root/radiance/ray/src/util/glrad.c
Revision: 3.6
Committed: Fri Jun 19 11:29:50 1998 UTC (25 years, 10 months ago) by gwlarson
Changes since 3.5: +0 -2 lines
got rid of problematic test in gotoview() which failed for single views
1 /* Copyright (c) 1998 Silicon Graphics, Inc. */
2
3 #ifndef lint
4 static char SCCSid[] = "$SunId$ SGI";
5 #endif
6
7 /*
8 * Program to display Radiance scene using OpenGL.
9 */
10
11 #include "radogl.h"
12 #include "view.h"
13 #include "paths.h"
14 #include <sys/types.h>
15 #include <GL/glx.h>
16 #ifndef NOSTEREO
17 #include <X11/extensions/SGIStereo.h>
18 #endif
19 #include <ctype.h>
20 #include "glradicon.h"
21
22 #ifndef MAXVIEW
23 #define MAXVIEW 63 /* maximum number of standard views */
24 #endif
25 #ifndef MAXSCENE
26 #define MAXSCENE 127 /* maximum number of scene files */
27 #endif
28
29 #define ZOOMPCT 9 /* percent to zoom at a time */
30
31 #define MOVPCT 7 /* percent distance to move /frame */
32 #define MOVDIR(b) ((b)==Button1 ? 1 : (b)==Button2 ? 0 : -1)
33 #define MOVDEG (-5) /* degrees to orbit CW/down /frame */
34 #define MOVORB(s) ((s)&ShiftMask ? 1 : (s)&ControlMask ? -1 : 0)
35
36 #define BORWIDTH 5 /* border width */
37
38 #define ourscreen DefaultScreen(ourdisplay)
39 #define ourroot RootWindow(ourdisplay,ourscreen)
40 #define ourmask (StructureNotifyMask|ExposureMask|KeyPressMask|\
41 ButtonPressMask|ButtonReleaseMask)
42
43 #define levptr(etype) ((etype *)&currentevent)
44
45 XEvent currentevent; /* current event */
46
47 int mapped = 0; /* window is mapped? */
48 unsigned long ourblack=0, ourwhite=~0;
49
50 Display *ourdisplay = NULL; /* our display */
51 XVisualInfo *ourvinf; /* our visual information */
52 Window gwind = 0; /* our graphics window */
53 int hres, vres; /* rendering window dimensions */
54 int maxhres, maxvres; /* maximum given dimensions */
55 GLXContext gctx; /* our GLX context */
56
57 double pwidth, pheight; /* pixel dimensions (mm) */
58
59 int headlocked = 0; /* lock vertical motion */
60
61 struct {
62 char *nam; /* view name (NULL if none) */
63 VIEW *v; /* parameters (NULL term.) */
64 } vwl[MAXVIEW+1]; /* our list of views */
65
66 int currentview = 0; /* current view number */
67 VIEW thisview = STDVIEW; /* displayed view */
68 double eyedist = 1; /* interocular distance */
69 VIEW lastview; /* last recorded view */
70
71 char *progname; /* global argv[0] */
72 char *radfile; /* rad input file */
73 char *scene[MAXSCENE+1]; /* material and scene file list */
74 int nscenef = 0; /* number of scene files */
75 char *octree; /* octree name (NULL if unnec.) */
76
77 int rtpd[3]; /* rtrace process descriptors */
78
79 int silent = 0; /* run rad silently? */
80 int backvis = 1; /* back faces visible? */
81 int stereo = 0; /* do stereo? */
82
83 #ifdef NOSTEREO
84 #define setstereobuf(bid) 0
85 #else
86 #define setstereobuf(bid) (glXWaitGL(), \
87 XSGISetStereoBuffer(ourdisplay, gwind, bid), \
88 glXWaitX())
89 #endif
90
91 int displist; /* our scene display list */
92
93 int no_render = 0; /* don't rerender */
94
95 #ifdef BSD
96 #define strchr index
97 #endif
98
