| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id$";
| 3 |
#endif
| 4 |
| 5 |
* Program to display Radiance scene using OpenGL.
| 6 |
| 7 |
| 8 |
#include <sys/types.h>
| 9 |
#include <GL/glx.h>
| 10 |
#ifndef NOSTEREO
| 11 |
#include <X11/extensions/SGIStereo.h>
| 12 |
#endif
| 13 |
#include <ctype.h>
| 14 |
#include <time.h>
| 15 |
#include "radogl.h"
| 16 |
#include "view.h"
| 17 |
#include "paths.h"
| 18 |
#include "glradicon.h"
| 19 |
| 20 |
#ifndef MAXVIEW
| 21 |
#define MAXVIEW 63 /* maximum number of standard views */
| 22 |
#endif
| 23 |
#ifndef MAXSCENE
| 24 |
#define MAXSCENE 127 /* maximum number of scene files */
| 25 |
#endif
| 26 |
| 27 |
#define ZOOMPCT 9 /* percent to zoom at a time */
| 28 |
| 29 |
#define MOVPCT 7 /* percent distance to move /frame */
| 30 |
#define MOVDIR(b) ((b)==Button1 ? 1 : (b)==Button2 ? 0 : -1)
| 31 |
#define MOVDEG (-5) /* degrees to orbit CW/down /frame */
| 32 |
#define MOVORB(s) ((s)&ShiftMask ? 1 : (s)&ControlMask ? -1 : 0)
| 33 |
| 34 |
#define BORWIDTH 5 /* border width */
| 35 |
| 36 |
#define ourscreen DefaultScreen(ourdisplay)
| 37 |
#define ourroot RootWindow(ourdisplay,ourscreen)
| 38 |
#define ourmask (StructureNotifyMask|ExposureMask|KeyPressMask|\
| 39 |
ButtonPressMask|ButtonReleaseMask)
| 40 |
| 41 |
#define levptr(etype) ((etype *)¤tevent)
| 42 |
| 43 |
XEvent currentevent; /* current event */
| 44 |
| 45 |
int mapped = 0; /* window is mapped? */
| 46 |
unsigned long ourblack=0, ourwhite=~0;
| 47 |
| 48 |
Display *ourdisplay = NULL; /* our display */
| 49 |
XVisualInfo *ourvinf; /* our visual information */
| 50 |
Window gwind = 0; /* our graphics window */
| 51 |
int hres, vres; /* rendering window dimensions */
| 52 |
int maxhres, maxvres; /* maximum given dimensions */
| 53 |
GLXContext gctx; /* our GLX context */
| 54 |
| 55 |
double pwidth, pheight; /* pixel dimensions (mm) */
| 56 |
| 57 |
int headlocked = 0; /* lock vertical motion */
| 58 |
| 59 |
struct {
| 60 |
char *nam; /* view name (NULL if none) */
| 61 |
VIEW *v; /* parameters (NULL term.) */
| 62 |
} vwl[MAXVIEW+1]; /* our list of views */
| 63 |
| 64 |
int currentview = 0; /* current view number */
| 65 |
VIEW thisview = STDVIEW; /* displayed view */
| 66 |
double eyedist = 1; /* interocular distance */
| 67 |
VIEW lastview; /* last recorded view */
| 68 |
| 69 |
char *progname; /* global argv[0] */
| 70 |
char *radfile; /* rad input file */
| 71 |
char *scene[MAXSCENE+1]; /* material and scene file list */
| 72 |
int nscenef = 0; /* number of scene files */
| 73 |
char *octree; /* octree name (NULL if unnec.) */
| 74 |
| 75 |
int rtpd[3]; /* rtrace process descriptors */
| 76 |
| 77 |
int silent = 0; /* run rad silently? */
| 78 |
int backvis = 1; /* back faces visible? */
| 79 |
int stereo = 0; /* do stereo? */
| 80 |
| 81 |
#ifdef NOSTEREO
| 82 |
#define setstereobuf(bid) 0
| 83 |
#else
| 84 |
#define setstereobuf(bid) (glXWaitGL(), \
| 85 |
XSGISetStereoBuffer(ourdisplay, gwind, bid), \
| 86 |
glXWaitX())
| 87 |
#endif
| 88 |
| 89 |
int displist; /* our scene display list */
| 90 |
| 91 |
int no_render = 0; /* don't rerender */
| 92 |
| 93 |
#ifdef BSD
| 94 |
#define strchr index
| 95 |
#endif
| 96 |
| 97 |
extern char *strchr(), *fgets(), *fgetline(), *atos(), *scan4var();
| 98 |
extern int nowarn; /* turn warnings off? */
| 99 |
extern time_t time();
| 100 |
| 101 |
| 102 |
main(argc, argv)
| 103 |
int argc;
| 104 |
char *argv[];
| 105 |
| 106 |
char *viewsel = NULL;
