root/Development/ray/src/util/glrad.c
Revision: 3.20
Committed: Sun Jul 24 19:53:08 2005 UTC (20 years, 4 months ago) by greg
CVS Tags: rad4R0, rad3R9, rad3R8, rad3R7P2, rad3R7P1
Changes since 3.19: +3 -3 lines
2 static const char RCSid[] = "$Id: glrad.c,v 3.19 2004/03/26 23:34:23 schorsch Exp $";
5 * Program to display Radiance scene using OpenGL.
6 */
7
8 #include <sys/types.h>
9 #include <GL/glx.h>
10 #ifndef NOSTEREO
11 #include <X11/extensions/SGIStereo.h>
12 #endif
13 #include <ctype.h>
14 #include <string.h>
15 #include <time.h>
16
17 #include "radogl.h"
18 #include "view.h"
19 #include "paths.h"
20 #include "glradicon.h"
21 #include "rtprocess.h"
22
23 #ifndef MAXVIEW
24 #define MAXVIEW 63 /* maximum number of standard views */
25 #endif
26 #ifndef MAXSCENE
27 #define MAXSCENE 127 /* maximum number of scene files */
28 #endif
29
30 #define ZOOMPCT 9 /* percent to zoom at a time */
31
32 #define MOVPCT 7 /* percent distance to move /frame */
33 #define MOVDIR(b) ((b)==Button1 ? 1 : (b)==Button2 ? 0 : -1)
34 #define MOVDEG (-5) /* degrees to orbit CW/down /frame */
35 #define MOVORB(s) ((s)&ShiftMask ? 1 : (s)&ControlMask ? -1 : 0)
36
37 #define BORWIDTH 5 /* border width */
38
39 #define ourscreen DefaultScreen(ourdisplay)
40 #define ourroot RootWindow(ourdisplay,ourscreen)
41 #define ourmask (StructureNotifyMask|ExposureMask|KeyPressMask|\
42 ButtonPressMask|ButtonReleaseMask)
43
44 #define levptr(etype) ((etype *)&currentevent)
45
46 XEvent currentevent; /* current event */
47
48 int mapped = 0; /* window is mapped? */
49 unsigned long ourblack=0, ourwhite=~0;
50
51 Display *ourdisplay = NULL; /* our display */
52 XVisualInfo *ourvinf; /* our visual information */
53 Window gwind = 0; /* our graphics window */
54 int hres, vres; /* rendering window dimensions */
55 int maxhres, maxvres; /* maximum given dimensions */
56 GLXContext gctx; /* our GLX context */
57
58 double pwidth, pheight; /* pixel dimensions (mm) */
59
60 int headlocked = 0; /* lock vertical motion */
61
62 struct {
63 char *nam; /* view name (NULL if none) */
64 VIEW *v; /* parameters (NULL term.) */
65 } vwl[MAXVIEW+1]; /* our list of views */
66
67 int currentview = 0; /* current view number */
68 VIEW thisview = STDVIEW; /* displayed view */
69 double eyedist = 1; /* interocular distance */
70 VIEW lastview; /* last recorded view */
71
72 char *progname; /* global argv[0] */
73 char *radfile; /* rad input file */
74 char *scene[MAXSCENE+1]; /* material and scene file list */
75 int nscenef = 0; /* number of scene files */
76 char *octree; /* octree name (NULL if unnec.) */
77
78 SUBPROC rtpd; /* rtrace process descriptors */
79
80 int silent = 0; /* run rad silently? */
81 int backvis = 1; /* back faces visible? */
82 int stereo = 0; /* do stereo? */
83
84 #ifdef NOSTEREO
85 #define setstereobuf(bid)
86 #else
87 #define setstereobuf(bid) (glXWaitGL(), \
88 XSGISetStereoBuffer(ourdisplay, gwind, bid), \
89 glXWaitX())
90 #endif
91
92 int displist; /* our scene display list */
93
94 int no_render = 0; /* don't rerender */
95
96 extern int nowarn; /* turn warnings off? */
97
98 static void startrtrace(char *octname);
99 static void runrad(int ac, char **av);
100 static int findvw(register char *nm);
101 static int varmatch(register char *s, register char *vn);
