root/Development/ray/src/util/glarendx.c
Revision: 2.17
Committed: Tue Jun 3 21:31:51 2025 UTC (6 months, 3 weeks ago) by greg
CVS Tags: rad6R0, HEAD
Changes since 2.16: +1 -2 lines
# User Rev Content
1 greg 1.1 #ifndef lint
2 greg 2.17 static const char RCSid[] = "$Id: glarendx.c,v 2.16 2020/07/24 16:58:16 greg Exp $";
3 greg 1.1 #endif
4     /*
5 greg 1.9 * Compute Glare Index given by program name or -t option:
6 greg 1.1 *
7 greg 2.4 * dgi - Daylight Glare Index
8     * brs_gi - Building Research Station Glare Index (Petherbridge
9     * & Hopkinson)
10     * ugr - Unified Glare Rating System (Fischer)
11 greg 1.2 * guth_dgr - Guth discomfort glare rating
12     * guth_vcp - Guth visual comfort probability
13 greg 1.9 * cie_cgi - CIE Glare Index (1983, due to Einhorn)
14     * vert_dir - Direct vertical illuminance
15     * vert_ind - Indirect vertical illuminance (from input)
16     * vert_ill - Total vertical illuminance
17 greg 1.1 *
18     * 12 April 1991 Greg Ward EPFL
19 greg 2.4 * 19 April 1993 R. Compagnon EPFL (added dgi, brs_gi, ugr)
20 greg 1.1 */
21 schorsch 2.10
22 schorsch 2.8 #include <string.h>
23
24 greg 1.1 #include "standard.h"
25 greg 2.16 #include "paths.h"
26 greg 1.1 #include "view.h"
27 schorsch 2.10
28
29     struct glare_src {
30     FVECT dir; /* source direction */
31     double dom; /* solid angle */
32     double lum; /* average luminance */
33     struct glare_src *next;
34     } *all_srcs = NULL;
35
36     struct glare_dir {
37     double ang; /* angle (in radians) */
38     double indirect; /* indirect illuminance */
39     struct glare_dir *next;
40     } *all_dirs = NULL;
41
42     typedef double gdfun(struct glare_dir *gd);
43
44     static gdfun dgi;
45     static gdfun brs_gi;
46     static gdfun ugr;
47     static gdfun guth_dgr;
48     static gdfun guth_vcp;
49     static gdfun cie_cgi;
50     static gdfun direct;
51     static gdfun indirect;
52     static gdfun total;
53
54     static gethfunc headline;
55     static void init(void);
56     static void read_input(void);
57     static void print_values(gdfun *func);
58     static double posindex(FVECT sd, FVECT vd, FVECT vu);
59
60
61 greg 1.1 struct named_func {
62     char *name;
63 schorsch 2.10 gdfun *func;
64 greg 1.9 char *descrip;
65 greg 1.1 } all_funcs[] = {
66 greg 2.4 {"dgi", dgi, "Daylight Glare Index"},
67     {"brs_gi", brs_gi, "BRS Glare Index"},
68     {"ugr", ugr, "Unified Glare Rating"},
69 greg 1.9 {"guth_vcp", guth_vcp, "Guth Visual Comfort Probability"},
70     {"cie_cgi", cie_cgi, "CIE Glare Index (Einhorn)"},
71     {"guth_dgr", guth_dgr, "Guth Disability Glare Rating"},
72     {"vert_dir", direct, "Direct Vertical Illuminance"},
73     {"vert_ill", total, "Total Vertical Illuminance"},
74     {"vert_ind", indirect, "Indirect Vertical Illuminance"},
75 greg 1.1 {NULL}
76     };
77 schorsch 2.10
78 greg 1.1 #define newp(type) (type *)malloc(sizeof(type))
79 schorsch 2.10
80 greg 1.1 int print_header = 1;
81 schorsch 2.10
82 greg 1.1 VIEW midview = STDVIEW;
83 schorsch 2.10
84 greg 1.4 int wrongformat = 0;
85 schorsch 2.10
86
87     int