| 107 |
long vwintvl = 0;
| 108 |
int i;
| 109 |
| 110 |
progname = argv[0];
| 111 |
for (i = 1; i < argc && argv[i][0] == '-'; i++)
| 112 |
switch (argv[i][1]) {
| 113 |
case 'v':
| 114 |
viewsel = argv[++i];
| 115 |
break;
| 116 |
case 'w':
| 117 |
nowarn = !nowarn;
| 118 |
break;
| 119 |
case 's':
| 120 |
silent = !silent;
| 121 |
break;
| 122 |
case 'S':
| 123 |
stereo = !stereo;
| 124 |
break;
| 125 |
case 'c':
| 126 |
vwintvl = atoi(argv[++i]);
| 127 |
break;
| 128 |
case 'b':
| 129 |
backvis = !backvis;
| 130 |
break;
| 131 |
default:
| 132 |
goto userr;
| 133 |
| 134 |
if (i >= argc)
| 135 |
goto userr;
| 136 |
#ifdef NOSTEREO
| 137 |
if (stereo)
| 138 |
error(INTERNAL, "stereo not supported in this version");
| 139 |
#endif
| 140 |
/* run rad and get views */
| 141 |
runrad(argc-i, argv+i);
| 142 |
/* check view */
| 143 |
if (viewsel != NULL)
| 144 |
if (viewsel[0] == '-') {
| 145 |
char *ve = viewsel;
| 146 |
if (!sscanview(&thisview, viewsel) ||
| 147 |
(ve = setview(&thisview)) != NULL) {
| 148 |
fprintf(stderr, "%s: bad view: %s\n",
| 149 |
progname, ve);
| 150 |
quit(1);
| 151 |
| 152 |
currentview = -1;
| 153 |
} else if ((currentview = findvw(viewsel)) < 0) {
| 154 |
fprintf(stderr, "%s: no such view: %s\n",
| 155 |
progname, viewsel);
| 156 |
quit(1);
| 157 |
| 158 |
/* open GL */
| 159 |
dev_open(radfile = argv[i]);
| 160 |
/* load octree or scene files */
| 161 |
if (octree != NULL) {
| 162 |
displist = rgl_octlist(octree, NULL, NULL, NULL);
| 163 |
startrtrace(octree);
| 164 |
} else
| 165 |
displist = rgl_filelist(nscenef, scene, NULL);
| 166 |
/* set initial view */
| 167 |
dev_view(currentview < 0 ? &thisview : vwl[currentview].v);
| 168 |
/* input/render loop */
| 169 |
while (dev_input(vwintvl))
| 170 |
| 171 |
/* all done */
| 172 |
quit(0);
| 173 |
userr:
| 174 |
fprintf(stderr,
| 175 |
"Usage: %s [-w][-s][-b][-S][-v view] rfile [VAR=value]..\n",
| 176 |
argv[0]);
| 177 |
quit(1);
| 178 |
| 179 |
| 180 |
| 181 |
void
| 182 |
quit(code) /* exit gracefully */
| 183 |
int code;
| 184 |
| 185 |
if (ourdisplay != NULL)
| 186 |
dev_close();
| 187 |
if (rtpd[2] > 0) {
| 188 |
if (close_process(rtpd) > 0)
| 189 |
wputs("bad exit status from rtrace\n");
| 190 |
rtpd[2] = 0;
| 191 |
| 192 |
exit(code);
| 193 |
| 194 |
| 195 |
| 196 |
startrtrace(octname) /* start rtrace on octname */
| 197 |
char *octname;
| 198 |
| 199 |
static char *av[12] = {"rtrace", "-h", "-fff", "-ld+",
| 200 |
"-opL", "-x", "1"};
| 201 |
int ac = 7;
| 202 |
| 203 |
if (nowarn) av[ac++] = "-w-";
| 204 |
av[ac++] = octname;
| 205 |
av[ac] = NULL;
| 206 |
if (open_process(rtpd, av) <= 0)
| 207 |
error(SYSTEM, "cannot start rtrace process");
| 208 |
| 209 |
| 210 |
| 211 |
runrad(ac, av) /* run rad and load variables */
| 212 |
int ac;
| 213 |
char **av;
| 214 |
| 215 |
static char optfile[] = TEMPLATE;
| 216 |
int nvn = 0, nvv = 0;
| 217 |
FILE *fp;
| 218 |
int cval;
| 219 |
register char *cp;
| 220 |
char radcomm[256], buf[128], nam[32];
| 221 |
/* set rad commmand */
| 222 |
strcpy(radcomm, "rad -w -v 0 "); /* look out below! */
| 223 |
cp = radcomm + 19;
| 224 |
if (silent) {
| 225 |
strcpy(cp, "-s ");
| 226 |
cp += 3;
| 227 |
| 228 |
while (ac--) {
| 229 |
strcpy(cp, *av++);
| 230 |
while (*cp) cp++;
| 231 |
*cp++ = ' ';
| 232 |
| 233 |
strcpy(cp, "OPTFILE="); /* create temporary options file */
| 234 |
strcpy(cp+8, mktemp(optfile));
| 235 |
if (system(radcomm)) /* update octree */
| 236 |
error(USER, "error executing rad command");
