| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: glarendx.c,v 2.16 2020/07/24 16:58:16 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* Compute Glare Index given by program name or -t option:
| 6 |
| 7 |
* dgi - Daylight Glare Index
| 8 |
* brs_gi - Building Research Station Glare Index (Petherbridge
| 9 |
* & Hopkinson)
| 10 |
* ugr - Unified Glare Rating System (Fischer)
| 11 |
* guth_dgr - Guth discomfort glare rating
| 12 |
* guth_vcp - Guth visual comfort probability
| 13 |
* cie_cgi - CIE Glare Index (1983, due to Einhorn)
| 14 |
* vert_dir - Direct vertical illuminance
| 15 |
* vert_ind - Indirect vertical illuminance (from input)
| 16 |
* vert_ill - Total vertical illuminance
| 17 |
| 18 |
* 12 April 1991 Greg Ward EPFL
| 19 |
* 19 April 1993 R. Compagnon EPFL (added dgi, brs_gi, ugr)
| 20 |
| 21 |
| 22 |
#include <string.h>
| 23 |
| 24 |
#include "standard.h"
| 25 |
#include "paths.h"
| 26 |
#include "view.h"
| 27 |
| 28 |
| 29 |
struct glare_src {
| 30 |
FVECT dir; /* source direction */
| 31 |
double dom; /* solid angle */
| 32 |
double lum; /* average luminance */
| 33 |
struct glare_src *next;
| 34 |
} *all_srcs = NULL;
| 35 |
| 36 |
struct glare_dir {
| 37 |
double ang; /* angle (in radians) */
| 38 |
double indirect; /* indirect illuminance */
| 39 |
struct glare_dir *next;
| 40 |
} *all_dirs = NULL;
| 41 |
| 42 |
typedef double gdfun(struct glare_dir *gd);
| 43 |
| 44 |
static gdfun dgi;
| 45 |
static gdfun brs_gi;
| 46 |
static gdfun ugr;
| 47 |
static gdfun guth_dgr;
| 48 |
static gdfun guth_vcp;
| 49 |
static gdfun cie_cgi;
| 50 |
static gdfun direct;
| 51 |
static gdfun indirect;
| 52 |
static gdfun total;
| 53 |
| 54 |
static gethfunc headline;
| 55 |
static void init(void);
| 56 |
static void read_input(void);
| 57 |
static void print_values(gdfun *func);
| 58 |
static double posindex(FVECT sd, FVECT vd, FVECT vu);
| 59 |
| 60 |
| 61 |
struct named_func {
| 62 |
char *name;
| 63 |
gdfun *func;
| 64 |
char *descrip;
| 65 |
} all_funcs[] = {
| 66 |
{"dgi", dgi, "Daylight Glare Index"},
| 67 |
{"brs_gi", brs_gi, "BRS Glare Index"},
| 68 |
{"ugr", ugr, "Unified Glare Rating"},
| 69 |
{"guth_vcp", guth_vcp, "Guth Visual Comfort Probability"},
| 70 |
{"cie_cgi", cie_cgi, "CIE Glare Index (Einhorn)"},
| 71 |
{"guth_dgr", guth_dgr, "Guth Disability Glare Rating"},
| 72 |
{"vert_dir", direct, "Direct Vertical Illuminance"},
| 73 |
{"vert_ill", total, "Total Vertical Illuminance"},
| 74 |
{"vert_ind", indirect, "Indirect Vertical Illuminance"},
| 75 |
{NULL}
| 76 |
| 77 |
| 78 |
#define newp(type) (type *)malloc(sizeof(type))
| 79 |
| 80 |
int print_header = 1;
| 81 |
| 82 |
VIEW midview = STDVIEW;
| 83 |
| 84 |
int wrongformat = 0;
| 85 |
| 86 |
| 87 |
int
| 88 |
main(
| 89 |