88     main(
89     int argc,
90     char *argv[]
91     )
92 greg 1.1 {
93     struct named_func *funp;
94     int i;
95     /* get program name */
96 greg 2.16 progname = fixargv0(argv[0]);
97 greg 1.1 /* get options */
98     for (i = 1; i < argc && argv[i][0] == '-'; i++)
99     switch (argv[i][1]) {
100     case 't':
101 greg 2.16 progname = argv[++i];
102 greg 1.1 break;
103     case 'h':
104     print_header = 0;
105     break;
106     default:
107     goto userr;
108     }
109     if (i < argc-1)
110     goto userr;
111     if (i == argc-1) /* open file */
112     if (freopen(argv[i], "r", stdin) == NULL) {
113     perror(argv[i]);
114     exit(1);
115     }
116 greg 1.9 /* find and run calculation */
117 greg 1.1 for (funp = all_funcs; funp->name != NULL; funp++)
118 greg 2.16 if (!strcmp(funp->name, progname)) {
119 greg 1.9 init();
120     read_input();
121     if (print_header) {
122     printargs(i, argv, stdout);
123     putchar('\n');
124     }
125 greg 1.1 print_values(funp->func);
126     exit(0); /* we're done */
127     }
128     /* invalid function */
129     userr:
130 greg 1.9 fprintf(stderr, "Usage: %s -t type [-h] [input]\n", progname);
131     fprintf(stderr, "\twhere 'type' is one of the following:\n");
132     for (funp = all_funcs; funp->name != NULL; funp++)
133     fprintf(stderr, "\t%12s\t%s\n", funp->name, funp->descrip);
134 greg 1.1 exit(1);
135     }
136 schorsch 2.10
137
138     static int
139     headline( /* get line from header */
140     char *s,
141     void *p
142     )
143 greg 1.1 {
144 greg 2.13 char fmt[MAXFMTLEN];
145 schorsch 2.10
146 greg 1.1 if (print_header) /* copy to output */
147     fputs(s, stdout);
148 greg 2.2 if (isview(s))
149     sscanview(&midview, s);
150 greg 1.4 else if (isformat(s)) {
151     formatval(fmt, s);
152 greg 1.6 wrongformat = strcmp(fmt, "ascii");
153 greg 1.4 }
154 gwlarson 2.6 return(0);
155 greg 1.1 }
156 schorsch 2.10
157
158     static void
159     init(void) /* initialize calculation */
160 greg 1.9 {
161 greg 2.14 char *err;
162 greg 1.9 /* read header */
163     getheader(stdin, headline, NULL);
164     if (wrongformat) {
165     fprintf(stderr, "%s: bad input format\n", progname);
166     exit(1);
167     }
168     /* set view */
169 greg 2.14 if ((err = setview(&midview)) != NULL) {
170     fprintf(stderr, "%s: %s\n",
171     progname, err);
172     exit(1);
173     }
174     if (fabs(DOT(midview.vdir, midview.vup)) > 1e-4) {
175     fprintf(stderr,
176     "%s: Input view direction not perpendicular to up vector\n",
177 greg 1.9 progname);
178     exit(1);
179     }
180     }
181 schorsch 2.10
182
183     static void
184     read_input(void) /* read glare sources from stdin */
185 greg 1.1 {
186     #define S_SEARCH 0
187     #define S_SOURCE 1
188     #define S_DIREC 2
189     int state = S_SEARCH;
190     char buf[128];
191 greg 2.11 struct glare_src *gs;
192     struct glare_dir *gd;
193 schorsch 2.10
194 greg 1.1 while (fgets(buf, sizeof(buf), stdin) != NULL)
195     switch (state) {
196     case S_SEARCH:
197     if (!strcmp(buf, "BEGIN glare source\n"))