99 extern char *strchr(), *fgets(), *fgetline(), *atos(), *scan4var();
100 extern int nowarn; /* turn warnings off? */
101 extern time_t time();
102
103
104 main(argc, argv)
105 int argc;
106 char *argv[];
107 {
108 char *viewsel = NULL;
109 long vwintvl = 0;
110 int i;
111
112 progname = argv[0];
113 for (i = 1; i < argc && argv[i][0] == '-'; i++)
114 switch (argv[i][1]) {
115 case 'v':
116 viewsel = argv[++i];
117 break;
118 case 'w':
119 nowarn = !nowarn;
120 break;
121 case 's':
122 silent = !silent;
123 break;
124 case 'S':
125 stereo = !stereo;
126 break;
127 case 'c':
128 vwintvl = atoi(argv[++i]);
129 break;
130 case 'b':
131 backvis = !backvis;
132 break;
133 default:
134 goto userr;
135 }
136 if (i >= argc)
137 goto userr;
138 #ifdef NOSTEREO
139 if (stereo)
140 error(INTERNAL, "stereo not supported in this version");
141 #endif
142 /* run rad and get views */
143 runrad(argc-i, argv+i);
144 /* check view */
145 if (viewsel != NULL)
146 if (viewsel[0] == '-') {
147 char *ve = viewsel;
148 if (!sscanview(&thisview, viewsel) ||
149 (ve = setview(&thisview)) != NULL) {
150 fprintf(stderr, "%s: bad view: %s\n",
151 progname, ve);
152 quit(1);
153 }
154 currentview = -1;
155 } else if ((currentview = findvw(viewsel)) < 0) {
156 fprintf(stderr, "%s: no such view: %s\n",
157 progname, viewsel);
158 quit(1);
159 }
160 /* open GL */
161 dev_open(radfile = argv[i]);
162 /* load octree or scene files */
163 if (octree != NULL) {
164 displist = rgl_octlist(octree, NULL, NULL);
165 startrtrace(octree);
166 } else
167 displist = rgl_filelist(nscenef, scene);
168 /* set initial view */
169 dev_view(currentview < 0 ? &thisview : vwl[currentview].v);
170 /* input/render loop */
171 while (dev_input(vwintvl))
172 ;
173 /* all done */
174 quit(0);
175 userr:
176 fprintf(stderr, "Usage: %s [-w][-b][-v view] rfile [VAR=value]..\n",
177 argv[0]);
178 quit(1);
179 }
180
181
182 quit(code) /* exit gracefully */
183 int code;
184 {
185 if (ourdisplay != NULL)
186 dev_close();
187 if (rtpd[2] > 0) {
188 if (close_process(rtpd) > 0)
189 wputs("bad exit status from rtrace\n");
190 rtpd[2] = 0;
191 }
192 exit(code);
193 }
194
195
196 startrtrace(octname) /* start rtrace on octname */
197 char *octname;
198 {
199 static char *av[12] = {"rtrace", "-h", "-fff", "-ld+",
200 "-opL", "-x", "1"};
201 int ac = 7;
202
203 if (nowarn) av[ac++] = "-w-";
204 av[ac++] = octname;
205 av[ac] = NULL;
206 if (open_process(rtpd, av) <= 0)
207 error(SYSTEM, "cannot start rtrace process");
208 }
209
210
211 runrad(ac, av) /* run rad and load variables */
212 int ac;
213 char **av;
214 {
215 static char optfile[] = TEMPLATE;
216 int nvn = 0, nvv = 0;
217 FILE *fp;
218 int cval;
219 register char *cp;
220 char radcomm[256], buf[128], nam[32];
221 /* set rad commmand */
222 strcpy(radcomm, "rad -w -v 0 "); /* look out below! */
223 cp = radcomm + 19;
224 if (silent) {
225 strcpy(cp, "-s ");
226 cp += 3;
227 }
228 while (ac--) {
229 strcpy(cp, *av++);
230 while (*cp) cp++;
231 *cp++ = ' ';
232 }
233 strcpy(cp, "OPTFILE="); /* create temporary options file */
234 strcpy(cp+8, mktemp(optfile));