| 237 |
/* replace "-v 0" with "-n -e -s -V" */
| 238 |
strcpy(radcomm+7, "-n -e -s -V");
| 239 |
radcomm[18] = ' ';
| 240 |
if ((fp = popen(radcomm, "r")) == NULL)
| 241 |
error(SYSTEM, "cannot start rad command");
| 242 |
buf[0] = '\0'; /* read variables alphabetically */
| 243 |
/* get exposure */
| 244 |
if ((cp = scan4var(buf, sizeof(buf), "EXPOSURE", fp)) != NULL) {
| 245 |
expval = atof(cp);
| 246 |
if (*cp == '-' | *cp == '+')
| 247 |
expval = pow(2., expval);
| 248 |
expval *= 0.5; /* compensate for local shading */
| 249 |
| 250 |
/* look for eye separation */
| 251 |
if ((cp = scan4var(buf, sizeof(buf), "EYESEP", fp)) != NULL)
| 252 |
eyedist = atof(cp);
| 253 |
/* look for materials */
| 254 |
while ((cp = scan4var(buf, sizeof(buf), "materials", fp)) != NULL) {
| 255 |
nscenef += wordstring(scene+nscenef, cp);
| 256 |
buf[0] = '\0';
| 257 |
| 258 |
/* look for octree */
| 259 |
if ((cp = scan4var(buf, sizeof(buf), "OCTREE", fp)) != NULL)
| 260 |
octree = savqstr(cp);
| 261 |
/* look for scene files */
| 262 |
while ((cp = scan4var(buf, sizeof(buf), "scene", fp)) != NULL) {
| 263 |
| 264 |
buf[0] = '\0';
| 265 |
| 266 |
/* load view names */
| 267 |
while ((cp = scan4var(buf, sizeof(buf), "view", fp)) != NULL) {
| 268 |
if (nvn >= MAXVIEW)
| 269 |
error(INTERNAL, "too many views in rad file");
| 270 |
vwl[nvn++].nam = *cp == '-' ? (char *)NULL :
| 271 |
savqstr(atos(nam, sizeof(nam), cp));
| 272 |
buf[0] = '\0';
| 273 |
| 274 |
/* load actual views */
| 275 |
do
| 276 |
if (isview(buf)) {
| 277 |
vwl[nvv].v = (VIEW *)bmalloc(sizeof(VIEW));
| 278 |
copystruct(vwl[nvv].v, &stdview);
| 279 |
sscanview(vwl[nvv].v, buf);
| 280 |
if ((cp = setview(vwl[nvv++].v)) != NULL) {
| 281 |
fprintf(stderr, "%s: bad view %d - %s\n",
| 282 |
progname, nvv, cp);
| 283 |
quit(1);
| 284 |
| 285 |
| 286 |
while (fgets(buf, sizeof(buf), fp) != NULL);
| 287 |
if (nvv != nvn)
| 288 |
error(INTERNAL, "view miscount in runrad");
| 289 |
pclose(fp);
| 290 |
/* open options file */
| 291 |
if ((fp = fopen(optfile, "r")) == NULL)
| 292 |
error(SYSTEM, "cannot open options file");
| 293 |
/* get relevant options */
| 294 |
| 295 |
if (!strncmp(buf, "-av ", 4))
| 296 |
setcolor(ambval, atof(buf+4),
| 297 |
atof(sskip2(buf+4,1)),
| 298 |
atof(sskip2(buf+4,2)));
| 299 |
else if (backvis && !strncmp(buf, "-bv", 3) &&
| 300 |
(!buf[3] || strchr("0-FfNn \n",buf[3])!=NULL))
| 301 |
backvis = 0;
| 302 |
fclose(fp);
| 303 |
unlink(optfile); /* delete options file */
| 304 |
| 305 |
| 306 |
| 307 |
int
| 308 |
findvw(nm) /* find named view */
| 309 |
register char *nm;
| 310 |
| 311 |
register int n;
| 312 |
| 313 |
if (*nm >= '1' & *nm <= '9' &&
| 314 |
(n = atoi(nm)-1) <= MAXVIEW && vwl[n].v != NULL)
| 315 |
return(n);
| 316 |
for (n = 0; vwl[n].v != NULL; n++)
| 317 |
if (vwl[n].nam != NULL && !strcmp(nm, vwl[n].nam))
| 318 |
return(n);
| 319 |
return(-1);
| 320 |
| 321 |
| 322 |
| 323 |
int
| 324 |
varmatch(s, vn) /* match line to variable */
| 325 |
register char *s, *vn;
| 326 |
| 327 |
register int c;
| 328 |
| 329 |
for ( ; *vn && *s == *vn; s++, vn++)
| 330 |
| 331 |
while (isspace(*s))
| 332 |
s++;
| 333 |
if (*s == '=')
| 334 |
return(*vn);
| 335 |
while (!(c = toupper(*s++) - toupper(*vn)) && *vn++)
| 336 |
| 337 |
return(c);
| 338 |
| 339 |
| 340 |
| 341 |
char *
| 342 |
scan4var(buf, buflen, vname, fp) /* scan for variable from fp */
| 343 |
char *buf;
| 344 |
int buflen;
| 345 |
char *vname;
| 346 |