102 static char * scan4var(char *buf, int buflen, char *vname, FILE *fp);
103 static void dev_open(char *id);
104 static void dev_close(void);
105 static int dev_view(register VIEW *nv);
106 static int dev_input(int nsecs);
107 static void render(void);
108 static int moveview(int dx, int dy, int mov, int orb);
109 static void waitabit(void);
110 static void getmove(XButtonPressedEvent *ebut);
111 static int getintersect(FVECT wp, FVECT org, FVECT dir, double md);
112 static void setglpersp(register VIEW *vp);
113 static int getkey(register XKeyPressedEvent *ekey);
114 static void zoomview(int pct, int dx, int dy);
115 static void gotoview(int vwnum);
116 static void appendview(char *nm, VIEW *vp);
117 static void copylastv(char *cause);
118 static void fixwindow(register XExposeEvent *eexp);
119 static void resizewindow(register XConfigureEvent *ersz);
120
121
122 int
123 main(
124 int argc,
125 char *argv[]
126 )
127 {
128 char *viewsel = NULL;
129 long vwintvl = 0;
130 int i;
131
132 progname = argv[0];
133 for (i = 1; i < argc && argv[i][0] == '-'; i++)
134 switch (argv[i][1]) {
135 case 'v':
136 viewsel = argv[++i];
137 break;
138 case 'w':
139 nowarn = !nowarn;
140 break;
141 case 's':
142 silent = !silent;
143 break;
144 case 'S':
145 stereo = !stereo;
146 break;
147 case 'c':
148 vwintvl = atoi(argv[++i]);
149 break;
150 case 'b':
151 backvis = !backvis;
152 break;
153 default:
154 goto userr;
155 }
156 if (i >= argc)
157 goto userr;
158 #ifdef NOSTEREO
159 if (stereo)
160 error(INTERNAL, "stereo not supported in this version");
161 #endif
162 /* run rad and get views */
163 runrad(argc-i, argv+i);
164 /* check view */
165 if (viewsel != NULL) {
166 if (viewsel[0] == '-') {
167 char *ve = viewsel;
168 if (!sscanview(&thisview, viewsel) ||
169 (ve = setview(&thisview)) != NULL) {
170 fprintf(stderr, "%s: bad view: %s\n",
171 progname, ve);
172 quit(1);
173 }
174 currentview = -1;
175 } else if ((currentview = findvw(viewsel)) < 0) {
176 fprintf(stderr, "%s: no such view: %s\n",
177 progname, viewsel);
178 quit(1);
179 }
180 }
181 /* open GL */
182 dev_open(radfile = argv[i]);
183 /* load octree or scene files */
184 if (octree != NULL) {
185 displist = rgl_octlist(octree, NULL, NULL, NULL);
186 startrtrace(octree);
187 } else
188 displist = rgl_filelist(nscenef, scene, NULL);
189 /* set initial view */
190 dev_view(currentview < 0 ? &thisview : vwl[currentview].v);
191 /* input/render loop */
192 while (dev_input(vwintvl))
193 ;
194 /* all done */
195 quit(0);
196 userr:
197 fprintf(stderr,
198 "Usage: %s [-w][-s][-b][-S][-v view] rfile [VAR=value]..\n",
199 argv[0]);
200 quit(1);
201 return 1; /* pro forma return */
202 }
203
204
205 void
206 quit( /* exit gracefully */
207 int code
208 )
209 {
210 if (ourdisplay != NULL)
211 dev_close();
212 /* if (rtpd.pid > 0) { */
213 if (rtpd.running) {
214 if (close_process(&rtpd) > 0)
215 wputs("bad exit status from rtrace\n");
216 /* rtpd.pid = 0; */
217 }
218 exit(code);
219 }
220
221
222 static void
223 startrtrace( /* start rtrace on octname */
224 char *octname
225 )
226 {
227 static char *av[12] = {"rtrace", "-h", "-fff", "-ld+",
228 "-opL", "-x", "1"};
229 int ac = 7;
230
231 if (nowarn) av[ac++] = "-w-";
232 av[ac++] = octname;
233 av[ac] = NULL;
234 if (open_process(&rtpd, av) <= 0)