235 if (system(radcomm)) /* update octree */
236 error(USER, "error executing rad command");
237 /* replace "-v 0" with "-n -e -s -V" */
238 strcpy(radcomm+7, "-n -e -s -V");
239 radcomm[18] = ' ';
240 if ((fp = popen(radcomm, "r")) == NULL)
241 error(SYSTEM, "cannot start rad command");
242 buf[0] = '\0'; /* read variables alphabetically */
243 /* get exposure */
244 if ((cp = scan4var(buf, sizeof(buf), "EXPOSURE", fp)) != NULL) {
245 expval = atof(cp);
246 if (*cp == '-' | *cp == '+')
247 expval = pow(2., expval);
248 expval *= 0.5; /* compensate for local shading */
249 }
250 /* look for eye separation */
251 if ((cp = scan4var(buf, sizeof(buf), "EYESEP", fp)) != NULL)
252 eyedist = atof(cp);
253 /* look for materials */
254 while ((cp = scan4var(buf, sizeof(buf), "materials", fp)) != NULL) {
255 nscenef += wordstring(scene+nscenef, cp);
256 buf[0] = '\0';
257 }
258 /* look for octree */
259 if ((cp = scan4var(buf, sizeof(buf), "OCTREE", fp)) != NULL)
260 octree = savqstr(cp);
261 /* look for scene files */
262 while ((cp = scan4var(buf, sizeof(buf), "scene", fp)) != NULL) {
263 nscenef += wordstring(scene+nscenef, cp);
264 buf[0] = '\0';
265 }
266 /* load view names */
267 while ((cp = scan4var(buf, sizeof(buf), "view", fp)) != NULL) {
268 if (nvn >= MAXVIEW)
269 error(INTERNAL, "too many views in rad file");
270 vwl[nvn++].nam = *cp == '-' ? (char *)NULL :
271 savqstr(atos(nam, sizeof(nam), cp));
272 buf[0] = '\0';
273 }
274 /* load actual views */
275 do
276 if (isview(buf)) {
277 vwl[nvv].v = (VIEW *)bmalloc(sizeof(VIEW));
278 copystruct(vwl[nvv].v, &stdview);
279 sscanview(vwl[nvv].v, buf);
280 if ((cp = setview(vwl[nvv++].v)) != NULL) {
281 fprintf(stderr, "%s: bad view %d - %s\n",
282 progname, nvv, cp);
283 quit(1);
284 }
285 }
286 while (fgets(buf, sizeof(buf), fp) != NULL);
287 if (nvv != nvn)
288 error(INTERNAL, "view miscount in runrad");
289 pclose(fp);
290 /* open options file */
291 if ((fp = fopen(optfile, "r")) == NULL)
292 error(SYSTEM, "cannot open options file");
293 /* get relevant options */
294 while (fgets(buf, sizeof(buf), fp) != NULL)
295 if (!strncmp(buf, "-av ", 4))
296 setcolor(ambval, atof(buf+4),
297 atof(sskip2(buf+4,1)),
298 atof(sskip2(buf+4,2)));
299 else if (backvis && !strncmp(buf, "-bv", 3) &&
300 (!buf[3] || strchr(" 0-FfNn", buf[3]) != NULL))
301 backvis = 0;
302 fclose(fp);
303 unlink(optfile); /* delete options file */
304 }
305
306
307 int
308 findvw(nm) /* find named view */
309 register char *nm;
310 {
311 register int n;
312
313 if (*nm >= '1' & *nm <= '9' &&
314 (n = atoi(nm)-1) <= MAXVIEW && vwl[n].v != NULL)
315 return(n);
316 for (n = 0; vwl[n].v != NULL; n++)
317 if (vwl[n].nam != NULL && !strcmp(nm, vwl[n].nam))
318 return(n);
319 return(-1);
320 }
321
322
323 int
324 varmatch(s, vn) /* match line to variable */
325 register char *s, *vn;
326 {
327 register int c;
328
329 for ( ; *vn && *s == *vn; s++, vn++)
330 ;
331 while (isspace(*s))
332 s++;
333 if (*s == '=')
334 return(*vn);
335 while (!(c = toupper(*s++) - toupper(*vn)) && *vn++)
336 ;
337 return(c);
338 }
339
340
341 char *