FILE *fp;
| 347 |
| 348 |
int cval;
| 349 |
register char *cp;
| 350 |
/* search out matching line */
| 351 |
while ((cval = varmatch(buf, vname))) {
| 352 |
if (cval > 0) /* gone too far? */
| 353 |
return(NULL);
| 354 |
buf[0] = '\0'; /* else get next line */
| 355 |
if (fgetline(buf, buflen, fp) == NULL)
| 356 |
return(NULL);
| 357 |
| 358 |
/* skip variable name and '=' */
| 359 |
for (cp = buf; *cp++ != '='; )
| 360 |
| 361 |
while (isspace(*cp)) cp++;
| 362 |
return(cp);
| 363 |
| 364 |
| 365 |
| 366 |
dev_open(id) /* initialize GLX driver */
| 367 |
char *id;
| 368 |
| 369 |
static int atlBest[] = {GLX_RGBA, GLX_RED_SIZE,4,
| 370 |
GLX_GREEN_SIZE,4, GLX_BLUE_SIZE,4,
| 371 |
GLX_DOUBLEBUFFER, GLX_DEPTH_SIZE,15, None};
| 372 |
XSetWindowAttributes ourwinattr;
| 373 |
XWMHints ourxwmhints;
| 374 |
/* open display server */
| 375 |
ourdisplay = XOpenDisplay(NULL);
| 376 |
if (ourdisplay == NULL)
| 377 |
error(USER, "cannot open X-windows; DISPLAY variable set?\n");
| 378 |
/* find a usable visual */
| 379 |
ourvinf = glXChooseVisual(ourdisplay, ourscreen, atlBest);
| 380 |
if (ourvinf == NULL)
| 381 |
error(USER, "no suitable visuals available");
| 382 |
/* get a context */
| 383 |
gctx = glXCreateContext(ourdisplay, ourvinf, NULL, GL_TRUE);
| 384 |
/* open window */
| 385 |
ourwinattr.background_pixel = ourblack;
| 386 |
ourwinattr.border_pixel = ourblack;
| 387 |
ourwinattr.event_mask = ourmask;
| 388 |
/* this is stupid */
| 389 |
ourwinattr.colormap = XCreateColormap(ourdisplay, ourroot,
| 390 |
ourvinf->visual, AllocNone);
| 391 |
gwind = XCreateWindow(ourdisplay, ourroot, 0, 0,
| 392 |
DisplayWidth(ourdisplay,ourscreen)-2*BORWIDTH,
| 393 |
DisplayHeight(ourdisplay,ourscreen)-2*BORWIDTH,
| 394 |
BORWIDTH, ourvinf->depth, InputOutput, ourvinf->visual,
| 395 |
CWBackPixel|CWBorderPixel|CWColormap|CWEventMask, &ourwinattr);
| 396 |
if (gwind == 0)
| 397 |
error(SYSTEM, "cannot create window\n");
| 398 |
XStoreName(ourdisplay, gwind, id);
| 399 |
#ifndef NOSTEREO
| 400 |
if (stereo) /* check if stereo working */
| 401 |
switch (XSGIQueryStereoMode(ourdisplay, gwind)) {
| 402 |
case STEREO_TOP:
| 403 |
case STEREO_BOTTOM:
| 404 |
break;
| 405 |
case STEREO_OFF:
| 406 |
error(USER,
| 407 |
"wrong video mode: run \"/usr/gfx/setmon -n STR_TOP\" first");
| 408 |
case X_STEREO_UNSUPPORTED:
| 409 |
error(USER, "stereo not supported on this screen");
| 410 |
default:
| 411 |
error(INTERNAL, "unknown stereo mode");
| 412 |
| 413 |
#endif
| 414 |
/* set window manager hints */
| 415 |
ourxwmhints.flags = InputHint|IconPixmapHint;
| 416 |
ourxwmhints.input = True;
| 417 |
ourxwmhints.icon_pixmap = XCreateBitmapFromData(ourdisplay,
| 418 |
gwind, glradicon_bits, glradicon_width, glradicon_height);
| 419 |
XSetWMHints(ourdisplay, gwind, &ourxwmhints);
| 420 |
/* set GLX context */
| 421 |
glXMakeCurrent(ourdisplay, gwind, gctx);
| 422 |
glEnable(GL_DEPTH_TEST);
| 423 |
glDepthFunc(GL_LESS);
| 424 |
glShadeModel(GL_SMOOTH);
| 425 |
glPolygonMode(GL_FRONT_AND_BACK, GL_FILL);
| 426 |
glLightModeli(GL_LIGHT_MODEL_TWO_SIDE, GL_TRUE);
| 427 |
glEnable(GL_LIGHTING);
| 428 |
glFrontFace(GL_CCW);
| 429 |
glCullFace(GL_BACK);
| 430 |
if (backvis)
| 431 |
glDisable(GL_CULL_FACE);
| 432 |
else
| 433 |
glEnable(GL_CULL_FACE);
| 434 |
glDrawBuffer(GL_BACK);
| 435 |
/* figure out sensible view */
| 436 |
pwidth = (double)DisplayWidthMM(ourdisplay, ourscreen) /
| 437 |
DisplayWidth(ourdisplay, ourscreen);
| 438 |