235 error(SYSTEM, "cannot start rtrace process");
236 }
237
238
239 static void
240 runrad( /* run rad and load variables */
241 int ac,
242 char **av
243 )
244 {
245 static char optfile[] = TEMPLATE;
246 int nvn = 0, nvv = 0;
247 FILE *fp;
248 register char *cp;
249 char radcomm[256], buf[128], nam[32];
250 /* set rad commmand */
251 strcpy(radcomm, "rad -w -v 0 "); /* look out below! */
252 cp = radcomm + 19;
253 if (silent) {
254 strcpy(cp, "-s ");
255 cp += 3;
256 }
257 while (ac--) {
258 strcpy(cp, *av++);
259 while (*cp) cp++;
260 *cp++ = ' ';
261 }
262 strcpy(cp, "OPTFILE="); /* create temporary options file */
263 strcpy(cp+8, mktemp(optfile));
264 if (system(radcomm)) /* update octree */
265 error(USER, "error executing rad command");
266 /* replace "-v 0" with "-n -e -s -V" */
267 strcpy(radcomm+7, "-n -e -s -V");
268 radcomm[18] = ' ';
269 if ((fp = popen(radcomm, "r")) == NULL)
270 error(SYSTEM, "cannot start rad command");
271 buf[0] = '\0'; /* read variables alphabetically */
272 /* get exposure */
273 if ((cp = scan4var(buf, sizeof(buf), "EXPOSURE", fp)) != NULL) {
274 expval = atof(cp);
275 if ((*cp == '-') | (*cp == '+'))
276 expval = pow(2., expval);
277 expval *= 0.5; /* compensate for local shading */
278 }
279 /* look for eye separation */
280 if ((cp = scan4var(buf, sizeof(buf), "EYESEP", fp)) != NULL)
281 eyedist = atof(cp);
282 /* look for materials */
283 while ((cp = scan4var(buf, sizeof(buf), "materials", fp)) != NULL) {
284 nscenef += wordstring(scene+nscenef, cp);
285 buf[0] = '\0';
286 }
287 /* look for octree */
288 if ((cp = scan4var(buf, sizeof(buf), "OCTREE", fp)) != NULL)
289 octree = savqstr(cp);
290 /* look for scene files */
291 while ((cp = scan4var(buf, sizeof(buf), "scene", fp)) != NULL) {
292 nscenef += wordstring(scene+nscenef, cp);
293 buf[0] = '\0';
294 }
295 /* load view names */
296 while ((cp = scan4var(buf, sizeof(buf), "view", fp)) != NULL) {
297 if (nvn >= MAXVIEW)
298 error(INTERNAL, "too many views in rad file");
299 vwl[nvn++].nam = *cp == '-' ? (char *)NULL :
300 savqstr(atos(nam, sizeof(nam), cp));
301 buf[0] = '\0';
302 }
303 /* load actual views */
304 do
305 if (isview(buf)) {
306 vwl[nvv].v = (VIEW *)bmalloc(sizeof(VIEW));
307 *(vwl[nvv].v) = stdview;
308 sscanview(vwl[nvv].v, buf);
309 if ((cp = setview(vwl[nvv++].v)) != NULL) {
310 fprintf(stderr, "%s: bad view %d - %s\n",
311 progname, nvv, cp);
312 quit(1);
313 }
314 }
315 while (fgets(buf, sizeof(buf), fp) != NULL);
316 if (nvv != nvn)
317 error(INTERNAL, "view miscount in runrad");
318 pclose(fp);
319 /* open options file */
320 if ((fp = fopen(optfile, "r")) == NULL)
321 error(SYSTEM, "cannot open options file");
322 /* get relevant options */
323 while (fgets(buf, sizeof(buf), fp) != NULL)
324 if (!strncmp(buf, "-av ", 4))
325 setcolor(ambval, atof(buf+4),
326 atof(sskip2(buf+4,1)),
327 atof(sskip2(buf+4,2)));
328 else if (backvis && !strncmp(buf, "-bv", 3) &&
329 (!buf[3] || strchr("0-FfNn \n",buf[3])!=NULL))
330 backvis = 0;
331 fclose(fp);
332 unlink(optfile); /* delete options file */
333 }
334
335
336 static int
337 findvw( /* find named view */
338 register char *nm
339 )
340 {
341 register int n;
342
343 if ((*nm >= '1') & (*nm <= '9') &&
344 (n = atoi(nm)-1) <= MAXVIEW && vwl[n].v != NULL)
345 return(n);
