root/radiance/ray/src/util/glrad.c
Revision: 3.3
Committed: Tue Jun 9 15:16:55 1998 UTC (25 years, 11 months ago) by gwlarson
Changes since 3.2: +23 -7 lines
more viewing fixes -- changed -v option to allow views\
1 /* Copyright (c) 1998 Silicon Graphics, Inc. */
2
3 #ifndef lint
4 static char SCCSid[] = "$SunId$ SGI";
5 #endif
6
7 /*
8 * Program to display Radiance scene using OpenGL.
9 */
10
11 #include "radogl.h"
12 #include "view.h"
13 #include "paths.h"
14 #include <sys/types.h>
15 #include <GL/glx.h>
16 #include <ctype.h>
17 #include "glradicon.h"
18
19 #ifndef MAXVIEW
20 #define MAXVIEW 63 /* maximum number of standard views */
21 #endif
22 #ifndef MAXSCENE
23 #define MAXSCENE 127 /* maximum number of scene files */
24 #endif
25
26 #define ZOOMPCT 9 /* percent to zoom at a time */
27
28 #define MOVPCT 7 /* percent distance to move /frame */
29 #define MOVDIR(b) ((b)==Button1 ? 1 : (b)==Button2 ? 0 : -1)
30 #define MOVDEG (-5) /* degrees to orbit CW/down /frame */
31 #define MOVORB(s) ((s)&ShiftMask ? 1 : (s)&ControlMask ? -1 : 0)
32
33 #define MINWIDTH 480 /* minimum graphics window width */
34 #define MINHEIGHT 400 /* minimum graphics window height */
35
36 #define BORWIDTH 5 /* border width */
37
38 #define ourscreen DefaultScreen(ourdisplay)
39 #define ourroot RootWindow(ourdisplay,ourscreen)
40 #define ourmask (StructureNotifyMask|ExposureMask|KeyPressMask|\
41 ButtonPressMask|ButtonReleaseMask)
42
43 #define levptr(etype) ((etype *)&currentevent)
44
45 XEvent currentevent; /* current event */
46
47 int mapped = 0; /* window is mapped? */
48 unsigned long ourblack=0, ourwhite=~0;
49
50 Display *ourdisplay = NULL; /* our display */
51 XVisualInfo *ourvinf; /* our visual information */
52 Window gwind = 0; /* our graphics window */
53 int hres, vres; /* rendering window dimensions */
54 int maxhres, maxvres; /* maximum given dimensions */
55 GLXContext gctx; /* our GLX context */
56
57 double pwidth, pheight; /* pixel dimensions (mm) */
58
59 int headlocked = 0; /* lock vertical motion */
60
61 struct {
62 char *nam; /* view name (NULL if none) */
63 VIEW *v; /* parameters (NULL term.) */
64 } vwl[MAXVIEW+1]; /* our list of views */
65
66 int currentview = 0; /* current view number */
67 VIEW thisview = STDVIEW; /* displayed view */
68 VIEW lastview; /* last recorded view */
69
70 char *progname; /* global argv[0] */
71 char *radfile; /* rad input file */
72 char *scene[MAXSCENE+1]; /* material and scene file list */
73 int nscenef = 0; /* number of scene files */
74 char *octree; /* octree name (NULL if unnec.) */
75
76 int rtpd[3]; /* rtrace process descriptors */
77
78 int backvis = 1; /* back faces visible? */
79
80 int displist; /* our scene display list */
81
82 int in_dev_view = 0; /* currently in dev_view() */
83
84 extern char *fgets(), *fgetline(), *atos(), *scan4var();
85 extern int nowarn; /* turn warnings off? */
86 extern time_t time();
87
88
89 main(argc, argv)
90 int argc;
91 char *argv[];
92 {
93 char *viewsel = NULL;
94 long vwintvl = 0;
95 int i;
96
97 progname = argv[0];
98 for (i = 1; i < argc && argv[i][0] == '-'; i++)
