Fixed -DDEBUG compile
Abstracted process and path handling for Windows. Renamed FLOAT to RREAL because of conflict on Windows. Added conditional compiles for some signal handlers.
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
minor bug fix
changed malloc() to bmalloc() calls
added zeroing of position to rt_compute()
moved rtrace i/o routines to library
fixed minor bug in fork_rtrace
fixed syntax error
increased scanline buffer to .75 Meg
changed reporting of scanline reclamation
minor changes and bug fixes
reduced scanline buffer size and added debugging output for reclaims
improved and debugged retirescans()
fixed bug in scanretire and increased scanline buffer lims
added rather sophisticated LRU scanline replacement scheme
fixed debug reporting
fixed bug in getpictscan()
