root/radiance/ray/src/util/glrad.c
Revision: 3.4
Committed: Wed Jun 10 17:52:18 1998 UTC (27 years ago) by gwlarson
Changes since 3.3: +77 -7 lines
added stereo viewing with -S option
added -s option for silent running
added check of render options for -bv-
1 /* Copyright (c) 1998 Silicon Graphics, Inc. */
2
3 #ifndef lint
4 static char SCCSid[] = "$SunId$ SGI";
5 #endif
6
7 /*
8 * Program to display Radiance scene using OpenGL.
9 */
10
11 #include "radogl.h"
12 #include "view.h"
13 #include "paths.h"
14 #include <sys/types.h>
15 #include <GL/glx.h>
16 #ifndef NOSTEREO
17 #include <X11/extensions/SGIStereo.h>
18 #endif
19 #include <ctype.h>
20 #include "glradicon.h"
21
22 #ifndef MAXVIEW
23 #define MAXVIEW 63 /* maximum number of standard views */
24 #endif
25 #ifndef MAXSCENE
26 #define MAXSCENE 127 /* maximum number of scene files */
27 #endif
28
29 #define ZOOMPCT 9 /* percent to zoom at a time */
30
31 #define MOVPCT 7 /* percent distance to move /frame */
32 #define MOVDIR(b) ((b)==Button1 ? 1 : (b)==Button2 ? 0 : -1)
33 #define MOVDEG (-5) /* degrees to orbit CW/down /frame */
34 #define MOVORB(s) ((s)&ShiftMask ? 1 : (s)&ControlMask ? -1 : 0)
35
36 #define MINWIDTH 480 /* minimum graphics window width */
37 #define MINHEIGHT 400 /* minimum graphics window height */
38
39 #define BORWIDTH 5 /* border width */
40
41 #define ourscreen DefaultScreen(ourdisplay)
42 #define ourroot RootWindow(ourdisplay,ourscreen)
43 #define ourmask (StructureNotifyMask|ExposureMask|KeyPressMask|\
44 ButtonPressMask|ButtonReleaseMask)
45
46 #define levptr(etype) ((etype *)&currentevent)
47
48 XEvent currentevent; /* current event */
49
50 int mapped = 0; /* window is mapped? */
51 unsigned long ourblack=0, ourwhite=~0;
52
53 Display *ourdisplay = NULL; /* our display */
54 XVisualInfo *ourvinf; /* our visual information */
55 Window gwind = 0; /* our graphics window */
56 int hres, vres; /* rendering window dimensions */
57 int maxhres, maxvres; /* maximum given dimensions */
58 GLXContext gctx; /* our GLX context */
59
60 double pwidth, pheight; /* pixel dimensions (mm) */
61
62 int headlocked = 0; /* lock vertical motion */
63
64 struct {
65 char *nam; /* view name (NULL if none) */
66 VIEW *v; /* parameters (NULL term.) */
67 } vwl[MAXVIEW+1]; /* our list of views */
68
69 int currentview = 0; /* current view number */
70 VIEW thisview = STDVIEW; /* displayed view */
71 double eyedist = 1; /* interocular distance */
72 VIEW lastview; /* last recorded view */
73
74 char *progname; /* global argv[0] */
75 char *radfile; /* rad input file */
76 char *scene[MAXSCENE+1]; /* material and scene file list */
77 int nscenef = 0; /* number of scene files */
78 char *octree; /* octree name (NULL if unnec.) */
79
80 int rtpd[3]; /* rtrace process descriptors */
81
82 int silent = 0; /* run rad silently? */
83 int backvis = 1; /* back faces visible? */
84 int stereo = 0; /* do stereo? */
85
86 #ifdef NOSTEREO
87 #define setstereobuf(bid) 0
88 #else
89 #define setstereobuf(bid) (glXWaitGL(), \
90 XSGISetStereoBuffer(ourdisplay, gwind, bid), \
91 glXWaitX())
92 #endif
93
94 int displist; /* our scene display list */
95
