| 1 |
greg |
1.1 |
#ifndef lint |
| 2 |
greg |
2.17 |
static const char RCSid[] = "$Id: glarendx.c,v 2.16 2020/07/24 16:58:16 greg Exp $"; |
| 3 |
greg |
1.1 |
#endif |
| 4 |
| 5 |
greg |
1.9 |
* Compute Glare Index given by program name or -t option: |
| 6 |
greg |
1.1 |
| 7 |
greg |
2.4 |
* dgi - Daylight Glare Index |
| 8 |
* brs_gi - Building Research Station Glare Index (Petherbridge |
| 9 |
* & Hopkinson) |
| 10 |
* ugr - Unified Glare Rating System (Fischer) |
| 11 |
greg |
1.2 |
* guth_dgr - Guth discomfort glare rating |
| 12 |
* guth_vcp - Guth visual comfort probability |
| 13 |
greg |
1.9 |
* cie_cgi - CIE Glare Index (1983, due to Einhorn) |
| 14 |
* vert_dir - Direct vertical illuminance |
| 15 |
* vert_ind - Indirect vertical illuminance (from input) |
| 16 |
* vert_ill - Total vertical illuminance |
| 17 |
greg |
1.1 |
| 18 |
* 12 April 1991 Greg Ward EPFL |
| 19 |
greg |
2.4 |
* 19 April 1993 R. Compagnon EPFL (added dgi, brs_gi, ugr) |
| 20 |
greg |
1.1 |
| 21 |
schorsch |
2.10 |
| 22 |
schorsch |
2.8 |
#include <string.h> |
| 23 |
| 24 |
greg |
1.1 |
#include "standard.h" |
| 25 |
greg |
2.16 |
#include "paths.h" |
| 26 |
greg |
1.1 |
#include "view.h" |
| 27 |
schorsch |
2.10 |
| 28 |
| 29 |
struct glare_src { |
| 30 |
FVECT dir; /* source direction */ |
| 31 |
double dom; /* solid angle */ |
| 32 |
double lum; /* average luminance */ |
| 33 |
struct glare_src *next; |
| 34 |
} *all_srcs = NULL; |
| 35 |
| 36 |
struct glare_dir { |
| 37 |
double ang; /* angle (in radians) */ |
| 38 |
double indirect; /* indirect illuminance */ |
| 39 |
struct glare_dir *next; |
| 40 |
} *all_dirs = NULL; |
| 41 |
| 42 |
typedef double gdfun(struct glare_dir *gd); |
| 43 |
| 44 |
static gdfun dgi; |
| 45 |
static gdfun brs_gi; |
| 46 |
static gdfun ugr; |
| 47 |
static gdfun guth_dgr; |
| 48 |
static gdfun guth_vcp; |
| 49 |
static gdfun cie_cgi; |
| 50 |
static gdfun direct; |
| 51 |
static gdfun indirect; |
| 52 |
static gdfun total; |
| 53 |
| 54 |
static gethfunc headline; |
| 55 |
static void init(void); |
| 56 |
static void read_input(void); |
| 57 |
static void print_values(gdfun *func); |
| 58 |
static double posindex(FVECT sd, FVECT vd, FVECT vu); |
| 59 |
| 60 |
| 61 |
greg |
1.1 |
struct named_func { |
| 62 |
char *name; |
| 63 |
schorsch |
2.10 |
gdfun *func; |
| 64 |
greg |
1.9 |
char *descrip; |
| 65 |
greg |
1.1 |
} all_funcs[] = { |
| 66 |
greg |
2.4 |
{"dgi", dgi, "Daylight Glare Index"}, |
| 67 |
{"brs_gi", brs_gi, "BRS Glare Index"}, |
| 68 |
{"ugr", ugr, "Unified Glare Rating"}, |
| 69 |
greg |
1.9 |
{"guth_vcp", guth_vcp, "Guth Visual Comfort Probability"}, |
| 70 |
{"cie_cgi", cie_cgi, "CIE Glare Index (Einhorn)"}, |
| 71 |
{"guth_dgr", guth_dgr, "Guth Disability Glare Rating"}, |