342 scan4var(buf, buflen, vname, fp) /* scan for variable from fp */
343 char *buf;
344 int buflen;
345 char *vname;
346 FILE *fp;
347 {
348 int cval;
349 register char *cp;
350 /* search out matching line */
351 while ((cval = varmatch(buf, vname))) {
352 if (cval > 0) /* gone too far? */
353 return(NULL);
354 buf[0] = '\0'; /* else get next line */
355 if (fgetline(buf, buflen, fp) == NULL)
356 return(NULL);
357 }
358 /* skip variable name and '=' */
359 for (cp = buf; *cp++ != '='; )
360 ;
361 while (isspace(*cp)) cp++;
362 return(cp);
363 }
364
365
366 dev_open(id) /* initialize GLX driver */
367 char *id;
368 {
369 static int atlBest[] = {GLX_RGBA, GLX_RED_SIZE,4,
370 GLX_GREEN_SIZE,4, GLX_BLUE_SIZE,4,
371 GLX_DOUBLEBUFFER, GLX_DEPTH_SIZE,15, None};
372 XSetWindowAttributes ourwinattr;
373 XWMHints ourxwmhints;
374 /* open display server */
375 ourdisplay = XOpenDisplay(NULL);
376 if (ourdisplay == NULL)
377 error(USER, "cannot open X-windows; DISPLAY variable set?\n");
378 /* find a usable visual */
379 ourvinf = glXChooseVisual(ourdisplay, ourscreen, atlBest);
380 if (ourvinf == NULL)
381 error(USER, "no suitable visuals available");
382 /* get a context */
383 gctx = glXCreateContext(ourdisplay, ourvinf, NULL, GL_TRUE);
384 /* open window */
385 ourwinattr.background_pixel = ourblack;
386 ourwinattr.border_pixel = ourblack;
387 ourwinattr.event_mask = ourmask;
388 /* this is stupid */
389 ourwinattr.colormap = XCreateColormap(ourdisplay, ourroot,
390 ourvinf->visual, AllocNone);
391 gwind = XCreateWindow(ourdisplay, ourroot, 0, 0,
392 DisplayWidth(ourdisplay,ourscreen)-2*BORWIDTH,
393 DisplayHeight(ourdisplay,ourscreen)-2*BORWIDTH,
394 BORWIDTH, ourvinf->depth, InputOutput, ourvinf->visual,
395 CWBackPixel|CWBorderPixel|CWColormap|CWEventMask, &ourwinattr);
396 if (gwind == 0)
397 error(SYSTEM, "cannot create window\n");
398 XStoreName(ourdisplay, gwind, id);
399 #ifndef NOSTEREO
400 if (stereo) /* check if stereo working */
401 switch (XSGIQueryStereoMode(ourdisplay, gwind)) {
402 case STEREO_TOP:
403 case STEREO_BOTTOM:
404 break;
405 case STEREO_OFF:
406 error(USER,
407 "wrong video mode: run \"/usr/gfx/setmon -n STR_TOP\" first");
408 case X_STEREO_UNSUPPORTED:
409 error(USER, "stereo not supported on this screen");
410 default:
411 error(INTERNAL, "unknown stereo mode");
412 }
413 #endif
414 /* set window manager hints */
415 ourxwmhints.flags = InputHint|IconPixmapHint;
416 ourxwmhints.input = True;
417 ourxwmhints.icon_pixmap = XCreateBitmapFromData(ourdisplay,
418 gwind, glradicon_bits, glradicon_width, glradicon_height);
419 XSetWMHints(ourdisplay, gwind, &ourxwmhints);
420 /* set GLX context */
421 glXMakeCurrent(ourdisplay, gwind, gctx);
422 glEnable(GL_DEPTH_TEST);
423 glDepthFunc(GL_LESS);
424 glShadeModel(GL_SMOOTH);
425 glPolygonMode(GL_FRONT_AND_BACK, GL_FILL);
426 glLightModelf(GL_LIGHT_MODEL_TWO_SIDE, GL_TRUE);
427 glEnable(GL_LIGHTING);
428 if (backvis)
429 glDisable(GL_CULL_FACE);
430 else {
431 glFrontFace(GL_CCW);
432 glCullFace(GL_BACK);
433 glEnable(GL_CULL_FACE);
434 }
435 glDrawBuffer(GL_BACK);
436 /* figure out sensible view */