346 for (n = 0; vwl[n].v != NULL; n++)
347 if (vwl[n].nam != NULL && !strcmp(nm, vwl[n].nam))
348 return(n);
349 return(-1);
350 }
351
352
353 static int
354 varmatch( /* match line to variable */
355 register char *s,
356 register char *vn
357 )
358 {
359 register int c;
360
361 for ( ; *vn && *s == *vn; s++, vn++)
362 ;
363 while (isspace(*s))
364 s++;
365 if (*s == '=')
366 return(*vn);
367 while (!(c = toupper(*s++) - toupper(*vn)) && *vn++)
368 ;
369 return(c);
370 }
371
372
373 static char *
374 scan4var( /* scan for variable from fp */
375 char *buf,
376 int buflen,
377 char *vname,
378 FILE *fp
379 )
380 {
381 int cval;
382 register char *cp;
383 /* search out matching line */
384 while ((cval = varmatch(buf, vname))) {
385 if (cval > 0) /* gone too far? */
386 return(NULL);
387 buf[0] = '\0'; /* else get next line */
388 if (fgetline(buf, buflen, fp) == NULL)
389 return(NULL);
390 }
391 /* skip variable name and '=' */
392 for (cp = buf; *cp++ != '='; )
393 ;
394 while (isspace(*cp)) cp++;
395 return(cp);
396 }
397
398
399 static void
400 dev_open( /* initialize GLX driver */
401 char *id
402 )
403 {
404 static int atlBest[] = {GLX_RGBA, GLX_RED_SIZE,4,
405 GLX_GREEN_SIZE,4, GLX_BLUE_SIZE,4,
406 GLX_DOUBLEBUFFER, GLX_DEPTH_SIZE,15, None};
407 XSetWindowAttributes ourwinattr;
408 XWMHints ourxwmhints;
409 /* open display server */
410 ourdisplay = XOpenDisplay(NULL);
411 if (ourdisplay == NULL)
412 error(USER, "cannot open X-windows; DISPLAY variable set?\n");
413 /* find a usable visual */
414 ourvinf = glXChooseVisual(ourdisplay, ourscreen, atlBest);
415 if (ourvinf == NULL)
416 error(USER, "no suitable visuals available");
417 /* get a context */
418 gctx = glXCreateContext(ourdisplay, ourvinf, NULL, GL_TRUE);
419 /* open window */
420 ourwinattr.background_pixel = ourblack;
421 ourwinattr.border_pixel = ourblack;
422 ourwinattr.event_mask = ourmask;
423 /* this is stupid */
424 ourwinattr.colormap = XCreateColormap(ourdisplay, ourroot,
425 ourvinf->visual, AllocNone);
426 gwind = XCreateWindow(ourdisplay, ourroot, 0, 0,
427 DisplayWidth(ourdisplay,ourscreen)-2*BORWIDTH,
428 DisplayHeight(ourdisplay,ourscreen)-2*BORWIDTH,
429 BORWIDTH, ourvinf->depth, InputOutput, ourvinf->visual,
430 CWBackPixel|CWBorderPixel|CWColormap|CWEventMask, &ourwinattr);
431 if (gwind == 0)
432 error(SYSTEM, "cannot create window\n");
433 XStoreName(ourdisplay, gwind, id);
434 #ifndef NOSTEREO
435 if (stereo) /* check if stereo working */
436 switch (XSGIQueryStereoMode(ourdisplay, gwind)) {
437 case STEREO_TOP:
438 case STEREO_BOTTOM:
439 break;
440 case STEREO_OFF:
441 error(USER,
442 "wrong video mode: run \"/usr/gfx/setmon -n STR_TOP\" first");
443 case X_STEREO_UNSUPPORTED:
444 error(USER, "stereo not supported on this screen");
445 default:
446 error(INTERNAL, "unknown stereo mode");
447 }
448 #endif
449 /* set window manager hints */
450 ourxwmhints.flags = InputHint|IconPixmapHint;
451 ourxwmhints.input = True;
452 ourxwmhints.icon_pixmap = XCreateBitmapFromData(ourdisplay, gwind,
453 (char *)glradicon_bits, glradicon_width, glradicon_height);
454 XSetWMHints(ourdisplay, gwind, &ourxwmhints);
455 /* set GLX context */
456 glXMakeCurrent(ourdisplay, gwind, gctx);
457 glEnable(GL_DEPTH_TEST);
458 glDepthFunc(GL_LESS);
459 glShadeModel(GL_SMOOTH);