pheight = (double)DisplayHeightMM(ourdisplay, ourscreen) /
| 439 |
DisplayHeight(ourdisplay, ourscreen);
| 440 |
if (stereo) { /* set stereo mode */
| 441 |
setstereobuf(STEREO_BUFFER_LEFT);
| 442 |
pheight *= 2.;
| 443 |
| 444 |
/* map the window */
| 445 |
XMapWindow(ourdisplay, gwind);
| 446 |
no_render++;
| 447 |
do
| 448 |
dev_input(0); /* get resize event */
| 449 |
while (hres == 0 & vres == 0);
| 450 |
no_render--;
| 451 |
rgl_checkerr("initializing GLX");
| 452 |
| 453 |
| 454 |
| 455 |
dev_close() /* close our display and free resources */
| 456 |
| 457 |
glXMakeCurrent(ourdisplay, None, NULL);
| 458 |
glXDestroyContext(ourdisplay, gctx);
| 459 |
XDestroyWindow(ourdisplay, gwind);
| 460 |
gwind = 0;
| 461 |
XCloseDisplay(ourdisplay);
| 462 |
ourdisplay = NULL;
| 463 |
| 464 |
| 465 |
| 466 |
int
| 467 |
dev_view(nv) /* assign new driver view */
| 468 |
register VIEW *nv;
| 469 |
| 470 |
int newhres = hres, newvres = vres;
| 471 |
double wa, va;
| 472 |
/* check view legality */
| 473 |
if (nv->type != VT_PER) {
| 474 |
error(COMMAND, "illegal view type");
| 475 |
nv->type = VT_PER;
| 476 |
| 477 |
if (nv->horiz > 160. | nv->vert > 160.) {
| 478 |
error(COMMAND, "illegal view angle");
| 479 |
if (nv->horiz > 160.)
| 480 |
nv->horiz = 160.;
| 481 |
if (nv->vert > 160.)
| 482 |
nv->vert = 160.;
| 483 |
| 484 |
if (hres != 0 & vres != 0) {
| 485 |
wa = (vres*pheight)/(hres*pwidth);
| 486 |
va = viewaspect(nv);
| 487 |
if (va > wa+.05) {
| 488 |
newvres = (pwidth/pheight)*va*newhres + .5;
| 489 |
if (newvres > maxvres) {
| 490 |
newvres = maxvres;
| 491 |
newhres = (pheight/pwidth)/va*newvres + .5;
| 492 |
| 493 |
} else if (va < wa-.05) {
| 494 |
| 495 |
if (newhres > maxhres) {
| 496 |
newhres = maxhres;
| 497 |
| 498 |
| 499 |
| 500 |
if (newhres != hres | newvres != vres) {
| 501 |
no_render++;
| 502 |
XResizeWindow(ourdisplay, gwind, newhres, newvres);
| 503 |
do
| 504 |
| 505 |
while (newhres != hres | newvres != vres);
| 506 |
no_render--;
| 507 |
| 508 |
| 509 |
copystruct(&thisview, nv);
| 510 |
setglpersp(&thisview);
| 511 |
render();
| 512 |
return(1);
| 513 |
| 514 |
| 515 |
| 516 |
int
| 517 |
dev_input(nsecs) /* get next input event */
| 518 |
int nsecs;
| 519 |
| 520 |
#if 0
| 521 |
static time_t lasttime = 0;
| 522 |
time_t thistime;
| 523 |
| 524 |
if (nsecs > 0) {
| 525 |
thistime = time(0);
| 526 |
nsecs -= (long)(thistime - lasttime);
| 527 |
lasttime = thistime;
| 528 |
| 529 |
if (nsecs > 0)
| 530 |
alarm(nsecs);
| 531 |
#endif
| 532 |
XNextEvent(ourdisplay, levptr(XEvent));
| 533 |
switch (levptr(XEvent)->type) {
| 534 |
case ConfigureNotify:
| 535 |
resizewindow(levptr(XConfigureEvent));
| 536 |
break;
| 537 |
case UnmapNotify:
| 538 |
mapped = 0;
| 539 |
break;
| 540 |
case MapNotify:
| 541 |
mapped = 1;
| 542 |
break;
| 543 |
case Expose:
| 544 |
fixwindow(levptr(XExposeEvent));
| 545 |
break;
| 546 |
case KeyPress:
| 547 |
return(getkey(levptr(XKeyPressedEvent)));
| 548 |
case ButtonPress:
| 549 |
getmove(levptr(XButtonPressedEvent));
| 550 |
break;
| 551 |
| 552 |
return(1);
| 553 |
| 554 |
| 555 |
| 556 |
render() /* render our display list and swap buffers */
| 557 |
| 558 |
double d;
| 559 |
| 560 |
if (!mapped | no_render)
| 561 |
return;
| 562 |
glClear(GL_COLOR_BUFFER_BIT|GL_DEPTH_BUFFER_BIT);
| 563 |
glCallList(displist);
| 564 |
if (stereo) { /* do right eye for stereo */
| 565 |
setstereobuf(STEREO_BUFFER_RIGHT);
| 566 |
| 567 |
glMatrixMode(GL_MODELVIEW);
| 568 |
glPushMatrix();