437 pwidth = (double)DisplayWidthMM(ourdisplay, ourscreen) /
438 DisplayWidth(ourdisplay, ourscreen);
439 pheight = (double)DisplayHeightMM(ourdisplay, ourscreen) /
440 DisplayHeight(ourdisplay, ourscreen);
441 if (stereo) { /* set stereo mode */
442 setstereobuf(STEREO_BUFFER_LEFT);
443 pheight *= 2.;
444 }
445 /* map the window */
446 XMapWindow(ourdisplay, gwind);
447 no_render++;
448 do
449 dev_input(0); /* get resize event */
450 while (hres == 0 & vres == 0);
451 no_render--;
452 rgl_checkerr("initializing GLX");
453 }
454
455
456 dev_close() /* close our display and free resources */
457 {
458 glXMakeCurrent(ourdisplay, None, NULL);
459 glXDestroyContext(ourdisplay, gctx);
460 XDestroyWindow(ourdisplay, gwind);
461 gwind = 0;
462 XCloseDisplay(ourdisplay);
463 ourdisplay = NULL;
464 }
465
466
467 int
468 dev_view(nv) /* assign new driver view */
469 register VIEW *nv;
470 {
471 int newhres = hres, newvres = vres;
472 double wa, va;
473 /* check view legality */
474 if (nv->type != VT_PER) {
475 error(COMMAND, "illegal view type");
476 nv->type = VT_PER;
477 }
478 if (nv->horiz > 160. | nv->vert > 160.) {
479 error(COMMAND, "illegal view angle");
480 if (nv->horiz > 160.)
481 nv->horiz = 160.;
482 if (nv->vert > 160.)
483 nv->vert = 160.;
484 }
485 if (hres != 0 & vres != 0) {
486 wa = (vres*pheight)/(hres*pwidth);
487 va = viewaspect(nv);
488 if (va > wa+.05) {
489 newvres = (pwidth/pheight)*va*newhres + .5;
490 if (newvres > maxvres) {
491 newvres = maxvres;
492 newhres = (pheight/pwidth)/va*newvres + .5;
493 }
494 } else if (va < wa-.05) {
495 newhres = (pheight/pwidth)/va*newvres + .5;
496 if (newhres > maxhres) {
497 newhres = maxhres;
498 newvres = (pwidth/pheight)*va*newhres + .5;
499 }
500 }
501 if (newhres != hres | newvres != vres) {
502 no_render++;
503 XResizeWindow(ourdisplay, gwind, newhres, newvres);
504 do
505 dev_input(0); /* get resize event */
506 while (newhres != hres | newvres != vres);
507 no_render--;
508 }
509 }
510 copystruct(&thisview, nv);
511 setglpersp(&thisview);
512 render();
513 return(1);
514 }
515
516
517 int
518 dev_input(nsecs) /* get next input event */
519 int nsecs;
520 {
521 #if 0
522 static time_t lasttime = 0;
523 time_t thistime;
524
525 if (nsecs > 0) {
526 thistime = time(0);
527 nsecs -= (long)(thistime - lasttime);
528 lasttime = thistime;
529 }
530 if (nsecs > 0)
531 alarm(nsecs);
532 #endif
533 XNextEvent(ourdisplay, levptr(XEvent));
534 switch (levptr(XEvent)->type) {
535 case ConfigureNotify:
536 resizewindow(levptr(XConfigureEvent));
537 break;
538 case UnmapNotify:
539 mapped = 0;
540 break;
541 case MapNotify:
542 mapped = 1;
543 break;
544 case Expose:
545 fixwindow(levptr(XExposeEvent));
546 break;
547 case KeyPress:
548 return(getkey(levptr(XKeyPressedEvent)));
549 case ButtonPress:
550 getmove(levptr(XButtonPressedEvent));
551 break;
552 }
553 return(1);
554 }
555
556
557 render() /* render our display list and swap buffers */
558 {
559 double d;
560
561 if (!mapped | no_render)
562 return;
563 glClear(GL_COLOR_BUFFER_BIT|GL_DEPTH_BUFFER_BIT);
564 glCallList(displist);
565 if (stereo) { /* do right eye for stereo */