99 switch (argv[i][1]) {
100 case 'v':
101 viewsel = argv[++i];
102 break;
103 case 'w':
104 nowarn = !nowarn;
105 break;
106 case 'c':
107 vwintvl = atoi(argv[++i]);
108 break;
109 case 'b':
110 backvis = !backvis;
111 break;
112 default:
113 goto userr;
114 }
115 if (i >= argc)
116 goto userr;
117 /* run rad and get views */
118 runrad(argc-i, argv+i);
119 /* check view */
120 if (viewsel != NULL)
121 if (viewsel[0] == '-') {
122 char *ve = viewsel;
123 if (!sscanview(&thisview, viewsel) ||
124 (ve = setview(&thisview)) != NULL) {
125 fprintf(stderr, "%s: bad view: %s\n",
126 progname, ve);
127 quit(1);
128 }
129 currentview = -1;
130 } else if ((currentview = findvw(viewsel)) < 0) {
131 fprintf(stderr, "%s: no such view: %s\n",
132 progname, viewsel);
133 quit(1);
134 }
135 /* open GL */
136 dev_open(radfile = argv[i]);
137 /* load octree or scene files */
138 if (octree != NULL) {
139 displist = rgl_octlist(octree, NULL, NULL);
140 startrtrace(octree);
141 } else
142 displist = rgl_filelist(nscenef, scene);
143 /* set initial view */
144 dev_view(currentview < 0 ? &thisview : vwl[currentview].v);
145 /* input/render loop */
146 while (dev_input(vwintvl))
147 ;
148 /* all done */
149 quit(0);
150 userr:
151 fprintf(stderr, "Usage: %s [-w][-b][-v view] rfile [VAR=value]..\n",
152 argv[0]);
153 quit(1);
154 }
155
156
157 quit(code) /* exit gracefully */
158 int code;
159 {
160 if (ourdisplay != NULL)
161 dev_close();
162 if (rtpd[2] > 0) {
163 if (close_process(rtpd) > 0)
164 wputs("bad exit status from rtrace\n");
165 rtpd[2] = 0;
166 }
167 exit(code);
168 }
169
170
171 startrtrace(octname) /* start rtrace on octname */
172 char *octname;
173 {
174 static char *av[12] = {"rtrace", "-h", "-fff", "-ld+",
175 "-opL", "-x", "1"};
176 int ac = 7;
177
178 if (nowarn) av[ac++] = "-w-";
179 av[ac++] = octname;
180 av[ac] = NULL;
181 if (open_process(rtpd, av) <= 0)
182 error(SYSTEM, "cannot start rtrace process");
183 }
184
185
186 runrad(ac, av) /* run rad and load variables */
187 int ac;
188 char **av;
189 {
190 static char optfile[] = TEMPLATE;
191 int nvn = 0, nvv = 0;
192 FILE *fp;
193 int cval;
194 register char *cp;
195 char radcomm[256], buf[128], nam[32];
196 /* set rad commmand */
197 strcpy(radcomm, "rad -w -v 0 "); /* look out below! */
198 cp = radcomm + 19;
199 while (ac--) {
200 strcpy(cp, *av++);
201 while (*cp) cp++;
202 *cp++ = ' ';
203 }
204 strcpy(cp, "OPTFILE="); /* create temporary options file */
205 strcpy(cp+8, mktemp(optfile));
206 if (system(radcomm)) /* update octree */
207 error(USER, "error executing rad command");
208 /* replace "-v 0" with "-n -e -s -V" */
209 strcpy(radcomm+7, "-n -e -s -V");
210 radcomm[18] = ' ';
211 if ((fp = popen(radcomm, "r")) == NULL)
212 error(SYSTEM, "cannot start rad command");
213 buf[0] = '\0'; /* read variables alphabetically */
214 /* get exposure */
215 if ((cp = scan4var(buf, sizeof(buf), "EXPOSURE", fp)) != NULL) {
216 expval = atof(cp);
217 if (*cp == '-' | *cp == '+')
218 expval = pow(2., expval);
219 expval *= 0.5; /* compensate for local shading */
220 }
221 /* look for materials */