96 int in_dev_view = 0; /* currently in dev_view() */
97
98 #ifdef BSD
99 #define strchr index
100 #endif
101
102 extern char *strchr(), *fgets(), *fgetline(), *atos(), *scan4var();
103 extern int nowarn; /* turn warnings off? */
104 extern time_t time();
105
106
107 main(argc, argv)
108 int argc;
109 char *argv[];
110 {
111 char *viewsel = NULL;
112 long vwintvl = 0;
113 int i;
114
115 progname = argv[0];
116 for (i = 1; i < argc && argv[i][0] == '-'; i++)
117 switch (argv[i][1]) {
118 case 'v':
119 viewsel = argv[++i];
120 break;
121 case 'w':
122 nowarn = !nowarn;
123 break;
124 case 's':
125 silent = !silent;
126 break;
127 case 'S':
128 stereo = !stereo;
129 break;
130 case 'c':
131 vwintvl = atoi(argv[++i]);
132 break;
133 case 'b':
134 backvis = !backvis;
135 break;
136 default:
137 goto userr;
138 }
139 if (i >= argc)
140 goto userr;
141 #ifdef NOSTEREO
142 if (stereo)
143 error(INTERNAL, "stereo not supported in this version");
144 #endif
145 /* run rad and get views */
146 runrad(argc-i, argv+i);
147 /* check view */
148 if (viewsel != NULL)
149 if (viewsel[0] == '-') {
150 char *ve = viewsel;
151 if (!sscanview(&thisview, viewsel) ||
152 (ve = setview(&thisview)) != NULL) {
153 fprintf(stderr, "%s: bad view: %s\n",
154 progname, ve);
155 quit(1);
156 }
157 currentview = -1;
158 } else if ((currentview = findvw(viewsel)) < 0) {
159 fprintf(stderr, "%s: no such view: %s\n",
160 progname, viewsel);
161 quit(1);
162 }
163 /* open GL */
164 dev_open(radfile = argv[i]);
165 /* load octree or scene files */
166 if (octree != NULL) {
167 displist = rgl_octlist(octree, NULL, NULL);
168 startrtrace(octree);
169 } else
170 displist = rgl_filelist(nscenef, scene);
171 /* set initial view */
172 dev_view(currentview < 0 ? &thisview : vwl[currentview].v);
173 /* input/render loop */
174 while (dev_input(vwintvl))
175 ;
176 /* all done */
177 quit(0);
178 userr:
179 fprintf(stderr, "Usage: %s [-w][-b][-v view] rfile [VAR=value]..\n",
180 argv[0]);
181 quit(1);
182 }
183
184
185 quit(code) /* exit gracefully */
186 int code;
187 {
188 if (ourdisplay != NULL)
189 dev_close();
190 if (rtpd[2] > 0) {
191 if (close_process(rtpd) > 0)
192 wputs("bad exit status from rtrace\n");
193 rtpd[2] = 0;
194 }
195 exit(code);
196 }
197
198
199 startrtrace(octname) /* start rtrace on octname */
200 char *octname;
201 {
202 static char *av[12] = {"rtrace", "-h", "-fff", "-ld+",
203 "-opL", "-x", "1"};
204 int ac = 7;
205
206 if (nowarn) av[ac++] = "-w-";
207 av[ac++] = octname;
208 av[ac] = NULL;
209 if (open_process(rtpd, av) <= 0)
210 error(SYSTEM, "cannot start rtrace process");
211 }
212
213
214 runrad(ac, av) /* run rad and load variables */
215 int ac;
216 char **av;
217 {
218 static char optfile[] = TEMPLATE;
219 int nvn = 0, nvv = 0;
220 FILE *fp;
221 int cval;
222 register char *cp;
223 char radcomm[256], buf[128], nam[32];
224 /* set rad commmand */
225 strcpy(radcomm, "rad -w -v 0 "); /* look out below! */
226 cp = radcomm + 19;
227 if (silent) {
228 strcpy(cp, "-s ");
229 cp += 3;
230 }
231 while (ac--) {
232 strcpy(cp, *av++);
233 while (*cp) cp++;
234 *cp++ = ' ';
235 }
236 strcpy(cp, "OPTFILE="); /* create temporary options file */
