--- ray/src/util/glareval.c 1991/03/21 12:28:23 1.5 +++ ray/src/util/glareval.c 2004/01/02 12:48:36 2.11 @@ -1,65 +1,111 @@ -/* Copyright (c) 1991 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: glareval.c,v 2.11 2004/01/02 12:48:36 schorsch Exp $"; #endif - /* * Compute pixels for glare calculation */ +#include "copyright.h" + +#include +#include + +#include "rtprocess.h" /* Windows: must come first because of conflicts */ #include "glare.h" -#include - /* compute rtrace buffer size */ -#ifndef PIPE_BUF -#define PIPE_BUF 512 /* hyperconservative */ -#endif -#define MAXPIX (PIPE_BUF/(6*sizeof(float)) - 1) -#ifndef BSD -#define vfork fork -#endif + /* maximum rtrace buffer size */ +#define MAXPIX (4096/(6*sizeof(float))) -#define NSCANS 64 /* number of scanlines to buffer */ +#define MAXSBUF 786432 /* maximum total size of scanline buffer */ +#define HSIZE 317 /* size of scanline hash table */ +#define NRETIRE 16 /* number of scanlines to retire at once */ -int rt_pid = -1; /* process id for rtrace */ -int fd_tort, fd_fromrt; /* pipe descriptors */ +static SUBPROC rt_pd = SP_INACTIVE; /* process id & descriptors for rtrace */ FILE *pictfp = NULL; /* picture file pointer */ double exposure; /* picture exposure */ int pxsiz, pysiz; /* picture dimensions */ -int curpos; /* current scanline */ -long *scanpos; /* scanline positions */ -struct { - long lused; /* for LRU replacement */ + +static int curpos; /* current scanline */ +static long *scanpos; /* scanline positions */ + +typedef struct scan { int y; /* scanline position */ - COLR *sl; /* scanline contents */ -} scan[NSCANS]; /* buffered scanlines */ + long lused; /* for LRU replacement */ + struct scan *next; /* next in this hash or free list */ + /* followed by the scanline data */ +} SCAN; /* buffered scanline */ +#define scandata(sl) ((COLR *)((sl)+1)) +#define shash(y) ((y)%HSIZE) + +static int maxpix; /* maximum number of pixels to buffer */ + +static SCAN *freelist; /* scanline free list */ +static SCAN *hashtab[HSIZE]; /* scanline hash table */ + +static long scanbufsiz; /* size of allocated scanline buffer */ + static long ncall = 0L; /* number of calls to getpictscan */ static long nread = 0L; /* number of scanlines read */ +static long nrecl = 0L; /* number of scanlines reclaimed */ -extern long ftell(); +static int wrongformat = 0; +static SCAN * claimscan(int y); +static COLR * getpictscan(int y); +static double pict_val(FVECT vd); +static void rt_compute(float *pb, int np); +static gethfunc getexpos; +static SCAN * scanretire(void); +static void initscans(void); +static void donescans(void); -COLR * -getpictscan(y) /* get picture scanline */ -int y; + +static SCAN * +claimscan( /* claim scanline from buffers */ + int y +) { - int minused; + int hi = shash(y); + SCAN *slast; + register SCAN *sl; + + for (sl = hashtab[hi]; sl != NULL; sl = sl->next) + if (sl->y == y) /* active scanline */ + return(sl); + for (slast = NULL, sl = freelist; sl != NULL; slast = sl, sl = sl->next) + if (sl->y == -1 || sl->y == y || sl->next == NULL) { + if (slast == NULL) /* remove from free */ + freelist = sl->next; + else + slast->next = sl->next; + if (sl->y == y) { /* reclaim */ + sl->next = hashtab[hi]; + hashtab[hi] = sl; + nrecl++; + } + return(sl); + } + return(scanretire()); /* need more free scanlines */ +} + + +static COLR * +getpictscan( /* get picture scanline */ + int y +) +{ + register SCAN *sl; register int i; /* first check our buffers */ - ncall++; - minused = 0; - for (i = 0; i < NSCANS; i++) { - if (scan[i].y == y) { - scan[i].lused = ncall; - return(scan[i].sl); - } - if (scan[i].lused < scan[minused].lused) - minused = i; - } - /* not there, read it in */ + sl = claimscan(y); + if (sl == NULL) + memerr("claimscan()"); + sl->lused = ncall++; + if (sl->y == y) /* scan hit */ + return(scandata(sl)); + /* else read in replacement */ if (scanpos[y] < 0) { /* need to search */ for (i = y+1; i < curpos; i++) if (scanpos[i] >= 0) { @@ -70,7 +116,7 @@ int y; } while (curpos >= y) { scanpos[curpos] = ftell(pictfp); - if (freadcolrs(scan[minused].sl, pxsiz, pictfp) < 0) + if (freadcolrs(scandata(sl), pxsiz, pictfp) < 0) goto readerr; nread++; curpos--; @@ -78,14 +124,16 @@ int y; } else { if (curpos != y && fseek(pictfp, scanpos[y], 0) < 0) goto seekerr; - if (freadcolrs(scan[minused].sl, pxsiz, pictfp) < 0) + if (freadcolrs(scandata(sl), pxsiz, pictfp) < 0) goto readerr; nread++; curpos = y-1; } - scan[minused].lused = ncall; - scan[minused].y = y; - return(scan[minused].sl); + sl->y = y; + i = shash(y); /* add to hash list */ + sl->next = hashtab[i]; + hashtab[i] = sl; + return(scandata(sl)); readerr: fprintf(stderr, "%s: picture read error\n", progname); exit(1); @@ -95,27 +143,32 @@ seekerr: } -pict_stats() /* print out picture read statistics */ +#ifdef DEBUG +static void +pict_stats(void) /* print out picture read statistics */ { static long lastcall = 0L; /* ncall at last report */ static long lastread = 0L; /* nread at last report */ + static long lastrecl = 0L; /* nrecl at last report */ if (ncall == lastcall) return; - fprintf(stderr, "%s: %ld scanlines read, %ld reused\n", - progname, nread-lastread, - (ncall-lastcall)-(nread-lastread)); + fprintf(stderr, "%s: %ld scanlines read (%ld reclaimed) in %ld calls\n", + progname, nread-lastread, nrecl-lastrecl, ncall-lastcall); lastcall = ncall; lastread = nread; + lastrecl = nrecl; } +#endif -double -pict_val(vd) /* find picture value for view direction */ -FVECT vd; +static double +pict_val( /* find picture value for view direction */ + FVECT vd +) { FVECT pp; - double vpx, vpy, vpz; + FVECT ip; COLOR res; if (pictfp == NULL) @@ -123,28 +176,34 @@ FVECT vd; pp[0] = pictview.vp[0] + vd[0]; pp[1] = pictview.vp[1] + vd[1]; pp[2] = pictview.vp[2] + vd[2]; - viewpixel(&vpx, &vpy, &vpz, &pictview, pp); - if (vpz <= FTINY || vpx < 0. || vpx >= 1. || vpy < 0. || vpy >= 1.) + viewloc(ip, &pictview, pp); + if (ip[2] <= FTINY || ip[0] < 0. || ip[0] >= 1. || + ip[1] < 0. || ip[1] >= 1.) return(-1.0); - colr_color(res, getpictscan((int)(vpy*pysiz))[(int)(vpx*pxsiz)]); + colr_color(res, getpictscan((int)(ip[1]*pysiz))[(int)(ip[0]*pxsiz)]); return(luminance(res)/exposure); } -double -getviewpix(vh, vv) /* compute single view pixel */ -int vh, vv; +extern double +getviewpix( /* compute single view pixel */ + int vh, + int vv +) { FVECT dir; - float rt_buf[6]; + float rt_buf[12]; double res; if (compdir(dir, vh, vv) < 0) return(-1.0); + npixinvw++; if ((res = pict_val(dir)) >= 0.0) return(res); - if (rt_pid == -1) + if (rt_pd.r == -1) { + npixmiss++; return(-1.0); + } rt_buf[0] = ourview.vp[0]; rt_buf[1] = ourview.vp[1]; rt_buf[2] = ourview.vp[2]; @@ -156,9 +215,11 @@ int vh, vv; } -getviewspan(vv, vb) /* compute a span of view pixels */ -int vv; -float *vb; +extern void +getviewspan( /* compute a span of view pixels */ + int vv, + float *vb +) { float rt_buf[6*MAXPIX]; /* rtrace send/receive buffer */ register int n; /* number of pixels in buffer */ @@ -173,16 +234,19 @@ float *vb; #endif n = 0; for (vh = -hsize; vh <= hsize; vh++) { - if (compdir(dir, vh, vv) < 0) { /* off viewable region */ + if (compdir(dir, vh, vv) < 0) { /* not in view */ vb[vh+hsize] = -1.0; continue; } + npixinvw++; if ((vb[vh+hsize] = pict_val(dir)) >= 0.0) continue; - if (rt_pid == -1) /* missing information */ + if (rt_pd.r == -1) { /* missing information */ + npixmiss++; continue; + } /* send to rtrace */ - if (n >= MAXPIX) { /* flush */ + if (n >= maxpix) { /* flush */ rt_compute(rt_buf, n); while (n-- > 0) vb[buf_vh[n]+hsize] = luminance(rt_buf+3*n); @@ -207,169 +271,200 @@ float *vb; } -rt_compute(pb, np) /* process buffer through rtrace */ -float *pb; -int np; +static void +rt_compute( /* process buffer through rtrace */ + float *pb, + int np +) { - static float nbuf[6] = {0.,0.,0.,0.,0.,0.}; - #ifdef DEBUG if (verbose && np > 1) fprintf(stderr, "%s: sending %d samples to rtrace...\n", progname, np); #endif - if (writebuf(fd_tort,(char *)pb,6*sizeof(float)*np) < 6*sizeof(float)*np - || writebuf(fd_tort,(char *)nbuf,sizeof(nbuf)) < sizeof(nbuf)) { - fprintf(stderr, "%s: error writing to rtrace process\n", + memset(pb+6*np, '\0', 6*sizeof(float)); + if (process(&rt_pd, (char *)pb, (char *)pb, 3*sizeof(float)*(np+1), + 6*sizeof(float)*(np+1)) < 3*sizeof(float)*(np+1)) { + fprintf(stderr, "%s: rtrace communication error\n", progname); exit(1); } - if (readbuf(fd_fromrt, (char *)pb, 3*sizeof(float)*np) - < 3*sizeof(float)*np) { - fprintf(stderr, "%s: error reading from rtrace process\n", - progname); - exit(1); - } } -getexpos(s) /* get exposure from header line */ -char *s; +static int +getexpos( /* get exposure from header line */ + char *s, + void *p +) { + char fmt[32]; + if (isexpos(s)) exposure *= exposval(s); + else if (isformat(s)) { + formatval(fmt, s); + wrongformat = strcmp(fmt, COLRFMT); + } + return(0); } -open_pict(fn) /* open picture file */ -char *fn; +extern void +open_pict( /* open picture file */ + char *fn +) { - register int i; - if ((pictfp = fopen(fn, "r")) == NULL) { - fprintf("%s: cannot open\n", fn); + fprintf(stderr, "%s: cannot open\n", fn); exit(1); } exposure = 1.0; - getheader(pictfp, getexpos); - if (fgetresolu(&pxsiz, &pysiz, pictfp) != (YMAJOR|YDECR)) { - fprintf("%s: bad picture resolution\n", fn); + getheader(pictfp, getexpos, NULL); + if (wrongformat || !fscnresolu(&pxsiz, &pysiz, pictfp)) { + fprintf(stderr, "%s: incompatible picture format\n", fn); exit(1); } - scanpos = (long *)malloc(pysiz*sizeof(long)); - if (scanpos == NULL) - memerr("scanline positions"); - for (i = pysiz-1; i >= 0; i--) - scanpos[i] = -1L; - curpos = pysiz-1; - for (i = 0; i < NSCANS; i++) { - scan[i].lused = -1; - scan[i].y = -1; - scan[i].sl = (COLR *)malloc(pxsiz*sizeof(COLR)); - if (scan[i].sl == NULL) - memerr("scanline buffers"); - } + initscans(); } -close_pict() /* done with picture */ +extern void +close_pict(void) /* done with picture */ { - register int i; - if (pictfp == NULL) return; fclose(pictfp); - free((char *)scanpos); - for (i = 0; i < NSCANS; i++) - free((char *)scan[i].sl); + donescans(); pictfp = NULL; } -fork_rtrace(av) /* open pipe and start rtrace */ -char *av[]; +extern void +fork_rtrace( /* open pipe and start rtrace */ + char *av[] +) { - int p0[2], p1[2]; + int rval; - if (pipe(p0) < 0 || pipe(p1) < 0) { + rval = open_process(&rt_pd, av); + if (rval < 0) { perror(progname); exit(1); } - if ((rt_pid = vfork()) == 0) { /* if child */ - close(p0[1]); - close(p1[0]); - if (p0[0] != 