222 while ((cp = scan4var(buf, sizeof(buf), "materials", fp)) != NULL) {
223 nscenef += wordstring(scene+nscenef, cp);
224 buf[0] = '\0';
225 }
226 /* look for octree */
227 if ((cp = scan4var(buf, sizeof(buf), "OCTREE", fp)) != NULL)
228 octree = savqstr(cp);
229 /* look for scene files */
230 while ((cp = scan4var(buf, sizeof(buf), "scene", fp)) != NULL) {
231 nscenef += wordstring(scene+nscenef, cp);
232 buf[0] = '\0';
233 }
234 /* load view names */
235 while ((cp = scan4var(buf, sizeof(buf), "view", fp)) != NULL) {
236 if (nvn >= MAXVIEW)
237 error(INTERNAL, "too many views in rad file");
238 vwl[nvn++].nam = *cp == '-' ? (char *)NULL :
239 savqstr(atos(nam, sizeof(nam), cp));
240 buf[0] = '\0';
241 }
242 /* load actual views */
243 do
244 if (isview(buf)) {
245 vwl[nvv].v = (VIEW *)bmalloc(sizeof(VIEW));
246 copystruct(vwl[nvv].v, &stdview);
247 sscanview(vwl[nvv].v, buf);
248 if ((cp = setview(vwl[nvv++].v)) != NULL) {
249 fprintf(stderr, "%s: bad view %d - %s\n",
250 progname, nvv, cp);
251 quit(1);
252 }
253 }
254 while (fgets(buf, sizeof(buf), fp) != NULL);
255 if (nvv != nvn)
256 error(INTERNAL, "view miscount in runrad");
257 pclose(fp);
258 /* open options file */
259 if ((fp = fopen(optfile, "r")) == NULL)
260 error(SYSTEM, "cannot open options file");
261 /* get ambient value */
262 while (fgets(buf, sizeof(buf), fp) != NULL)
263 if (!strncmp(buf, "-av ", 4)) {
264 setcolor(ambval, atof(buf+4),
265 atof(sskip2(buf+4,1)),
266 atof(sskip2(buf+4,2)));
267 break;
268 }
269 fclose(fp);
270 unlink(optfile); /* delete options file */
271 }
272
273
274 int
275 findvw(nm) /* find named view */
276 register char *nm;
277 {
278 register int n;
279
280 if (*nm >= '1' & *nm <= '9' &&
281 (n = atoi(nm)-1) <= MAXVIEW && vwl[n].v != NULL)
282 return(n);
283 for (n = 0; vwl[n].v != NULL; n++)
284 if (vwl[n].nam != NULL && !strcmp(nm, vwl[n].nam))
285 return(n);
286 return(-1);
287 }
288
289
290 int
291 varmatch(s, vn) /* match line to variable */
292 register char *s, *vn;
293 {
294 register int c;
295
296 for ( ; *vn && *s == *vn; s++, vn++)
297 ;
298 while (isspace(*s))
299 s++;
300 if (*s == '=')
301 return(*vn);
302 while (!(c = toupper(*s++) - toupper(*vn)) && *vn++)
303 ;
304 return(c);
305 }
306
307
308 char *
309 scan4var(buf, buflen, vname, fp) /* scan for variable from fp */
310 char *buf;
311 int buflen;
312 char *vname;
313 FILE *fp;
314 {
315 int cval;
316 register char *cp;
317 /* search out matching line */
318 while ((cval = varmatch(buf, vname))) {
319 if (cval > 0) /* gone too far? */
320 return(NULL);
321 buf[0] = '\0'; /* else get next line */
322 if (fgetline(buf, buflen, fp) == NULL)
323 return(NULL);
324 }
325 /* skip variable name and '=' */
326 for (cp = buf; *cp++ != '='; )
327 ;
328 while (isspace(*cp)) cp++;
329 return(cp);
330 }
331
332
333 dev_open(id) /* initialize GLX driver */
334 char *id;
335 {
336 static int atlBest[] = {GLX_RGBA, GLX_RED_SIZE,4,
337 GLX_GREEN_SIZE,4, GLX_BLUE_SIZE,4,
338 GLX_DOUBLEBUFFER, GLX_DEPTH_SIZE,15, None};
339 XSetWindowAttributes ourwinattr;
340 XWMHints ourxwmhints;