| 569 |
d = -eyedist / sqrt(thisview.hn2);
| 570 |
glTranslated(d*thisview.hvec[0], d*thisview.hvec[1],
| 571 |
d*thisview.hvec[2]);
| 572 |
| 573 |
| 574 |
glPopMatrix();
| 575 |
| 576 |
| 577 |
glXSwapBuffers(ourdisplay, gwind); /* calls glFlush() */
| 578 |
rgl_checkerr("rendering display list");
| 579 |
| 580 |
| 581 |
| 582 |
moveview(dx, dy, mov, orb) /* move our view */
| 583 |
int dx, dy, mov, orb;
| 584 |
| 585 |
VIEW nv;
| 586 |
FVECT odir, v1, wp;
| 587 |
double d;
| 588 |
register int li;
| 589 |
/* start with old view */
| 590 |
copystruct(&nv, &thisview);
| 591 |
/* change view direction */
| 592 |
if ((d = viewray(v1, odir, &thisview,
| 593 |
(dx+.5)/hres, (dy+.5)/vres)) < -FTINY)
| 594 |
return(0); /* outside view */
| 595 |
if (mov | orb) {
| 596 |
if (!getintersect(wp, v1, odir, d))
| 597 |
return(0);
| 598 |
VSUM(odir, wp, nv.vp, -1.);
| 599 |
} else
| 600 |
VCOPY(nv.vdir, odir);
| 601 |
if (orb && mov) { /* orbit left/right */
| 602 |
spinvector(odir, odir, nv.vup, d=MOVDEG*PI/180.*mov);
| 603 |
VSUM(nv.vp, wp, odir, -1.);
| 604 |
spinvector(nv.vdir, nv.vdir, nv.vup, d);
| 605 |
} else if (orb) { /* orbit up/down */
| 606 |
fcross(v1, odir, nv.vup);
| 607 |
if (normalize(v1) == 0.)
| 608 |
return(0);
| 609 |
spinvector(odir, odir, v1, d=MOVDEG*PI/180.*orb);
| 610 |
| 611 |
spinvector(nv.vdir, nv.vdir, v1, d);
| 612 |
} else if (mov) { /* move forward/backward */
| 613 |
d = MOVPCT/100. * mov;
| 614 |
VSUM(nv.vp, nv.vp, odir, d);
| 615 |
| 616 |
if (!mov ^ !orb && headlocked) { /* restore head height */
| 617 |
VSUM(v1, thisview.vp, nv.vp, -1.);
| 618 |
d = DOT(v1, thisview.vup);
| 619 |
VSUM(nv.vp, nv.vp, thisview.vup, d);
| 620 |
| 621 |
if (setview(&nv) != NULL)
| 622 |
return(0); /* illegal view */
| 623 |
dev_view(&nv);
| 624 |
return(1);
| 625 |
| 626 |
| 627 |
| 628 |
static
| 629 |
waitabit() /* pause a moment */
| 630 |
| 631 |
struct timespec ts;
| 632 |
ts.tv_sec = 0;
| 633 |
ts.tv_nsec = 5000000;
| 634 |
nanosleep(&ts, NULL);
| 635 |
| 636 |
| 637 |
| 638 |
getmove(ebut) /* get view change */
| 639 |
XButtonPressedEvent *ebut;
| 640 |
| 641 |
int movdir = MOVDIR(ebut->button);
| 642 |
int movorb = MOVORB(ebut->state);
| 643 |
int moved = 0;
| 644 |
Window rootw, childw;
| 645 |
int rootx, rooty, wx, wy;
| 646 |
unsigned int statemask;
| 647 |
| 648 |
copylastv( movorb ? (movdir ? "left/right" : "up/down") :
| 649 |
(movdir ? "fore/back" : "rotate") );
| 650 |
XNoOp(ourdisplay);
| 651 |
| 652 |
while (!XCheckMaskEvent(ourdisplay,
| 653 |
ButtonReleaseMask, levptr(XEvent))) {
| 654 |
/* pause so as not to move too fast */
| 655 |
waitabit();
| 656 |
| 657 |
if (!XQueryPointer(ourdisplay, gwind, &rootw, &childw,
| 658 |
&rootx, &rooty, &wx, &wy, &statemask))
| 659 |
break; /* on another screen */
| 660 |
| 661 |
if (!moveview(wx, vres-1-wy, movdir, movorb)) {
| 662 |
sleep(1);
| 663 |
continue;
| 664 |
} else
| 665 |
moved++;
| 666 |
| 667 |
if (!moved) { /* do final motion */
| 668 |
movdir = MOVDIR(levptr(XButtonReleasedEvent)->button);
| 669 |
wx = levptr(XButtonReleasedEvent)->x;
| 670 |
wy = levptr(XButtonReleasedEvent)->y;
| 671 |
moveview(wx, vres-1-wy, movdir, movorb);
| 672 |
| 673 |
| 674 |
| 675 |
| 676 |
getintersect(wp, org, dir, md) /* intersect ray with scene geometry */
| 677 |
FVECT wp; /* returned world intersection point */
| 678 |
FVECT org, dir;
| 679 |
double md;
| 680 |
| 681 |
float fbuf[6];
| 682 |
/* check to see if rtrace is running */
| 683 |