237 strcpy(cp+8, mktemp(optfile));
238 if (system(radcomm)) /* update octree */
239 error(USER, "error executing rad command");
240 /* replace "-v 0" with "-n -e -s -V" */
241 strcpy(radcomm+7, "-n -e -s -V");
242 radcomm[18] = ' ';
243 if ((fp = popen(radcomm, "r")) == NULL)
244 error(SYSTEM, "cannot start rad command");
245 buf[0] = '\0'; /* read variables alphabetically */
246 /* get exposure */
247 if ((cp = scan4var(buf, sizeof(buf), "EXPOSURE", fp)) != NULL) {
248 expval = atof(cp);
249 if (*cp == '-' | *cp == '+')
250 expval = pow(2., expval);
251 expval *= 0.5; /* compensate for local shading */
252 }
253 /* look for eye separation */
254 if ((cp = scan4var(buf, sizeof(buf), "EYESEP", fp)) != NULL)
255 eyedist = atof(cp);
256 /* look for materials */
257 while ((cp = scan4var(buf, sizeof(buf), "materials", fp)) != NULL) {
258 nscenef += wordstring(scene+nscenef, cp);
259 buf[0] = '\0';
260 }
261 /* look for octree */
262 if ((cp = scan4var(buf, sizeof(buf), "OCTREE", fp)) != NULL)
263 octree = savqstr(cp);
264 /* look for scene files */
265 while ((cp = scan4var(buf, sizeof(buf), "scene", fp)) != NULL) {
266 nscenef += wordstring(scene+nscenef, cp);
267 buf[0] = '\0';
268 }
269 /* load view names */
270 while ((cp = scan4var(buf, sizeof(buf), "view", fp)) != NULL) {
271 if (nvn >= MAXVIEW)
272 error(INTERNAL, "too many views in rad file");
273 vwl[nvn++].nam = *cp == '-' ? (char *)NULL :
274 savqstr(atos(nam, sizeof(nam), cp));
275 buf[0] = '\0';
276 }
277 /* load actual views */
278 do
279 if (isview(buf)) {
280 vwl[nvv].v = (VIEW *)bmalloc(sizeof(VIEW));
281 copystruct(vwl[nvv].v, &stdview);
282 sscanview(vwl[nvv].v, buf);
283 if ((cp = setview(vwl[nvv++].v)) != NULL) {
284 fprintf(stderr, "%s: bad view %d - %s\n",
285 progname, nvv, cp);
286 quit(1);
287 }
288 }
289 while (fgets(buf, sizeof(buf), fp) != NULL);
290 if (nvv != nvn)
291 error(INTERNAL, "view miscount in runrad");
292 pclose(fp);
293 /* open options file */
294 if ((fp = fopen(optfile, "r")) == NULL)
295 error(SYSTEM, "cannot open options file");
296 /* get relevant options */
297 while (fgets(buf, sizeof(buf), fp) != NULL)
298 if (!strncmp(buf, "-av ", 4))
299 setcolor(ambval, atof(buf+4),
300 atof(sskip2(buf+4,1)),
301 atof(sskip2(buf+4,2)));
302 else if (backvis && !strncmp(buf, "-bv", 3) &&
303 (!buf[3] || strchr(" 0-FfNn", buf[3]) != NULL))
304 backvis = 0;
305 fclose(fp);
306 unlink(optfile); /* delete options file */
307 }
308
309
310 int
311 findvw(nm) /* find named view */
312 register char *nm;
313 {
314 register int n;
315
316 if (*nm >= '1' & *nm <= '9' &&
317 (n = atoi(nm)-1) <= MAXVIEW && vwl[n].v != NULL)
318 return(n);
319 for (n = 0; vwl[n].v != NULL; n++)
320 if (vwl[n].nam != NULL && !strcmp(nm, vwl[n].nam))
321 return(n);
322 return(-1);
323 }
324
325
326 int
327 varmatch(s, vn) /* match line to variable */
328 register char *s, *vn;
329 {
330 register int c;
331
332 for ( ; *vn && *s == *vn; s++, vn++)
333 ;
334 while (isspace(*s))
335 s++;
336 if (*s == '=')
337 return(*vn);
338 while (!(c = toupper(*s++) - toupper(*vn)) && *vn++)
339 ;
340 return(c);
341 }
342
343
344 char *