0) { /* connect p0 to stdin */ - dup2(p0[0], 0); - close(p0[0]); - } - if (p1[1] != 0) { /* connect p1 to stdout */ - dup2(p1[1], 1); - close(p1[1]); - } - execvp(av[0], av); - perror(av[0]); - _exit(127); - } - if (rt_pid == -1) { - perror(progname); + if (rval == 0) { + fprintf(stderr, "%s: command not found\n", av[0]); exit(1); } - close(p0[0]); - close(p1[1]); - fd_tort = p0[1]; - fd_fromrt = p1[0]; + maxpix = rval/(6*sizeof(float)); + if (maxpix > MAXPIX) + maxpix = MAXPIX; + maxpix--; } -done_rtrace() /* wait for rtrace to finish */ +extern void +done_rtrace(void) /* wait for rtrace to finish */ { - int pid, status; + int status; - if (rt_pid == -1) - return; - close(fd_tort); - close(fd_fromrt); - while ((pid = wait(&status)) != -1 && pid != rt_pid) - ; - if (pid == rt_pid && status != 0) { + status = close_process(&rt_pd); + if (status > 0) { fprintf(stderr, "%s: bad status (%d) from rtrace\n", progname, status); exit(1); } - rt_pid = -1; + rt_pd.r = -1; } -int -readbuf(fd, bpos, siz) -int fd; -char *bpos; -int siz; +static SCAN * +scanretire(void) /* retire old scanlines to free list */ { - register int cc, nrem = siz; - - while (nrem > 0 && (cc = read(fd, bpos, nrem)) > 0) { - bpos += cc; - nrem -= cc; + SCAN *sold[NRETIRE]; + int n; + int h; + register SCAN *sl; + register int i; + /* grab the NRETIRE oldest scanlines */ + sold[n = 0] = NULL; + for (h = 0; h < HSIZE; h++) + for (sl = hashtab[h]; sl != NULL; sl = sl->next) { + for (i = n; i && sold[i-1]->lused > sl->lused; i--) + if (i < NRETIRE) + sold[i] = sold[i-1]; + if (i < NRETIRE) { + sold[i] = sl; + if (n < NRETIRE) /* grow list */ + n++; + } + } + /* put scanlines into free list */ + for (i = 0; i < n; i++) { + h = shash(sold[i]->y); + sl = hashtab[h]; + if (sl == sold[i]) + hashtab[h] = sl->next; + else { + while (sl->next != sold[i]) /* IS in list */ + sl = sl->next; + sl->next = sold[i]->next; + } + if (i > 0) { /* save oldest as return value */ + sold[i]->next = freelist; + freelist = sold[i]; + } } - if (cc < 0) - return(cc); - return(siz-nrem); + return(sold[0]); } -int -writebuf(fd, bpos, siz) -char *bpos; -int siz; -{ - register int cc, nrem = siz; +static char *scan_buf; - while (nrem > 0 && (cc = write(fd, bpos, nrem)) > 0) { - bpos += cc; - nrem -= cc; + +static void +initscans(void) /* initialize scanline buffers */ +{ + int scansize; + register SCAN *ptr; + register int i; + /* initialize positions */ + scanpos = (long *)bmalloc(pysiz*sizeof(long)); + if (scanpos == NULL) + memerr("scanline positions"); + for (i = pysiz-1; i >= 0; i--) + scanpos[i] = -1L; + curpos = pysiz-1; + /* clear hash table */ + for (i = 0; i < HSIZE; i++) + hashtab[i] = NULL; + /* allocate scanline buffers */ + scansize = sizeof(SCAN) + pxsiz*sizeof(COLR); +#ifdef ALIGNT + scansize = scansize+(sizeof(ALIGNT)-1) & ~(sizeof(ALIGNT)-1); +#endif + i = MAXSBUF / scansize; /* compute number to allocate */ + if (i > HSIZE) + i = HSIZE; + scanbufsiz = i*scansize; + scan_buf = bmalloc(scanbufsiz); /* get in one big chunk */ + if (scan_buf == NULL) + memerr("scanline buffers"); + ptr = (SCAN *)scan_buf; + freelist = NULL; /* build our free list */ + while (i-- > 0) { + ptr->y = -1; + ptr->lused = -1; + ptr->next = freelist; + freelist = ptr; + ptr = (SCAN *)((char *)ptr + scansize); /* beware of C bugs */ } - if (cc < 0) - return(cc); - return(siz-nrem); +} + + +static void +donescans(void) /* free up scanlines */ +{ + bfree(scan_buf, scanbufsiz); + bfree((char *)scanpos, pysiz*sizeof(long)); }
