg 2.1 die("ltpict: bad option '$_'\n");
44     } else {
45 greg 2.2 last; # No more options. What's left is the actual file name.
46     }
47 greg 2.1 shift @ARGV;
48     }
49
50 greg 2.2 # We need exactly one Radiance luminaires or IES file
51     if ( !$#ARGV == 0 ) {
52     die("ltpict: Need one Radiance luminaire or IES file.\n");
53     } elsif ( $is_ies == 0 ) {
54
55     # Input file is a Radiance luminaire
56     $lumi = $ARGV[0];
57 greg 2.1 } else {
58 greg 2.2
59     # Input file is IES photometry
60     system qq[ ies2rad -p $td -o lumi "$ARGV[0]" ];
61 greg 2.1 }
62
63     my $res2 = $res / 2; # Each rendering is half the size of final composite
64
65     # Scale luminaire and center at origin
66 greg 2.2 my $dimstr = `getbbox -h "$lumi"`;
67 greg 2.1 chomp $dimstr;
68 greg 2.2
69 greg 2.1 # Values returned by getbbox are indented and delimited with multiple spaces.
70 greg 2.2 $dimstr =~ s/^\s+//; # remove leading spaces
71     my @dims = split( /\s+/, $dimstr ); # convert to array
72 greg 2.1
73     # Find largest axes-aligned dimension
74 greg 2.2 my @diffs = ( $dims[1] - $dims[0], $dims[3] - $dims[2], $dims[5] - $dims[4] );
75 greg 2.1 @diffs = reverse sort { $a <=> $b } @diffs;
76     my $size = $diffs[0];
77
78     # Move luminaire so centre is at origin, and scale
79 greg 2.2 my $xtrans = -1.0 * ( $dims[0] + $dims[1] ) / 2;
80     my $ytrans = -1.0 * ( $dims[2] + $dims[3] ) / 2;
81     my $ztrans = -1.0 * ( $dims[4] + $dims[5] ) / 2;
82     my $scale = $maxsize / $size;
83     system qq[ xform -t $xtrans $ytrans $ztrans "$lumi" > $lumi2 ];
84 greg 2.1
85     # Material for the room
86 greg 2.2 open( FH, ">$mat" )
87     or die("ltpict: Cannot write to temporary file $mat");
88 greg 2.1 print FH "void plastic wall_mat 0 0 5 .5 .5 .5 0 0";
89     close FH;
90
91     # Different 'room' geometry for different views
92 greg 2.2 my $o = 0.1; # Offset
93 greg 2.1
94     # C0-C180
95 greg 2.2 open( FH, ">$room1" )
96     or die("ltpict: Cannot write to temporary file $room1");
97     print FH
98     "wall_mat polygon box.4620 0 0 12 -$o -5 5 -$o 5 5 -$o 5 -5 -$o -5 -5";
99 greg 2.1 close(FH);
100
101     # C90-C270
102 greg 2.2 open( FH, ">$room2" )
103     or die("ltpict: Cannot write to temporary file $room2");
104     print FH
105     "wall_mat polygon box.1540 0 0 12 5 $o -5 5 $o 5 -5 $o 5 -5 $o -5";
106 greg 2.1 close(FH);
107
108     # Lower hemisphere
109 greg 2.2 open( FH, ">$room3" )
110     or die("ltpict: Cannot write to temporary file $room3");
111 greg 2.1 print FH "wall_mat bubble lower 0 0 4 0 0 $dims[4] 5";
112     close(FH);
113
114     # Upper hemisphere
115 greg 2.2 open( FH, ">$room4" )
116     or die("ltpict: Cannot write to temporary file $room4");
117 greg 2.1 print FH "wall_mat bubble upper 0 0 4 0 0 $dims[5] 5";
118     close(FH);
119
120     # Call bbox again, for the translated and scaled luminaire.
121     $dimstr = `getbbox -h $lumi2`;
122     chomp $dimstr;
123 greg 2.2
124 greg 2.1 # Values returned by getbbox are indented and delimited with multiple spaces.
125 greg 2.2 $dimstr =~ s/^\s+//; # remove leading spaces
126     @dims = split( /\s+/, $dimstr ); # convert to array
127 greg 2.1
128     # Define the four views
129 greg 2.2 my $vw1 = "-vtl -vp 4.5 0 0 -vd -1 0 0 -vh 10 -vv 10";
130     my $vw2 = "-vtl -vp 0 -4.5 0 -vd 0 1 0 -vh 10 -vv 10";
131 greg 2.1 my $zcent3 = $dims[4] - $tiny;
132 greg 2.2 my $vw3 = "-vta -vp 0 0 $zcent3 -vd 0 0 -1 -vu 0 1 0 -vh 180 -vv 180";
133 greg 2.1 my $zcent4 = $dims[5] + $tiny;
134 greg 2.2 my $vw4 = "-vta -vp 0 0 $zcent4 -vd 0 0 1 -vu 0 1 0 -vh 180 -vv 180";
135 greg 2.1
136 greg 2.2 # Compile octrees
137 greg 2.1 system "oconv $mat $room1 $lumi2 > $oct1";
138     system "oconv $mat $room2 $lumi2 > $oct2";
139     system "oconv $mat $room3 $lumi2 > $oct3";
140     system "oconv $mat $room4 $lumi2 > $oct4";
141
142     # Render four different views of the objects
143     my $rpict_cmd = "rpict -ab 0 -ds 0 -dv -av 0 0 0 -x $res2 -y $res2";
144     system "$rpict_cmd $vw1 $oct1 > $td/right.hdr";
145     system "$rpict_cmd $vw2 $oct2 > $td/front.hdr";
146     system "$rpict_cmd $vw3 $oct3 > $td/down.hdr";
147     system "$rpict_cmd $vw4 $oct4 > $td/up.hdr";
148
149     # Compose the four views into one image
150 greg 2.2 my $vtl = "$td/vtl.hdr"; # The two parallel views
151     my $vta = "$td/vta.hdr"; # The two fisheye views
152 greg 2.1
153     # Auto-expose right/front and down/up pairs separately
154     my $pcond_cmd = "pcond -l";
155     system "pcompos -a 2 $td/right.hdr $td/front.hdr > $td/rf.hdr";
156     system "$pcond_cmd $td/rf.hdr > $vtl";
157     system "pcompos -a 2 $td/down.hdr $td/up.hdr > $td/du.hdr";
158     system "$pcond_cmd $td/du.hdr > $vta";
159
160     # Combine top two images with bottom row. Output HDR.
161     exec "pcompos -a 1 $vtl $vta";
162
163     #EOF