341 XSizeHints oursizhints;
342 /* open display server */
343 ourdisplay = XOpenDisplay(NULL);
344 if (ourdisplay == NULL)
345 error(USER, "cannot open X-windows; DISPLAY variable set?\n");
346 /* find a usable visual */
347 ourvinf = glXChooseVisual(ourdisplay, ourscreen, atlBest);
348 if (ourvinf == NULL)
349 error(USER, "no suitable visuals available");
350 /* get a context */
351 gctx = glXCreateContext(ourdisplay, ourvinf, NULL, GL_TRUE);
352 /* open window */
353 ourwinattr.background_pixel = ourblack;
354 ourwinattr.border_pixel = ourblack;
355 ourwinattr.event_mask = ourmask;
356 /* this is stupid */
357 ourwinattr.colormap = XCreateColormap(ourdisplay, ourroot,
358 ourvinf->visual, AllocNone);
359 gwind = XCreateWindow(ourdisplay, ourroot, 0, 0,
360 DisplayWidth(ourdisplay,ourscreen)-2*BORWIDTH,
361 DisplayHeight(ourdisplay,ourscreen)-2*BORWIDTH,
362 BORWIDTH, ourvinf->depth, InputOutput, ourvinf->visual,
363 CWBackPixel|CWBorderPixel|CWColormap|CWEventMask, &ourwinattr);
364 if (gwind == 0)
365 error(SYSTEM, "cannot create window\n");
366 XStoreName(ourdisplay, gwind, id);
367 /* set window manager hints */
368 ourxwmhints.flags = InputHint|IconPixmapHint;
369 ourxwmhints.input = True;
370 ourxwmhints.icon_pixmap = XCreateBitmapFromData(ourdisplay,
371 gwind, glradicon_bits, glradicon_width, glradicon_height);
372 XSetWMHints(ourdisplay, gwind, &ourxwmhints);
373 oursizhints.min_width = MINWIDTH;
374 oursizhints.min_height = MINHEIGHT;
375 oursizhints.flags = PMinSize;
376 XSetNormalHints(ourdisplay, gwind, &oursizhints);
377 /* set GLX context */
378 glXMakeCurrent(ourdisplay, gwind, gctx);
379 glEnable(GL_DEPTH_TEST);
380 glDepthFunc(GL_LESS);
381 glShadeModel(GL_SMOOTH);
382 glPolygonMode(GL_FRONT_AND_BACK, GL_FILL);
383 glLightModelf(GL_LIGHT_MODEL_TWO_SIDE, GL_TRUE);
384 glEnable(GL_LIGHTING);
385 if (backvis)
386 glDisable(GL_CULL_FACE);
387 else {
388 glFrontFace(GL_CCW);
389 glCullFace(GL_BACK);
390 glEnable(GL_CULL_FACE);
391 }
392 glDrawBuffer(GL_BACK);
393 /* figure out sensible view */
394 pwidth = (double)DisplayWidthMM(ourdisplay, ourscreen) /
395 DisplayWidth(ourdisplay, ourscreen);
396 pheight = (double)DisplayHeightMM(ourdisplay, ourscreen) /
397 DisplayHeight(ourdisplay, ourscreen);
398 /* map the window */
399 XMapWindow(ourdisplay, gwind);
400 do
401 dev_input(0); /* get resize event */
402 while (hres == 0 & vres == 0);
403 rgl_checkerr("initializing GLX");
404 }
405
406
407 dev_close() /* close our display and free resources */
408 {
409 glXMakeCurrent(ourdisplay, None, NULL);
410 glXDestroyContext(ourdisplay, gctx);
411 XDestroyWindow(ourdisplay, gwind);
412 gwind = 0;
413 XCloseDisplay(ourdisplay);
414 ourdisplay = NULL;
415 }
416
417
418 int
419 dev_view(nv) /* assign new driver view */
420 register VIEW *nv;
421 {
422 int newhres = hres, newvres = vres;
423 double wa, va;
424 /* check view legality */
425 if (nv->type != VT_PER) {
426 error(COMMAND, "illegal view type");
427 nv->type = VT_PER;
428 }
429 if (nv->horiz > 160. | nv->vert > 160.) {
430 error(COMMAND, "illegal view angle");
431 if (nv->horiz > 160.)