int argc,
| 90 |
char *argv[]
| 91 |
| 92 |
| 93 |
struct named_func *funp;
| 94 |
int i;
| 95 |
/* get program name */
| 96 |
progname = fixargv0(argv[0]);
| 97 |
/* get options */
| 98 |
for (i = 1; i < argc && argv[i][0] == '-'; i++)
| 99 |
switch (argv[i][1]) {
| 100 |
case 't':
| 101 |
progname = argv[++i];
| 102 |
break;
| 103 |
case 'h':
| 104 |
print_header = 0;
| 105 |
break;
| 106 |
default:
| 107 |
goto userr;
| 108 |
| 109 |
if (i < argc-1)
| 110 |
goto userr;
| 111 |
if (i == argc-1) /* open file */
| 112 |
if (freopen(argv[i], "r", stdin) == NULL) {
| 113 |
perror(argv[i]);
| 114 |
exit(1);
| 115 |
| 116 |
/* find and run calculation */
| 117 |
for (funp = all_funcs; funp->name != NULL; funp++)
| 118 |
if (!strcmp(funp->name, progname)) {
| 119 |
init();
| 120 |
read_input();
| 121 |
if (print_header) {
| 122 |
printargs(i, argv, stdout);
| 123 |
putchar('\n');
| 124 |
| 125 |
print_values(funp->func);
| 126 |
exit(0); /* we're done */
| 127 |
| 128 |
/* invalid function */
| 129 |
userr:
| 130 |
fprintf(stderr, "Usage: %s -t type [-h] [input]\n", progname);
| 131 |
fprintf(stderr, "\twhere 'type' is one of the following:\n");
| 132 |
| 133 |
fprintf(stderr, "\t%12s\t%s\n", funp->name, funp->descrip);
| 134 |
exit(1);
| 135 |
| 136 |
| 137 |
| 138 |
static int
| 139 |
headline( /* get line from header */
| 140 |
char *s,
| 141 |
void *p
| 142 |
| 143 |
| 144 |
char fmt[MAXFMTLEN];
| 145 |
| 146 |
if (print_header) /* copy to output */
| 147 |
fputs(s, stdout);
| 148 |
if (isview(s))
| 149 |
sscanview(&midview, s);
| 150 |
else if (isformat(s)) {
| 151 |
formatval(fmt, s);
| 152 |
wrongformat = strcmp(fmt, "ascii");
| 153 |
| 154 |
return(0);
| 155 |
| 156 |
| 157 |
| 158 |
static void
| 159 |
init(void) /* initialize calculation */
| 160 |
| 161 |
char *err;
| 162 |
/* read header */
| 163 |
getheader(stdin, headline, NULL);
| 164 |
if (wrongformat) {
| 165 |
fprintf(stderr, "%s: bad input format\n", progname);
| 166 |
exit(1);
| 167 |
| 168 |
/* set view */
| 169 |
if ((err = setview(&midview)) != NULL) {
| 170 |
fprintf(stderr, "%s: %s\n",
| 171 |
progname, err);
| 172 |
exit(1);
| 173 |
| 174 |
if (fabs(DOT(midview.vdir, midview.vup)) > 1e-4) {
| 175 |
fprintf(stderr,
| 176 |
"%s: Input view direction not perpendicular to up vector\n",
| 177 |
progname);
| 178 |
exit(1);
| 179 |
| 180 |
| 181 |
| 182 |
| 183 |
static void
| 184 |
read_input(void) /* read glare sources from stdin */
| 185 |
| 186 |
#define S_SEARCH 0
| 187 |
#define S_SOURCE 1
| 188 |
#define S_DIREC 2
| 189 |
int state = S_SEARCH;
| 190 |
char buf[128];
| 191 |
struct glare_src *gs;
| 192 |
struct glare_dir *gd;
| 193 |
| 194 |
while (fgets(buf, sizeof(buf), stdin) != NULL)
| 195 |
switch (state) {
| 196 |
case S_SEARCH:
