--- ray/src/util/glareval.c 1991/03/18 14:33:53 1.2 +++ ray/src/util/glareval.c 1991/04/05 14:57:28 1.11 @@ -20,7 +20,9 @@ static char SCCSid[] = "$SunId$ LBL"; #define vfork fork #endif -#define NSCANS 32 /* number of scanlines to buffer */ +#define MAXSBUF 524268 /* maximum total size of scanline buffer */ +#define HSIZE 317 /* size of scanline hash table */ +#define NRETIRE 16 /* number of scanlines to retire at once */ int rt_pid = -1; /* process id for rtrace */ int fd_tort, fd_fromrt; /* pipe descriptors */ @@ -28,61 +30,116 @@ int fd_tort, fd_fromrt; /* pipe descriptors */ FILE *pictfp = NULL; /* picture file pointer */ double exposure; /* picture exposure */ int pxsiz, pysiz; /* picture dimensions */ -int curpos; /* current scanline */ -long *scanpos; /* scanline positions */ -struct { - long lused; /* for LRU replacement */ + +static int curpos; /* current scanline */ +static long *scanpos; /* scanline positions */ + +typedef struct scan { int y; /* scanline position */ - COLR *sl; /* scanline contents */ -} scan[NSCANS]; /* buffered scanlines */ + long lused; /* for LRU replacement */ + struct scan *next; /* next in this hash or free list */ + /* followed by the scanline data */ +} SCAN; /* buffered scanline */ +#define scandata(sl) ((COLR *)((sl)+1)) +#define shash(y) ((y)%HSIZE) + +static SCAN *freelist; /* scanline free list */ +static SCAN *hashtab[HSIZE]; /* scanline hash table */ + static long ncall = 0L; /* number of calls to getpictscan */ static long nread = 0L; /* number of scanlines read */ +SCAN *scanretire(); +extern long ftell(); + + +SCAN * +claimscan(y) /* claim scanline from buffers */ +int y; +{ + int hi = shash(y); + SCAN *slast; + register SCAN *sl; + + for (sl = hashtab[hi]; sl != NULL; sl = sl->next) + if (sl->y == y) /* active scanline */ + return(sl); + for (slast = NULL, sl = freelist; sl != NULL; slast = sl, sl = sl->next) + if (sl->y == -1 || sl->y == y || sl->next == NULL) { + if (slast == NULL) /* remove from free */ + freelist = sl->next; + else + slast->next = sl->next; + if (sl->y == y) { /* reclaim */ + sl->next = hashtab[hi]; + hashtab[hi] = sl; +#ifdef DEBUG + if (verbose) + fprintf(stderr, + "%s: scanline %d reclaimed\n", + progname, y); +#endif + } + return(sl); + } + return(scanretire()); /* need more free scanlines */ +} + + COLR * getpictscan(y) /* get picture scanline */ int y; { - extern long ftell(); - int minused; + register SCAN *sl; register int i; /* first check our buffers */ - ncall++; - minused = 0; - for (i = 0; i < NSCANS; i++) { - if (scan[i].y == y) { - scan[i].lused = ncall; - return(scan[i].sl); - } - if (scan[i].lused < scan[minused].lused) - minused = i; - } - /* not there, read it in */ - if (scanpos[y] == -1) { /* need to search */ - while (curpos > y) { + sl = claimscan(y); + if (sl == NULL) + memerr("claimscan()"); + sl->lused = ncall++; + if (sl->y == y) /* scan hit */ + return(scandata(sl)); + /* else read in replacement */ + if (scanpos[y] < 0) { /* need to search */ + for (i = y+1; i < curpos; i++) + if (scanpos[i] >= 0) { + if (fseek(pictfp, scanpos[i], 0) < 0) + goto seekerr; + curpos = i; + break; + } + while (curpos >= y) { scanpos[curpos] = ftell(pictfp); - if (freadcolrs(scan[minused].sl, pxsiz, pictfp) < 0) + if (freadcolrs(scandata(sl), pxsiz, pictfp) < 0) goto readerr; + nread++; curpos--; } - } else