432 nv->horiz = 160.;
433 if (nv->vert > 160.)
434 nv->vert = 160.;
435 }
436 if (hres != 0 & vres != 0) {
437 wa = (vres*pheight)/(hres*pwidth);
438 va = viewaspect(nv);
439 if (va > wa+.05) {
440 newvres = (pwidth/pheight)*va*newhres + .5;
441 if (newvres > maxvres) {
442 newvres = maxvres;
443 newhres = (pheight/pwidth)/va*newvres + .5;
444 }
445 } else if (va < wa-.05) {
446 newhres = (pheight/pwidth)/va*newvres + .5;
447 if (newhres > maxhres) {
448 newhres = maxhres;
449 newvres = (pwidth/pheight)*va*newhres + .5;
450 }
451 }
452 if (newhres != hres | newvres != vres) {
453 in_dev_view++;
454 XResizeWindow(ourdisplay, gwind, newhres, newvres);
455 do
456 dev_input(0); /* get resize event */
457 while (newhres != hres | newvres != vres);
458 in_dev_view--;
459 }
460 }
461 copystruct(&thisview, nv);
462 setglpersp(&thisview);
463 render();
464 return(1);
465 }
466
467
468 int
469 dev_input(nsecs) /* get next input event */
470 int nsecs;
471 {
472 #if 0
473 static time_t lasttime = 0;
474 time_t thistime;
475
476 if (nsecs > 0) {
477 thistime = time(0);
478 nsecs -= (long)(thistime - lasttime);
479 lasttime = thistime;
480 }
481 if (nsecs > 0)
482 alarm(nsecs);
483 #endif
484 XNextEvent(ourdisplay, levptr(XEvent));
485 switch (levptr(XEvent)->type) {
486 case ConfigureNotify:
487 resizewindow(levptr(XConfigureEvent));
488 break;
489 case UnmapNotify:
490 mapped = 0;
491 break;
492 case MapNotify:
493 mapped = 1;
494 break;
495 case Expose:
496 fixwindow(levptr(XExposeEvent));
497 break;
498 case KeyPress:
499 return(getkey(levptr(XKeyPressedEvent)));
500 case ButtonPress:
501 getmove(levptr(XButtonPressedEvent));
502 break;
503 }
504 return(1);
505 }
506
507
508 render() /* render our display list and swap buffers */
509 {
510 if (!mapped)
511 return;
512 glClear(GL_COLOR_BUFFER_BIT|GL_DEPTH_BUFFER_BIT);
513 glCallList(displist);
514 glXSwapBuffers(ourdisplay, gwind); /* calls glFlush() */
515 rgl_checkerr("rendering display list");
516 }
517
518
519 moveview(dx, dy, mov, orb) /* move our view */
520 int dx, dy, mov, orb;
521 {
522 VIEW nv;
523 FVECT odir, v1, wp;
524 double d;
525 register int li;
526 /* start with old view */
527 copystruct(&nv, &thisview);
528 /* change view direction */
529 if ((d = viewray(v1, odir, &thisview,
530 (dx+.5)/hres, (dy+.5)/vres)) < -FTINY)
531 return(0); /* outside view */
532 if (mov | orb) {
533 if (!getintersect(wp, v1, odir, d))
534 return(0);
535 VSUM(odir, wp, nv.vp, -1.);
536 } else
537 VCOPY(nv.vdir, odir);
538 if (orb && mov) { /* orbit left/right */
539 spinvector(odir, odir, nv.vup, d=MOVDEG*PI/180.*mov);
540 VSUM(nv.vp, wp, odir, -1.);
541 spinvector(nv.vdir, nv.vdir, nv.vup, d);
542 } else if (orb) { /* orbit up/down */
543 fcross(v1, odir, nv.vup);
544 if (normalize(v1) == 0.)