566 setstereobuf(STEREO_BUFFER_RIGHT);
567 glClear(GL_COLOR_BUFFER_BIT|GL_DEPTH_BUFFER_BIT);
568 glMatrixMode(GL_MODELVIEW);
569 glPushMatrix();
570 d = -eyedist / sqrt(thisview.hn2);
571 glTranslated(d*thisview.hvec[0], d*thisview.hvec[1],
572 d*thisview.hvec[2]);
573 glCallList(displist);
574 glMatrixMode(GL_MODELVIEW);
575 glPopMatrix();
576 setstereobuf(STEREO_BUFFER_LEFT);
577 }
578 glXSwapBuffers(ourdisplay, gwind); /* calls glFlush() */
579 rgl_checkerr("rendering display list");
580 }
581
582
583 moveview(dx, dy, mov, orb) /* move our view */
584 int dx, dy, mov, orb;
585 {
586 VIEW nv;
587 FVECT odir, v1, wp;
588 double d;
589 register int li;
590 /* start with old view */
591 copystruct(&nv, &thisview);
592 /* change view direction */
593 if ((d = viewray(v1, odir, &thisview,
594 (dx+.5)/hres, (dy+.5)/vres)) < -FTINY)
595 return(0); /* outside view */
596 if (mov | orb) {
597 if (!getintersect(wp, v1, odir, d))
598 return(0);
599 VSUM(odir, wp, nv.vp, -1.);
600 } else
601 VCOPY(nv.vdir, odir);
602 if (orb && mov) { /* orbit left/right */
603 spinvector(odir, odir, nv.vup, d=MOVDEG*PI/180.*mov);
604 VSUM(nv.vp, wp, odir, -1.);
605 spinvector(nv.vdir, nv.vdir, nv.vup, d);
606 } else if (orb) { /* orbit up/down */
607 fcross(v1, odir, nv.vup);
608 if (normalize(v1) == 0.)
609 return(0);
610 spinvector(odir, odir, v1, d=MOVDEG*PI/180.*orb);
611 VSUM(nv.vp, wp, odir, -1.);
612 spinvector(nv.vdir, nv.vdir, v1, d);
613 } else if (mov) { /* move forward/backward */
614 d = MOVPCT/100. * mov;
615 VSUM(nv.vp, nv.vp, odir, d);
616 }
617 if (!mov ^ !orb && headlocked) { /* restore head height */
618 VSUM(v1, thisview.vp, nv.vp, -1.);
619 d = DOT(v1, thisview.vup);
620 VSUM(nv.vp, nv.vp, thisview.vup, d);
621 }
622 if (setview(&nv) != NULL)
623 return(0); /* illegal view */
624 dev_view(&nv);
625 return(1);
626 }
627
628
629 getmove(ebut) /* get view change */
630 XButtonPressedEvent *ebut;
631 {
632 int movdir = MOVDIR(ebut->button);
633 int movorb = MOVORB(ebut->state);
634 int moved = 0;
635 Window rootw, childw;
636 int rootx, rooty, wx, wy;
637 unsigned int statemask;
638
639 copylastv( movorb ? (movdir ? "left/right" : "up/down") :
640 (movdir ? "fore/back" : "rotate") );
641 XNoOp(ourdisplay);
642
643 while (!XCheckMaskEvent(ourdisplay,
644 ButtonReleaseMask, levptr(XEvent))) {
645
646 if (!XQueryPointer(ourdisplay, gwind, &rootw, &childw,
647 &rootx, &rooty, &wx, &wy, &statemask))
648 break; /* on another screen */
649
650 if (!moveview(wx, vres-1-wy, movdir, movorb)) {
651 sleep(1);
652 continue;
653 } else
654 moved++;
655 }
656 if (!moved) { /* do final motion */
657 movdir = MOVDIR(levptr(XButtonReleasedEvent)->button);
658 wx = levptr(XButtonReleasedEvent)->x;
659 wy = levptr(XButtonReleasedEvent)->y;
660 moveview(wx, vres-1-wy, movdir, movorb);
661 }
662 }
663
664
665 getintersect(wp, org, dir, md) /* intersect ray with scene geometry */
666 FVECT wp; /* returned world intersection point */
667 FVECT org, dir;
668 double md;
669 {
670 float fbuf[6];
671 /* check to see if rtrace is running */
672 if (rtpd[2] <= 0)
673 return(0);