if (fseek(pictfp, scanpos[y], 0) < 0) { - fprintf(stderr, "%s: picture seek error\n", progname); - exit(1); + } else { + if (curpos != y && fseek(pictfp, scanpos[y], 0) < 0) + goto seekerr; + if (freadcolrs(scandata(sl), pxsiz, pictfp) < 0) + goto readerr; + nread++; + curpos = y-1; } - if (freadcolrs(scan[minused].sl, pxsiz, pictfp) < 0) - goto readerr; - nread++; - curpos = y-1; - scan[minused].lused = ncall; - scan[minused].y = y; - return(scan[minused].sl); + sl->y = y; + i = shash(y); /* add to hash list */ + sl->next = hashtab[i]; + hashtab[i] = sl; + return(scandata(sl)); readerr: fprintf(stderr, "%s: picture read error\n", progname); exit(1); +seekerr: + fprintf(stderr, "%s: picture seek error\n", progname); + exit(1); } +#ifdef DEBUG pict_stats() /* print out picture read statistics */ { static long lastcall = 0L; /* ncall at last report */ @@ -90,12 +147,12 @@ pict_stats() /* print out picture read statistics */ if (ncall == lastcall) return; - fprintf(stderr, "%s: %ld scanlines read, %ld reused\n", - progname, nread-lastread, - (ncall-lastcall)-(nread-lastread)); + fprintf(stderr, "%s: %ld scanlines read in %ld calls\n", + progname, nread-lastread, ncall-lastcall); lastcall = ncall; lastread = nread; } +#endif double @@ -129,10 +186,13 @@ int vh, vv; if (compdir(dir, vh, vv) < 0) return(-1.0); + npixinvw++; if ((res = pict_val(dir)) >= 0.0) return(res); - if (rt_pid == -1) + if (rt_pid == -1) { + npixmiss++; return(-1.0); + } rt_buf[0] = ourview.vp[0]; rt_buf[1] = ourview.vp[1]; rt_buf[2] = ourview.vp[2]; @@ -149,47 +209,52 @@ int vv; float *vb; { float rt_buf[6*MAXPIX]; /* rtrace send/receive buffer */ - int npix_tort; /* number of pixels in buffer */ + register int n; /* number of pixels in buffer */ short buf_vh[MAXPIX]; /* pixel positions */ FVECT dir; register int vh; - register int i; +#ifdef DEBUG if (verbose) fprintf(stderr, "%s: computing view span at %d...\n", progname, vv); - npix_tort = 0; +#endif + n = 0; for (vh = -hsize; vh <= hsize; vh++) { if (compdir(dir, vh, vv) < 0) { /* off viewable region */ vb[vh+hsize] = -1.0; continue; } + npixinvw++; if ((vb[vh+hsize] = pict_val(dir)) >= 0.0) continue; - if (rt_pid == -1) /* missing information */ + if (rt_pid == -1) { /* missing information */ + npixmiss++; continue; + } /* send to rtrace */ - if (npix_tort >= MAXPIX) { /* flush */ - rt_compute(rt_buf, npix_tort); - for (i = 0; i < npix_tort; i++) - vb[buf_vh[i]+hsize] = luminance(rt_buf+3*i); - npix_tort = 0; + if (n >= MAXPIX) { /* flush */ + rt_compute(rt_buf, n); + while (n-- > 0) + vb[buf_vh[n]+hsize] = luminance(rt_buf+3*n); } - rt_buf[6*npix_tort] = ourview.vp[0]; - rt_buf[6*npix_tort+1] = ourview.vp[1]; - rt_buf[6*npix_tort+2] = ourview.vp[2]; - rt_buf[6*npix_tort+3] = dir[0]; - rt_buf[6*npix_tort+4] = dir[1]; - rt_buf[6*npix_tort+5] = dir[2]; - buf_vh[npix_tort++] = vh; + rt_buf[6*n] = ourview.vp[0]; + rt_buf[6*n+1] = ourview.vp[1]; + rt_buf[6*n+2] = ourview.vp[2]; + rt_buf[6*n+3] = dir[0]; + rt_buf[6*n+4] = dir[1]; + rt_buf[6*n+5] = dir[2]; + buf_vh[n++] = vh; } - if (npix_tort > 0) { /* process pending buffer */ - rt_compute(rt_buf, npix_tort); - for (i = 0; i < npix_tort; i++) - vb[buf_vh[i]+hsize] = luminance(rt_buf+3*i); - } +#ifdef DEBUG if (verbose) pict_stats(); +#endif + if (n > 0) { /* process pending buffer */ + rt_compute(rt_buf, n); + while (n-- > 0) + vb[buf_vh[n]+hsize] = luminance(rt_buf+3*n); + } } @@ -199,9 +264,11 @@ int np; { static float nbuf[6] = {0.,0.,0.,0.,0.,0.