545 return(0);
546 spinvector(odir, odir, v1, d=MOVDEG*PI/180.*orb);
547 VSUM(nv.vp, wp, odir, -1.);
548 spinvector(nv.vdir, nv.vdir, v1, d);
549 } else if (mov) { /* move forward/backward */
550 d = MOVPCT/100. * mov;
551 VSUM(nv.vp, nv.vp, odir, d);
552 }
553 if (!mov ^ !orb && headlocked) { /* restore head height */
554 VSUM(v1, thisview.vp, nv.vp, -1.);
555 d = DOT(v1, thisview.vup);
556 VSUM(nv.vp, nv.vp, thisview.vup, d);
557 }
558 if (setview(&nv) != NULL)
559 return(0); /* illegal view */
560 dev_view(&nv);
561 return(1);
562 }
563
564
565 getmove(ebut) /* get view change */
566 XButtonPressedEvent *ebut;
567 {
568 int movdir = MOVDIR(ebut->button);
569 int movorb = MOVORB(ebut->state);
570 int moved = 0;
571 Window rootw, childw;
572 int rootx, rooty, wx, wy;
573 unsigned int statemask;
574
575 copylastv( movorb ? (movdir ? "left/right" : "up/down") :
576 (movdir ? "fore/back" : "rotate") );
577 XNoOp(ourdisplay);
578
579 while (!XCheckMaskEvent(ourdisplay,
580 ButtonReleaseMask, levptr(XEvent))) {
581
582 if (!XQueryPointer(ourdisplay, gwind, &rootw, &childw,
583 &rootx, &rooty, &wx, &wy, &statemask))
584 break; /* on another screen */
585
586 if (!moveview(wx, vres-1-wy, movdir, movorb)) {
587 sleep(1);
588 continue;
589 } else
590 moved++;
591 }
592 if (!moved) { /* do final motion */
593 movdir = MOVDIR(levptr(XButtonReleasedEvent)->button);
594 wx = levptr(XButtonReleasedEvent)->x;
595 wy = levptr(XButtonReleasedEvent)->y;
596 moveview(wx, vres-1-wy, movdir, movorb);
597 }
598 }
599
600
601 getintersect(wp, org, dir, md) /* intersect ray with scene geometry */
602 FVECT wp; /* returned world intersection point */
603 FVECT org, dir;
604 double md;
605 {
606 float fbuf[6];
607 /* check to see if rtrace is running */
608 if (rtpd[2] <= 0)
609 return(0);
610 /* assign origin */
611 fbuf[0] = org[0]; fbuf[1] = org[1]; fbuf[2] = org[2];
612 /* compute clipping distance */
613 if (md <= FTINY) md = FHUGE;
614 fbuf[3] = dir[0]*md; fbuf[4] = dir[1]*md; fbuf[5] = dir[2]*md;
615 /* trace that ray */
616 if (process(rtpd, fbuf, fbuf, 4*sizeof(float), 6*sizeof(float)) !=
617 4*sizeof(float))
618 error(INTERNAL, "error getting data back from rtrace process");
619 if (fbuf[3] >= .99*FHUGE)
620 return(0); /* missed local objects */
621 wp[0] = fbuf[0]; wp[1] = fbuf[1]; wp[2] = fbuf[2];
622 return(1); /* else return world intersection */
623 }
624
625
626 setglpersp(vp) /* set perspective view in GL */
627 register VIEW *vp;
628 {
629 double d, xmin, xmax, ymin, ymax, zmin, zmax;
630
631 zmin = 0.1;
632 zmax = 1000.;
633 if (thisview.vfore > FTINY)
634 zmin = thisview.vfore;
635 if (thisview.vaft > FTINY)
636 zmax = thisview.vaft;