674 /* assign origin */
675 fbuf[0] = org[0]; fbuf[1] = org[1]; fbuf[2] = org[2];
676 /* compute clipping distance */
677 if (md <= FTINY) md = FHUGE;
678 fbuf[3] = dir[0]*md; fbuf[4] = dir[1]*md; fbuf[5] = dir[2]*md;
679 /* trace that ray */
680 if (process(rtpd, fbuf, fbuf, 4*sizeof(float), 6*sizeof(float)) !=
681 4*sizeof(float))
682 error(INTERNAL, "error getting data back from rtrace process");
683 if (fbuf[3] >= .99*FHUGE)
684 return(0); /* missed local objects */
685 wp[0] = fbuf[0]; wp[1] = fbuf[1]; wp[2] = fbuf[2];
686 return(1); /* else return world intersection */
687 }
688
689
690 setglpersp(vp) /* set perspective view in GL */
691 register VIEW *vp;
692 {
693 double d, xmin, xmax, ymin, ymax, zmin, zmax;
694
695 zmin = 0.1;
696 zmax = 1000.;
697 if (thisview.vfore > FTINY)
698 zmin = thisview.vfore;
699 if (thisview.vaft > FTINY)
700 zmax = thisview.vaft;
701 xmax = zmin * tan(PI/180./2. * thisview.horiz);
702 xmin = -xmax;
703 d = thisview.hoff * (xmax - xmin);
704 xmin += d; xmax += d;
705 ymax = zmin * tan(PI/180./2. * thisview.vert);
706 ymin = -ymax;
707 d = thisview.voff * (ymax - ymin);
708 ymin += d; ymax += d;
709 /* set view matrix */
710 glMatrixMode(GL_PROJECTION);
711 glLoadIdentity();
712 glFrustum(xmin, xmax, ymin, ymax, zmin, zmax);
713 gluLookAt(thisview.vp[0], thisview.vp[1], thisview.vp[2],
714 thisview.vp[0] + thisview.vdir[0],
715 thisview.vp[1] + thisview.vdir[1],
716 thisview.vp[2] + thisview.vdir[2],
717 thisview.vup[0], thisview.vup[1], thisview.vup[2]);
718 rgl_checkerr("setting perspective view");
719 }
720
721
722 int
723 getkey(ekey) /* get input key */
724 register XKeyPressedEvent *ekey;
725 {
726 int n;
727 char buf[8];
728
729 n = XLookupString(ekey, buf, sizeof(buf), NULL, NULL);
730 if (n != 1)
731 return(1);
732 switch (buf[0]) {
733 case 'h': /* turn on height motion lock */
734 headlocked = 1;
735 break;
736 case 'H': /* turn off height motion lock */
737 headlocked = 0;
738 break;
739 case 'l': /* retrieve last (premouse) view */
740 if (lastview.type) {
741 VIEW vtmp;
742 copystruct(&vtmp, &thisview);
743 dev_view(&lastview);
744 copystruct(&lastview, &vtmp);
745 } else
746 XBell(ourdisplay, 0);
747 break;
748 case 'n': /* move to next standard view */
749 gotoview(currentview+1);
750 break;
751 case 'p': /* move to last standard view */
752 gotoview(currentview-1);
753 break;
754 case '+': /* zoom in */
755 zoomview(100+ZOOMPCT, ekey->x, vres-1-ekey->y);
756 break;
757 case '-': /* zoom out */
758 zoomview(100-ZOOMPCT, ekey->x, vres-1-ekey->y);
759 break;
760 case 'v': /* spit current view to stdout */
761 fputs(VIEWSTR, stdout);
762 fprintview(&thisview, stdout);
763 fputc('\n', stdout);
764 break;
765 case 'V': /* append view to rad file */
766 appendview(NULL, &thisview);
767 break;
768 case 'q': /* quit the program */
769 return(0);
770 default:
771 XBell(ourdisplay, 0);
772 break;
773 }
774 return(1);
775 }
776
777
778 zoomview(pct, dx, dy) /* zoom in or out around (dx,dy) */
779 int pct;
780 int dx, dy;
781 {
782 double h, v;
783 FVECT direc;
784
785 if (pct == 100 | pct <= 0)
786 return;
