1 |
/* Copyright (c) 1991 Regents of the University of California */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ LBL"; |
5 |
#endif |
6 |
7 |
8 |
* Compute Glare Index given by program name or -t option: |
9 |
10 |
* dgi - Daylight Glare Index |
11 |
* brs_gi - Building Research Station Glare Index (Petherbridge |
12 |
* & Hopkinson) |
13 |
* ugr - Unified Glare Rating System (Fischer) |
14 |
* guth_dgr - Guth discomfort glare rating |
15 |
* guth_vcp - Guth visual comfort probability |
16 |
* cie_cgi - CIE Glare Index (1983, due to Einhorn) |
17 |
* vert_dir - Direct vertical illuminance |
18 |
* vert_ind - Indirect vertical illuminance (from input) |
19 |
* vert_ill - Total vertical illuminance |
20 |
21 |
* 12 April 1991 Greg Ward EPFL |
22 |
* 19 April 1993 R. Compagnon EPFL (added dgi, brs_gi, ugr) |
23 |
24 |
25 |
#include "standard.h" |
26 |
#include "view.h" |
27 |
28 |
29 |
double posindex(); |
30 |
31 |
double direct(), guth_dgr(), guth_vcp(), cie_cgi(), |
32 |
indirect(), total(), dgi(), brs_gi(), ugr(); |
33 |
34 |
struct named_func { |
35 |
char *name; |
36 |
double (*func)(); |
37 |
char *descrip; |
38 |
} all_funcs[] = { |
39 |
{"dgi", dgi, "Daylight Glare Index"}, |
40 |
{"brs_gi", brs_gi, "BRS Glare Index"}, |
41 |
{"ugr", ugr, "Unified Glare Rating"}, |
42 |
{"guth_vcp", guth_vcp, "Guth Visual Comfort Probability"}, |
43 |
{"cie_cgi", cie_cgi, "CIE Glare Index (Einhorn)"}, |
44 |
{"guth_dgr", guth_dgr, "Guth Disability Glare Rating"}, |
45 |
{"vert_dir", direct, "Direct Vertical Illuminance"}, |
46 |
{"vert_ill", total, "Total Vertical Illuminance"}, |
47 |
{"vert_ind", indirect, "Indirect Vertical Illuminance"}, |
48 |
{NULL} |
49 |
50 |
51 |
struct glare_src { |
52 |
FVECT dir; /* source direction */ |
53 |
double dom; /* solid angle */ |
54 |
double lum; /* average luminance */ |
55 |
struct glare_src *next; |
56 |
} *all_srcs = NULL; |
57 |
58 |
struct glare_dir { |
59 |
double ang; /* angle (in radians) */ |
60 |
double indirect; /* indirect illuminance */ |
61 |
struct glare_dir *next; |
62 |
} *all_dirs = NULL; |
63 |
64 |
#define newp(type) (type *)malloc(sizeof(type)) |
65 |
66 |
char *progname; |
67 |
int print_header = 1; |
68 |
69 |
VIEW midview = STDVIEW; |
70 |
71 |
int wrongformat = 0; |
72 |
73 |
74 |
main(argc, argv) |
75 |
int argc; |
76 |
char *argv[]; |
77 |
78 |
extern char *rindex(); |
79 |
struct named_func *funp; |
80 |
char *progtail; |
81 |
int i; |
82 |
/* get program name */ |
83 |
progname = argv[0]; |
84 |
progtail = rindex(progname, '/'); /* final component */ |
85 |
if (progtail == NULL) |
86 |
progtail = progname; |
87 |
else |
88 |
progtail++; |
89 |
/* get options */ |
90 |
for (i = 1; i < argc && argv[i][0] == '-'; i++) |
91 |
switch (argv[i][1]) { |
92 |
case 't': |
93 |
progtail = argv[++i]; |
94 |
break; |
95 |
case 'h': |
96 |
print_header = 0; |
97 |
break; |
98 |
default: |
99 |
goto userr; |
100 |
101 |
if (i < argc-1) |
102 |
goto userr; |
103 |
if (i == argc-1) /* open file */ |
104 |
