root/radiance/ray/src/util/glaresrc.c
Tue Nov 29 20:45:21 2022 UTC (15 months, 4 weeks ago) by greg
CVS Tags: HEAD, rad5R4
Changes since 2.6: +26 -27 lines
Diff to previous 2.6 , to selected 1.8
refactor(findglare): Removed outdated type modifiers
Mon May 29 16:47:54 2006 UTC (17 years, 10 months ago) by greg
CVS Tags: rad3R8, rad3R9, rad4R0, rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0, rad5R1, rad5R2, rad5R3
Diff to previous 2.5 , to selected 1.8
Fixed -DDEBUG compile
Fri Jan 2 12:51:54 2004 UTC (20 years, 3 months ago) by schorsch
Changes since 2.4: +78 -35 lines
Diff to previous 2.4 , to selected 1.8
Ansification.
Sat Feb 22 02:07:30 2003 UTC (21 years, 1 month ago) by greg
Changes since 2.3: +6 -9 lines
Diff to previous 2.3 , to selected 1.8
Mon Jun 7 10:32:02 1993 UTC (30 years, 9 months ago) by greg
Diff to previous 2.2 , to selected 1.8
bug fix -- double check for tiny sources on boundary
Tue Mar 10 10:00:33 1992 UTC (32 years ago) by greg
Diff to previous 2.1 , to selected 1.8
added flush to progress report
Tue Nov 12 17:19:19 1991 UTC (32 years, 4 months ago) by greg
Diff to previous 1.15 , to selected 1.8
Tue Apr 30 16:39:39 1991 UTC (32 years, 11 months ago) by greg
Changes since 1.14: +97 -4 lines
Diff to previous 1.14 , to selected 1.8
added routines for splitting long sources
Mon Apr 22 08:20:58 1991 UTC (32 years, 11 months ago) by greg
Changes since 1.13: +1 -2 lines
Diff to previous 1.13 , to selected 1.8
Fri Apr 19 17:41:03 1991 UTC (32 years, 11 months ago) by greg
Changes since 1.12: +20 -23 lines
Diff to previous 1.12 , to selected 1.8
Fri Apr 12 10:28:36 1991 UTC (32 years, 11 months ago) by greg
Changes since 1.11: +9 -6 lines
Diff to previous 1.11 , to selected 1.8
minor changes and bug fixes
Wed Apr 10 15:59:10 1991 UTC (32 years, 11 months ago) by greg
Changes since 1.10: +2 -3 lines
Diff to previous 1.10 , to selected 1.8
Thu Mar 21 17:11:50 1991 UTC (33 years ago) by greg
Changes since 1.9: +9 -8 lines
Diff to previous 1.9 , to selected 1.8
Thu Mar 21 14:53:56 1991 UTC (33 years ago) by greg
Changes since 1.8: +4 -4 lines
Diff to previous 1.8
fixed bug in addindirect -- forgot to update after reorienting theta
Revision 1.8 - (view) (download) (annotate) - [selected]
Wed Mar 20 13:32:56 1991 UTC (33 years ago) by greg
Changes since 1.7: +7 -0 lines
Diff to previous 1.7
Wed Mar 20 12:18:14 1991 UTC (33 years ago) by greg
Changes since 1.6: +77 -4 lines
Diff to previous 1.6 , to selected 1.8
added routines to absorb too-small sources
Tue Mar 19 17:21:31 1991 UTC (33 years ago) by greg
Changes since 1.5: +0 -2 lines
Diff to previous 1.5 , to selected 1.8
Tue Mar 19 17:06:25 1991 UTC (33 years ago) by greg
Changes since 1.4: +20 -19 lines
Diff to previous 1.4 , to selected 1.8
Tue Mar 19 09:10:58 1991 UTC (33 years ago) by greg
Diff to previous 1.3 , to selected 1.8
fixed bug in closeallsrcs()
Mon Mar 18 16:06:53 1991 UTC (33 years ago) by greg
Changes since 1.2: +3 -2 lines
Diff to previous 1.2 , to selected 1.8
Mon Mar 18 14:32:17 1991 UTC (33 years ago) by greg
Changes since 1.1: +11 -7 lines
Diff to previous 1.1 , to selected 1.8
Mon Mar 18 12:15:40 1991 UTC (33 years ago) by greg
Diff to selected 1.8