| 72 |
{"vert_dir", direct, "Direct Vertical Illuminance"}, |
| 73 |
{"vert_ill", total, "Total Vertical Illuminance"}, |
| 74 |
{"vert_ind", indirect, "Indirect Vertical Illuminance"}, |
| 75 |
greg |
1.1 |
{NULL} |
| 76 |
| 77 |
schorsch |
2.10 |
| 78 |
greg |
1.1 |
#define newp(type) (type *)malloc(sizeof(type)) |
| 79 |
schorsch |
2.10 |
| 80 |
greg |
1.1 |
int print_header = 1; |
| 81 |
schorsch |
2.10 |
| 82 |
greg |
1.1 |
VIEW midview = STDVIEW; |
| 83 |
schorsch |
2.10 |
| 84 |
greg |
1.4 |
int wrongformat = 0; |
| 85 |
schorsch |
2.10 |
| 86 |
| 87 |
int |
| 88 |
main( |
| 89 |
int argc, |
| 90 |
char *argv[] |
| 91 |
| 92 |
greg |
1.1 |
| 93 |
struct named_func *funp; |
| 94 |
int i; |
| 95 |
/* get program name */ |
| 96 |
greg |
2.16 |
progname = fixargv0(argv[0]); |
| 97 |
greg |
1.1 |
/* get options */ |
| 98 |
for (i = 1; i < argc && argv[i][0] == '-'; i++) |
| 99 |
switch (argv[i][1]) { |
| 100 |
case 't': |
| 101 |
greg |
2.16 |
progname = argv[++i]; |
| 102 |
greg |
1.1 |
break; |
| 103 |
case 'h': |
| 104 |
print_header = 0; |
| 105 |
break; |
| 106 |
default: |
| 107 |
goto userr; |
| 108 |
| 109 |
if (i < argc-1) |
| 110 |
goto userr; |
| 111 |
if (i == argc-1) /* open file */ |
| 112 |
if (freopen(argv[i], "r", stdin) == NULL) { |
| 113 |
perror(argv[i]); |
| 114 |
exit(1); |
| 115 |
| 116 |
greg |
1.9 |
/* find and run calculation */ |
| 117 |
greg |
1.1 |
for (funp = all_funcs; funp->name != NULL; funp++) |
| 118 |
greg |
2.16 |
if (!strcmp(funp->name, progname)) { |
| 119 |
greg |
1.9 |
init(); |
| 120 |
read_input(); |
| 121 |
if (print_header) { |
| 122 |
printargs(i, argv, stdout); |
| 123 |
putchar('\n'); |
| 124 |
| 125 |
greg |
1.1 |
print_values(funp->func); |
| 126 |
exit(0); /* we're done */ |
| 127 |
| 128 |
/* invalid function */ |
| 129 |
userr: |
| 130 |
greg |
1.9 |
fprintf(stderr, "Usage: %s -t type [-h] [input]\n", progname); |
| 131 |
fprintf(stderr, "\twhere 'type' is one of the following:\n"); |
| 132 |
| 133 |
fprintf(stderr, "\t%12s\t%s\n", funp->name, funp->descrip); |
| 134 |
greg |
1.1 |
exit(1); |
| 135 |
| 136 |
schorsch |
2.10 |
| 137 |
| 138 |
static int |
| 139 |
headline( /* get line from header */ |
| 140 |
char *s, |
| 141 |
void *p |
| 142 |
| 143 |
greg |
1.1 |
| 144 |
greg |
2.13 |
char fmt[MAXFMTLEN]; |
| 145 |
schorsch |
2.10 |
| 146 |
greg |
1.1 |
if (print_header) /* copy to output */ |
| 147 |
fputs(s, stdout); |
| 148 |
greg |
2.2 |
if (isview(s)) |
| 149 |
sscanview(&midview, s); |
| 150 |
greg |
1.4 |
else if (isformat(s)) { |
| 151 |
formatval(fmt, s); |
| 152 |
greg |
1.6 |
wrongformat = strcmp(fmt, "ascii"); |
| 153 |
greg |
1.4 |
| 154 |
gwlarson |
2.6 |
return(0); |
| 155 |
greg |
1.1 |
| 156 |
schorsch |
2.10 |
| 157 |
| 158 |
static void |