if (freopen(argv[i], "r", stdin) == NULL) { |
105 |
perror(argv[i]); |
106 |
exit(1); |
107 |
108 |
/* find and run calculation */ |
109 |
for (funp = all_funcs; funp->name != NULL; funp++) |
110 |
if (!strcmp(funp->name, progtail)) { |
111 |
init(); |
112 |
read_input(); |
113 |
if (print_header) { |
114 |
printargs(i, argv, stdout); |
115 |
putchar('\n'); |
116 |
117 |
print_values(funp->func); |
118 |
exit(0); /* we're done */ |
119 |
120 |
/* invalid function */ |
121 |
userr: |
122 |
fprintf(stderr, "Usage: %s -t type [-h] [input]\n", progname); |
123 |
fprintf(stderr, "\twhere 'type' is one of the following:\n"); |
124 |
125 |
fprintf(stderr, "\t%12s\t%s\n", funp->name, funp->descrip); |
126 |
exit(1); |
127 |
128 |
129 |
130 |
headline(s) /* get line from header */ |
131 |
char *s; |
132 |
133 |
char fmt[32]; |
134 |
135 |
if (print_header) /* copy to output */ |
136 |
fputs(s, stdout); |
137 |
if (isview(s)) |
138 |
sscanview(&midview, s); |
139 |
else if (isformat(s)) { |
140 |
formatval(fmt, s); |
141 |
wrongformat = strcmp(fmt, "ascii"); |
142 |
143 |
144 |
145 |
146 |
init() /* initialize calculation */ |
147 |
148 |
/* read header */ |
149 |
getheader(stdin, headline, NULL); |
150 |
if (wrongformat) { |
151 |
fprintf(stderr, "%s: bad input format\n", progname); |
152 |
exit(1); |
153 |
154 |
/* set view */ |
155 |
if (setview(&midview) != NULL) { |
156 |
fprintf(stderr, "%s: bad view information in input\n", |
157 |
progname); |
158 |
exit(1); |
159 |
160 |
161 |
162 |
163 |
read_input() /* read glare sources from stdin */ |
164 |
165 |
#define S_SEARCH 0 |
166 |
#define S_SOURCE 1 |
167 |
#define S_DIREC 2 |
168 |
int state = S_SEARCH; |
169 |
char buf[128]; |
170 |
register struct glare_src *gs; |
171 |
register struct glare_dir *gd; |
172 |
173 |
while (fgets(buf, sizeof(buf), stdin) != NULL) |
174 |
switch (state) { |
175 |
case S_SEARCH: |
176 |
if (!strcmp(buf, "BEGIN glare source\n")) |
177 |
state = S_SOURCE; |
178 |
else if (!strcmp(buf, "BEGIN indirect illuminance\n")) |
179 |
state = S_DIREC; |
180 |
break; |
181 |
case S_SOURCE: |
182 |
if (!strncmp(buf, "END", 3)) { |
183 |
state = S_SEARCH; |
184 |
break; |
185 |
186 |
if ((gs = newp(struct glare_src)) == NULL) |
187 |
goto memerr; |
188 |
if (sscanf(buf, "%lf %lf %lf %lf %lf", |
189 |
&gs->dir[0], &gs->dir[1], &gs->dir[2], |
190 |
&gs->dom, &gs->lum) != 5) |
191 |
goto readerr; |
192 |
normalize(gs->dir); |
193 |
gs->next = all_srcs; |
194 |
all_srcs = gs; |
195 |
break; |
196 |
case S_DIREC: |
197 |
198 |
state = S_SEARCH; |
199 |
break; |
200 |
201 |
if ((gd = newp(struct glare_dir)) == NULL) |
202 |
goto memerr; |
203 |
if (sscanf(buf, "%lf %lf", |
204 |
&gd->ang, &gd->indirect) != 2) |
205 |
goto readerr; |
206 |
gd->ang *= PI/180.0; /* convert to radians */ |
207 |
gd->next = all_dirs; |
208 |
all_dirs = gd; |
209 |
break; |
210 |
211 |
return; |
212 |
memerr: |
213 |
perror(progname); |
214 |
exit(1); |
215 |
readerr: |
216 |
fprintf(stderr, "%s: read error on input\n", progname); |