787 copylastv("zooming");
788 h = (dx+.5)/hres - 0.5;
789 v = (dy+.5)/vres - 0.5;
790 h *= (1. - 100./pct);
791 v *= (1. - 100./pct);
792 thisview.vdir[0] += h*thisview.hvec[0] + v*thisview.vvec[0];
793 thisview.vdir[1] += h*thisview.hvec[1] + v*thisview.vvec[1];
794 thisview.vdir[2] += h*thisview.hvec[2] + v*thisview.vvec[2];
795 thisview.horiz = 2.*180./PI * atan( 100./pct *
796 tan(PI/180./2.*thisview.horiz) );
797 thisview.vert = 2.*180./PI * atan( 100./pct *
798 tan(PI/180./2.*thisview.vert) );
799 setview(&thisview);
800 dev_view(&thisview);
801 }
802
803
804 gotoview(vwnum) /* go to specified view number */
805 int vwnum;
806 {
807 if (vwnum < 0)
808 for (vwnum = currentview; vwl[vwnum+1].v != NULL; vwnum++)
809 ;
810 else if (vwnum >= MAXVIEW || vwl[vwnum].v == NULL)
811 vwnum = 0;
812 copylastv("standard view");
813 dev_view(vwl[currentview=vwnum].v);
814 }
815
816
817 appendview(nm, vp) /* append standard view */
818 char *nm;
819 VIEW *vp;
820 {
821 FILE *fp;
822 /* check if already in there */
823 if (!bcmp(&thisview, vwl[currentview].v, sizeof(VIEW))) {
824 error(COMMAND, "view already in standard list");
825 return;
826 }
827 /* append to file */
828 if ((fp = fopen(radfile, "a")) == NULL) {
829 error(COMMAND, "cannot append rad input file");
830 return;
831 }
832 fputs("view=", fp);
833 if (nm != NULL) {
834 fputc(' ', fp); fputs(nm, fp);
835 }
836 fprintview(vp, fp); fputc('\n', fp);
837 fclose(fp);
838 /* append to our list */
839 while (vwl[currentview].v != NULL)
840 currentview++;
841 if (currentview >= MAXVIEW)
842 error(INTERNAL, "too many views in appendview");
843 vwl[currentview].v = (VIEW *)bmalloc(sizeof(VIEW));
844 copystruct(vwl[currentview].v, &thisview);
845 if (nm != NULL)
846 vwl[currentview].nam = savqstr(nm);
847 }
848
849
850 copylastv(cause) /* copy last view position */
851 char *cause;
852 {
853 static char *lastvc;
854
855 if (cause == lastvc)
856 return; /* only record one view per cause */
857 lastvc = cause;
858 copystruct(&lastview, &thisview);
859 }
860
861
862 fixwindow(eexp) /* repair damage to window */
863 register XExposeEvent *eexp;
864 {
865 if (hres == 0 | vres == 0) { /* first exposure */
866 resizewindow((XConfigureEvent *)eexp);
867 return;
868 }
869 if (eexp->count) /* wait for final exposure */
870 return;
871 /* rerender everything */
872 render();
873 }
874
875
876 resizewindow(ersz) /* resize window */
877 register XConfigureEvent *ersz;
878 {
879 static char resizing[] = "resizing window";
880 double wa, va;
881
882 glViewport(0, 0, hres=ersz->width, vres=ersz->height);
883 if (hres > maxhres) maxhres = hres;
884 if (vres > maxvres) maxvres = vres;
885 if (no_render)
886 return;
887 wa = (vres*pheight)/(hres*pwidth);
888 va = viewaspect(&thisview);
889 if (va > wa+.05) {
890 copylastv(resizing);
891 thisview.vert = 2.*180./PI *
892 atan( tan(PI/180./2. * thisview.horiz) * wa );
893 } else if (va < wa-.05) {
894 copylastv(resizing);
895 thisview.horiz = 2.*180./PI *
896 atan( tan(PI/180./2. * thisview.vert) / wa );
897 } else
898 return;
899 setview(&thisview);
900 dev_view(&thisview);
901 }
