root/Development/ray/src/util/ltpict.pl
Revision: 2.2
Committed: Wed Apr 16 20:32:00 2014 UTC (11 years, 4 months ago) by greg
CVS Tags: rad5R4, rad5R2, rad5R3, rad5R0, rad5R1, rad4R2, rad6R0, rad4R2P1, rad4R2P2, HEAD
Changes since 2.1: +58 -55 lines
Error occurred while calculating annotation data.
Axel updates to ltview and ltpict
1 #!/usr/bin/perl
2
3 # Make a four-view picture of the photometry of a luminaire
4 #
5 # This is inspired by objpict.pl that renders four-view
6 # images of objects that are not light sources.
7 #
8 # Written by Axel Jacobs <[email protected]>
9
10 use strict;
11 use warnings;
12
13 use File::Temp qw/ tempdir /;
14 my $td = tempdir( CLEANUP => 1 );
15
16 my $res = 1024; # Default output image dimensions. Same as objpict.
17 my $tiny = 0.01;
18 my $maxsize = 0.001; # max luminaire size after scaling
19 my $is_ies = 0;
20
21 my $ies = "$td/dist.ies";
22 my $lumi = "$td/lumi.rad"; # Fitting given on cmd line, or generated by ies2rad
23 my $lumi2 = "$td/lumi2.rad"; # Fitting scaled to size
24 my $mat = "$td/lt.mat";
25 my $room1 = "$td/room1.rad";
26 my $room2 = "$td/room2.rad";
27 my $room3 = "$td/room3.rad";
28 my $room4 = "$td/room4.rad";
29 my $oct1 = "$td/lt1.oct";
30 my $oct2 = "$td/lt2.oct";
31 my $oct3 = "$td/lt3.oct";
32 my $oct4 = "$td/lt4.oct";
33
34 # Parse command line arguments
35 while (@ARGV) {
36 $_ = $ARGV[0];
37 if (m/-i/) { # File is an IES file, not a Radiance luminaire
38 $is_ies = 1;
39 } elsif (m/-d/) { # Resolution of the output HDR image
40 $res = $ARGV[1];
41 shift @ARGV;
42 } elsif (m/^-\w/) { # Oops! Illegal option
43 die("ltpict: bad option '$_'\n");
44 } else {
45 last; # No more options. What's left is the actual file name.
46 }
47 shift @ARGV;
48 }
49
50 # We need exactly one Radiance luminaires or IES file
51 if ( !$#ARGV == 0 ) {
52 die("ltpict: Need one Radiance luminaire or IES file.\n");
53 } elsif ( $is_ies == 0 ) {
54
55 # Input file is a Radiance luminaire
56 $lumi = $ARGV[0];
57 } else {
58
59 # Input file is IES photometry
60 system qq[ ies2rad -p $td -o lumi "$ARGV[0]" ];
61 }
62
63 my $res2 = $res / 2; # Each rendering is half the size of final composite
64
65 # Scale luminaire and center at origin
66 my $dimstr = `getbbox -h "$lumi"`;
67 chomp $dimstr;
68
69 # Values returned by getbbox are indented and delimited with multiple spaces.