| 159 |
init(void) /* initialize calculation */ |
| 160 |
greg |
1.9 |
| 161 |
greg |
2.14 |
char *err; |
| 162 |
greg |
1.9 |
/* read header */ |
| 163 |
getheader(stdin, headline, NULL); |
| 164 |
if (wrongformat) { |
| 165 |
fprintf(stderr, "%s: bad input format\n", progname); |
| 166 |
exit(1); |
| 167 |
| 168 |
/* set view */ |
| 169 |
greg |
2.14 |
if ((err = setview(&midview)) != NULL) { |
| 170 |
fprintf(stderr, "%s: %s\n", |
| 171 |
progname, err); |
| 172 |
exit(1); |
| 173 |
| 174 |
if (fabs(DOT(midview.vdir, midview.vup)) > 1e-4) { |
| 175 |
fprintf(stderr, |
| 176 |
"%s: Input view direction not perpendicular to up vector\n", |
| 177 |
greg |
1.9 |
progname); |
| 178 |
exit(1); |
| 179 |
| 180 |
| 181 |
schorsch |
2.10 |
| 182 |
| 183 |
static void |
| 184 |
read_input(void) /* read glare sources from stdin */ |
| 185 |
greg |
1.1 |
| 186 |
#define S_SEARCH 0 |
| 187 |
#define S_SOURCE 1 |
| 188 |
#define S_DIREC 2 |
| 189 |
int state = S_SEARCH; |
| 190 |
char buf[128]; |
| 191 |
greg |
2.11 |
struct glare_src *gs; |
| 192 |
struct glare_dir *gd; |
| 193 |
schorsch |
2.10 |
| 194 |
greg |
1.1 |
while (fgets(buf, sizeof(buf), stdin) != NULL) |
| 195 |
switch (state) { |
| 196 |
case S_SEARCH: |
| 197 |
if (!strcmp(buf, "BEGIN glare source\n")) |
| 198 |
state = S_SOURCE; |
| 199 |
else if (!strcmp(buf, "BEGIN indirect illuminance\n")) |
| 200 |
state = S_DIREC; |
| 201 |
break; |
| 202 |
case S_SOURCE: |
| 203 |
if (!strncmp(buf, "END", 3)) { |
| 204 |
state = S_SEARCH; |
| 205 |
break; |
| 206 |
| 207 |
if ((gs = newp(struct glare_src)) == NULL) |
| 208 |
goto memerr; |
| 209 |
greg |
2.11 |
if (sscanf(buf, FVFORMAT, &gs->dir[0], &gs->dir[1], |
| 210 |
&gs->dir[2]) != 3 || |
| 211 |
greg |
2.12 |
sscanf(sskip2(buf, 3), "%lf %lf", |
| 212 |
greg |
2.11 |
&gs->dom, &gs->lum) != 2) |
| 213 |
greg |
1.1 |
goto readerr; |
| 214 |
greg |
1.2 |
normalize(gs->dir); |
| 215 |
greg |
1.1 |
gs->next = all_srcs; |
| 216 |
all_srcs = gs; |
| 217 |
break; |
| 218 |
case S_DIREC: |
| 219 |
| 220 |
state = S_SEARCH; |
| 221 |
break; |
| 222 |
| 223 |
if ((gd = newp(struct glare_dir)) == NULL) |
| 224 |
goto memerr; |
| 225 |
if (sscanf(buf, "%lf %lf", |
| 226 |
&gd->ang, &gd->indirect) != 2) |
| 227 |
goto readerr; |
| 228 |
gd->ang *= PI/180.0; /* convert to radians */ |
| 229 |
gd->next = all_dirs; |
| 230 |
all_dirs = gd; |
| 231 |
break; |
| 232 |
| 233 |
return; |
| 234 |
memerr: |
| 235 |
perror(progname); |
| 236 |
exit(1); |
| 237 |
readerr: |
| 238 |
fprintf(stderr, "%s: read error on input\n", progname); |
| 239 |
exit(1); |
| 240 |
#undef S_SEARCH |
| 241 |
#undef S_SOURCE |
| 242 |
#undef S_DIREC |
| 243 |
| 244 |
schorsch |
2.10 |
| 245 |
| 246 |
static void |
| 247 |
print_values( /* print out calculations */ |