345 scan4var(buf, buflen, vname, fp) /* scan for variable from fp */
346 char *buf;
347 int buflen;
348 char *vname;
349 FILE *fp;
350 {
351 int cval;
352 register char *cp;
353 /* search out matching line */
354 while ((cval = varmatch(buf, vname))) {
355 if (cval > 0) /* gone too far? */
356 return(NULL);
357 buf[0] = '\0'; /* else get next line */
358 if (fgetline(buf, buflen, fp) == NULL)
359 return(NULL);
360 }
361 /* skip variable name and '=' */
362 for (cp = buf; *cp++ != '='; )
363 ;
364 while (isspace(*cp)) cp++;
365 return(cp);
366 }
367
368
369 dev_open(id) /* initialize GLX driver */
370 char *id;
371 {
372 static int atlBest[] = {GLX_RGBA, GLX_RED_SIZE,4,
373 GLX_GREEN_SIZE,4, GLX_BLUE_SIZE,4,
374 GLX_DOUBLEBUFFER, GLX_DEPTH_SIZE,15, None};
375 XSetWindowAttributes ourwinattr;
376 XWMHints ourxwmhints;
377 XSizeHints oursizhints;
378 /* open display server */
379 ourdisplay = XOpenDisplay(NULL);
380 if (ourdisplay == NULL)
381 error(USER, "cannot open X-windows; DISPLAY variable set?\n");
382 /* find a usable visual */
383 ourvinf = glXChooseVisual(ourdisplay, ourscreen, atlBest);
384 if (ourvinf == NULL)
385 error(USER, "no suitable visuals available");
386 /* get a context */
387 gctx = glXCreateContext(ourdisplay, ourvinf, NULL, GL_TRUE);
388 /* open window */
389 ourwinattr.background_pixel = ourblack;
390 ourwinattr.border_pixel = ourblack;
391 ourwinattr.event_mask = ourmask;
392 /* this is stupid */
393 ourwinattr.colormap = XCreateColormap(ourdisplay, ourroot,
394 ourvinf->visual, AllocNone);
395 gwind = XCreateWindow(ourdisplay, ourroot, 0, 0,
396 DisplayWidth(ourdisplay,ourscreen)-2*BORWIDTH,
397 DisplayHeight(ourdisplay,ourscreen)-2*BORWIDTH,
398 BORWIDTH, ourvinf->depth, InputOutput, ourvinf->visual,
399 CWBackPixel|CWBorderPixel|CWColormap|CWEventMask, &ourwinattr);
400 if (gwind == 0)
401 error(SYSTEM, "cannot create window\n");
402 XStoreName(ourdisplay, gwind, id);
403 #ifndef NOSTEREO
404 if (stereo) /* check if stereo working */
405 switch (XSGIQueryStereoMode(ourdisplay, gwind)) {
406 case STEREO_TOP:
407 case STEREO_BOTTOM:
408 break;
409 case STEREO_OFF:
410 error(USER,
411 "wrong video mode: run \"/usr/gfx/setmon -n STR_TOP\" first");
412 case X_STEREO_UNSUPPORTED:
413 error(USER, "stereo not supported on this screen");
414 default:
415 error(INTERNAL, "unknown stereo mode");
416 }
417 #endif
418 /* set window manager hints */
419 ourxwmhints.flags = InputHint|IconPixmapHint;
420 ourxwmhints.input = True;
421 ourxwmhints.icon_pixmap = XCreateBitmapFromData(ourdisplay,
422 gwind, glradicon_bits, glradicon_width, glradicon_height);
423 XSetWMHints(ourdisplay, gwind, &ourxwmhints);
424 oursizhints.min_width = MINWIDTH;
425 oursizhints.min_height = stereo ? MINHEIGHT/2 : MINHEIGHT;
426 oursizhints.flags = PMinSize;
427 XSetNormalHints(ourdisplay, gwind, &oursizhints);
428 /* set GLX context */
429 glXMakeCurrent(ourdisplay, gwind, gctx);
430 glEnable(GL_DEPTH_TEST);
431 glDepthFunc(GL_LESS);
432 glShadeModel(GL_SMOOTH);
433 glPolygonMode(GL_FRONT_AND_BACK, GL_FILL);
434 glLightModelf(GL_LIGHT_MODEL_TWO_SIDE, GL_TRUE);
435 glEnable(GL_LIGHTING);
436 if (backvis)
