--- ray/src/util/glaresrc.c 1991/03/18 12:15:40 1.1 +++ ray/src/util/glaresrc.c 1991/04/30 16:39:39 1.15 @@ -9,6 +9,7 @@ static char SCCSid[] = "$SunId$ LBL"; */ #include "glare.h" +#include "linregr.h" #define vcont(vd,vu) ((vu)-(vd)<=SEPS) #define hcont(s1,s2) ((s1)->r-(s2)->l>=-SEPS&&(s2)->r-(s1)->l>=-SEPS) @@ -16,9 +17,7 @@ static char SCCSid[] = "$SunId$ LBL"; struct source *curlist = NULL; /* current source list */ struct source *donelist = NULL; /* finished sources */ -double threshold; /* glare threshold */ - struct srcspan * newspan(l, r, v, sb) /* allocate a new source span */ int l, r, v; @@ -50,76 +49,84 @@ analyze() /* analyze our scene */ if (spanbr == NULL) memerr("view span brightness buffer"); for (v = vsize; v >= -vsize; v--) { + close_sources(v); +#ifndef DEBUG + if (verbose) + fprintf(stderr, "%s: analyzing... %3ld%%\r", + progname, 100L*(vsize-v)/(2*vsize)); +#endif getviewspan(v, spanbr); left = hsize + 1; - for (h = -hsize; h <= hsize; h++) + for (h = -hsize; h <= hsize; h++) { if (spanbr[h+hsize] < 0.0) { /* off view */ if (left < h) { - addsrcspan(newspan(left,h-1,v,spanbr)); + addsrcspan(newspan(left,h,v,spanbr)); left = hsize + 1; } continue; } if (spanbr[h+hsize] > threshold) { /* in source */ - if (left >= h) + if (left > h) left = h; } else { /* out of source */ if (left < h) { - addsrcspan(newspan(left,h-1,v,spanbr)); + addsrcspan(newspan(left,h,v,spanbr)); left = hsize + 1; } - addindirect(h, spanbr[h+hsize]); + addindirect(h, v, spanbr[h+hsize]); } + } if (left < h) - addsrcspan(newspan(left,h-1,v,spanbr)); - close_sources(v); + addsrcspan(newspan(left,h,v,spanbr)); } - close_allsrcs(); free((char *)spanbr); + close_allsrcs(); } -addindirect(h, br) /* add brightness to indirect illuminances */ -int h; +addindirect(h, v, br) /* add brightness to indirect illuminances */ +int h, v; double br; { double tanb, d; + int hl; register int i; - if (h <= -hlim) { /* left region */ - d = (double)(h+hlim)/SAMPDENS; - if (d <= -1.0+FTINY) + hl = hlim(v); + if (h <= -hl) { /* left region */ + d = (double)(-h-hl)/sampdens; + if (d >= 1.0-FTINY) return; tanb = d/sqrt(1.0-d*d); for (i = 0; i < nglardirs; i++) { d = indirect[i].lcos - tanb*indirect[i].lsin; if (d > 0.0) { indirect[i].sum += d * br; - indirect[i].n++; + indirect[i].n += d; } } return; } - if (h >= hlim) { /* right region */ - d = (double)(h-hlim)/SAMPDENS; - if (d >= 1.0-FTINY) + if (h >= hl) { /* right region */ + d = (double)(-h+hl)/sampdens; + if (d <= -1.0+FTINY) return; tanb = d/sqrt(1.0-d*d); for (i = 0; i < nglardirs; i++) { d = indirect[i].rcos - tanb*indirect[i].rsin; if (d > 0.0) { indirect[i].sum += d * br; - indirect[i].n++; + indirect[i].n += d; } } return; } /* central region */ for (i = 0; i < nglardirs; i++) { - d = cos(h_theta(h) - indirect[i].theta); + d = cos(h_theta(h,v) - indirect[i].theta); if (d > 0.0) { indirect[i].sum += d * br; - indirect[i].n++; + indirect[i].n += d; } } } @@ -136,13 +143,14 @@ comp_thresh() /* compute glare threshold */ progname); brsum = 0.0; nsamps = 0; - for (v = vsize; v >= -vsize; v -= TSAMPSTEP) + for (v = vsize; v >= -vsize; v -= TSAMPSTEP) { for (h = -hsize; h <= hsize; h += TSAMPSTEP) { if ((br = getviewpix(h, v)) < 0.0) continue; brsum += br; nsamps++; } + } if (nsamps == 0) { fprintf(stderr, "%s: no viewable scene!