--- ray/src/util/glrad.c 2005/07/24 19:53:08 3.20 +++ ray/src/util/glrad.c 2016/04/25 02:04:22 3.24 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: glrad.c,v 3.20 2005/07/24 19:53:08 greg Exp $"; +static const char RCSid[] = "$Id: glrad.c,v 3.24 2016/04/25 02:04:22 greg Exp $"; #endif /* * Program to display Radiance scene using OpenGL. @@ -97,26 +97,26 @@ extern int nowarn; /* turn warnings off? */ static void startrtrace(char *octname); static void runrad(int ac, char **av); -static int findvw(register char *nm); -static int varmatch(register char *s, register char *vn); +static int findvw(char *nm); +static int varmatch(char *s, char *vn); static char * scan4var(char *buf, int buflen, char *vname, FILE *fp); static void dev_open(char *id); static void dev_close(void); -static int dev_view(register VIEW *nv); +static int dev_view(VIEW *nv); static int dev_input(int nsecs); static void render(void); static int moveview(int dx, int dy, int mov, int orb); static void waitabit(void); static void getmove(XButtonPressedEvent *ebut); static int getintersect(FVECT wp, FVECT org, FVECT dir, double md); -static void setglpersp(register VIEW *vp); -static int getkey(register XKeyPressedEvent *ekey); +static void setglpersp(VIEW *vp); +static int getkey(XKeyPressedEvent *ekey); static void zoomview(int pct, int dx, int dy); static void gotoview(int vwnum); static void appendview(char *nm, VIEW *vp); static void copylastv(char *cause); -static void fixwindow(register XExposeEvent *eexp); -static void resizewindow(register XConfigureEvent *ersz); +static void fixwindow(XExposeEvent *eexp); +static void resizewindow(XConfigureEvent *ersz); int @@ -245,7 +245,7 @@ runrad( /* run rad and load variables */ static char optfile[] = TEMPLATE; int nvn = 0, nvv = 0; FILE *fp; - register char *cp; + char *cp; char radcomm[256], buf[128], nam[32]; /* set rad commmand */ strcpy(radcomm, "rad -w -v 0 "); /* look out below! */ @@ -281,7 +281,7 @@ runrad( /* run rad and load variables */ eyedist = atof(cp); /* look for materials */ while ((cp = scan4var(buf, sizeof(buf), "materials", fp)) != NULL) { - nscenef += wordstring(scene+nscenef, cp); + nscenef += wordstring(scene+nscenef, MAXSCENE-nscenef, cp); buf[0] = '\0'; } /* look for octree */ @@ -289,7 +289,7 @@ runrad( /* run rad and load variables */ octree = savqstr(cp); /* look for scene files */ while ((cp = scan4var(buf, sizeof(buf), "scene", fp)) != NULL) { - nscenef += wordstring(scene+nscenef, cp); + nscenef += wordstring(scene+nscenef, MAXSCENE-nscenef, cp); buf[0] = '\0'; } /* load view names */ @@ -335,10 +335,10 @@ runrad( /* run rad and load variables */ static int findvw( /* find named view */ - register char *nm + char *nm ) { - register int n; + int n; if ((*nm >= '1') & (*nm <= '9') && (n = atoi(nm)-1) <= MAXVIEW && vwl[n].v != NULL) @@ -352,11 +352,11 @@ findvw( /* find named view */ static int varmatch( /* match line to variable */ - register char *s, - register char *vn + char *s, + char *vn ) { - register int c; + int c; for ( ; *vn && *s == *vn; s++, vn++) ; @@ -379,7 +379,7 @@ scan4var( /* scan for variable from fp */ ) { int cval; - register char *cp; + char *cp; /* search out matching line */ while ((cval = varmatch(buf, vname))) { if (cval > 0) /* gone too far? */ @@ -501,7 +501,7 @@ dev_close(void) /* close our display and free resour static int dev_view( /* assign new driver view */ - register VIEW *nv + VIEW *nv ) { int newhres = hres, newvres = vres; @@ -539,7 +539,7 @@ dev_view( /* assign new driver view */ XResizeWindow(ourdisplay, gwind, newhres, newvres); do dev_input(0); /* get resize event */ - while ((newhres != hres) | (newvres != vres)); + while ((newhres != hres) & (newvres != vres)); no_render--; } } @@ -646,12 +646,11 @@ moveview( /* move our view */ VSUM(nv.vp, wp, odir, -1.); spinvector(nv.vdir, nv.vdir, nv.vup, d); } else if (orb) { /* orbit up/down */ - fcross(v1, odir, nv.vup); - if (normalize(v1) == 0.) + if (geodesic(odir, odir, nv.vup, + d=MOVDEG*PI/180.*orb, GEOD_RAD) == 0.0) return(0); - spinvector(odir, odir, v1, d=MOVDEG*PI/180.*orb); VSUM(nv.vp, wp, odir, -1.); - spinvector(nv.vdir, nv.vdir, v1, d); + geodesic(nv.vdir, nv.vdir, nv.vup, d, GEOD_RAD); } else if (mov) { /* move forward/backward */ d = MOVPCT/100. * mov; VSUM(nv.vp, nv.vp, odir, d); @@ -673,7 +672,7 @@ waitabit(void) /* pause a moment */ { struct timespec ts; ts.tv_sec = 0; - ts.tv_nsec = 5000000; + ts.tv_nsec = 50000000; nanosleep(&ts, NULL); } @@ -749,7 +748,7 @@ getintersect( /* intersect ray with scene geometry */ static void setglpersp( /* set perspective view in GL */ - register VIEW *vp + VIEW *vp ) { double d, xmin, xmax, ymin, ymax, zmin, zmax; @@ -783,7 +782,7 @@ setglpersp( /* set perspective view in GL */ static int getkey( /* get input key */ - register XKeyPressedEvent *ekey + XKeyPressedEvent *ekey ) { int n; @@ -932,7 +931,7 @@ copylastv( /* copy last view position */ static void fixwindow( /* repair damage to window */ - register XExposeEvent *eexp + XExposeEvent *eexp ) { if ((hres == 0) | (vres == 0)) { /* first exposure */ @@ -948,7 +947,7 @@ fixwindow( /* repair damage to window */ static void resizewindow( /* resize window */ - register XConfigureEvent *ersz + XConfigureEvent *ersz ) { static char resizing[] = "resizing window";