| 197 |
if (!strcmp(buf, "BEGIN glare source\n"))
| 198 |
state = S_SOURCE;
| 199 |
else if (!strcmp(buf, "BEGIN indirect illuminance\n"))
| 200 |
state = S_DIREC;
| 201 |
break;
| 202 |
case S_SOURCE:
| 203 |
if (!strncmp(buf, "END", 3)) {
| 204 |
state = S_SEARCH;
| 205 |
break;
| 206 |
| 207 |
if ((gs = newp(struct glare_src)) == NULL)
| 208 |
goto memerr;
| 209 |
if (sscanf(buf, FVFORMAT, &gs->dir[0], &gs->dir[1],
| 210 |
&gs->dir[2]) != 3 ||
| 211 |
sscanf(sskip2(buf, 3), "%lf %lf",
| 212 |
&gs->dom, &gs->lum) != 2)
| 213 |
goto readerr;
| 214 |
normalize(gs->dir);
| 215 |
gs->next = all_srcs;
| 216 |
all_srcs = gs;
| 217 |
break;
| 218 |
case S_DIREC:
| 219 |
| 220 |
state = S_SEARCH;
| 221 |
break;
| 222 |
| 223 |
if ((gd = newp(struct glare_dir)) == NULL)
| 224 |
goto memerr;
| 225 |
if (sscanf(buf, "%lf %lf",
| 226 |
&gd->ang, &gd->indirect) != 2)
| 227 |
goto readerr;
| 228 |
gd->ang *= PI/180.0; /* convert to radians */
| 229 |
gd->next = all_dirs;
| 230 |
all_dirs = gd;
| 231 |
break;
| 232 |
| 233 |
return;
| 234 |
memerr:
| 235 |
perror(progname);
| 236 |
exit(1);
| 237 |
readerr:
| 238 |
fprintf(stderr, "%s: read error on input\n", progname);
| 239 |
exit(1);
| 240 |
#undef S_SEARCH
| 241 |
#undef S_SOURCE
| 242 |
#undef S_DIREC
| 243 |
| 244 |
| 245 |
| 246 |
static void
| 247 |
print_values( /* print out calculations */
| 248 |
gdfun *func
| 249 |
| 250 |
| 251 |
| 252 |
| 253 |
for (gd = all_dirs; gd != NULL; gd = gd->next)
| 254 |
printf("%f\t%f\n", gd->ang*(180.0/PI), (*func)(gd));
| 255 |
| 256 |
| 257 |
| 258 |
static double
| 259 |
direct( /* compute direct vertical illuminance */
| 260 |
| 261 |
| 262 |
| 263 |
FVECT mydir;
| 264 |
double d, dval;
| 265 |
| 266 |
| 267 |
spinvector(mydir, midview.vdir, midview.vup, gd->ang);
| 268 |
dval = 0.0;
| 269 |
for (gs = all_srcs; gs != NULL; gs = gs->next) {
| 270 |
d = DOT(mydir,gs->dir);
| 271 |
if (d > FTINY)
| 272 |
dval += d * gs->dom * gs->lum;
| 273 |
| 274 |
return(dval);
| 275 |
| 276 |
| 277 |
| 278 |
static double
| 279 |
indirect( /* return indirect vertical illuminance */
| 280 |
| 281 |
| 282 |
| 283 |
return(gd->indirect);
| 284 |
| 285 |
| 286 |
| 287 |
static double
| 288 |
total( /* return total vertical illuminance */
| 289 |
| 290 |
| 291 |
| 292 |
return(direct(gd)+gd->indirect);
| 293 |
| 294 |
| 295 |
| 296 |
| 297 |
* posindex - compute glare position index from:
| 298 |
| 299 |
* Source Direction
| 300 |
* View Direction
| 301 |
* View Up Direction
| 302 |
| 303 |
* All vectors are assumed to be normalized.
| 304 |
* This function is an implementation of the method proposed by
| 305 |
* Robert Levin in his 1975 JIES article.
| 306 |
* This calculation presumes the view direction and up vectors perpendicular.