if (rtpd[2] <= 0)
| 684 |
return(0);
| 685 |
/* assign origin */
| 686 |
fbuf[0] = org[0]; fbuf[1] = org[1]; fbuf[2] = org[2];
| 687 |
/* compute clipping distance */
| 688 |
if (md <= FTINY) md = FHUGE;
| 689 |
fbuf[3] = dir[0]*md; fbuf[4] = dir[1]*md; fbuf[5] = dir[2]*md;
| 690 |
/* trace that ray */
| 691 |
if (process(rtpd, (char *)fbuf, (char *)fbuf,
| 692 |
4*sizeof(float), 6*sizeof(float)) != 4*sizeof(float))
| 693 |
error(INTERNAL, "error getting data back from rtrace process");
| 694 |
if (fbuf[3] >= .99*FHUGE)
| 695 |
return(0); /* missed local objects */
| 696 |
wp[0] = fbuf[0]; wp[1] = fbuf[1]; wp[2] = fbuf[2];
| 697 |
return(1); /* else return world intersection */
| 698 |
| 699 |
| 700 |
| 701 |
setglpersp(vp) /* set perspective view in GL */
| 702 |
register VIEW *vp;
| 703 |
| 704 |
double d, xmin, xmax, ymin, ymax, zmin, zmax;
| 705 |
| 706 |
zmin = 0.1;
| 707 |
zmax = 1000.;
| 708 |
if (thisview.vfore > FTINY)
| 709 |
zmin = thisview.vfore;
| 710 |
if (thisview.vaft > FTINY)
| 711 |
zmax = thisview.vaft;
| 712 |
xmax = zmin * tan(PI/180./2. * thisview.horiz);
| 713 |
xmin = -xmax;
| 714 |
d = thisview.hoff * (xmax - xmin);
| 715 |
xmin += d; xmax += d;
| 716 |
ymax = zmin * tan(PI/180./2. * thisview.vert);
| 717 |
ymin = -ymax;
| 718 |
d = thisview.voff * (ymax - ymin);
| 719 |
ymin += d; ymax += d;
| 720 |
/* set view matrix */
| 721 |
glMatrixMode(GL_PROJECTION);
| 722 |
glLoadIdentity();
| 723 |
glFrustum(xmin, xmax, ymin, ymax, zmin, zmax);
| 724 |
gluLookAt(thisview.vp[0], thisview.vp[1], thisview.vp[2],
| 725 |
thisview.vp[0] + thisview.vdir[0],
| 726 |
thisview.vp[1] + thisview.vdir[1],
| 727 |
thisview.vp[2] + thisview.vdir[2],
| 728 |
thisview.vup[0], thisview.vup[1], thisview.vup[2]);
| 729 |
rgl_checkerr("setting perspective view");
| 730 |
| 731 |
| 732 |
| 733 |
int
| 734 |
getkey(ekey) /* get input key */
| 735 |
register XKeyPressedEvent *ekey;
| 736 |
| 737 |
int n;
| 738 |
char buf[8];
| 739 |
| 740 |
n = XLookupString(ekey, buf, sizeof(buf), NULL, NULL);
| 741 |
if (n != 1)
| 742 |
return(1);
| 743 |
switch (buf[0]) {
| 744 |
case 'h': /* turn on height motion lock */
| 745 |
headlocked = 1;
| 746 |
break;
| 747 |
case 'H': /* turn off height motion lock */
| 748 |
headlocked = 0;
| 749 |
break;
| 750 |
case 'l': /* retrieve last (premouse) view */
| 751 |
if (lastview.type) {
| 752 |
VIEW vtmp;
| 753 |
copystruct(&vtmp, &thisview);
| 754 |
dev_view(&lastview);
| 755 |
copystruct(&lastview, &vtmp);
| 756 |
} else
| 757 |
XBell(ourdisplay, 0);
| 758 |
break;
| 759 |
case 'n': /* move to next standard view */
| 760 |
gotoview(currentview+1);
| 761 |
break;
| 762 |
case 'p': /* move to last standard view */
| 763 |
gotoview(currentview-1);
| 764 |
break;
| 765 |
case '+': /* zoom in */
| 766 |
zoomview(100+ZOOMPCT, ekey->x, vres-1-ekey->y);
| 767 |
break;
| 768 |
case '-': /* zoom out */
| 769 |
zoomview(100-ZOOMPCT, ekey->x, vres-1-ekey->y);
| 770 |
break;
| 771 |
case 'v': /* spit current view to stdout */
| 772 |
fputs(VIEWSTR, stdout);
| 773 |
fprintview(&thisview, stdout);
| 774 |
fputc('\n', stdout);
| 775 |
break;
| 776 |
case 'V': /* append view to rad file */
| 777 |
appendview(NULL, &thisview);
| 778 |
break;
| 779 |
case 'q': /* quit the program */
| 780 |
return(0);
| 781 |
default:
| 782 |
| 783 |
break;
| 784 |
| 785 |
return(1);
| 786 |
| 787 |
| 788 |
| 789 |
zoomview(pct, dx, dy) /* zoom in or out around (dx,dy) */
| 790 |
int pct;
| 791 |
int dx, dy;
| 792 |
| 793 |