637 xmax = zmin * tan(PI/180./2. * thisview.horiz);
638 xmin = -xmax;
639 d = thisview.hoff * (xmax - xmin);
640 xmin += d; xmax += d;
641 ymax = zmin * tan(PI/180./2. * thisview.vert);
642 ymin = -ymax;
643 d = thisview.voff * (ymax - ymin);
644 ymin += d; ymax += d;
645 /* set view matrix */
646 glMatrixMode(GL_PROJECTION);
647 glLoadIdentity();
648 glFrustum(xmin, xmax, ymin, ymax, zmin, zmax);
649 gluLookAt(thisview.vp[0], thisview.vp[1], thisview.vp[2],
650 thisview.vp[0] + thisview.vdir[0],
651 thisview.vp[1] + thisview.vdir[1],
652 thisview.vp[2] + thisview.vdir[2],
653 thisview.vup[0], thisview.vup[1], thisview.vup[2]);
654 rgl_checkerr("setting perspective view");
655 }
656
657
658 int
659 getkey(ekey) /* get input key */
660 register XKeyPressedEvent *ekey;
661 {
662 int n;
663 char buf[8];
664
665 n = XLookupString(ekey, buf, sizeof(buf), NULL, NULL);
666 if (n != 1)
667 return(1);
668 switch (buf[0]) {
669 case 'h': /* turn on height motion lock */
670 headlocked = 1;
671 break;
672 case 'H': /* turn off height motion lock */
673 headlocked = 0;
674 break;
675 case 'l': /* retrieve last (premouse) view */
676 if (lastview.type) {
677 VIEW vtmp;
678 copystruct(&vtmp, &thisview);
679 dev_view(&lastview);
680 copystruct(&lastview, &vtmp);
681 } else
682 XBell(ourdisplay, 0);
683 break;
684 case 'n': /* move to next standard view */
685 gotoview(currentview+1);
686 break;
687 case 'p': /* move to last standard view */
688 gotoview(currentview-1);
689 break;
690 case '+': /* zoom in */
691 zoomview(100+ZOOMPCT, ekey->x, vres-1-ekey->y);
692 break;
693 case '-': /* zoom out */
694 zoomview(100-ZOOMPCT, ekey->x, vres-1-ekey->y);
695 break;
696 case 'v': /* spit current view to stdout */
697 fputs(VIEWSTR, stdout);
698 fprintview(&thisview, stdout);
699 fputc('\n', stdout);
700 break;
701 case 'V': /* append view to rad file */
702 appendview(NULL, &thisview);
703 break;
704 case 'q': /* quit the program */
705 return(0);
706 default:
707 XBell(ourdisplay, 0);
708 break;
709 }
710 return(1);
711 }
712
713
714 zoomview(pct, dx, dy) /* zoom in or out around (dx,dy) */
715 int pct;
716 int dx, dy;
717 {
718 double h, v;
719 FVECT direc;
720
721 if (pct == 100 | pct <= 0)
722 return;
723 copylastv("zooming");
724 h = (dx+.5)/hres - 0.5;
725 v = (dy+.5)/vres - 0.5;
726 h *= (1. - 100./pct);
727 v *= (1. - 100./pct);
728 thisview.vdir[0] += h*thisview.hvec[0] + v*thisview.vvec[0];
729 thisview.vdir[1] += h*thisview.hvec[1] + v*thisview.vvec[1];
730 thisview.vdir[2] += h*thisview.hvec[2] + v*thisview.vvec[2];
731 thisview.horiz = 2.*180./PI * atan( 100./pct *
732 tan(PI/180./2.*thisview.horiz) );
733 thisview.vert = 2.*180./PI * atan( 100./pct *
