root/radiance/ray/src/util/glrad.c
Fri Feb 28 05:18:49 2020 UTC (4 years, 1 month ago) by greg
Changes since 3.26: +4 -4 lines
Diff to previous 3.26 , to selected 3.22
Thu Apr 28 16:28:20 2016 UTC (7 years, 11 months ago) by greg
CVS Tags: rad5R1, rad5R2
Changes since 3.25: +17 -3 lines
Diff to previous 3.25 , to selected 3.22
Added listening for mouse wheel
Mon Apr 25 20:06:22 2016 UTC (8 years ago) by greg
Changes since 3.24: +3 -3 lines
Diff to previous 3.24 , to selected 3.22
Tweaked speed parameters to slow things down a bit
Mon Apr 25 02:04:22 2016 UTC (8 years ago) by greg
Changes since 3.23: +21 -21 lines
Diff to previous 3.23 , to selected 3.22
Punting because window size negotiation doesn't work as before
Mon Mar 21 19:06:08 2016 UTC (8 years, 1 month ago) by greg
Changes since 3.22: +3 -3 lines
Diff to previous 3.22
Revision 3.22 - (view) (download) (annotate) - [selected]
Thu Sep 6 00:07:43 2012 UTC (11 years, 7 months ago) by greg
Changes since 3.21: +4 -5 lines
Diff to previous 3.21
Sun Sep 26 15:47:33 2010 UTC (13 years, 7 months ago) by greg
Diff to previous 3.20 , to selected 3.22
Increased delays for slight improvement in interactive behavior
Sun Jul 24 19:53:08 2005 UTC (18 years, 9 months ago) by greg
Changes since 3.19: +3 -3 lines
Diff to previous 3.19 , to selected 3.22
Changes since 3.18: +4 -3 lines
Diff to previous 3.18 , to selected 3.22
Continued ANSIfication.
Fri Jan 2 12:51:54 2004 UTC (20 years, 3 months ago) by schorsch
Changes since 3.17: +136 -73 lines
Diff to previous 3.17 , to selected 3.22
Ansification.
Changes since 3.16: +10 -10 lines
Diff to previous 3.16 , to selected 3.22
Changes since 3.15: +3 -2 lines
Diff to previous 3.15 , to selected 3.22
Changes since 3.14: +12 -8 lines
Diff to previous 3.14 , to selected 3.22
Mon May 19 16:32:19 2003 UTC (20 years, 11 months ago) by greg
Changes since 3.13: +1 -6 lines
Diff to previous 3.13 , to selected 3.22
Eliminated unnecessary and problematic external function declarations
Changes since 3.12: +17 -6 lines
Diff to previous 3.12 , to selected 3.22
Fri Jan 29 15:28:36 1999 UTC (25 years, 3 months ago) by gwlarson
Diff to previous 3.11 , to selected 3.22
return number of lists allocated for proper deallocation
Wed Oct 21 17:48:51 1998 UTC (25 years, 6 months ago) by gwlarson
Changes since 3.10: +3 -3 lines
Diff to previous 3.10 , to selected 3.22
modifications to avoid problems with redeclared BYTE type
Thu Oct 15 08:30:48 1998 UTC (25 years, 6 months ago) by gwlarson
Diff to previous 3.9 , to selected 3.22
fixed minor bug that made back face culling fail for -bv option
Wed Jul 15 17:51:13 1998 UTC (25 years, 9 months ago) by gwlarson
Changes since 3.8: +3 -4 lines
Diff to previous 3.8 , to selected 3.22
minor cosmetic changes
Wed Jul 8 18:00:39 1998 UTC (25 years, 9 months ago) by gwlarson
Changes since 3.7: +2 -1 lines
Diff to previous 3.7 , to selected 3.22
fixed usage message
Tue Jul 7 08:58:34 1998 UTC (25 years, 9 months ago) by gwlarson
Changes since 3.6: +1 -1 lines
Diff to previous 3.6 , to selected 3.22
minor bug fix in GL call
Fri Jun 19 11:29:50 1998 UTC (25 years, 10 months ago) by gwlarson
Changes since 3.5: +0 -2 lines
Diff to previous 3.5 , to selected 3.22
got rid of problematic test in gotoview() which failed for single views
Thu Jun 18 17:18:27 1998 UTC (25 years, 10 months ago) by gwlarson
Changes since 3.4: +7 -13 lines
Diff to previous 3.4 , to selected 3.22
fixed rendering lockup problem
Wed Jun 10 17:52:18 1998 UTC (25 years, 10 months ago) by gwlarson
Changes since 3.3: +77 -7 lines
Diff to previous 3.3 , to selected 3.22
added stereo viewing with -S option
added -s option for silent running
added check of render options for -bv-
Tue Jun 9 15:16:55 1998 UTC (25 years, 10 months ago) by gwlarson
Changes since 3.2: +23 -7 lines
Diff to previous 3.2 , to selected 3.22
more viewing fixes -- changed -v option to allow views\
Tue Jun 9 12:46:45 1998 UTC (25 years, 10 months ago) by gwlarson
Changes since 3.1: +13 -5 lines
Diff to previous 3.1 , to selected 3.22
minor viewing fixes
Tue Jun 9 11:43:18 1998 UTC (25 years, 10 months ago) by gwlarson
Diff to selected 3.22