460 glPolygonMode(GL_FRONT_AND_BACK, GL_FILL);
461 glLightModeli(GL_LIGHT_MODEL_TWO_SIDE, GL_TRUE);
462 glEnable(GL_LIGHTING);
463 glFrontFace(GL_CCW);
464 glCullFace(GL_BACK);
465 if (backvis)
466 glDisable(GL_CULL_FACE);
467 else
468 glEnable(GL_CULL_FACE);
469 glDrawBuffer(GL_BACK);
470 /* figure out sensible view */
471 pwidth = (double)DisplayWidthMM(ourdisplay, ourscreen) /
472 DisplayWidth(ourdisplay, ourscreen);
473 pheight = (double)DisplayHeightMM(ourdisplay, ourscreen) /
474 DisplayHeight(ourdisplay, ourscreen);
475 if (stereo) { /* set stereo mode */
476 setstereobuf(STEREO_BUFFER_LEFT);
477 pheight *= 2.;
478 }
479 /* map the window */
480 XMapWindow(ourdisplay, gwind);
481 no_render++;
482 do
483 dev_input(0); /* get resize event */
484 while ((hres == 0) & (vres == 0));
485 no_render--;
486 rgl_checkerr("initializing GLX");
487 }
488
489
490 static void
491 dev_close(void) /* close our display and free resources */
492 {
493 glXMakeCurrent(ourdisplay, None, NULL);
494 glXDestroyContext(ourdisplay, gctx);
495 XDestroyWindow(ourdisplay, gwind);
496 gwind = 0;
497 XCloseDisplay(ourdisplay);
498 ourdisplay = NULL;
499 }
500
501
502 static int
503 dev_view( /* assign new driver view */
504 register VIEW *nv
505 )
506 {
507 int newhres = hres, newvres = vres;
508 double wa, va;
509 /* check view legality */
510 if (nv->type != VT_PER) {
511 error(COMMAND, "illegal view type");
512 nv->type = VT_PER;
513 }
514 if ((nv->horiz > 160.) | (nv->vert > 160.)) {
515 error(COMMAND, "illegal view angle");
516 if (nv->horiz > 160.)
517 nv->horiz = 160.;
518 if (nv->vert > 160.)
519 nv->vert = 160.;
520 }
521 if ((hres != 0) & (vres != 0)) {
522 wa = (vres*pheight)/(hres*pwidth);
523 va = viewaspect(nv);
524 if (va > wa+.05) {
525 newvres = (pwidth/pheight)*va*newhres + .5;
526 if (newvres > maxvres) {
527 newvres = maxvres;
528 newhres = (pheight/pwidth)/va*newvres + .5;
529 }
530 } else if (va < wa-.05) {
531 newhres = (pheight/pwidth)/va*newvres + .5;
532 if (newhres > maxhres) {
533 newhres = maxhres;
534 newvres = (pwidth/pheight)*va*newhres + .5;
535 }
536 }
537 if ((newhres != hres) | (newvres != vres)) {
538 no_render++;
539 XResizeWindow(ourdisplay, gwind, newhres, newvres);
540 do
541 dev_input(0); /* get resize event */
542 while ((newhres != hres) | (newvres != vres));
543 no_render--;
544 }
545 }
546 thisview = *nv;
547 setglpersp(&thisview);
548 render();
549 return(1);
550 }
551
552
553 static int
554 dev_input( /* get next input event */
555 int nsecs
556 )
557 {
558 #if 0
559 static time_t lasttime = 0;
560 time_t thistime;
561
562 if (nsecs > 0) {
563 thistime = time(0);
564 nsecs -= (long)(thistime - lasttime);
565 lasttime = thistime;
566 }
567 if (nsecs > 0)
568 alarm(nsecs);
569 #endif
570 XNextEvent(ourdisplay, levptr(XEvent));
571 switch (levptr(XEvent)->type) {
572 case ConfigureNotify:
573 resizewindow(levptr(XConfigureEvent));
574 break;
575 case UnmapNotify:
576 mapped = 0;
577 break;
578 case MapNotify:
579 mapped = 1;
580 break;
581 case Expose:
582 fixwindow(levptr(XExposeEvent));
583 break;
584 case KeyPress:
585 return(getkey(levptr(XKeyPressedEvent)));
586 case ButtonPress:
587 getmove(levptr(XButtonPressedEvent));
588 break;
589 }
590 return(1);
591 }
592
593
594 static void
595 render(void) /* render our display list and swap buffers */