70 $dimstr =~ s/^\s+//; # remove leading spaces
71 my @dims = split( /\s+/, $dimstr ); # convert to array
72
73 # Find largest axes-aligned dimension
74 my @diffs = ( $dims[1] - $dims[0], $dims[3] - $dims[2], $dims[5] - $dims[4] );
75 @diffs = reverse sort { $a <=> $b } @diffs;
76 my $size = $diffs[0];
77
78 # Move luminaire so centre is at origin, and scale
79 my $xtrans = -1.0 * ( $dims[0] + $dims[1] ) / 2;
80 my $ytrans = -1.0 * ( $dims[2] + $dims[3] ) / 2;
81 my $ztrans = -1.0 * ( $dims[4] + $dims[5] ) / 2;
82 my $scale = $maxsize / $size;
83 system qq[ xform -t $xtrans $ytrans $ztrans "$lumi" > $lumi2 ];
84
85 # Material for the room
86 open( FH, ">$mat" )
87 or die("ltpict: Cannot write to temporary file $mat");
88 print FH "void plastic wall_mat 0 0 5 .5 .5 .5 0 0";
89 close FH;
90
91 # Different 'room' geometry for different views
92 my $o = 0.1; # Offset
93
94 # C0-C180
95 open( FH, ">$room1" )
96 or die("ltpict: Cannot write to temporary file $room1");
97 print FH
98 "wall_mat polygon box.4620 0 0 12 -$o -5 5 -$o 5 5 -$o 5 -5 -$o -5 -5";
99 close(FH);
100
101 # C90-C270
102 open( FH, ">$room2" )
103 or die("ltpict: Cannot write to temporary file $room2");
104 print FH
105 "wall_mat polygon box.1540 0 0 12 5 $o -5 5 $o 5 -5 $o 5 -5 $o -5";
106 close(FH);
107
108 # Lower hemisphere
109 open( FH, ">$room3" )
110 or die("ltpict: Cannot write to temporary file $room3");
111 print FH "wall_mat bubble lower 0 0 4 0 0 $dims[4] 5";
112 close(FH);
113
114 # Upper hemisphere
115 open( FH, ">$room4" )
116 or die("ltpict: Cannot write to temporary file $room4");
117 print FH "wall_mat bubble upper 0 0 4 0 0 $dims[5] 5";
118 close(FH);
119
120 # Call bbox again, for the translated and scaled luminaire.
121 $dimstr = `getbbox -h $lumi2`;
122 chomp $dimstr;
123
124 # Values returned by getbbox are indented and delimited with multiple spaces.
125 $dimstr =~ s/^\s+//; # remove leading spaces
126 @dims = split( /\s+/, $dimstr ); # convert to array
127
128 # Define the four views
129 my $vw1 = "-vtl -vp 4.5 0 0 -vd -1 0 0 -vh 10 -vv 10";
130 my $vw2 = "-vtl -vp 0 -4.5 0 -vd 0 1 0 -vh 10 -vv 10";
131 my $zcent3 = $dims[4] - $tiny;
132 my $vw3 = "-vta -vp 0 0 $zcent3 -vd 0 0 -1 -vu 0 1 0 -vh 180 -vv 180";
133 my $zcent4 = $dims[5] + $tiny;
134 my $vw4 = "-vta -vp 0 0 $zcent4 -vd 0 0 1 -vu 0 1 0 -vh 180 -vv 180";
135
136 # Compile octrees
137 system "oconv $mat $room1 $lumi2 > $oct1";
138 system "oconv $mat $room2 $lumi2 > $oct2";
139 system "oconv $mat $room3 $lumi2 > $oct3";
140 system "oconv $mat $room4 $lumi2 > $oct4";
141
142 # Render four different views of the objects
143 my $rpict_cmd = "rpict -ab 0 -ds 0 -dv -av 0 0 0 -x $res2 -y $res2";
144 system "$rpict_cmd $vw1 $oct1 > $td/right.hdr";
145 system "$rpict_cmd $vw2 $oct2 > $td/front.hdr";
146 system "$rpict_cmd $vw3 $oct3 > $td/down.hdr";
147 system "$rpict_cmd $vw4 $oct4 > $td/up.hdr";
148
149 # Compose the four views into one image
150 my $vtl = "$td/vtl.hdr"; # The two parallel views
151 my $vta = "$td/vta.hdr"; # The two fisheye views
152
153 # Auto-expose right/front and down/up pairs separately
154 my $pcond_cmd = "pcond -l";
155 system "pcompos -a 2 $td/right.hdr $td/front.hdr > $td/rf.hdr";
156 system "$pcond_cmd $td/rf.hdr > $vtl";
157 system "pcompos -a 2 $td/down.hdr $td/up.hdr > $td/du.hdr";
158 system "$pcond_cmd $td/du.hdr > $vta";
159
160 # Combine top two images with bottom row. Output HDR.
161 exec "pcompos -a 1 $vtl $vta";
162
163 #EOF