734 tan(PI/180./2.*thisview.vert) );
735 setview(&thisview);
736 dev_view(&thisview);
737 }
738
739
740 gotoview(vwnum) /* go to specified view number */
741 int vwnum;
742 {
743 if (vwnum < 0)
744 for (vwnum = currentview; vwl[vwnum+1].v != NULL; vwnum++)
745 ;
746 else if (vwnum >= MAXVIEW || vwl[vwnum].v == NULL)
747 vwnum = 0;
748 if (vwnum == currentview)
749 return;
750 /* copylastv("change view"); */
751 dev_view(vwl[currentview=vwnum].v);
752 }
753
754
755 appendview(nm, vp) /* append standard view */
756 char *nm;
757 VIEW *vp;
758 {
759 FILE *fp;
760 /* check if already in there */
761 if (!bcmp(&thisview, vwl[currentview].v, sizeof(VIEW))) {
762 error(COMMAND, "view already in standard list");
763 return;
764 }
765 /* append to file */
766 if ((fp = fopen(radfile, "a")) == NULL) {
767 error(COMMAND, "cannot append rad input file");
768 return;
769 }
770 fputs("view=", fp);
771 if (nm != NULL) {
772 fputc(' ', fp); fputs(nm, fp);
773 }
774 fprintview(vp, fp); fputc('\n', fp);
775 fclose(fp);
776 /* append to our list */
777 while (vwl[currentview].v != NULL)
778 currentview++;
779 if (currentview >= MAXVIEW)
780 error(INTERNAL, "too many views in appendview");
781 vwl[currentview].v = (VIEW *)bmalloc(sizeof(VIEW));
782 copystruct(vwl[currentview].v, &thisview);
783 if (nm != NULL)
784 vwl[currentview].nam = savqstr(nm);
785 }
786
787
788 copylastv(cause) /* copy last view position */
789 char *cause;
790 {
791 static char *lastvc;
792
793 if (cause == lastvc)
794 return; /* only record one view per cause */
795 lastvc = cause;
796 copystruct(&lastview, &thisview);
797 }
798
799
800 fixwindow(eexp) /* repair damage to window */
801 register XExposeEvent *eexp;
802 {
803 if (hres == 0 | vres == 0) { /* first exposure */
804 resizewindow((XConfigureEvent *)eexp);
805 return;
806 }
807 if (eexp->count) /* wait for final exposure */
808 return;
809 /* rerender everything */
810 render();
811 }
812
813
814 resizewindow(ersz) /* resize window */
815 register XConfigureEvent *ersz;
816 {
817 static char resizing[] = "resizing window";
818 double wa, va;
819
820 glViewport(0, 0, hres=ersz->width, vres=ersz->height);
821 if (hres > maxhres) maxhres = hres;
822 if (vres > maxvres) maxvres = vres;
823 if (in_dev_view)
824 return;
825 wa = (vres*pheight)/(hres*pwidth);
826 va = viewaspect(&thisview);
827 if (va > wa+.05) {
828 copylastv(resizing);
829 thisview.vert = 2.*180./PI *
830 atan( tan(PI/180./2. * thisview.horiz) * wa );
831 } else if (va < wa-.05) {
832 copylastv(resizing);
833 thisview.horiz = 2.*180./PI *
834 atan( tan(PI/180./2. * thisview.vert) / wa );
835 } else
836 return;
837 setview(&thisview);
838 dev_view(&thisview);
839 }