596 {
597 double d;
598
599 if (!mapped | no_render)
600 return;
601 glClear(GL_COLOR_BUFFER_BIT|GL_DEPTH_BUFFER_BIT);
602 glCallList(displist);
603 if (stereo) { /* do right eye for stereo */
604 setstereobuf(STEREO_BUFFER_RIGHT);
605 glClear(GL_COLOR_BUFFER_BIT|GL_DEPTH_BUFFER_BIT);
606 glMatrixMode(GL_MODELVIEW);
607 glPushMatrix();
608 d = -eyedist / sqrt(thisview.hn2);
609 glTranslated(d*thisview.hvec[0], d*thisview.hvec[1],
610 d*thisview.hvec[2]);
611 glCallList(displist);
612 glMatrixMode(GL_MODELVIEW);
613 glPopMatrix();
614 setstereobuf(STEREO_BUFFER_LEFT);
615 }
616 glXSwapBuffers(ourdisplay, gwind); /* calls glFlush() */
617 rgl_checkerr("rendering display list");
618 }
619
620
621 static int
622 moveview( /* move our view */
623 int dx,
624 int dy,
625 int mov,
626 int orb
627 )
628 {
629 VIEW nv;
630 FVECT odir, v1, wp;
631 double d;
632 /* start with old view */
633 nv = thisview;
634 /* change view direction */
635 if ((d = viewray(v1, odir, &thisview,
636 (dx+.5)/hres, (dy+.5)/vres)) < -FTINY)
637 return(0); /* outside view */
638 if (mov | orb) {
639 if (!getintersect(wp, v1, odir, d))
640 return(0);
641 VSUM(odir, wp, nv.vp, -1.);
642 } else
643 VCOPY(nv.vdir, odir);
644 if (orb && mov) { /* orbit left/right */
645 spinvector(odir, odir, nv.vup, d=MOVDEG*PI/180.*mov);
646 VSUM(nv.vp, wp, odir, -1.);
647 spinvector(nv.vdir, nv.vdir, nv.vup, d);
648 } else if (orb) { /* orbit up/down */
649 fcross(v1, odir, nv.vup);
650 if (normalize(v1) == 0.)
651 return(0);
652 spinvector(odir, odir, v1, d=MOVDEG*PI/180.*orb);
653 VSUM(nv.vp, wp, odir, -1.);
654 spinvector(nv.vdir, nv.vdir, v1, d);
655 } else if (mov) { /* move forward/backward */
656 d = MOVPCT/100. * mov;
657 VSUM(nv.vp, nv.vp, odir, d);
658 }
659 if (!mov ^ !orb && headlocked) { /* restore head height */
660 VSUM(v1, thisview.vp, nv.vp, -1.);
661 d = DOT(v1, thisview.vup);
662 VSUM(nv.vp, nv.vp, thisview.vup, d);
663 }
664 if (setview(&nv) != NULL)
665 return(0); /* illegal view */
666 dev_view(&nv);
667 return(1);
668 }
669
670
671 static void
672 waitabit(void) /* pause a moment */
673 {
674 struct timespec ts;
675 ts.tv_sec = 0;
676 ts.tv_nsec = 5000000;
677 nanosleep(&ts, NULL);
678 }
679
680
681 static void
682 getmove( /* get view change */
683 XButtonPressedEvent *ebut
684 )
685 {
686 int movdir = MOVDIR(ebut->button);
687 int movorb = MOVORB(ebut->state);
688 int moved = 0;
689 Window rootw, childw;
690 int rootx, rooty, wx, wy;
691 unsigned int statemask;
692
693 copylastv( movorb ? (movdir ? "left/right" : "up/down") :
694 (movdir ? "fore/back" : "rotate") );
695 XNoOp(ourdisplay);
696
697 while (!XCheckMaskEvent(ourdisplay,
698 ButtonReleaseMask, levptr(XEvent))) {
699 /* pause so as not to move too fast */
700 waitabit();
701
702 if (!XQueryPointer(ourdisplay, gwind, &rootw, &childw,
703 &rootx, &rooty, &wx, &wy, &statemask))
704 break; /* on another screen */
705
706 if (!moveview(wx, vres-1-wy, movdir, movorb)) {
707 sleep(1);
708 continue;
709 } else
710 moved++;
711 }
712 if (!moved) { /* do final motion */
713 movdir = MOVDIR(levptr(XButtonReleasedEvent)->button);
714 wx = levptr(XButtonReleasedEvent)->x;
715 wy = levptr(XButtonReleasedEvent)->y;
716 moveview(wx, vres-1-wy, movdir, movorb);
717 }
718 }
719
720
721 static int
