root/radiance/ray/src/util/glareval.c
Fri Jan 2 12:48:36 2004 UTC (21 years, 6 months ago) by schorsch
Changes since 2.10: +61 -36 lines
Diff to previous 2.10 , to selected 2.3
Thu Jul 3 22:41:45 2003 UTC (22 years ago) by schorsch
Diff to previous 2.9 , to selected 2.3
Mon Jun 30 14:59:13 2003 UTC (22 years ago) by schorsch
Changes since 2.8: +6 -2 lines
Fri Jun 27 06:53:23 2003 UTC (22 years ago) by greg
Thu Jun 26 00:58:11 2003 UTC (22 years ago) by schorsch
Changes since 2.6: +10 -8 lines
Sat Feb 22 02:07:30 2003 UTC (22 years, 4 months ago) by greg
Tue Oct 27 08:47:18 1998 UTC (26 years, 8 months ago) by gwlarson
Wed Jul 9 11:22:11 1997 UTC (28 years ago) by gregl
Tue Sep 21 10:53:45 1993 UTC (31 years, 9 months ago) by greg
minor bug fix
Sun Jun 21 17:52:58 1992 UTC (33 years ago) by greg
Changes since 2.1: +7 -4 lines
changed malloc() to bmalloc() calls
Tue Nov 12 17:19:21 1991 UTC (33 years, 7 months ago) by greg
Diff to previous 1.21 , to selected 2.3
Mon Nov 11 15:09:42 1991 UTC (33 years, 7 months ago) by greg
Changes since 1.20: +8 -7 lines
Diff to previous 1.20 , to selected 2.3
Tue Jul 30 12:56:36 1991 UTC (33 years, 11 months ago) by greg
Diff to previous 1.19 , to selected 2.3
added zeroing of position to rt_compute()
Mon Jul 22 09:40:20 1991 UTC (33 years, 11 months ago) by greg
Changes since 1.18: +26 -94 lines
Diff to previous 1.18 , to selected 2.3
moved rtrace i/o routines to library
Wed Jun 26 13:35:16 1991 UTC (34 years ago) by greg
Diff to previous 1.17 , to selected 2.3
fixed minor bug in fork_rtrace
Wed May 1 08:50:49 1991 UTC (34 years, 2 months ago) by greg
Diff to previous 1.16 , to selected 2.3
fixed syntax error
Mon Apr 22 15:43:21 1991 UTC (34 years, 2 months ago) by greg
Diff to previous 1.15 , to selected 2.3
increased scanline buffer to .75 Meg
Mon Apr 22 15:41:01 1991 UTC (34 years, 2 months ago) by greg
Changes since 1.14: +6 -8 lines
Diff to previous 1.14 , to selected 2.3
changed reporting of scanline reclamation
Fri Apr 19 17:41:06 1991 UTC (34 years, 2 months ago) by greg
Changes since 1.13: +3 -6 lines
Diff to previous 1.13 , to selected 2.3
Thu Apr 18 15:18:25 1991 UTC (34 years, 2 months ago) by greg
Changes since 1.12: +12 -3 lines
Diff to previous 1.12 , to selected 2.3
Fri Apr 12 10:28:34 1991 UTC (34 years, 2 months ago) by greg
Changes since 1.11: +6 -7 lines
Diff to previous 1.11 , to selected 2.3
minor changes and bug fixes
Fri Apr 5 14:57:28 1991 UTC (34 years, 3 months ago) by greg
Changes since 1.10: +7 -1 lines
Diff to previous 1.10 , to selected 2.3
reduced scanline buffer size and added debugging output for reclaims
Fri Apr 5 14:41:55 1991 UTC (34 years, 3 months ago) by greg
Changes since 1.9: +20 -26 lines
Diff to previous 1.9 , to selected 2.3
improved and debugged retirescans()
Wed Apr 3 15:43:12 1991 UTC (34 years, 3 months ago) by greg
Changes since 1.8: +7 -5 lines
Diff to previous 1.8 , to selected 2.3
fixed bug in scanretire and increased scanline buffer lims
Wed Apr 3 15:20:35 1991 UTC (34 years, 3 months ago) by greg
Changes since 1.7: +157 -40 lines
Diff to previous 1.7 , to selected 2.3
added rather sophisticated LRU scanline replacement scheme
Tue Apr 2 14:29:17 1991 UTC (34 years, 3 months ago) by greg
Changes since 1.6: +8 -2 lines
Diff to previous 1.6 , to selected 2.3
Thu Mar 21 16:46:25 1991 UTC (34 years, 3 months ago) by greg
Diff to previous 1.5 , to selected 2.3
fixed debug reporting
Thu Mar 21 12:28:23 1991 UTC (34 years, 3 months ago) by greg
Changes since 1.4: +24 -12 lines
Diff to previous 1.4 , to selected 2.3
fixed bug in getpictscan()
Wed Mar 20 13:20:06 1991 UTC (34 years, 3 months ago) by greg
Changes since 1.3: +6 -0 lines
Diff to previous 1.3 , to selected 2.3
Tue Mar 19 17:06:27 1991 UTC (34 years, 3 months ago) by greg
Changes since 1.2: +21 -21 lines
Diff to previous 1.2 , to selected 2.3
Mon Mar 18 14:33:53 1991 UTC (34 years, 3 months ago) by greg
Changes since 1.1: +28 -13 lines
Diff to previous 1.1 , to selected 2.3
Mon Mar 18 12:15:41 1991 UTC (34 years, 3 months ago) by greg
Diff to selected 2.3