198     state = S_SOURCE;
199     else if (!strcmp(buf, "BEGIN indirect illuminance\n"))
200     state = S_DIREC;
201     break;
202     case S_SOURCE:
203     if (!strncmp(buf, "END", 3)) {
204     state = S_SEARCH;
205     break;
206     }
207     if ((gs = newp(struct glare_src)) == NULL)
208     goto memerr;
209 greg 2.11 if (sscanf(buf, FVFORMAT, &gs->dir[0], &gs->dir[1],
210     &gs->dir[2]) != 3 ||
211 greg 2.12 sscanf(sskip2(buf, 3), "%lf %lf",
212 greg 2.11 &gs->dom, &gs->lum) != 2)
213 greg 1.1 goto readerr;
214 greg 1.2 normalize(gs->dir);
215 greg 1.1 gs->next = all_srcs;
216     all_srcs = gs;
217     break;
218     case S_DIREC:
219     if (!strncmp(buf, "END", 3)) {
220     state = S_SEARCH;
221     break;
222     }
223     if ((gd = newp(struct glare_dir)) == NULL)
224     goto memerr;
225     if (sscanf(buf, "%lf %lf",
226     &gd->ang, &gd->indirect) != 2)
227     goto readerr;
228     gd->ang *= PI/180.0; /* convert to radians */
229     gd->next = all_dirs;
230     all_dirs = gd;
231     break;
232     }
233     return;
234     memerr:
235     perror(progname);
236     exit(1);
237     readerr:
238     fprintf(stderr, "%s: read error on input\n", progname);
239     exit(1);
240     #undef S_SEARCH
241     #undef S_SOURCE
242     #undef S_DIREC
243     }
244 schorsch 2.10
245
246     static void
247     print_values( /* print out calculations */
248     gdfun *func
249     )
250 greg 1.1 {
251 greg 2.11 struct glare_dir *gd;
252 schorsch 2.10
253 greg 1.1 for (gd = all_dirs; gd != NULL; gd = gd->next)
254 schorsch 2.10 printf("%f\t%f\n", gd->ang*(180.0/PI), (*func)(gd));
255 greg 1.1 }
256 schorsch 2.10
257
258     static double
259     direct( /* compute direct vertical illuminance */
260     struct glare_dir *gd
261     )
262 greg 1.1 {
263     FVECT mydir;
264     double d, dval;
265 greg 2.11 struct glare_src *gs;
266 schorsch 2.10
267 greg 1.1 spinvector(mydir, midview.vdir, midview.vup, gd->ang);
268     dval = 0.0;
269     for (gs = all_srcs; gs != NULL; gs = gs->next) {
270     d = DOT(mydir,gs->dir);
271     if (d > FTINY)
272     dval += d * gs->dom * gs->lum;
273     }
274     return(dval);
275 greg 1.9 }
276 schorsch 2.10
277
278     static double
279     indirect( /* return indirect vertical illuminance */
280     struct glare_dir *gd
281     )
282 greg 1.9 {
283     return(gd->indirect);
284     }
285 schorsch 2.10
286
287     static double
288     total( /* return total vertical illuminance */
289     struct glare_dir *gd
290     )
291 greg 1.9 {
292     return(direct(gd)+gd->indirect);
293 greg 1.1 }
294 schorsch 2.10
295
296 greg 1.1 /*
297     * posindex - compute glare position index from:
298     *
299     * Source Direction
300     * View Direction
301     * View Up Direction
302     *
303     * All vectors are assumed to be normalized.
304     * This function is an implementation of the method proposed by
305     * Robert Levin in his 1975 JIES article.
306 greg 1.5 * This calculation presumes the view direction and up vectors perpendicular.
307 greg 1.1 * We return a value less than zero for improper positions.
