1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: glaresrc.c,v 2.5 2004/01/02 12:51:54 schorsch Exp $"; |
3 |
#endif |
4 |
5 |
* Gather samples and compute glare sources. |
6 |
7 |
8 |
#include "glare.h" |
9 |
#include "linregr.h" |
10 |
11 |
#define vcont(vd,vu) ((vu)-(vd)<=SEPS) |
12 |
#define hcont(s1,s2) ((s1)->r-(s2)->l>=-SEPS&&(s2)->r-(s1)->l>=-SEPS) |
13 |
14 |
struct source *curlist = NULL; /* current source list */ |
15 |
struct source *donelist = NULL; /* finished sources */ |
16 |
17 |
void pict_stats(void); |
18 |
19 |
static struct srcspan * newspan(int l, int r, int v, float *sb); |
20 |
21 |
static void addindirect(int h, int v, double br); |
22 |
static void addsrcspan(struct srcspan *nss); |
23 |
static void mergesource(struct source *sp, struct source *ap); |
24 |
static void close_sources(int v); |
25 |
static void close_allsrcs(void); |
26 |
static struct srcspan * splitspan(register struct srcspan *sso, double h, double v, double m); |
27 |
static struct source * splitsource(struct source *so); |
28 |
static void donesource(register struct source *sp); |
29 |
static struct source * findbuddy(register struct source *s, register struct source *l); |
30 |
static void absorb(register struct source *s); |
31 |
static void freespans(struct source *sp); |
32 |
33 |
34 |
static struct srcspan * |
35 |
newspan( /* allocate a new source span */ |
36 |
int l, |
37 |
int r, |
38 |
int v, |
39 |
float *sb |
40 |
41 |
42 |
register struct srcspan *ss; |
43 |
register int i; |
44 |
45 |
ss = (struct srcspan *)malloc(sizeof(struct srcspan)); |
46 |
if (ss == NULL) |
47 |
memerr("source spans"); |
48 |
ss->l = l; |
49 |
ss->r = r; |
50 |
ss->v = v; |
51 |
ss->brsum = 0.0; |
52 |
for (i = l; i < r; i++) |
53 |
ss->brsum += sb[i+hsize]; |
54 |
return(ss); |
55 |
56 |
57 |
58 |
extern void |
59 |
analyze(void) /* analyze our scene */ |
60 |
61 |
int h, v; |
62 |
int left; |
63 |
float *spanbr; |
64 |
65 |
spanbr = (float *)malloc((2*hsize+1)*sizeof(float)); |
66 |
if (spanbr == NULL) |
67 |
memerr("view span brightness buffer"); |
68 |
for (v = vsize; v >= -vsize; v--) { |
69 |
close_sources(v); |
70 |
#ifndef DEBUG |
71 |
if (verbose) { |
72 |
fprintf(stderr, "%s: analyzing... %3ld%%\r", |
73 |
progname, 100L*(vsize-v)/(2*vsize)); |
74 |
fflush(stderr); |
75 |
76 |
#endif |
77 |
getviewspan(v, spanbr); |
78 |
left = hsize + 1; |
79 |
for (h = -hsize; h <= hsize; h++) { |
80 |
if (spanbr[h+hsize] < 0.0) { /* off view */ |
81 |
if (left < h) { |
82 |
addsrcspan(newspan(left,h,v,spanbr)); |
83 |
left = hsize + 1; |
84 |
85 |
continue; |
86 |
87 |
if (spanbr[h+hsize] > threshold) { /* in source */ |
88 |
if (left > h) |
89 |
left = h; |
90 |
} else { /* out of source */ |
91 |
if (left < h) { |
92 |
93 |
left = hsize + 1; |
94 |
95 |
addindirect(h, v, spanbr[h+hsize]); |
96 |
97 |
98 |
if (left < h) |
99 |
100 |
101 |
free((void *)spanbr); |
102 |
close_allsrcs(); |
103 |
104 |
105 |
106 |
static void |
107 |
addindirect( /* add brightness to indirect illuminances */ |
108 |
int h, |
109 |
int v, |
110 |
double br |
111 |
112 |
113 |
double tanb, d; |
114 |
int hl; |
115 |
register int i; |
116 |
117 |
hl = hlim(v); |
118 |
if (h <= -hl) { /* left region */ |
119 |
d = (double)(-h-hl)/sampdens; |
120 |