722 getintersect( /* intersect ray with scene geometry */
723 FVECT wp, /* returned world intersection point */
724 FVECT org,
725 FVECT dir,
726 double md
727 )
728 {
729 float fbuf[6];
730 /* check to see if rtrace is running */
731 /* if (rtpd.pid <= 0) */
732 if (!rtpd.running)
733 return(0);
734 /* assign origin */
735 fbuf[0] = org[0]; fbuf[1] = org[1]; fbuf[2] = org[2];
736 /* compute clipping distance */
737 if (md <= FTINY) md = FHUGE;
738 fbuf[3] = dir[0]*md; fbuf[4] = dir[1]*md; fbuf[5] = dir[2]*md;
739 /* trace that ray */
740 if (process(&rtpd, (char *)fbuf, (char *)fbuf,
741 4*sizeof(float), 6*sizeof(float)) != 4*sizeof(float))
742 error(INTERNAL, "error getting data back from rtrace process");
743 if (fbuf[3] >= .99*FHUGE)
744 return(0); /* missed local objects */
745 wp[0] = fbuf[0]; wp[1] = fbuf[1]; wp[2] = fbuf[2];
746 return(1); /* else return world intersection */
747 }
748
749
750 static void
751 setglpersp( /* set perspective view in GL */
752 register VIEW *vp
753 )
754 {
755 double d, xmin, xmax, ymin, ymax, zmin, zmax;
756
757 zmin = 0.1;
758 zmax = 1000.;
759 if (thisview.vfore > FTINY)
760 zmin = thisview.vfore;
761 if (thisview.vaft > FTINY)
762 zmax = thisview.vaft;
763 xmax = zmin * tan(PI/180./2. * thisview.horiz);
764 xmin = -xmax;
765 d = thisview.hoff * (xmax - xmin);
766 xmin += d; xmax += d;
767 ymax = zmin * tan(PI/180./2. * thisview.vert);
768 ymin = -ymax;
769 d = thisview.voff * (ymax - ymin);
770 ymin += d; ymax += d;
771 /* set view matrix */
772 glMatrixMode(GL_PROJECTION);
773 glLoadIdentity();
774 glFrustum(xmin, xmax, ymin, ymax, zmin, zmax);
775 gluLookAt(thisview.vp[0], thisview.vp[1], thisview.vp[2],
776 thisview.vp[0] + thisview.vdir[0],
777 thisview.vp[1] + thisview.vdir[1],
778 thisview.vp[2] + thisview.vdir[2],
779 thisview.vup[0], thisview.vup[1], thisview.vup[2]);
780 rgl_checkerr("setting perspective view");
781 }
782
783
784 static int
785 getkey( /* get input key */
786 register XKeyPressedEvent *ekey
787 )
788 {
789 int n;
790 char buf[8];
791
792 n = XLookupString(ekey, buf, sizeof(buf), NULL, NULL);
793 if (n != 1)
794 return(1);
795 switch (buf[0]) {
796 case 'h': /* turn on height motion lock */
797 headlocked = 1;
798 break;
799 case 'H': /* turn off height motion lock */
800 headlocked = 0;
801 break;
802 case 'l': /* retrieve last (premouse) view */
803 if (lastview.type) {
804 VIEW vtmp;
805 vtmp = thisview;
806 dev_view(&lastview);
807 lastview = vtmp;
808 } else
809 XBell(ourdisplay, 0);
810 break;
811 case 'n': /* move to next standard view */
812 gotoview(currentview+1);
813 break;
814 case 'p': /* move to last standard view */
815 gotoview(currentview-1);
816 break;
817 case '+': /* zoom in */
818 zoomview(100+ZOOMPCT, ekey->x, vres-1-ekey->y);
819 break;
820 case '-': /* zoom out */
821 zoomview(100-ZOOMPCT, ekey->x, vres-1-ekey->y);
822 break;
823 case 'v': /* spit current view to stdout */
824 fputs(VIEWSTR, stdout);
825 fprintview(&thisview, stdout);
826 fputc('\n', stdout);
827 break;
828 case 'V': /* append view to rad file */
829 appendview(NULL, &thisview);
830 break;
831 case 'q': /* quit the program */
832 return(0);
833 default:
834 XBell(ourdisplay, 0);
835 break;
836 }
837 return(1);
838 }
839
840
841 static void
842 zoomview( /* zoom in or out around (dx,dy) */