217 |
exit(1); |
218 |
#undef S_SEARCH |
219 |
#undef S_SOURCE |
220 |
#undef S_DIREC |
221 |
222 |
223 |
224 |
print_values(funp) /* print out calculations */ |
225 |
double (*funp)(); |
226 |
227 |
228 |
229 |
for (gd = all_dirs; gd != NULL; gd = gd->next) |
230 |
printf("%f\t%f\n", gd->ang*(180.0/PI), (*funp)(gd)); |
231 |
232 |
233 |
234 |
double |
235 |
direct(gd) /* compute direct vertical illuminance */ |
236 |
237 |
238 |
FVECT mydir; |
239 |
double d, dval; |
240 |
241 |
242 |
spinvector(mydir, midview.vdir, midview.vup, gd->ang); |
243 |
dval = 0.0; |
244 |
for (gs = all_srcs; gs != NULL; gs = gs->next) { |
245 |
d = DOT(mydir,gs->dir); |
246 |
if (d > FTINY) |
247 |
dval += d * gs->dom * gs->lum; |
248 |
249 |
return(dval); |
250 |
251 |
252 |
253 |
double |
254 |
indirect(gd) /* return indirect vertical illuminance */ |
255 |
256 |
257 |
return(gd->indirect); |
258 |
259 |
260 |
261 |
double |
262 |
total(gd) /* return total vertical illuminance */ |
263 |
264 |
265 |
return(direct(gd)+gd->indirect); |
266 |
267 |
268 |
269 |
270 |
* posindex - compute glare position index from: |
271 |
272 |
* Source Direction |
273 |
* View Direction |
274 |
* View Up Direction |
275 |
276 |
* All vectors are assumed to be normalized. |
277 |
* This function is an implementation of the method proposed by |
278 |
* Robert Levin in his 1975 JIES article. |
279 |
* This calculation presumes the view direction and up vectors perpendicular. |
280 |
* We return a value less than zero for improper positions. |
281 |
282 |
283 |
double |
284 |
posindex(sd, vd, vu) /* compute position index */ |
285 |
FVECT sd, vd, vu; |
286 |
287 |
double sigma, tau; |
288 |
double d; |
289 |
290 |
d = DOT(sd,vd); |
291 |
if (d <= 0.0) |
292 |
return(-1.0); |
293 |
if (d >= 1.0) |
294 |
return(1.0); |
295 |
sigma = acos(d) * (180./PI); |
296 |
d = fabs(DOT(sd,vu)/sqrt(1.0-d*d)); |
297 |
if (d >= 1.0) |
298 |
tau = 0.0; |
299 |
else |
300 |
tau = acos(d) * (180./PI); |
301 |
return( exp( sigma*( (35.2 - tau*.31889 - 1.22*exp(-.22222*tau))*1e-3 |
302 |
+ sigma*(21. + tau*(.26667 + tau*-.002963))*1e-5 ) |
303 |
304 |
305 |
306 |
307 |
double |
308 |
dgi(gd) /* compute Daylight Glare Index */ |
309 |
310 |
311 |
312 |
FVECT mydir,testdir[7],vhor; |
313 |
double r,omega,p[7],sum; |
314 |
int i,n; |
315 |
316 |
317 |
sum = 0.0; n = 0; |
318 |
319 |
320 |
/* compute 1/p^2 weighted solid angle of the source */ |
321 |
r = sqrt(1 - pow(1.-gs->dom/2./PI,2.)); |
322 |
fcross(vhor,gs->dir,midview.vup); |
323 |
normalize(vhor); |
324 |
VCOPY(testdir[0],gs->dir); |
325 |
fvsum(testdir[1],gs->dir,vhor,r); |
326 |
fvsum(testdir[2],gs->dir,vhor,0.5*r); |
327 |
fvsum(testdir[5],testdir[2],midview.vup,-0.866*r); |
328 |
fvsum(testdir[2],testdir[2],midview.vup,0.866*r); |
329 |
fvsum(testdir[3],gs->dir,vhor,-r); |
330 |
fvsum(testdir[4],gs->dir,vhor,-0.5*r); |
331 |
fvsum(testdir[6],testdir[4],midview.vup,0.866*r); |
332 |
fvsum(testdir[4],testdir[4],midview.vup,-0.866*r); |
333 |
for (i = 0; i < 7; i++) { |