if (d >= 1.0-FTINY) |
121 |
return; |
122 |
tanb = d/sqrt(1.0-d*d); |
123 |
for (i = 0; i < nglardirs; i++) { |
124 |
d = indirect[i].lcos - tanb*indirect[i].lsin; |
125 |
if (d > 0.0) { |
126 |
indirect[i].sum += d * br; |
127 |
indirect[i].n += d; |
128 |
129 |
130 |
return; |
131 |
132 |
if (h >= hl) { /* right region */ |
133 |
d = (double)(-h+hl)/sampdens; |
134 |
if (d <= -1.0+FTINY) |
135 |
return; |
136 |
137 |
138 |
d = indirect[i].rcos - tanb*indirect[i].rsin; |
139 |
if (d > 0.0) { |
140 |
141 |
142 |
143 |
144 |
return; |
145 |
146 |
/* central region */ |
147 |
148 |
d = cos(h_theta(h,v) - indirect[i].theta); |
149 |
if (d > 0.0) { |
150 |
151 |
152 |
153 |
154 |
155 |
156 |
157 |
extern void |
158 |
comp_thresh(void) /* compute glare threshold */ |
159 |
160 |
int h, v; |
161 |
int nsamps; |
162 |
double brsum, br; |
163 |
164 |
if (verbose) |
165 |
fprintf(stderr, "%s: computing glare threshold...\n", |
166 |
progname); |
167 |
brsum = 0.0; |
168 |
nsamps = 0; |
169 |
for (v = vsize; v >= -vsize; v -= TSAMPSTEP) { |
170 |
for (h = -hsize; h <= hsize; h += TSAMPSTEP) { |
171 |
if ((br = getviewpix(h, v)) < 0.0) |
172 |
continue; |
173 |
brsum += br; |
174 |
nsamps++; |
175 |
176 |
177 |
if (nsamps == 0) { |
178 |
fprintf(stderr, "%s: no viewable scene!\n", progname); |
179 |
exit(1); |
180 |
181 |
threshold = GLAREBR * brsum / nsamps; |
182 |
if (threshold <= FTINY) { |
183 |
fprintf(stderr, "%s: threshold zero!\n", progname); |
184 |
exit(1); |
185 |
186 |
if (verbose) { |
187 |
#ifdef DEBUG |
188 |
pict_stats(); |
189 |
#endif |
190 |
fprintf(stderr, |
191 |
"%s: threshold set to %f cd/m2 from %d samples\n", |
192 |
progname, threshold, nsamps); |
193 |
194 |
195 |
196 |
197 |
static void |
198 |
addsrcspan( /* add new source span to our list */ |
199 |
struct srcspan *nss |
200 |
201 |
202 |
struct source *last, *cs, *this; |
203 |
204 |
205 |
cs = NULL; |
206 |
for (this = curlist; this != NULL; this = this->next) { |
207 |
for (ss = this->first; ss != NULL; ss = ss->next) { |
208 |
if (!vcont(nss->v, ss->v)) |
209 |
break; |
210 |
if (hcont(ss, nss)) { |
211 |
if (cs == NULL) |
212 |
cs = this; |
213 |
else { |
214 |
last->next = this->next; |
215 |
mergesource(cs, this); |
216 |
this = last; |
217 |
218 |
break; |
219 |
220 |
221 |
last = this; |
222 |
223 |
if (cs == NULL) { |
224 |
cs = (struct source *)malloc(sizeof(struct source)); |
225 |
if (cs == NULL) |
226 |
memerr("source records"); |
227 |
cs->dom = 0.0; |
228 |
cs->first = NULL; |
229 |
cs->next = curlist; |
230 |
curlist = cs; |
231 |
232 |
nss->next = cs->first; |
233 |
cs->first = nss; |
234 |
235 |
236 |
237 |
static void |
238 |
mergesource( /* merge source ap into source sp */ |
239 |
struct source *sp, |
240 |
struct source *ap |
241 |
242 |
243 |
struct srcspan head; |
244 |
register struct srcspan *alp, *prev, *tp; |
245 |
246 |
head.next = sp->first; |
247 |
prev = &head; |
248 |
alp = ap->first; |
249 |
while (alp != NULL && prev->next != NULL) { |
250 |
if (prev->next->v > alp->v) { |
251 |
tp = alp->next; |
252 |
alp->next = prev->next; |
253 |
prev->next = alp; |
254 |
alp = tp; |
255 |
256 |
prev = prev->next; |
257 |
258 |
if (prev->next == NULL) |
259 |
prev->next = alp; |
260 |
sp->first = head.next; |
