root/Development/ray/src/util/glrad.c
Tue Jun 3 21:31:51 2025 UTC (6 months, 3 weeks ago) by greg
CVS Tags: HEAD, rad6R0
Changes since 3.28: +3 -4 lines
Diff to previous 3.28 , to selected 3.13
Mon Jun 3 18:55:51 2024 UTC (18 months, 3 weeks ago) by greg
Changes since 3.27: +2 -2 lines
Diff to previous 3.27 , to selected 3.13
refactor: Changed buffer types in process(), readbuf(), writebuf()
Fri Feb 28 05:18:49 2020 UTC (5 years, 10 months ago) by greg
CVS Tags: rad5R3, rad5R4
Changes since 3.26: +4 -4 lines
Diff to previous 3.26 , to selected 3.13
Thu Apr 28 16:28:20 2016 UTC (9 years, 8 months ago) by greg
CVS Tags: rad5R1, rad5R2
Changes since 3.25: +17 -3 lines
Diff to previous 3.25 , to selected 3.13
Added listening for mouse wheel
Mon Apr 25 20:06:22 2016 UTC (9 years, 8 months ago) by greg
Changes since 3.24: +3 -3 lines
Diff to previous 3.24 , to selected 3.13
Tweaked speed parameters to slow things down a bit
Mon Apr 25 02:04:22 2016 UTC (9 years, 8 months ago) by greg
Changes since 3.23: +21 -21 lines
Diff to previous 3.23 , to selected 3.13
Punting because window size negotiation doesn't work as before
Mon Mar 21 19:06:08 2016 UTC (9 years, 9 months ago) by greg
Changes since 3.22: +3 -3 lines
Diff to previous 3.22 , to selected 3.13
Thu Sep 6 00:07:43 2012 UTC (13 years, 3 months ago) by greg
Changes since 3.21: +4 -5 lines
Diff to previous 3.21 , to selected 3.13
Sun Sep 26 15:47:33 2010 UTC (15 years, 3 months ago) by greg
Diff to previous 3.20 , to selected 3.13
Increased delays for slight improvement in interactive behavior
Sun Jul 24 19:53:08 2005 UTC (20 years, 5 months ago) by greg
Changes since 3.19: +3 -3 lines
Diff to previous 3.19 , to selected 3.13
Fri Mar 26 23:34:23 2004 UTC (21 years, 9 months ago) by schorsch
Changes since 3.18: +4 -3 lines
Diff to previous 3.18 , to selected 3.13
Continued ANSIfication.
Fri Jan 2 12:51:54 2004 UTC (22 years ago) by schorsch
Changes since 3.17: +136 -73 lines
Diff to previous 3.17 , to selected 3.13
Ansification.
Mon Jul 21 22:30:19 2003 UTC (22 years, 5 months ago) by schorsch
Changes since 3.16: +10 -10 lines
Diff to previous 3.16 , to selected 3.13
Mon Jun 30 14:59:13 2003 UTC (22 years, 6 months ago) by schorsch
Changes since 3.15: +3 -2 lines
Diff to previous 3.15 , to selected 3.13
Thu Jun 26 00:58:11 2003 UTC (22 years, 6 months ago) by schorsch
Changes since 3.14: +12 -8 lines
Diff to previous 3.14 , to selected 3.13
Mon May 19 16:32:19 2003 UTC (22 years, 7 months ago) by greg
Changes since 3.13: +1 -6 lines
Diff to previous 3.13
Eliminated unnecessary and problematic external function declarations
Revision 3.13 - (view) (download) (annotate) - [selected]
Sat Feb 22 02:07:30 2003 UTC (22 years, 10 months ago) by greg
Changes since 3.12: +17 -6 lines
Diff to previous 3.12
Fri Jan 29 15:28:36 1999 UTC (26 years, 11 months ago) by gwlarson
Diff to previous 3.11 , to selected 3.13
return number of lists allocated for proper deallocation
Wed Oct 21 17:48:51 1998 UTC (27 years, 2 months ago) by gwlarson
Changes since 3.10: +3 -3 lines
Diff to previous 3.10 , to selected 3.13
modifications to avoid problems with redeclared BYTE type
Thu Oct 15 08:30:48 1998 UTC (27 years, 2 months ago) by gwlarson
Diff to previous 3.9 , to selected 3.13
fixed minor bug that made back face culling fail for -bv option
Wed Jul 15 17:51:13 1998 UTC (27 years, 5 months ago) by gwlarson
Changes since 3.8: +3 -4 lines
Diff to previous 3.8 , to selected 3.13
minor cosmetic changes
Wed Jul 8 18:00:39 1998 UTC (27 years, 5 months ago) by gwlarson
Changes since 3.7: +2 -1 lines
Diff to previous 3.7 , to selected 3.13
fixed usage message
Tue Jul 7 08:58:34 1998 UTC (27 years, 5 months ago) by gwlarson
Changes since 3.6: +1 -1 lines
Diff to previous 3.6 , to selected 3.13
minor bug fix in GL call
Fri Jun 19 11:29:50 1998 UTC (27 years, 6 months ago) by gwlarson
Changes since 3.5: +0 -2 lines
Diff to previous 3.5 , to selected 3.13
got rid of problematic test in gotoview() which failed for single views
Thu Jun 18 17:18:27 1998 UTC (27 years, 6 months ago) by gwlarson
Changes since 3.4: +7 -13 lines
Diff to previous 3.4 , to selected 3.13
fixed rendering lockup problem
Wed Jun 10 17:52:18 1998 UTC (27 years, 6 months ago) by gwlarson
Changes since 3.3: +77 -7 lines
Diff to previous 3.3 , to selected 3.13
added stereo viewing with -S option
added -s option for silent running
added check of render options for -bv-
Tue Jun 9 15:16:55 1998 UTC (27 years, 6 months ago) by gwlarson
Changes since 3.2: +23 -7 lines
Diff to previous 3.2 , to selected 3.13
more viewing fixes -- changed -v option to allow views\
Tue Jun 9 12:46:45 1998 UTC (27 years, 6 months ago) by gwlarson
Changes since 3.1: +13 -5 lines
Diff to previous 3.1 , to selected 3.13
minor viewing fixes
Tue Jun 9 11:43:18 1998 UTC (27 years, 6 months ago) by gwlarson
Diff to selected 3.13
