refactor: Changed buffer types in process(), readbuf(), writebuf()
Added listening for mouse wheel
Tweaked speed parameters to slow things down a bit
Punting because window size negotiation doesn't work as before
Increased delays for slight improvement in interactive behavior
Continued ANSIfication.
Ansification.
Eliminated copystruct() macro, which is unnecessary in ANSI. Reduced ambiguity warnings for nested if/if/else clauses.
Abstracted process and path handling for Windows. Renamed FLOAT to RREAL because of conflict on Windows. Added conditional compiles for some signal handlers.
Eliminated unnecessary and problematic external function declarations
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
return number of lists allocated for proper deallocation
modifications to avoid problems with redeclared BYTE type
fixed minor bug that made back face culling fail for -bv option
minor cosmetic changes
fixed usage message
minor bug fix in GL call
got rid of problematic test in gotoview() which failed for single views
fixed rendering lockup problem
added stereo viewing with -S option added -s option for silent running added check of render options for -bv-
more viewing fixes -- changed -v option to allow views\
minor viewing fixes