261 |
if (ap->dom > 0.0 && sp->dom > 0.0) { /* sources are done */ |
262 |
sp->dir[0] *= sp->dom; |
263 |
sp->dir[1] *= sp->dom; |
264 |
sp->dir[2] *= sp->dom; |
265 |
fvsum(sp->dir, sp->dir, ap->dir, ap->dom); |
266 |
normalize(sp->dir); |
267 |
sp->brt = (sp->brt*sp->dom + ap->brt*ap->dom) |
268 |
/ (sp->dom + ap->dom); |
269 |
270 |
free((void *)ap); |
271 |
272 |
273 |
274 |
static void |
275 |
close_sources( /* close sources above v */ |
276 |
int v |
277 |
278 |
279 |
struct source head; |
280 |
register struct source *last, *this; |
281 |
282 |
head.next = curlist; |
283 |
last = &head; |
284 |
for (this = curlist; this != NULL; this = this->next) |
285 |
if (!vcont(v, this->first->v)) { |
286 |
287 |
donesource(this); |
288 |
this = last; |
289 |
} else |
290 |
last = this; |
291 |
curlist = head.next; |
292 |
293 |
294 |
295 |
static void |
296 |
close_allsrcs(void) /* done with everything */ |
297 |
298 |
register struct source *this, *next; |
299 |
300 |
this = curlist; |
301 |
while (this != NULL) { |
302 |
303 |
donesource(this); |
304 |
this = next; |
305 |
306 |
curlist = NULL; |
307 |
308 |
309 |
310 |
311 |
splitspan( /* divide source span at point */ |
312 |
register struct srcspan *sso, |
313 |
double h, |
314 |
double v, |
315 |
double m |
316 |
317 |
318 |
register struct srcspan *ssn; |
319 |
double d; |
320 |
int hs; |
321 |
322 |
d = h - m*(sso->v - v); |
323 |
hs = d < 0. ? d-.5 : d+.5; |
324 |
if (sso->l >= hs) |
325 |
return(NULL); |
326 |
if (sso->r <= hs) |
327 |
return(sso); |
328 |
/* need to split it */ |
329 |
ssn = (struct srcspan *)malloc(sizeof(struct srcspan)); |
330 |
if (ssn == NULL) |
331 |
memerr("source spans in splitspan"); |
332 |
ssn->brsum = (double)(hs - sso->l)/(sso->r - sso->l) * sso->brsum; |
333 |
sso->brsum -= ssn->brsum; |
334 |
ssn->v = sso->v; |
335 |
ssn->l = sso->l; |
336 |
ssn->r = sso->l = hs; |
337 |
return(ssn); |
338 |
339 |
340 |
341 |
static struct source * |
342 |
splitsource( /* divide source in two if it's big and long */ |
343 |
struct source *so |
344 |
345 |
346 |
LRSUM lr; |
347 |
LRLIN fit; |
348 |
register struct srcspan *ss, *ssn; |
349 |
struct srcspan *ssl, *ssnl, head; |
350 |
int h; |
351 |
double mh, mv; |
352 |
struct source *sn; |
353 |
354 |
lrclear(&lr); |
355 |
for (ss = so->first; ss != NULL; ss = ss->next) |
356 |
for (h = ss->l; h < ss->r; h++) |
357 |
lrpoint(h, ss->v, &lr); |
358 |
if ((double)lr.n/(sampdens*sampdens) < SABIG) |
359 |
return(NULL); /* too small */ |
360 |
if (lrfit(&fit, &lr) < 0) |
361 |
return(NULL); /* can't fit a line */ |
362 |
if (fit.correlation < LCORR && fit.correlation > -LCORR) |
363 |
return(NULL); |
364 |
if (verbose) |
365 |
fprintf(stderr, "%s: splitting large source\n", progname); |
366 |
mh = lrxavg(&lr); |
367 |
mv = lryavg(&lr); |
368 |
sn = (struct source *)malloc(sizeof(struct source)); |
369 |
if (sn == NULL) |
370 |
memerr("source records in splitsource"); |
371 |
sn->dom = 0.0; |
372 |
sn->first = NULL; |
373 |
ssnl = NULL; |
374 |
head.next = so->first; |
375 |
ssl = &head; |
376 |
for (ss = so->first; ss != NULL; ssl = ss, ss = ss->next) |
377 |
if ((ssn = splitspan(ss, mh, mv, fit.slope)) != NULL) { |
378 |
if (ssn == ss) { /* remove from old */ |
379 |
ssl->next = ss->next; |