| 248 |
gdfun *func |
| 249 |
| 250 |
greg |
1.1 |
| 251 |
greg |
2.11 |
| 252 |
schorsch |
2.10 |
| 253 |
greg |
1.1 |
for (gd = all_dirs; gd != NULL; gd = gd->next) |
| 254 |
schorsch |
2.10 |
printf("%f\t%f\n", gd->ang*(180.0/PI), (*func)(gd)); |
| 255 |
greg |
1.1 |
| 256 |
schorsch |
2.10 |
| 257 |
| 258 |
static double |
| 259 |
direct( /* compute direct vertical illuminance */ |
| 260 |
struct glare_dir *gd |
| 261 |
| 262 |
greg |
1.1 |
| 263 |
FVECT mydir; |
| 264 |
double d, dval; |
| 265 |
greg |
2.11 |
| 266 |
schorsch |
2.10 |
| 267 |
greg |
1.1 |
spinvector(mydir, midview.vdir, midview.vup, gd->ang); |
| 268 |
dval = 0.0; |
| 269 |
for (gs = all_srcs; gs != NULL; gs = gs->next) { |
| 270 |
d = DOT(mydir,gs->dir); |
| 271 |
if (d > FTINY) |
| 272 |
dval += d * gs->dom * gs->lum; |
| 273 |
| 274 |
return(dval); |
| 275 |
greg |
1.9 |
| 276 |
schorsch |
2.10 |
| 277 |
| 278 |
static double |
| 279 |
indirect( /* return indirect vertical illuminance */ |
| 280 |
| 281 |
| 282 |
greg |
1.9 |
| 283 |
return(gd->indirect); |
| 284 |
| 285 |
schorsch |
2.10 |
| 286 |
| 287 |
static double |
| 288 |
total( /* return total vertical illuminance */ |
| 289 |
| 290 |
| 291 |
greg |
1.9 |
| 292 |
return(direct(gd)+gd->indirect); |
| 293 |
greg |
1.1 |
| 294 |
schorsch |
2.10 |
| 295 |
| 296 |
greg |
1.1 |
| 297 |
* posindex - compute glare position index from: |
| 298 |
| 299 |
* Source Direction |
| 300 |
* View Direction |
| 301 |
* View Up Direction |
| 302 |
| 303 |
* All vectors are assumed to be normalized. |
| 304 |
* This function is an implementation of the method proposed by |
| 305 |
* Robert Levin in his 1975 JIES article. |
| 306 |
greg |
1.5 |
* This calculation presumes the view direction and up vectors perpendicular. |
| 307 |
greg |
1.1 |
* We return a value less than zero for improper positions. |
| 308 |
| 309 |
schorsch |
2.10 |
| 310 |
static double |
| 311 |
posindex( /* compute position index */ |
| 312 |
FVECT sd, |
| 313 |
FVECT vd, |
| 314 |
FVECT vu |
| 315 |
| 316 |
greg |
1.1 |
| 317 |
double sigma, tau; |
| 318 |
double d; |
| 319 |
schorsch |
2.10 |
| 320 |
greg |
1.1 |
d = DOT(sd,vd); |
| 321 |
if (d <= 0.0) |
| 322 |
return(-1.0); |
| 323 |
greg |
2.14 |
if (d >= 1.0-FTINY) |
| 324 |
greg |
1.5 |
return(1.0); |
| 325 |
greg |
1.1 |
sigma = acos(d) * (180./PI); |
| 326 |
greg |
2.4 |
d = fabs(DOT(sd,vu)/sqrt(1.0-d*d)); |
| 327 |
greg |
2.14 |
tau = Acos(d) * (180./PI); |
| 328 |
greg |
1.1 |
return( exp( sigma*( (35.2 - tau*.31889 - 1.22*exp(-.22222*tau))*1e-3 |
| 329 |
+ sigma*(21. + tau*(.26667 + tau*-.002963))*1e-5 ) |
| 330 |
| 331 |
| 332 |
schorsch |
2.10 |
| 333 |
| 334 |
static double |
| 335 |
dgi( /* compute Daylight Glare Index */ |
| 336 |
