root/Development/ray/src/util/help.hlp
Revision: 2.1
Committed: Thu Oct 27 15:56:03 1994 UTC (31 years ago) by greg
1 $Id$
2
3 This help file is for the gethelp.tcl utility itself, and explains
4 the various buttons and windows it uses.
5
6 All help files have the same general format. Each help section is
7 named by its category and topic, and its position in the file is
8 indicated with a line beginning with ".Category.Topic", where
9 "Category" and "Topic" are replaced by the appropriate names.
10 These names must begin with letters and may contain letters and/or
11 numbers, but no special characters. They will appear on the menus
12 of the help utility when that file is open.
13
14 The file is unformatted, and will be filled by the help utility
15 dynamically based on the current window size. The formatting code
16 is very simple, placing a single space between adjacent lines,
17 except when a line ends a sentence, when two spaces are used.
18 Regular expression searches will not cross newline boundaries in the
19 original file, so some care should be used not to break lines at
20 likely search strings. (This is a pain, I know.)
21
22 The first section of the file, which you are now reading, is
23 generally reserved for comments such as this, and is not accessed
24 directly by the user.
25
26 .Help.Intro
27
28 While holding down the control key,
29 press and release the left mouse button on any object of curiosity,
30 and if there is something to say about it, that
31 something will appear in this window.
32
33 Typically, a program will access multiple help files
34 through this help interface.
35 The particular file being viewed is indicated by the text at the
36 top right of this window.
37 It is not possible through this interface to switch from one help
38 file to another, as the particular file being viewed is controlled by
39 the calling program.
40
41 The help window itself offers the ability to search through the
42 available topics in the selected file via the "Category" and "Topic" menus.
43 Each general category consists of an introduction (such as this
44 one), followed by zero or more topics.
45 Selecting a new topic starts automatically at the introduction page.
46 From there, various topics within that category may be selected
47 using the "Topic" menu.
48
49 .Help.Category
50
51 Help information is divided logically into categories, then
52 into topics within each category.
53 Changing categories via the "Category" menu immediately selects the
54 default topic for the new category, which is always called "intro."
55
56 Other topics for the new category will be listed by the (new) topic
57 menu for that category.
58 Some categories may have only an intro topic.
59
60 The current category and topic are given as the title in the
61 displayed help window.
62
63 .Help.Topic
64
65 The topic menu allows you to select which subtopic in this category
66 you wish to display.
67
68 The next logical topic is available via the "Next" button,
69 unless the end of the help file has been reached.
70
71 The current category and topic are given as the title in the
72 displayed help window.
73
74 .Navigate.Intro
75
76 Besides accessing the category and topic menus, you can navigate
77 forward and backward in the history list for the current help file,
78 go directly to the next help topic, and search for regular
79 expressions.
80
81 The history list is filled in one of two ways.
82 The first way is by running a search which results in multiple topic
83 matches, in which case the additional matches are put in the future
84 history of this file.
85
86 The second way is by selecting additional topics, either explicitly
87 via the "Category" and "Topic" menus, or implicitly by getting more
88 help from the calling application without quitting the help window
89 in between.
90
91 .Navigate.Search
92
93 To search for a particular pattern, type a regular expression
94 in the text entry field.
95 Hitting <return> causes all matches in the current topic to be
96 highlighted.
97 Hitting the "Grep" button causes all categories and topics to be
98 searched.
99 The first matching topic is displayed, and other matching topics (if
100 any) may be accessed with the "Forward" button.
101
102 Each time a new topic is selected, matching words will be highlighted
103 in bold, whether or not <return> or the "Grep" button has been pressed.
104 To prevent new matches from being highlighted, clear the search entry
105 with <control-U>.
106
107 Matches are insensitive to case and word boundaries.
108
109 .Navigate.Forward
110
111 The "Forward" button moves from the current topic to the next one in
112 the history list, if any.
113 In most cases, the "Forward" button will not be activated unless
114 a search has been conducted with the "Grep" button or
115 the "Back" button has been pressed one or more times.
116
117 .Navigate.Back
118
119 Use the "Back" button to go to previously accessed topics in the
120 history list.
121
122 If this button is disabled, it simply means that you are already at
123 the beginning of the help file history.
124
125 .Navigate.Next
126
127 The "Next" button moves to the next sequential topic in the help file,
128 which is named at the bottom of the current text.
129
130 If this button is disabled, it means that the end of the help file
131 has been reached.
132
133 .Helpwin.Intro
134
135 The help window displays the contents of the current help category and
136 topic.
137 The category and topic are given in bold at the top of the text in
138 the window.
139 The next category and topic are given at the end of the text in the
140 window.
141
142 Scrolling is accomplished with the scrollbar on the right.
143
144 .Helpwin.Scroll
145
146 Grab the bar with the mouse and drag it up and down to scroll
147 the text in the help window.
148 Click below or above the bar to jump a page forward or backward,
149 respectively.
150 Click on the little triangle at the bottom or top to move down or up
151 a line at a time.
152
153 .Help.Done
154
155 The "Done" button simply dismisses the help window.
156 (It is sometimes better to iconify the window, if frequent help is
157 needed.)