double h, v;
| 794 |
FVECT direc;
| 795 |
| 796 |
if (pct == 100 | pct <= 0)
| 797 |
return;
| 798 |
copylastv("zooming");
| 799 |
h = (dx+.5)/hres - 0.5;
| 800 |
v = (dy+.5)/vres - 0.5;
| 801 |
h *= (1. - 100./pct);
| 802 |
v *= (1. - 100./pct);
| 803 |
thisview.vdir[0] += h*thisview.hvec[0] + v*thisview.vvec[0];
| 804 |
thisview.vdir[1] += h*thisview.hvec[1] + v*thisview.vvec[1];
| 805 |
thisview.vdir[2] += h*thisview.hvec[2] + v*thisview.vvec[2];
| 806 |
thisview.horiz = 2.*180./PI * atan( 100./pct *
| 807 |
tan(PI/180./2.*thisview.horiz) );
| 808 |
thisview.vert = 2.*180./PI * atan( 100./pct *
| 809 |
tan(PI/180./2.*thisview.vert) );
| 810 |
setview(&thisview);
| 811 |
dev_view(&thisview);
| 812 |
| 813 |
| 814 |
| 815 |
gotoview(vwnum) /* go to specified view number */
| 816 |
int vwnum;
| 817 |
| 818 |
if (vwnum < 0)
| 819 |
for (vwnum = currentview; vwl[vwnum+1].v != NULL; vwnum++)
| 820 |
| 821 |
else if (vwnum >= MAXVIEW || vwl[vwnum].v == NULL)
| 822 |
vwnum = 0;
| 823 |
copylastv("standard view");
| 824 |
dev_view(vwl[currentview=vwnum].v);
| 825 |
| 826 |
| 827 |
| 828 |
appendview(nm, vp) /* append standard view */
| 829 |
char *nm;
| 830 |
VIEW *vp;
| 831 |
| 832 |
FILE *fp;
| 833 |
/* check if already in there */
| 834 |
if (!bcmp(&thisview, vwl[currentview].v, sizeof(VIEW))) {
| 835 |
error(COMMAND, "view already in standard list");
| 836 |
return;
| 837 |
| 838 |
/* append to file */
| 839 |
if ((fp = fopen(radfile, "a")) == NULL) {
| 840 |
error(COMMAND, "cannot append rad input file");
| 841 |
return;
| 842 |
| 843 |
fputs("view=", fp);
| 844 |
if (nm != NULL) {
| 845 |
fputc(' ', fp); fputs(nm, fp);
| 846 |
| 847 |
fprintview(vp, fp); fputc('\n', fp);
| 848 |
fclose(fp);
| 849 |
/* append to our list */
| 850 |
while (vwl[currentview].v != NULL)
| 851 |
currentview++;
| 852 |
if (currentview >= MAXVIEW)
| 853 |
error(INTERNAL, "too many views in appendview");
| 854 |
vwl[currentview].v = (VIEW *)bmalloc(sizeof(VIEW));
| 855 |
copystruct(vwl[currentview].v, &thisview);
| 856 |
if (nm != NULL)
| 857 |
vwl[currentview].nam = savqstr(nm);
| 858 |
| 859 |
| 860 |
| 861 |
copylastv(cause) /* copy last view position */
| 862 |
char *cause;
| 863 |
| 864 |
static char *lastvc;
| 865 |
| 866 |
if (cause == lastvc)
| 867 |
return; /* only record one view per cause */
| 868 |
lastvc = cause;
| 869 |
copystruct(&lastview, &thisview);
| 870 |
| 871 |
| 872 |
| 873 |
fixwindow(eexp) /* repair damage to window */
| 874 |
register XExposeEvent *eexp;
| 875 |
| 876 |
if (hres == 0 | vres == 0) { /* first exposure */
| 877 |
resizewindow((XConfigureEvent *)eexp);
| 878 |
return;
| 879 |
| 880 |
if (eexp->count) /* wait for final exposure */
| 881 |
return;
| 882 |
/* rerender everything */
| 883 |
render();
| 884 |
| 885 |
| 886 |
| 887 |
resizewindow(ersz) /* resize window */
| 888 |
register XConfigureEvent *ersz;
| 889 |
| 890 |
static char resizing[] = "resizing window";
| 891 |
double wa, va;
| 892 |
| 893 |
glViewport(0, 0, hres=ersz->width, vres=ersz->height);
| 894 |
if (hres > maxhres) maxhres = hres;
| 895 |
if (vres > maxvres) maxvres = vres;
| 896 |
if (no_render)
| 897 |
return;
| 898 |
| 899 |
va = viewaspect(&thisview);
| 900 |
if (va > wa+.05) {
| 901 |
copylastv(resizing);
| 902 |
| 903 |
atan( tan(PI/180./2. * thisview.horiz) * wa );
| 904 |
| 905 |
| 906 |
| 907 |
atan( tan(PI/180./2. * thisview.vert) / wa );
| 908 |
} else
| 909 |
return;
| 910 |
setview(&thisview);
| 911 |
| 912 |