\n", progname); exit(1); @@ -152,10 +160,14 @@ comp_thresh() /* compute glare threshold */ fprintf(stderr, "%s: threshold zero!\n", progname); exit(1); } - if (verbose) + if (verbose) { +#ifdef DEBUG + pict_stats(); +#endif fprintf(stderr, "%s: threshold set to %f cd/m2 from %d samples\n", progname, threshold, nsamps); + } } @@ -164,7 +176,6 @@ struct srcspan *nss; { struct source *last, *cs, *this; register struct srcspan *ss; - register int res; cs = NULL; for (this = curlist; this != NULL; this = this->next) { @@ -175,9 +186,9 @@ struct srcspan *nss; if (cs == NULL) cs = this; else { - mergesource(cs, this); last->next = this->next; - free((char *)this); + mergesource(cs, this); + this = last; } break; } @@ -188,6 +199,7 @@ struct srcspan *nss; cs = (struct source *)malloc(sizeof(struct source)); if (cs == NULL) memerr("source records"); + cs->dom = 0.0; cs->first = NULL; cs->next = curlist; curlist = cs; @@ -218,7 +230,16 @@ struct source *sp, *ap; if (prev->next == NULL) prev->next = alp; sp->first = head.next; - ap->first = NULL; + if (ap->dom > 0.0 && sp->dom > 0.0) { /* sources are done */ + sp->dir[0] *= sp->dom; + sp->dir[1] *= sp->dom; + sp->dir[2] *= sp->dom; + fvsum(sp->dir, sp->dir, ap->dir, ap->dom); + normalize(sp->dir); + sp->brt = (sp->brt*sp->dom + ap->brt*ap->dom) + / (sp->dom + ap->dom); + } + free((char *)ap); } @@ -243,47 +264,204 @@ int v; close_allsrcs() /* done with everything */ { - register struct source *this; + register struct source *this, *next; - for (this = curlist; this != NULL; this = this->next) + this = curlist; + while (this != NULL) { + next = this->next; donesource(this); + this = next; + } curlist = NULL; } +struct srcspan * +splitspan(sso, h, v, m) /* divide source span at point */ +register struct srcspan *sso; +double h, v, m; +{ + register struct srcspan *ssn; + double d; + int hs; + + d = h - m*(sso->v - v); + hs = d < 0. ? d-.5 : d+.5; + if (sso->l >= hs) + return(NULL); + if (sso->r <= hs) + return(sso); + /* need to split it */ + ssn = (struct srcspan *)malloc(sizeof(struct srcspan)); + if (ssn == NULL) + memerr("source spans in splitspan"); + ssn->brsum = (double)(hs - sso->l)/(sso->r - sso->l) * sso->brsum; + sso->brsum -= ssn->brsum; + ssn->v = sso->v; + ssn->l = sso->l; + ssn->r = sso->l = hs; + return(ssn); +} + + +struct source * +splitsource(so) /* divide source in two if it's big and long */ +struct source *so; +{ + LRSUM lr; + LRLIN fit; + register struct srcspan *ss, *ssn; + struct srcspan *ssl, *ssnl, head; + int h; + double mh, mv; + struct source *sn; + + lrclear(&lr); + for (ss = so->first; ss != NULL; ss = ss->next) + for (h = ss->l; h < ss->r; h++) + lrpoint(h, ss->v, &lr); + if ((double)lr.n/(sampdens*sampdens) < SABIG) + return(NULL); /* too small */ + if (lrfit(&fit, &lr) < 0) + return(NULL); /* can't fit a line */ + if (fit.correlation < LCORR && fit.correlation > -LCORR) + return(NULL); + if (verbose) + fprintf(stderr, "%s: splitting large source\n", progname); + mh = lrxavg(&lr); + mv = lryavg(&lr); + sn = (struct source *)malloc(sizeof(struct source)); + if (sn == NULL) + memerr("source records in splitsource"); + sn->dom = 0.0; + sn->first = NULL; + ssnl = NULL; + head.next = so->first; + ssl = &head; + for (ss = so->first; ss != NULL; ssl = ss, ss = ss->next) + if ((ssn = splitspan(ss, mh, mv, fit.slope)) != NULL) { + if (ssn == ss) { /* remove from old */ + ssl->next = ss->next; + ss = ssl; + } + if (ssnl == NULL) /* add to new */ + sn->first = ssn; + else + ssnl->next = ssn; + ssn->next = NULL; + ssnl = ssn; + } + so->first = head.next; + return(sn); +} + + donesource(sp) /* finished with this source */ register struct source *sp; { - FVECT dthis, dright; + struct source *newsrc; register struct srcspan *ss; int h, n; - double d; + double hsum, vsum, d; + while ((newsrc = splitsource(sp)) != NULL) /* split it? */ + donesource(newsrc); sp->dom = 0.0; - sp->dir[0] = sp->dir[1] = sp->dir[1] = 0.0; + hsum = vsum = 0.0; sp->brt = 0.0; + n = 0; for (ss = sp->first; ss != NULL; ss = ss->next) { sp->brt += ss->brsum; n += ss->r - ss->l; - compdir(dright, ss->r, ss->v); - for (h = ss->r-1; h >= ss->l; h--) { - compdir(dthis, h, ss->v); - d = dist2(dthis, dright); - fvsum(sp->dir, sp->dir, dthis, d); + for (h = ss->l; h < ss->r; h++) { + d = pixsize(h, ss->v); + hsum += d*h; + vsum += d*ss->v; sp->dom += d; - VCOPY(dright, dthis); } - free((char *)ss); } - sp->first = NULL; sp->brt /= (double)n; - sp->dir[0] /= sp->dom; - sp->dir[1] /= sp->dom; - sp->dir[2] /= sp->dom; + compdir(sp->dir, (int)(hsum/sp->dom), (int)(vsum/sp->dom)); + freespans(sp); sp->next = donelist; donelist = sp; if (verbose) fprintf(stderr, - "%s: found source at (%f,%f,%f), solid angle %f, brightness %f\n", - progname, sp->dir[0], sp->dir[1], sp->dir[2], sp->brt); + "%s: source at [%.3f,%.3f,%.3f], dw %.5f, br %.1f (%d samps)\n", + progname, sp->dir[0], sp->dir[1], sp->dir[2], + sp->dom, sp->brt, n); +} + + +struct source * +findbuddy(s, l) /* find close enough source to s in l*/ +register struct source *s, *l; +{ + struct source *bestbuddy = NULL; + double d, r, mindist = MAXBUDDY; + + r = sqrt(s->dom/PI); + for ( ; l != NULL; l = l->next) { + d = sqrt(dist2(l->dir, s->dir)) - sqrt(l->dom/PI) - r; + if (d < mindist) { + bestbuddy = l; + mindist = d; + } + } + return(bestbuddy); +} + + +absorb_specks() /* eliminate too-small sources */ +{ + struct source head, *buddy; + register struct source *last, *this; + + if (verbose) + fprintf(stderr, "%s: absorbing small sources...\n", progname); + head.next = donelist; + last = &head; + for (this = head.next; this != NULL; this = this->next) + if (TOOSMALL(this)) { + last->next = this->next; + buddy = findbuddy(this, head.next); + if (buddy != NULL) + mergesource(buddy, this); + else + absorb(this); + this = last; + } else + last = this; + donelist = head.next; +} + + +absorb(s) /* absorb a source into indirect */ +register struct source *s; +{ + FVECT dir; + double d; + register int i; + + for (i = 0; i < nglardirs; i++) { + spinvector(dir, ourview.vdir, ourview.vup, indirect[i].theta); + d = DOT(dir,s->dir)*s->dom*(sampdens*sampdens); + if (d <= 0.0) + continue; + indirect[i].sum += d * s->brt; + indirect[i].n += d; + } + freespans(s); + free((char *)s); +} + + +freespans(sp) /* free spans associated with source */ +struct source *sp; +{ + register struct srcspan *ss; + + for (ss = sp->first; ss != NULL; ss = ss->next) + free((char *)ss); + sp->first = NULL; }