843 int pct,
844 int dx,
845 int dy
846 )
847 {
848 double h, v;
849
850 if ((pct == 100) | (pct <= 0))
851 return;
852 copylastv("zooming");
853 h = (dx+.5)/hres - 0.5;
854 v = (dy+.5)/vres - 0.5;
855 h *= (1. - 100./pct);
856 v *= (1. - 100./pct);
857 thisview.vdir[0] += h*thisview.hvec[0] + v*thisview.vvec[0];
858 thisview.vdir[1] += h*thisview.hvec[1] + v*thisview.vvec[1];
859 thisview.vdir[2] += h*thisview.hvec[2] + v*thisview.vvec[2];
860 thisview.horiz = 2.*180./PI * atan( 100./pct *
861 tan(PI/180./2.*thisview.horiz) );
862 thisview.vert = 2.*180./PI * atan( 100./pct *
863 tan(PI/180./2.*thisview.vert) );
864 setview(&thisview);
865 dev_view(&thisview);
866 }
867
868
869 static void
870 gotoview( /* go to specified view number */
871 int vwnum
872 )
873 {
874 if (vwnum < 0)
875 for (vwnum = currentview; vwl[vwnum+1].v != NULL; vwnum++)
876 ;
877 else if (vwnum >= MAXVIEW || vwl[vwnum].v == NULL)
878 vwnum = 0;
879 copylastv("standard view");
880 dev_view(vwl[currentview=vwnum].v);
881 }
882
883
884 static void
885 appendview( /* append standard view */
886 char *nm,
887 VIEW *vp
888 )
889 {
890 FILE *fp;
891 /* check if already in there */
892 if (!memcmp(&thisview, vwl[currentview].v, sizeof(VIEW))) {
893 error(COMMAND, "view already in standard list");
894 return;
895 }
896 /* append to file */
897 if ((fp = fopen(radfile, "a")) == NULL) {
898 error(COMMAND, "cannot append rad input file");
899 return;
900 }
901 fputs("view=", fp);
902 if (nm != NULL) {
903 fputc(' ', fp); fputs(nm, fp);
904 }
905 fprintview(vp, fp); fputc('\n', fp);
906 fclose(fp);
907 /* append to our list */
908 while (vwl[currentview].v != NULL)
909 currentview++;
910 if (currentview >= MAXVIEW)
911 error(INTERNAL, "too many views in appendview");
912 vwl[currentview].v = (VIEW *)bmalloc(sizeof(VIEW));
913 *(vwl[currentview].v) = thisview;
914 if (nm != NULL)
915 vwl[currentview].nam = savqstr(nm);
916 }
917
918
919 static void
920 copylastv( /* copy last view position */
921 char *cause
922 )
923 {
924 static char *lastvc;
925
926 if (cause == lastvc)
927 return; /* only record one view per cause */
928 lastvc = cause;
929 lastview = thisview;
930 }
931
932
933 static void
934 fixwindow( /* repair damage to window */
935 register XExposeEvent *eexp
936 )
937 {
938 if ((hres == 0) | (vres == 0)) { /* first exposure */
939 resizewindow((XConfigureEvent *)eexp);
940 return;
941 }
942 if (eexp->count) /* wait for final exposure */
943 return;
944 /* rerender everything */
945 render();
946 }
947
948
949 static void
950 resizewindow( /* resize window */
951 register XConfigureEvent *ersz
952 )
953 {
954 static char resizing[] = "resizing window";
955 double wa, va;
956
957 glViewport(0, 0, hres=ersz->width, vres=ersz->height);
958 if (hres > maxhres) maxhres = hres;
959 if (vres > maxvres) maxvres = vres;
960 if (no_render)
961 return;
962 wa = (vres*pheight)/(hres*pwidth);
963 va = viewaspect(&thisview);
964 if (va > wa+.05) {
965 copylastv(resizing);
966 thisview.vert = 2.*180./PI *
967 atan( tan(PI/180./2. * thisview.horiz) * wa );
968 } else if (va < wa-.05) {
969 copylastv(resizing);
970 thisview.horiz = 2.*180./PI *
971 atan( tan(PI/180./2. * thisview.vert) / wa );
972 } else
973 return;
974 setview(&thisview);
975 dev_view(&thisview);
976 }