| 337 |
| 338 |
greg |
2.4 |
| 339 |
greg |
2.11 |
| 340 |
greg |
2.4 |
FVECT mydir,testdir[7],vhor; |
| 341 |
greg |
2.9 |
double r,posn,omega,p[7],sum; |
| 342 |
greg |
2.14 |
int i; |
| 343 |
schorsch |
2.10 |
| 344 |
greg |
2.4 |
| 345 |
greg |
2.14 |
sum = 0.0; |
| 346 |
greg |
2.4 |
| 347 |
greg |
1.1 |
| 348 |
greg |
2.4 |
/* compute 1/p^2 weighted solid angle of the source */ |
| 349 |
greg |
2.14 |
r = 1. - gs->dom*(.5/PI); |
| 350 |
r = sqrt(1. - r*r); |
| 351 |
greg |
2.4 |
fcross(vhor,gs->dir,midview.vup); |
| 352 |
greg |
2.14 |
if (normalize(vhor) == 0.) |
| 353 |
continue; |
| 354 |
greg |
2.4 |
VCOPY(testdir[0],gs->dir); |
| 355 |
fvsum(testdir[1],gs->dir,vhor,r); |
| 356 |
fvsum(testdir[2],gs->dir,vhor,0.5*r); |
| 357 |
fvsum(testdir[5],testdir[2],midview.vup,-0.866*r); |
| 358 |
fvsum(testdir[2],testdir[2],midview.vup,0.866*r); |
| 359 |
fvsum(testdir[3],gs->dir,vhor,-r); |
| 360 |
fvsum(testdir[4],gs->dir,vhor,-0.5*r); |
| 361 |
fvsum(testdir[6],testdir[4],midview.vup,0.866*r); |
| 362 |
fvsum(testdir[4],testdir[4],midview.vup,-0.866*r); |
| 363 |
for (i = 0; i < 7; i++) { |
| 364 |
greg |
2.14 |
p[i] = 0.0; |
| 365 |
if (normalize(testdir[i]) == 0.) |
| 366 |
continue; |
| 367 |
greg |
2.9 |
posn = posindex(testdir[i],mydir,midview.vup); |
| 368 |
greg |
2.14 |
if (posn > FTINY) |
| 369 |
greg |
2.9 |
p[i] = 1./(posn*posn); |
| 370 |
greg |
2.4 |
| 371 |
greg |
2.14 |
| 372 |
greg |
2.4 |
omega = gs->dom*p[0]; |
| 373 |
greg |
2.14 |
omega += (r*PI*(1.+1./(r*r))-2.*PI)*(-p[0]+(p[1]+p[2])*0.5); |
| 374 |
omega += (2.*PI-r*PI*(1.+1./(r*r)))*(-p[0]-0.1667*(p[1]+p[3]) |
| 375 |
greg |
2.4 |
+0.3334*(p[2]+p[4]+p[5]+p[6])); |
| 376 |
greg |
2.14 |
if (omega <= 0.) |
| 377 |
greg |
2.15 |
continue; |
| 378 |
schorsch |
2.10 |
sum += pow(gs->lum,1.6) * pow(omega,0.8) / |
| 379 |
greg |
2.14 |
(gd->indirect*(1./PI) + 0.07*sqrt(gs->dom)*gs->lum); |
| 380 |
greg |
2.4 |
| 381 |
greg |
2.14 |
if (sum <= FTINY) |
| 382 |
greg |
2.4 |
return(0.0); |
| 383 |
greg |
2.14 |
return( 10.*log10(0.478*sum) ); |
| 384 |
greg |
2.4 |
| 385 |
| 386 |
schorsch |
2.10 |
| 387 |
static double |
| 388 |
brs_gi( /* compute BRS Glare Index */ |
| 389 |
| 390 |
| 391 |
greg |
2.4 |
| 392 |
greg |
2.11 |
| 393 |
greg |
2.4 |
FVECT mydir; |
| 394 |
double p; |
| 395 |
double sum; |
| 396 |
schorsch |
2.10 |
| 397 |
greg |
2.4 |
| 398 |
sum = 0.0; |
| 399 |
| 400 |
p = posindex(gs->dir, mydir, midview.vup); |
| 401 |
if (p <= FTINY) |
| 402 |
continue; |
| 403 |
sum += pow(gs->lum/p,1.6) * pow(gs->dom,0.8); |
| 404 |
| 405 |
if (sum <= FTINY) |
| 406 |
return(0.0); |
| 407 |
greg |
2.14 |
sum *= PI/gd->indirect; |
| 408 |
greg |
2.4 |
return(10*log10(0.478*sum)); |
| 409 |
| 410 |
| 411 |
| 412 |
schorsch |
2.10 |
static double |