437 glDisable(GL_CULL_FACE);
438 else {
439 glFrontFace(GL_CCW);
440 glCullFace(GL_BACK);
441 glEnable(GL_CULL_FACE);
442 }
443 glDrawBuffer(GL_BACK);
444 /* figure out sensible view */
445 pwidth = (double)DisplayWidthMM(ourdisplay, ourscreen) /
446 DisplayWidth(ourdisplay, ourscreen);
447 pheight = (double)DisplayHeightMM(ourdisplay, ourscreen) /
448 DisplayHeight(ourdisplay, ourscreen);
449 if (stereo) { /* set stereo mode */
450 setstereobuf(STEREO_BUFFER_LEFT);
451 pheight *= 2.;
452 }
453 /* map the window */
454 XMapWindow(ourdisplay, gwind);
455 do
456 dev_input(0); /* get resize event */
457 while (hres == 0 & vres == 0);
458 rgl_checkerr("initializing GLX");
459 }
460
461
462 dev_close() /* close our display and free resources */
463 {
464 glXMakeCurrent(ourdisplay, None, NULL);
465 glXDestroyContext(ourdisplay, gctx);
466 XDestroyWindow(ourdisplay, gwind);
467 gwind = 0;
468 XCloseDisplay(ourdisplay);
469 ourdisplay = NULL;
470 }
471
472
473 int
474 dev_view(nv) /* assign new driver view */
475 register VIEW *nv;
476 {
477 int newhres = hres, newvres = vres;
478 double wa, va;
479 /* check view legality */
480 if (nv->type != VT_PER) {
481 error(COMMAND, "illegal view type");
482 nv->type = VT_PER;
483 }
484 if (nv->horiz > 160. | nv->vert > 160.) {
485 error(COMMAND, "illegal view angle");
486 if (nv->horiz > 160.)
487 nv->horiz = 160.;
488 if (nv->vert > 160.)
489 nv->vert = 160.;
490 }
491 if (hres != 0 & vres != 0) {
492 wa = (vres*pheight)/(hres*pwidth);
493 va = viewaspect(nv);
494 if (va > wa+.05) {
495 newvres = (pwidth/pheight)*va*newhres + .5;
496 if (newvres > maxvres) {
497 newvres = maxvres;
498 newhres = (pheight/pwidth)/va*newvres + .5;
499 }
500 } else if (va < wa-.05) {
501 newhres = (pheight/pwidth)/va*newvres + .5;
502 if (newhres > maxhres) {
503 newhres = maxhres;
504 newvres = (pwidth/pheight)*va*newhres + .5;
505 }
506 }
507 if (newhres != hres | newvres != vres) {
508 in_dev_view++;
509 XResizeWindow(ourdisplay, gwind, newhres, newvres);
510 do
511 dev_input(0); /* get resize event */
512 while (newhres != hres | newvres != vres);
513 in_dev_view--;
514 }
515 }
516 copystruct(&thisview, nv);
517 setglpersp(&thisview);
518 render();
519 return(1);
520 }
521
522
523 int
524 dev_input(nsecs) /* get next input event */
525 int nsecs;
526 {
527 #if 0
528 static time_t lasttime = 0;
529 time_t thistime;
530
531 if (nsecs > 0) {
532 thistime = time(0);
533 nsecs -= (long)(thistime - lasttime);
534 lasttime = thistime;
535 }
536 if (nsecs > 0)
537 alarm(nsecs);
538 #endif
539 XNextEvent(ourdisplay, levptr(XEvent));
540 switch (levptr(XEvent)->type) {
541 case ConfigureNotify:
542 resizewindow(levptr(XConfigureEvent));
543 break;
544 case UnmapNotify:
545 mapped = 0;
546 break;
547 case MapNotify:
548 mapped = 1;
549 break;
550 case Expose:
551 fixwindow(levptr(XExposeEvent));
552 break;
553 case KeyPress:
554 return(getkey(levptr(XKeyPressedEvent)));
555 case ButtonPress:
556 getmove(levptr(XButtonPressedEvent));
557 break;
558 }
559 return(1);
560 }
561
562
563 render() /* render our display list and swap buffers */
564 {
565 double d;
566
567 if (!mapped)
568 return;
