--- ray/src/util/glrad.c 1998/07/15 17:51:13 3.9 +++ ray/src/util/glrad.c 2003/06/26 00:58:11 3.15 @@ -1,23 +1,23 @@ -/* Copyright (c) 1998 Silicon Graphics, Inc. */ - #ifndef lint -static char SCCSid[] = "$SunId$ SGI"; +static const char RCSid[] = "$Id: glrad.c,v 3.15 2003/06/26 00:58:11 schorsch Exp $"; #endif - /* * Program to display Radiance scene using OpenGL. */ -#include "radogl.h" -#include "view.h" -#include "paths.h" #include #include #ifndef NOSTEREO #include #endif #include +#include + +#include "radogl.h" +#include "view.h" +#include "paths.h" #include "glradicon.h" +#include "rtprocess.h" #ifndef MAXVIEW #define MAXVIEW 63 /* maximum number of standard views */ @@ -74,7 +74,7 @@ char *scene[MAXSCENE+1]; /* material and scene file l int nscenef = 0; /* number of scene files */ char *octree; /* octree name (NULL if unnec.) */ -int rtpd[3]; /* rtrace process descriptors */ +SUBPROC rtpd; /* rtrace process descriptors */ int silent = 0; /* run rad silently? */ int backvis = 1; /* back faces visible? */ @@ -92,13 +92,8 @@ int displist; /* our scene display list */ int no_render = 0; /* don't rerender */ -#ifdef BSD -#define strchr index -#endif - -extern char *strchr(), *fgets(), *fgetline(), *atos(), *scan4var(); +extern char *fgetline(), *atos(), *scan4var(); extern int nowarn; /* turn warnings off? */ -extern time_t time(); main(argc, argv) @@ -161,10 +156,10 @@ char *argv[]; dev_open(radfile = argv[i]); /* load octree or scene files */ if (octree != NULL) { - displist = rgl_octlist(octree, NULL, NULL); + displist = rgl_octlist(octree, NULL, NULL, NULL); startrtrace(octree); } else - displist = rgl_filelist(nscenef, scene); + displist = rgl_filelist(nscenef, scene, NULL); /* set initial view */ dev_view(currentview < 0 ? &thisview : vwl[currentview].v); /* input/render loop */ @@ -180,15 +175,17 @@ userr: } +void quit(code) /* exit gracefully */ int code; { if (ourdisplay != NULL) dev_close(); - if (rtpd[2] > 0) { - if (close_process(rtpd) > 0) + /* if (rtpd.pid > 0) { */ + if (rtpd.running) { + if (close_process(&rtpd) > 0) wputs("bad exit status from rtrace\n"); - rtpd[2] = 0; + /* rtpd.pid = 0; */ } exit(code); } @@ -204,7 +201,7 @@ char *octname; if (nowarn) av[ac++] = "-w-"; av[ac++] = octname; av[ac] = NULL; - if (open_process(rtpd, av) <= 0) + if (open_process(&rtpd, av) <= 0) error(SYSTEM, "cannot start rtrace process"); } @@ -298,7 +295,7 @@ char **av; atof(sskip2(buf+4,1)), atof(sskip2(buf+4,2))); else if (backvis && !strncmp(buf, "-bv", 3) && - (!buf[3] || strchr(" 0-FfNn", buf[3]) != NULL)) + (!buf[3] || strchr("0-FfNn \n",buf[3])!=NULL)) backvis = 0; fclose(fp); unlink(optfile); /* delete options file */ @@ -626,6 +623,16 @@ int dx, dy, mov, orb; } +static +waitabit() /* pause a moment */ +{ + struct timespec ts; + ts.tv_sec = 0; + ts.tv_nsec = 5000000; + nanosleep(&ts, NULL); +} + + getmove(ebut) /* get view change */ XButtonPressedEvent *ebut; { @@ -642,6 +649,8 @@ XButtonPressedEvent *ebut; while (!XCheckMaskEvent(ourdisplay, ButtonReleaseMask, levptr(XEvent))) { + /* pause so as not to move too fast */ + waitabit(); if (!XQueryPointer(ourdisplay, gwind, &rootw, &childw, &rootx, &rooty, &wx, &wy, &statemask)) @@ -669,7 +678,8 @@ double md; { float fbuf[6]; /* check to see if rtrace is running */ - if (rtpd[2] <= 0) + /* if (rtpd.pid <= 0) */ + if (!rtpd.running) return(0); /* assign origin */ fbuf[0] = org[0]; fbuf[1] = org[1]; fbuf[2] = org[2]; @@ -677,8 +687,8 @@ double md; if (md <= FTINY) md = FHUGE; fbuf[3] = dir[0]*md; fbuf[4] = dir[1]*md; fbuf[5] = dir[2]*md; /* trace that ray */ - if (process(rtpd, fbuf, fbuf, 4*sizeof(float), 6*sizeof(float)) != - 4*sizeof(float)) + if (process(&rtpd, (char *)fbuf, (char *)fbuf, + 4*sizeof(float), 6*sizeof(float)) != 4*sizeof(float)) error(INTERNAL, "error getting data back from rtrace process"); if (fbuf[3] >= .99*FHUGE) return(0); /* missed local objects */