308     */
309 schorsch 2.10
310     static double
311     posindex( /* compute position index */
312     FVECT sd,
313     FVECT vd,
314     FVECT vu
315     )
316 greg 1.1 {
317     double sigma, tau;
318     double d;
319 schorsch 2.10
320 greg 1.1 d = DOT(sd,vd);
321     if (d <= 0.0)
322     return(-1.0);
323 greg 2.14 if (d >= 1.0-FTINY)
324 greg 1.5 return(1.0);
325 greg 1.1 sigma = acos(d) * (180./PI);
326 greg 2.4 d = fabs(DOT(sd,vu)/sqrt(1.0-d*d));
327 greg 2.14 tau = Acos(d) * (180./PI);
328 greg 1.1 return( exp( sigma*( (35.2 - tau*.31889 - 1.22*exp(-.22222*tau))*1e-3
329     + sigma*(21. + tau*(.26667 + tau*-.002963))*1e-5 )
330     ) );
331     }
332 schorsch 2.10
333
334     static double
335     dgi( /* compute Daylight Glare Index */
336     struct glare_dir *gd
337     )
338 greg 2.4 {
339 greg 2.11 struct glare_src *gs;
340 greg 2.4 FVECT mydir,testdir[7],vhor;
341 greg 2.9 double r,posn,omega,p[7],sum;
342 greg 2.14 int i;
343 schorsch 2.10
344 greg 2.4 spinvector(mydir, midview.vdir, midview.vup, gd->ang);
345 greg 2.14 sum = 0.0;
346 greg 2.4 for (gs = all_srcs; gs != NULL; gs = gs->next) {
347 greg 1.1
348 greg 2.4 /* compute 1/p^2 weighted solid angle of the source */
349 greg 2.14 r = 1. - gs->dom*(.5/PI);
350     r = sqrt(1. - r*r);
351 greg 2.4 fcross(vhor,gs->dir,midview.vup);
352 greg 2.14 if (normalize(vhor) == 0.)
353     continue;
354 greg 2.4 VCOPY(testdir[0],gs->dir);
355     fvsum(testdir[1],gs->dir,vhor,r);
356     fvsum(testdir[2],gs->dir,vhor,0.5*r);
357     fvsum(testdir[5],testdir[2],midview.vup,-0.866*r);
358     fvsum(testdir[2],testdir[2],midview.vup,0.866*r);
359     fvsum(testdir[3],gs->dir,vhor,-r);
360     fvsum(testdir[4],gs->dir,vhor,-0.5*r);
361     fvsum(testdir[6],testdir[4],midview.vup,0.866*r);
362     fvsum(testdir[4],testdir[4],midview.vup,-0.866*r);
363     for (i = 0; i < 7; i++) {
364 greg 2.14 p[i] = 0.0;
365     if (normalize(testdir[i]) == 0.)
366     continue;
367 greg 2.9 posn = posindex(testdir[i],mydir,midview.vup);
368 greg 2.14 if (posn > FTINY)
369 greg 2.9 p[i] = 1./(posn*posn);
370 greg 2.4 }
371 greg 2.14 r = 1. - gs->dom*(.5/PI);
372 greg 2.4 omega = gs->dom*p[0];
373 greg 2.14 omega += (r*PI*(1.+1./(r*r))-2.*PI)*(-p[0]+(p[1]+p[2])*0.5);
374     omega += (2.*PI-r*PI*(1.+1./(r*r)))*(-p[0]-0.1667*(p[1]+p[3])
375 greg 2.4 +0.3334*(p[2]+p[4]+p[5]+p[6]));
376 greg 2.14 if (omega <= 0.)
377 greg 2.15 continue;
378 schorsch 2.10 sum += pow(gs->lum,1.6) * pow(omega,0.8) /
379 greg 2.14 (gd->indirect*(1./PI) + 0.07*sqrt(gs->dom)*gs->lum);
380 greg 2.4 }
381 greg 2.14 if (sum <= FTINY)
382 greg 2.4 return(0.0);
383 greg 2.14 return( 10.*log10(0.478*sum) );
384 greg 2.4 }
385
386 schorsch 2.10
387     static double
388     brs_gi( /* compute BRS Glare Index */
389     struct glare_dir *gd
390     )
391 greg 2.4 {
392 greg 2.11 struct glare_src *gs;
393 greg 2.4 FVECT mydir;
394     double p;
395     double sum;
396 schorsch 2.10
397 greg 2.4 spinvector(mydir, midview.vdir, midview.vup, gd->ang);
398     sum = 0.0;
399     for (gs = all_srcs; gs != NULL; gs = gs->next) {
400     p = posindex(gs->dir, mydir, midview.vup);
401     if (p <= FTINY)
402     continue;