334 |
normalize(testdir[i]); |
335 |
p[i] = pow(posindex(testdir[i],mydir,midview.vup),-2.0); |
336 |
if (p[i] <= FTINY) p[i] = 0.0; |
337 |
338 |
r = 1-gs->dom/2./PI; |
339 |
omega = gs->dom*p[0]; |
340 |
omega += (r*PI*(1+1/r/r)-2*PI)*(-p[0]+(p[1]+p[2])*0.5); |
341 |
omega += (2*PI-r*PI*(1+1/r/r))*(-p[0]-0.1667*(p[1]+p[3]) |
342 |
+0.3334*(p[2]+p[4]+p[5]+p[6])); |
343 |
344 |
sum += pow(gs->lum,1.6) * pow(omega,0.8) / |
345 |
(gd->indirect/PI + 0.07*sqrt(gs->dom)*gs->lum); |
346 |
n++; |
347 |
348 |
if (n == 0) |
349 |
return(0.0); |
350 |
return( 10*log10(0.478*sum) ); |
351 |
352 |
353 |
354 |
double |
355 |
brs_gi(gd) /* compute BRS Glare Index */ |
356 |
357 |
358 |
359 |
FVECT mydir; |
360 |
double p; |
361 |
double sum; |
362 |
363 |
364 |
sum = 0.0; |
365 |
366 |
p = posindex(gs->dir, mydir, midview.vup); |
367 |
if (p <= FTINY) |
368 |
continue; |
369 |
sum += pow(gs->lum/p,1.6) * pow(gs->dom,0.8); |
370 |
371 |
if (sum <= FTINY) |
372 |
return(0.0); |
373 |
sum /= gd->indirect/PI; |
374 |
return(10*log10(0.478*sum)); |
375 |
376 |
377 |
378 |
double |
379 |
guth_dgr(gd) /* compute Guth discomfort glare rating */ |
380 |
381 |
382 |
#define q(w) (20.4*w+1.52*pow(w,.2)-.075) |
383 |
384 |
FVECT mydir; |
385 |
double p; |
386 |
double sum; |
387 |
double wtot, brsum; |
388 |
int n; |
389 |
390 |
391 |
sum = wtot = brsum = 0.0; n = 0; |
392 |
393 |
394 |
if (p <= FTINY) |
395 |
continue; |
396 |
sum += gs->lum * q(gs->dom) / p; |
397 |
brsum += gs->lum * gs->dom; |
398 |
wtot += gs->dom; |
399 |
n++; |
400 |
401 |
if (n == 0) |
402 |
return(0.0); |
403 |
return( pow(.5*sum/pow((brsum+(5.-wtot)*gd->indirect/PI)/5.,.44), |
404 |
pow((double)n, -.0914) ) ); |
405 |
#undef q |
406 |
407 |
408 |
409 |
#ifndef M_SQRT2 |
410 |
#define M_SQRT2 1.41421356237309504880 |
411 |
#endif |
412 |
413 |
#define norm_integral(z) (1.-.5*erfc((z)/M_SQRT2)) |
414 |
415 |
416 |
double |
417 |
guth_vcp(gd) /* compute Guth visual comfort probability */ |
418 |
419 |
420 |
extern double erfc(); |
421 |
double dgr; |
422 |
423 |
dgr = guth_dgr(gd); |
424 |
if (dgr <= FTINY) |
425 |
return(100.0); |
426 |
return(100.*norm_integral(6.374-1.3227*log(dgr))); |
427 |
428 |
429 |
430 |
double |
431 |
cie_cgi(gd) /* compute CIE Glare Index */ |
432 |
433 |
434 |
435 |
FVECT mydir; |
436 |
double dillum; |
437 |
double p; |
438 |
double sum; |
439 |
440 |
441 |
sum = 0.0; |
442 |
443 |
444 |
if (p <= FTINY) |
445 |
continue; |
446 |
sum += gs->lum*gs->lum * gs->dom / (p*p); |
447 |
448 |
if (sum <= FTINY) |
449 |
return(0.0); |
450 |
dillum = direct(gd); |
451 |
return(8.*log10(2.*sum*(1.+dillum/500.)/(dillum+gd->indirect))); |
452 |
453 |
454 |
455 |
double |
456 |
ugr(gd) /* compute Unified Glare Rating */ |
457 |
458 |
459 |
460 |
FVECT mydir; |
461 |
double p; |
462 |
double sum; |
463 |
464 |
465 |
sum = 0.0; |
466 |
467 |
468 |
if (p <= FTINY) |
469 |
continue; |
470 |
471 |
472 |
if (sum <= FTINY) |
473 |
return(0.0); |
474 |
return(8.*log10(0.25*sum*PI/gd->indirect)); |
475 |