569 glClear(GL_COLOR_BUFFER_BIT|GL_DEPTH_BUFFER_BIT);
570 glCallList(displist);
571 if (stereo) { /* do right eye for stereo */
572 setstereobuf(STEREO_BUFFER_RIGHT);
573 glClear(GL_COLOR_BUFFER_BIT|GL_DEPTH_BUFFER_BIT);
574 glMatrixMode(GL_MODELVIEW);
575 glPushMatrix();
576 d = -eyedist / sqrt(thisview.hn2);
577 glTranslated(d*thisview.hvec[0], d*thisview.hvec[1],
578 d*thisview.hvec[2]);
579 glCallList(displist);
580 glMatrixMode(GL_MODELVIEW);
581 glPopMatrix();
582 setstereobuf(STEREO_BUFFER_LEFT);
583 }
584 glXSwapBuffers(ourdisplay, gwind); /* calls glFlush() */
585 rgl_checkerr("rendering display list");
586 }
587
588
589 moveview(dx, dy, mov, orb) /* move our view */
590 int dx, dy, mov, orb;
591 {
592 VIEW nv;
593 FVECT odir, v1, wp;
594 double d;
595 register int li;
596 /* start with old view */
597 copystruct(&nv, &thisview);
598 /* change view direction */
599 if ((d = viewray(v1, odir, &thisview,
600 (dx+.5)/hres, (dy+.5)/vres)) < -FTINY)
601 return(0); /* outside view */
602 if (mov | orb) {
603 if (!getintersect(wp, v1, odir, d))
604 return(0);
605 VSUM(odir, wp, nv.vp, -1.);
606 } else
607 VCOPY(nv.vdir, odir);
608 if (orb && mov) { /* orbit left/right */
609 spinvector(odir, odir, nv.vup, d=MOVDEG*PI/180.*mov);
610 VSUM(nv.vp, wp, odir, -1.);
611 spinvector(nv.vdir, nv.vdir, nv.vup, d);
612 } else if (orb) { /* orbit up/down */
613 fcross(v1, odir, nv.vup);
614 if (normalize(v1) == 0.)
615 return(0);
616 spinvector(odir, odir, v1, d=MOVDEG*PI/180.*orb);
617 VSUM(nv.vp, wp, odir, -1.);
618 spinvector(nv.vdir, nv.vdir, v1, d);
619 } else if (mov) { /* move forward/backward */
620 d = MOVPCT/100. * mov;
621 VSUM(nv.vp, nv.vp, odir, d);
622 }
623 if (!mov ^ !orb && headlocked) { /* restore head height */
624 VSUM(v1, thisview.vp, nv.vp, -1.);
625 d = DOT(v1, thisview.vup);
626 VSUM(nv.vp, nv.vp, thisview.vup, d);
627 }
628 if (setview(&nv) != NULL)
629 return(0); /* illegal view */
630 dev_view(&nv);
631 return(1);
632 }
633
634
635 getmove(ebut) /* get view change */
636 XButtonPressedEvent *ebut;
637 {
638 int movdir = MOVDIR(ebut->button);
639 int movorb = MOVORB(ebut->state);
640 int moved = 0;
641 Window rootw, childw;
642 int rootx, rooty, wx, wy;
643 unsigned int statemask;
644
645 copylastv( movorb ? (movdir ? "left/right" : "up/down") :
646 (movdir ? "fore/back" : "rotate") );
647 XNoOp(ourdisplay);
648
649 while (!XCheckMaskEvent(ourdisplay,
650 ButtonReleaseMask, levptr(XEvent))) {
651
652 if (!XQueryPointer(ourdisplay, gwind, &rootw, &childw,
653 &rootx, &rooty, &wx, &wy, &statemask))
654 break; /* on another screen */
655
656 if (!moveview(wx, vres-1-wy, movdir, movorb)) {
657 sleep(1);
658 continue;
659 } else
660 moved++;
661 }
662 if (!moved) { /* do final motion */
663 movdir = MOVDIR(levptr(XButtonReleasedEvent)->button);
664 wx = levptr(XButtonReleasedEvent)->x;
665 wy = levptr(XButtonReleasedEvent)->y;
666 moveview(wx, vres-1-wy, movdir, movorb);
667 }
668 }
669
670
671 getintersect(wp, org, dir, md) /* intersect ray with scene geometry */
672 FVECT wp; /* returned world intersection point */
673 FVECT org, dir;
674 double md;
675 {
676 float fbuf[6];
677 /* check to see if rtrace is running */
