--- ray/src/util/glaresrc.c 1991/03/18 14:32:17 1.2 +++ ray/src/util/glaresrc.c 2004/01/02 12:51:54 2.5 @@ -1,14 +1,12 @@ -/* Copyright (c) 1991 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: glaresrc.c,v 2.5 2004/01/02 12:51:54 schorsch Exp $"; #endif - /* * Gather samples and compute glare sources. */ #include "glare.h" +#include "linregr.h" #define vcont(vd,vu) ((vu)-(vd)<=SEPS) #define hcont(s1,s2) ((s1)->r-(s2)->l>=-SEPS&&(s2)->r-(s1)->l>=-SEPS) @@ -16,13 +14,28 @@ static char SCCSid[] = "$SunId$ LBL"; struct source *curlist = NULL; /* current source list */ struct source *donelist = NULL; /* finished sources */ -double threshold; /* glare threshold */ +static struct srcspan * newspan(int l, int r, int v, float *sb); +static struct srcspan * newspan(int l, int r, int v, float *sb); +static void addindirect(int h, int v, double br); +static void addsrcspan(struct srcspan *nss); +static void mergesource(struct source *sp, struct source *ap); +static void close_sources(int v); +static void close_allsrcs(void); +static struct srcspan * splitspan(register struct srcspan *sso, double h, double v, double m); +static struct source * splitsource(struct source *so); +static void donesource(register struct source *sp); +static struct source * findbuddy(register struct source *s, register struct source *l); +static void absorb(register struct source *s); +static void freespans(struct source *sp); -struct srcspan * -newspan(l, r, v, sb) /* allocate a new source span */ -int l, r, v; -float *sb; +static struct srcspan * +newspan( /* allocate a new source span */ + int l, + int r, + int v, + float *sb +) { register struct srcspan *ss; register int i; @@ -40,7 +53,8 @@ float *sb; } -analyze() /* analyze our scene */ +extern void +analyze(void) /* analyze our scene */ { int h, v; int left; @@ -50,6 +64,14 @@ analyze() /* analyze our scene */ if (spanbr == NULL) memerr("view span brightness buffer"); for (v = vsize; v >= -vsize; v--) { + close_sources(v); +#ifndef DEBUG + if (verbose) { + fprintf(stderr, "%s: analyzing... %3ld%%\r", + progname, 100L*(vsize-v)/(2*vsize)); + fflush(stderr); + } +#endif getviewspan(v, spanbr); left = hsize + 1; for (h = -hsize; h <= hsize; h++) { @@ -68,65 +90,70 @@ analyze() /* analyze our scene */ addsrcspan(newspan(left,h,v,spanbr)); left = hsize + 1; } - addindirect(h, spanbr[h+hsize]); + addindirect(h, v, spanbr[h+hsize]); } } if (left < h) addsrcspan(newspan(left,h,v,spanbr)); - close_sources(v); } + free((void *)spanbr); close_allsrcs(); - free((char *)spanbr); } -addindirect(h, br) /* add brightness to indirect illuminances */ -int h; -double br; +static void +addindirect( /* add brightness to indirect illuminances */ + int h, + int v, + double br +) { double tanb, d; + int hl; register int i; - if (h <= -hlim) { /* left region */ - d = (double)(h+hlim)/SAMPDENS; - if (d <= -1.0+FTINY) + hl = hlim(v); + if (h <= -hl) { /* left region */ + d = (double)(-h-hl)/sampdens; + if (d >= 1.0-FTINY) return; tanb = d/sqrt(1.0-d*d); for (i = 0; i < nglardirs; i++) { d = indirect[i].lcos - tanb*indirect[i].lsin; if (d > 0.0) { indirect[i].sum += d * br; - indirect[i].n++; + indirect[i].n += d; } } return; } - if (h >= hlim) { /* right region */ - d = (double)(h-hlim)/SAMPDENS; - if (d >= 1.0-FTINY) + if (h >= hl) { /* right region */ + d = (double)(-h+hl)/sampdens; + if (d <= -1.0+FTINY) return; tanb = d/sqrt(1.0-d*d); for (i = 0; i < nglardirs; i++) { d = indirect[i].rcos - tanb*indirect[i].rsin; if (d > 0.0) { indirect[i].sum += d * br; - indirect[i].n++; + indirect[i].n += d; } } return; } /* central region */ for (i = 0; i < nglardirs; i++) { - d = cos(h_theta(h) - indirect[i].theta); + d = cos(h_theta(h,v) - indirect[i].theta); if (d > 0.0) { indirect[i].sum += d * br; - indirect[i].n++; + indirect[i].n += d; } } } -comp_thresh() /* compute glare threshold */ +extern void +comp_thresh(void) /* compute glare threshold */ { int h, v; int nsamps; @@ -137,13 +164,14 @@ comp_thresh() /* compute glare threshold */ progname); brsum = 0.0; nsamps = 0; - for (v = vsize; v >= -vsize; v -= TSAMPSTEP) + for (v = vsize; v >= -vsize; v -= TSAMPSTEP) { for (h = -hsize; h <= hsize; h += TSAMPSTEP) { if ((br = getviewpix(h, v)) < 0.0) continue; brsum += br; nsamps++; } + } if (nsamps == 0) { fprintf(stderr, "%s: no viewable scene!