| 413 |
guth_dgr( /* compute Guth discomfort glare rating */ |
| 414 |
| 415 |
| 416 |
greg |
1.1 |
| 417 |
#define q(w) (20.4*w+1.52*pow(w,.2)-.075) |
| 418 |
greg |
2.11 |
| 419 |
greg |
1.7 |
FVECT mydir; |
| 420 |
greg |
1.1 |
double p; |
| 421 |
double sum; |
| 422 |
greg |
1.3 |
double wtot, brsum; |
| 423 |
greg |
1.1 |
int n; |
| 424 |
schorsch |
2.10 |
| 425 |
greg |
1.7 |
| 426 |
greg |
1.3 |
sum = wtot = brsum = 0.0; n = 0; |
| 427 |
greg |
1.1 |
| 428 |
greg |
1.7 |
| 429 |
greg |
1.1 |
if (p <= FTINY) |
| 430 |
continue; |
| 431 |
sum += gs->lum * q(gs->dom) / p; |
| 432 |
greg |
1.3 |
brsum += gs->lum * gs->dom; |
| 433 |
wtot += gs->dom; |
| 434 |
greg |
1.1 |
n++; |
| 435 |
| 436 |
if (n == 0) |
| 437 |
return(0.0); |
| 438 |
greg |
1.8 |
return( pow(.5*sum/pow((brsum+(5.-wtot)*gd->indirect/PI)/5.,.44), |
| 439 |
greg |
1.1 |
pow((double)n, -.0914) ) ); |
| 440 |
#undef q |
| 441 |
| 442 |
schorsch |
2.10 |
| 443 |
| 444 |
greg |
1.1 |
#ifndef M_SQRT2 |
| 445 |
#define M_SQRT2 1.41421356237309504880 |
| 446 |
#endif |
| 447 |
schorsch |
2.10 |
| 448 |
greg |
1.1 |
#define norm_integral(z) (1.-.5*erfc((z)/M_SQRT2)) |
| 449 |
schorsch |
2.10 |
| 450 |
| 451 |
static double |
| 452 |
guth_vcp( /* compute Guth visual comfort probability */ |
| 453 |
| 454 |
| 455 |
greg |
1.1 |
| 456 |
greg |
2.5 |
extern double erfc(); |
| 457 |
greg |
1.7 |
double dgr; |
| 458 |
schorsch |
2.10 |
| 459 |
greg |
1.7 |
dgr = guth_dgr(gd); |
| 460 |
if (dgr <= FTINY) |
| 461 |
return(100.0); |
| 462 |
return(100.*norm_integral(6.374-1.3227*log(dgr))); |
| 463 |
greg |
1.8 |
| 464 |
schorsch |
2.10 |
| 465 |
| 466 |
static double |
| 467 |
cie_cgi( /* compute CIE Glare Index */ |
| 468 |
| 469 |
| 470 |
greg |
1.8 |
| 471 |
greg |
2.11 |
| 472 |
greg |
1.8 |
FVECT mydir; |
| 473 |
double dillum; |
| 474 |
double p; |
| 475 |
double sum; |
| 476 |
schorsch |
2.10 |
| 477 |
greg |
1.8 |
| 478 |
sum = 0.0; |
| 479 |
| 480 |
| 481 |
if (p <= FTINY) |
| 482 |
continue; |
| 483 |
sum += gs->lum*gs->lum * gs->dom / (p*p); |
| 484 |
| 485 |
if (sum <= FTINY) |
| 486 |
return(0.0); |
| 487 |
dillum = direct(gd); |
| 488 |
return(8.*log10(2.*sum*(1.+dillum/500.)/(dillum+gd->indirect))); |
| 489 |
greg |
2.4 |
| 490 |
| 491 |
| 492 |
schorsch |
2.10 |
static double |
| 493 |
ugr( /* compute Unified Glare Rating */ |
| 494 |
| 495 |
| 496 |
greg |
2.4 |
| 497 |
greg |
2.11 |
| 498 |
greg |
2.4 |
FVECT mydir; |
| 499 |
double p; |
| 500 |
double sum; |
| 501 |
schorsch |
2.10 |
| 502 |
greg |
2.4 |
| 503 |
sum = 0.0; |
| 504 |
| 505 |
| 506 |
if (p <= FTINY) |
| 507 |
continue; |
| 508 |
| 509 |
| 510 |
if (sum <= FTINY) |
| 511 |
return(0.0); |
| 512 |
return(8.*log10(0.25*sum*PI/gd->indirect)); |
| 513 |
greg |
1.1 |