}; +#ifdef DEBUG if (verbose && np > 1) fprintf(stderr, "%s: sending %d samples to rtrace...\n", progname, np); +#endif if (writebuf(fd_tort,(char *)pb,6*sizeof(float)*np) < 6*sizeof(float)*np || writebuf(fd_tort,(char *)nbuf,sizeof(nbuf)) < sizeof(nbuf)) { fprintf(stderr, "%s: error writing to rtrace process\n", @@ -240,19 +307,7 @@ char *fn; fprintf("%s: bad picture resolution\n", fn); exit(1); } - scanpos = (long *)malloc(pysiz*sizeof(long)); - if (scanpos == NULL) - memerr("scanline positions"); - for (i = 0; i < pysiz; i++) - scanpos[i] = -1L; - for (i = 0; i < NSCANS; i++) { - scan[i].lused = -1; - scan[i].y = -1; - scan[i].sl = (COLR *)malloc(pxsiz*sizeof(COLR)); - if (scan[i].sl == NULL) - memerr("scanline buffers"); - } - curpos = pysiz-1; + initscans(); } @@ -263,9 +318,7 @@ close_pict() /* done with picture */ if (pictfp == NULL) return; fclose(pictfp); - free((char *)scanpos); - for (i = 0; i < NSCANS; i++) - free((char *)scan[i].sl); + donescans(); pictfp = NULL; } @@ -298,6 +351,8 @@ char *av[]; perror(progname); exit(1); } + close(p0[0]); + close(p1[1]); fd_tort = p0[1]; fd_fromrt = p1[0]; } @@ -354,4 +409,93 @@ int siz; if (cc < 0) return(cc); return(siz-nrem); +} + + +SCAN * +scanretire() /* retire old scanlines to free list */ +{ + SCAN *sold[NRETIRE]; + int n; + int h; + register SCAN *sl; + register int i; + /* grab the NRETIRE oldest scanlines */ + sold[n = 0] = NULL; + for (h = 0; h < HSIZE; h++) + for (sl = hashtab[h]; sl != NULL; sl = sl->next) { + for (i = n; i && sold[i-1]->lused > sl->lused; i--) + if (i < NRETIRE) + sold[i] = sold[i-1]; + if (i < NRETIRE) { + sold[i] = sl; + if (n < NRETIRE) /* grow list */ + n++; + } + } + /* put scanlines into free list */ + for (i = 0; i < n; i++) { + h = shash(sold[i]->y); + sl = hashtab[h]; + if (sl == sold[i]) + hashtab[h] = sl->next; + else { + while (sl->next != sold[i]) /* IS in list */ + sl = sl->next; + sl->next = sold[i]->next; + } + if (i > 0) { /* save oldest as return value */ + sold[i]->next = freelist; + freelist = sold[i]; + } + } + return(sold[0]); +} + + +static char *scan_buf; + + +initscans() /* initialize scanline buffers */ +{ + int scansize; + register SCAN *ptr; + register int i; + /* initialize positions */ + scanpos = (long *)malloc(pysiz*sizeof(long)); + if (scanpos == NULL) + memerr("scanline positions"); + for (i = pysiz-1; i >= 0; i--) + scanpos[i] = -1L; + curpos = pysiz-1; + /* clear hash table */ + for (i = 0; i < HSIZE; i++) + hashtab[i] = NULL; + /* allocate scanline buffers */ + scansize = sizeof(SCAN) + pxsiz*sizeof(COLR); +#ifdef ALIGN + scansize = scansize+(sizeof(ALIGN)-1)) & ~(sizeof(ALIGN)-1); +#endif + i = MAXSBUF / scansize; /* compute number to allocate */ + if (i > HSIZE) + i = HSIZE; + scan_buf = malloc(i*scansize); /* get in one big chunk */ + if (scan_buf == NULL) + memerr("scanline buffers"); + ptr = (SCAN *)scan_buf; + freelist = NULL; /* build our free list */ + while (i-- > 0) { + ptr->y = -1; + ptr->lused = -1; + ptr->next = freelist; + freelist = ptr; + ptr = (SCAN *)((char *)ptr + scansize); /* beware of C bugs */ + } +} + + +donescans() /* free up scanlines */ +{ + free(scan_buf); + free((char *)scanpos); }