\n", progname); exit(1); @@ -154,7 +182,9 @@ comp_thresh() /* compute glare threshold */ exit(1); } if (verbose) { +#ifdef DEBUG pict_stats(); +#endif fprintf(stderr, "%s: threshold set to %f cd/m2 from %d samples\n", progname, threshold, nsamps); @@ -162,12 +192,13 @@ comp_thresh() /* compute glare threshold */ } -addsrcspan(nss) /* add new source span to our list */ -struct srcspan *nss; +static void +addsrcspan( /* add new source span to our list */ + struct srcspan *nss +) { struct source *last, *cs, *this; register struct srcspan *ss; - register int res; cs = NULL; for (this = curlist; this != NULL; this = this->next) { @@ -178,9 +209,9 @@ struct srcspan *nss; if (cs == NULL) cs = this; else { - mergesource(cs, this); last->next = this->next; - free((char *)this); + mergesource(cs, this); + this = last; } break; } @@ -191,6 +222,7 @@ struct srcspan *nss; cs = (struct source *)malloc(sizeof(struct source)); if (cs == NULL) memerr("source records"); + cs->dom = 0.0; cs->first = NULL; cs->next = curlist; curlist = cs; @@ -200,8 +232,11 @@ struct srcspan *nss; } -mergesource(sp, ap) /* merge source ap into source sp */ -struct source *sp, *ap; +static void +mergesource( /* merge source ap into source sp */ + struct source *sp, + struct source *ap +) { struct srcspan head; register struct srcspan *alp, *prev, *tp; @@ -221,12 +256,23 @@ struct source *sp, *ap; if (prev->next == NULL) prev->next = alp; sp->first = head.next; - ap->first = NULL; + if (ap->dom > 0.0 && sp->dom > 0.0) { /* sources are done */ + sp->dir[0] *= sp->dom; + sp->dir[1] *= sp->dom; + sp->dir[2] *= sp->dom; + fvsum(sp->dir, sp->dir, ap->dir, ap->dom); + normalize(sp->dir); + sp->brt = (sp->brt*sp->dom + ap->brt*ap->dom) + / (sp->dom + ap->dom); + } + free((void *)ap); } -close_sources(v) /* close sources above v */ -int v; +static void +close_sources( /* close sources above v */ + int v +) { struct source head; register struct source *last, *this; @@ -244,50 +290,225 @@ int v; } -close_allsrcs() /* done with everything */ +static void +close_allsrcs(void) /* done with everything */ { - register struct source *this; + register struct source *this, *next; - for (this = curlist; this != NULL; this = this->next) + this = curlist; + while (this != NULL) { + next = this->next; donesource(this); + this = next; + } curlist = NULL; } -donesource(sp) /* finished with this source */ -register struct source *sp; +static struct srcspan * +splitspan( /* divide source span at point */ + register struct srcspan *sso, + double h, + double v, + double m +) { - FVECT dthis, dright; + register struct srcspan *ssn; + double d; + int hs; + + d = h - m*(sso->v - v); + hs = d < 0. ? d-.5 : d+.5; + if (sso->l >= hs) + return(NULL); + if (sso->r <= hs) + return(sso); + /* need to split it */ + ssn = (struct srcspan *)malloc(sizeof(struct srcspan)); + if (ssn == NULL) + memerr("source spans in splitspan"); + ssn->brsum = (double)(hs - sso->l)/(sso->r - sso->l) * sso->brsum; + sso->brsum -= ssn->brsum; + ssn->v = sso->v; + ssn->l = sso->l; + ssn->r = sso->l = hs; + return(ssn); +} + + +static struct source * +splitsource( /* divide source in two if it's big and long */ + struct source *so +) +{ + LRSUM lr; + LRLIN fit; + register struct srcspan *ss, *ssn; + struct srcspan *ssl, *ssnl, head; + int h; + double mh, mv; + struct source *sn; + + lrclear(&lr); + for (ss = so->first; ss != NULL; ss = ss->next) + for (h = ss->l; h < ss->r; h++) + lrpoint(h, ss->v, &lr); + if ((double)lr.n/(sampdens*sampdens) < SABIG) + return(NULL); /* too small */ + if (lrfit(&fit, &lr) < 0) + return(NULL); /* can't fit a line */ + if (fit.correlation < LCORR && fit.correlation > -LCORR) + return(NULL); + if (verbose) + fprintf(stderr, "%s: splitting large source\n", progname); + mh = lrxavg(&lr); + mv = lryavg(&lr); + sn = (struct source *)malloc(sizeof(struct source)); + if (sn == NULL) + memerr("source records in splitsource"); + sn->dom = 0.0; + sn->first = NULL; + ssnl = NULL; + head.next = so->first; + ssl = &head; + for (ss = so->first; ss != NULL; ssl = ss, ss = ss->next) + if ((ssn = splitspan(ss, mh, mv, fit.slope)) != NULL) { + if (ssn == ss) { /* remove from old */ + ssl->next = ss->next; + ss = ssl; + } + if (ssnl == NULL) /* add to new */ + sn->first = ssn; + else + ssnl->next = ssn; + ssn->next = NULL; + ssnl = ssn; + } + so->first = head.next; + return(sn); +} + + +static void +donesource( /* finished with this source */ + register struct source *sp +) +{ + struct source *newsrc; register struct srcspan *ss; int h, n; - double d; + double hsum, vsum, d; + while ((newsrc = splitsource(sp)) != NULL) /* split it? */ + donesource(newsrc); sp->dom = 0.0; - sp->dir[0] = sp->dir[1] = sp->dir[1] = 0.0; + hsum = vsum = 0.0; sp->brt = 0.0; + n = 0; for (ss = sp->first; ss != NULL; ss = ss->next) { sp->brt += ss->brsum; n += ss->r - ss->l; - compdir(dright, ss->r, ss->v); - for (h = ss->r-1; h >= ss->l; h--) { - compdir(dthis, h, ss->v); - d = dist2(dthis, dright); - fvsum(sp->dir, sp->dir, dthis, d); + for (h = ss->l; h < ss->r; h++) { + d = pixsize(h, ss->v); + hsum += d*h; + vsum += d*ss->v; sp->dom += d; - VCOPY(dright, dthis); } - free((char *)ss); } - sp->first = NULL; + freespans(sp); + if (sp->dom <= FTINY) { /* must be right at edge of image */ + free((void *)sp); + return; + } sp->brt /= (double)n; - sp->dir[0] /= sp->dom; - sp->dir[1] /= sp->dom; - sp->dir[2] /= sp->dom; + compdir(sp->dir, (int)(hsum/sp->dom), (int)(vsum/sp->dom)); sp->next = donelist; donelist = sp; if (verbose) fprintf(stderr, - "%s: found source at (%f,%f,%f), solid angle %f, brightness %f\n", + "%s: source at [%.3f,%.3f,%.3f], dw %.5f, br %.1f (%d samps)\n", progname, sp->dir[0], sp->dir[1], sp->dir[2], - sp->dom, sp->brt); + sp->dom, sp->brt, n); +} + + +static struct source * +findbuddy( /* find close enough source to s in l*/ + register struct source *s, + register struct source *l +) +{ + struct source *bestbuddy = NULL; + double d, r, mindist = MAXBUDDY; + + r = sqrt(s->dom/PI); + for ( ; l != NULL; l = l->next) { + d = sqrt(dist2(l->dir, s->dir)) - sqrt(l->dom/PI) - r; + if (d < mindist) { + bestbuddy = l; + mindist = d; + } + } + return(bestbuddy); +} + + +extern void +absorb_specks(void) /* eliminate too-small sources */ +{ + struct source head, *buddy; + register struct source *last, *this; + + if (verbose) + fprintf(stderr, "%s: absorbing small sources...\n", progname); + head.next = donelist; + last = &head; + for (this = head.next; this != NULL; this = this->next) + if (TOOSMALL(this)) { + last->next = this->next; + buddy = findbuddy(this, head.next); + if (buddy != NULL) + mergesource(buddy, this); + else + absorb(this); + this = last; + } else + last = this; + donelist = head.next; +} + + +static void +absorb( /* absorb a source into indirect */ + register struct source *s +) +{ + FVECT dir; + double d; + register int i; + + for (i = 0; i < nglardirs; i++) { + spinvector(dir, ourview.vdir, ourview.vup, indirect[i].theta); + d = DOT(dir,s->dir)*s->dom*(sampdens*sampdens); + if (d <= 0.0) + continue; + indirect[i].sum += d * s->brt; + indirect[i].n += d; + } + freespans(s); + free((void *)s); +} + + +static void +freespans( /* free spans associated with source */ + struct source *sp +) +{ + register struct srcspan *ss; + + while ((ss = sp->first) != NULL) { + sp->first = ss->next; + free((void *)ss); + } }