678 if (rtpd[2] <= 0)
679 return(0);
680 /* assign origin */
681 fbuf[0] = org[0]; fbuf[1] = org[1]; fbuf[2] = org[2];
682 /* compute clipping distance */
683 if (md <= FTINY) md = FHUGE;
684 fbuf[3] = dir[0]*md; fbuf[4] = dir[1]*md; fbuf[5] = dir[2]*md;
685 /* trace that ray */
686 if (process(rtpd, fbuf, fbuf, 4*sizeof(float), 6*sizeof(float)) !=
687 4*sizeof(float))
688 error(INTERNAL, "error getting data back from rtrace process");
689 if (fbuf[3] >= .99*FHUGE)
690 return(0); /* missed local objects */
691 wp[0] = fbuf[0]; wp[1] = fbuf[1]; wp[2] = fbuf[2];
692 return(1); /* else return world intersection */
693 }
694
695
696 setglpersp(vp) /* set perspective view in GL */
697 register VIEW *vp;
698 {
699 double d, xmin, xmax, ymin, ymax, zmin, zmax;
700
701 zmin = 0.1;
702 zmax = 1000.;
703 if (thisview.vfore > FTINY)
704 zmin = thisview.vfore;
705 if (thisview.vaft > FTINY)
706 zmax = thisview.vaft;
707 xmax = zmin * tan(PI/180./2. * thisview.horiz);
708 xmin = -xmax;
709 d = thisview.hoff * (xmax - xmin);
710 xmin += d; xmax += d;
711 ymax = zmin * tan(PI/180./2. * thisview.vert);
712 ymin = -ymax;
713 d = thisview.voff * (ymax - ymin);
714 ymin += d; ymax += d;
715 /* set view matrix */
716 glMatrixMode(GL_PROJECTION);
717 glLoadIdentity();
718 glFrustum(xmin, xmax, ymin, ymax, zmin, zmax);
719 gluLookAt(thisview.vp[0], thisview.vp[1], thisview.vp[2],
720 thisview.vp[0] + thisview.vdir[0],
721 thisview.vp[1] + thisview.vdir[1],
722 thisview.vp[2] + thisview.vdir[2],
723 thisview.vup[0], thisview.vup[1], thisview.vup[2]);
724 rgl_checkerr("setting perspective view");
725 }
726
727
728 int
729 getkey(ekey) /* get input key */
730 register XKeyPressedEvent *ekey;
731 {
732 int n;
733 char buf[8];
734
735 n = XLookupString(ekey, buf, sizeof(buf), NULL, NULL);
736 if (n != 1)
737 return(1);
738 switch (buf[0]) {
739 case 'h': /* turn on height motion lock */
740 headlocked = 1;
741 break;
742 case 'H': /* turn off height motion lock */
743 headlocked = 0;
744 break;
745 case 'l': /* retrieve last (premouse) view */
746 if (lastview.type) {
747 VIEW vtmp;
748 copystruct(&vtmp, &thisview);
749 dev_view(&lastview);
750 copystruct(&lastview, &vtmp);
751 } else
752 XBell(ourdisplay, 0);
753 break;
754 case 'n': /* move to next standard view */
755 gotoview(currentview+1);
756 break;
757 case 'p': /* move to last standard view */
758 gotoview(currentview-1);
759 break;
760 case '+': /* zoom in */
761 zoomview(100+ZOOMPCT, ekey->x, vres-1-ekey->y);
762 break;
763 case '-': /* zoom out */
764 zoomview(100-ZOOMPCT, ekey->x, vres-1-ekey->y);
765 break;
766 case 'v': /* spit current view to stdout */
767 fputs(VIEWSTR, stdout);
768 fprintview(&thisview, stdout);
769 fputc('\n', stdout);
770 break;
771 case 'V': /* append view to rad file */
772 appendview(NULL, &thisview);
773 break;
774 case 'q': /* quit the program */
775 return(0);
776 default:
777 XBell(ourdisplay, 0);
778 break;
779 }
780 return(1);
781 }
782
783
784 zoomview(pct, dx, dy) /* zoom in or out around (dx,dy) */
785 int pct;
786 int dx, dy;
787 {
788 double h, v;
789 FVECT direc;
790
791 if (pct == 100 | pct <= 0)
792 return;