380 |
ss = ssl; |
381 |
382 |
if (ssnl == NULL) /* add to new */ |
383 |
sn->first = ssn; |
384 |
else |
385 |
ssnl->next = ssn; |
386 |
ssn->next = NULL; |
387 |
ssnl = ssn; |
388 |
389 |
so->first = head.next; |
390 |
return(sn); |
391 |
392 |
393 |
394 |
static void |
395 |
donesource( /* finished with this source */ |
396 |
register struct source *sp |
397 |
398 |
399 |
struct source *newsrc; |
400 |
401 |
int h, n; |
402 |
double hsum, vsum, d; |
403 |
404 |
while ((newsrc = splitsource(sp)) != NULL) /* split it? */ |
405 |
donesource(newsrc); |
406 |
sp->dom = 0.0; |
407 |
hsum = vsum = 0.0; |
408 |
sp->brt = 0.0; |
409 |
n = 0; |
410 |
for (ss = sp->first; ss != NULL; ss = ss->next) { |
411 |
sp->brt += ss->brsum; |
412 |
n += ss->r - ss->l; |
413 |
for (h = ss->l; h < ss->r; h++) { |
414 |
d = pixsize(h, ss->v); |
415 |
hsum += d*h; |
416 |
vsum += d*ss->v; |
417 |
sp->dom += d; |
418 |
419 |
420 |
freespans(sp); |
421 |
if (sp->dom <= FTINY) { /* must be right at edge of image */ |
422 |
free((void *)sp); |
423 |
return; |
424 |
425 |
sp->brt /= (double)n; |
426 |
compdir(sp->dir, (int)(hsum/sp->dom), (int)(vsum/sp->dom)); |
427 |
sp->next = donelist; |
428 |
donelist = sp; |
429 |
if (verbose) |
430 |
fprintf(stderr, |
431 |
"%s: source at [%.3f,%.3f,%.3f], dw %.5f, br %.1f (%d samps)\n", |
432 |
progname, sp->dir[0], sp->dir[1], sp->dir[2], |
433 |
sp->dom, sp->brt, n); |
434 |
435 |
436 |
437 |
438 |
findbuddy( /* find close enough source to s in l*/ |
439 |
register struct source *s, |
440 |
register struct source *l |
441 |
442 |
443 |
struct source *bestbuddy = NULL; |
444 |
double d, r, mindist = MAXBUDDY; |
445 |
446 |
r = sqrt(s->dom/PI); |
447 |
for ( ; l != NULL; l = l->next) { |
448 |
d = sqrt(dist2(l->dir, s->dir)) - sqrt(l->dom/PI) - r; |
449 |
if (d < mindist) { |
450 |
bestbuddy = l; |
451 |
mindist = d; |
452 |
453 |
454 |
return(bestbuddy); |
455 |
456 |
457 |
458 |
extern void |
459 |
absorb_specks(void) /* eliminate too-small sources */ |
460 |
461 |
struct source head, *buddy; |
462 |
463 |
464 |
if (verbose) |
465 |
fprintf(stderr, "%s: absorbing small sources...\n", progname); |
466 |
head.next = donelist; |
467 |
last = &head; |
468 |
for (this = head.next; this != NULL; this = this->next) |
469 |
if (TOOSMALL(this)) { |
470 |
471 |
buddy = findbuddy(this, head.next); |
472 |
if (buddy != NULL) |
473 |
mergesource(buddy, this); |
474 |
else |
475 |
absorb(this); |
476 |
this = last; |
477 |
} else |
478 |
last = this; |
479 |
donelist = head.next; |
480 |
481 |
482 |
483 |
static void |
484 |
absorb( /* absorb a source into indirect */ |
485 |
register struct source *s |
486 |
487 |
488 |
FVECT dir; |
489 |
double d; |
490 |
register int i; |
491 |
492 |
493 |
spinvector(dir, ourview.vdir, ourview.vup, indirect[i].theta); |
494 |
d = DOT(dir,s->dir)*s->dom*(sampdens*sampdens); |
495 |
if (d <= 0.0) |
496 |
continue; |
497 |
indirect[i].sum += d * s->brt; |
498 |
499 |
500 |
freespans(s); |
501 |
free((void *)s); |
502 |
503 |
504 |
505 |
static void |
506 |
freespans( /* free spans associated with source */ |
507 |
struct source *sp |
508 |
509 |
510 |
511 |
512 |
while ((ss = sp->first) != NULL) { |
513 |
sp->first = ss->next; |
514 |
free((void *)ss); |
515 |
516 |