403     sum += pow(gs->lum/p,1.6) * pow(gs->dom,0.8);
404     }
405     if (sum <= FTINY)
406     return(0.0);
407 greg 2.14 sum *= PI/gd->indirect;
408 greg 2.4 return(10*log10(0.478*sum));
409     }
410
411
412 schorsch 2.10 static double
413     guth_dgr( /* compute Guth discomfort glare rating */
414     struct glare_dir *gd
415     )
416 greg 1.1 {
417     #define q(w) (20.4*w+1.52*pow(w,.2)-.075)
418 greg 2.11 struct glare_src *gs;
419 greg 1.7 FVECT mydir;
420 greg 1.1 double p;
421     double sum;
422 greg 1.3 double wtot, brsum;
423 greg 1.1 int n;
424 schorsch 2.10
425 greg 1.7 spinvector(mydir, midview.vdir, midview.vup, gd->ang);
426 greg 1.3 sum = wtot = brsum = 0.0; n = 0;
427 greg 1.1 for (gs = all_srcs; gs != NULL; gs = gs->next) {
428 greg 1.7 p = posindex(gs->dir, mydir, midview.vup);
429 greg 1.1 if (p <= FTINY)
430     continue;
431     sum += gs->lum * q(gs->dom) / p;
432 greg 1.3 brsum += gs->lum * gs->dom;
433     wtot += gs->dom;
434 greg 1.1 n++;
435     }
436     if (n == 0)
437     return(0.0);
438 greg 1.8 return( pow(.5*sum/pow((brsum+(5.-wtot)*gd->indirect/PI)/5.,.44),
439 greg 1.1 pow((double)n, -.0914) ) );
440     #undef q
441     }
442 schorsch 2.10
443
444 greg 1.1 #ifndef M_SQRT2
445     #define M_SQRT2 1.41421356237309504880
446     #endif
447 schorsch 2.10
448 greg 1.1 #define norm_integral(z) (1.-.5*erfc((z)/M_SQRT2))
449 schorsch 2.10
450
451     static double
452     guth_vcp( /* compute Guth visual comfort probability */
453     struct glare_dir *gd
454     )
455 greg 1.1 {
456 greg 2.5 extern double erfc();
457 greg 1.7 double dgr;
458 schorsch 2.10
459 greg 1.7 dgr = guth_dgr(gd);
460     if (dgr <= FTINY)
461     return(100.0);
462     return(100.*norm_integral(6.374-1.3227*log(dgr)));
463 greg 1.8 }
464 schorsch 2.10
465
466     static double
467     cie_cgi( /* compute CIE Glare Index */
468     struct glare_dir *gd
469     )
470 greg 1.8 {
471 greg 2.11 struct glare_src *gs;
472 greg 1.8 FVECT mydir;
473     double dillum;
474     double p;
475     double sum;
476 schorsch 2.10
477 greg 1.8 spinvector(mydir, midview.vdir, midview.vup, gd->ang);
478     sum = 0.0;
479     for (gs = all_srcs; gs != NULL; gs = gs->next) {
480     p = posindex(gs->dir, mydir, midview.vup);
481     if (p <= FTINY)
482     continue;
483     sum += gs->lum*gs->lum * gs->dom / (p*p);
484     }
485     if (sum <= FTINY)
486     return(0.0);
487     dillum = direct(gd);
488     return(8.*log10(2.*sum*(1.+dillum/500.)/(dillum+gd->indirect)));
489 greg 2.4 }
490
491
492 schorsch 2.10 static double
493     ugr( /* compute Unified Glare Rating */
494     struct glare_dir *gd
495     )
496 greg 2.4 {
497 greg 2.11 struct glare_src *gs;
498 greg 2.4 FVECT mydir;
499     double p;
500     double sum;
501 schorsch 2.10
502 greg 2.4 spinvector(mydir, midview.vdir, midview.vup, gd->ang);
503     sum = 0.0;
504     for (gs = all_srcs; gs != NULL; gs = gs->next) {
505     p = posindex(gs->dir, mydir, midview.vup);
506     if (p <= FTINY)
507     continue;
508     sum += gs->lum*gs->lum * gs->dom / (p*p);
509     }
510     if (sum <= FTINY)
511     return(0.0);
512     return(8.*log10(0.25*sum*PI/gd->indirect));
513 greg 1.1 }