793 copylastv("zooming");
794 h = (dx+.5)/hres - 0.5;
795 v = (dy+.5)/vres - 0.5;
796 h *= (1. - 100./pct);
797 v *= (1. - 100./pct);
798 thisview.vdir[0] += h*thisview.hvec[0] + v*thisview.vvec[0];
799 thisview.vdir[1] += h*thisview.hvec[1] + v*thisview.vvec[1];
800 thisview.vdir[2] += h*thisview.hvec[2] + v*thisview.vvec[2];
801 thisview.horiz = 2.*180./PI * atan( 100./pct *
802 tan(PI/180./2.*thisview.horiz) );
803 thisview.vert = 2.*180./PI * atan( 100./pct *
804 tan(PI/180./2.*thisview.vert) );
805 setview(&thisview);
806 dev_view(&thisview);
807 }
808
809
810 gotoview(vwnum) /* go to specified view number */
811 int vwnum;
812 {
813 if (vwnum < 0)
814 for (vwnum = currentview; vwl[vwnum+1].v != NULL; vwnum++)
815 ;
816 else if (vwnum >= MAXVIEW || vwl[vwnum].v == NULL)
817 vwnum = 0;
818 if (vwnum == currentview)
819 return;
820 copylastv("standard view");
821 dev_view(vwl[currentview=vwnum].v);
822 }
823
824
825 appendview(nm, vp) /* append standard view */
826 char *nm;
827 VIEW *vp;
828 {
829 FILE *fp;
830 /* check if already in there */
831 if (!bcmp(&thisview, vwl[currentview].v, sizeof(VIEW))) {
832 error(COMMAND, "view already in standard list");
833 return;
834 }
835 /* append to file */
836 if ((fp = fopen(radfile, "a")) == NULL) {
837 error(COMMAND, "cannot append rad input file");
838 return;
839 }
840 fputs("view=", fp);
841 if (nm != NULL) {
842 fputc(' ', fp); fputs(nm, fp);
843 }
844 fprintview(vp, fp); fputc('\n', fp);
845 fclose(fp);
846 /* append to our list */
847 while (vwl[currentview].v != NULL)
848 currentview++;
849 if (currentview >= MAXVIEW)
850 error(INTERNAL, "too many views in appendview");
851 vwl[currentview].v = (VIEW *)bmalloc(sizeof(VIEW));
852 copystruct(vwl[currentview].v, &thisview);
853 if (nm != NULL)
854 vwl[currentview].nam = savqstr(nm);
855 }
856
857
858 copylastv(cause) /* copy last view position */
859 char *cause;
860 {
861 static char *lastvc;
862
863 if (cause == lastvc)
864 return; /* only record one view per cause */
865 lastvc = cause;
866 copystruct(&lastview, &thisview);
867 }
868
869
870 fixwindow(eexp) /* repair damage to window */
871 register XExposeEvent *eexp;
872 {
873 if (hres == 0 | vres == 0) { /* first exposure */
874 resizewindow((XConfigureEvent *)eexp);
875 return;
876 }
877 if (eexp->count) /* wait for final exposure */
878 return;
879 /* rerender everything */
880 render();
881 }
882
883
884 resizewindow(ersz) /* resize window */
885 register XConfigureEvent *ersz;
886 {
887 static char resizing[] = "resizing window";
888 double wa, va;
889
890 glViewport(0, 0, hres=ersz->width, vres=ersz->height);
891 if (hres > maxhres) maxhres = hres;
892 if (vres > maxvres) maxvres = vres;
893 if (in_dev_view)
894 return;
895 wa = (vres*pheight)/(hres*pwidth);
896 va = viewaspect(&thisview);
897 if (va > wa+.05) {
898 copylastv(resizing);
899 thisview.vert = 2.*180./PI *
900 atan( tan(PI/180./2. * thisview.horiz) * wa );
901 } else if (va < wa-.05) {
902 copylastv(resizing);
903 thisview.horiz = 2.*180./PI *
904 atan( tan(PI/180./2. * thisview.vert) / wa );
905 } else
906 return;
907 setview(&thisview);
908 dev_view(&thisview);
909 }