| 307 |
* We return a value less than zero for improper positions.
| 308 |
| 309 |
| 310 |
static double
| 311 |
posindex( /* compute position index */
| 312 |
FVECT sd,
| 313 |
FVECT vd,
| 314 |
FVECT vu
| 315 |
| 316 |
| 317 |
double sigma, tau;
| 318 |
double d;
| 319 |
| 320 |
d = DOT(sd,vd);
| 321 |
if (d <= 0.0)
| 322 |
return(-1.0);
| 323 |
if (d >= 1.0-FTINY)
| 324 |
return(1.0);
| 325 |
sigma = acos(d) * (180./PI);
| 326 |
d = fabs(DOT(sd,vu)/sqrt(1.0-d*d));
| 327 |
tau = Acos(d) * (180./PI);
| 328 |
return( exp( sigma*( (35.2 - tau*.31889 - 1.22*exp(-.22222*tau))*1e-3
| 329 |
+ sigma*(21. + tau*(.26667 + tau*-.002963))*1e-5 )
| 330 |
| 331 |
| 332 |
| 333 |
| 334 |
static double
| 335 |
dgi( /* compute Daylight Glare Index */
| 336 |
| 337 |
| 338 |
| 339 |
| 340 |
FVECT mydir,testdir[7],vhor;
| 341 |
double r,posn,omega,p[7],sum;
| 342 |
int i;
| 343 |
| 344 |
| 345 |
sum = 0.0;
| 346 |
| 347 |
| 348 |
/* compute 1/p^2 weighted solid angle of the source */
| 349 |
r = 1. - gs->dom*(.5/PI);
| 350 |
r = sqrt(1. - r*r);
| 351 |
fcross(vhor,gs->dir,midview.vup);
| 352 |
if (normalize(vhor) == 0.)
| 353 |
continue;
| 354 |
VCOPY(testdir[0],gs->dir);
| 355 |
fvsum(testdir[1],gs->dir,vhor,r);
| 356 |
fvsum(testdir[2],gs->dir,vhor,0.5*r);
| 357 |
fvsum(testdir[5],testdir[2],midview.vup,-0.866*r);
| 358 |
fvsum(testdir[2],testdir[2],midview.vup,0.866*r);
| 359 |
fvsum(testdir[3],gs->dir,vhor,-r);
| 360 |
fvsum(testdir[4],gs->dir,vhor,-0.5*r);
| 361 |
fvsum(testdir[6],testdir[4],midview.vup,0.866*r);
| 362 |
fvsum(testdir[4],testdir[4],midview.vup,-0.866*r);
| 363 |
for (i = 0; i < 7; i++) {
| 364 |
p[i] = 0.0;
| 365 |
if (normalize(testdir[i]) == 0.)
| 366 |
continue;
| 367 |
posn = posindex(testdir[i],mydir,midview.vup);
| 368 |
if (posn > FTINY)
| 369 |
p[i] = 1./(posn*posn);
| 370 |
| 371 |
| 372 |
omega = gs->dom*p[0];
| 373 |
omega += (r*PI*(1.+1./(r*r))-2.*PI)*(-p[0]+(p[1]+p[2])*0.5);
| 374 |
omega += (2.*PI-r*PI*(1.+1./(r*r)))*(-p[0]-0.1667*(p[1]+p[3])
| 375 |
+0.3334*(p[2]+p[4]+p[5]+p[6]));
| 376 |
if (omega <= 0.)
| 377 |
continue;
| 378 |
sum += pow(gs->lum,1.6) * pow(omega,0.8) /
| 379 |
(gd->indirect*(1./PI) + 0.07*sqrt(gs->dom)*gs->lum);
| 380 |
| 381 |
if (sum <= FTINY)
| 382 |
return(0.0);
| 383 |
return( 10.*log10(0.478*sum) );
| 384 |
| 385 |
| 386 |
| 387 |
static double
| 388 |
brs_gi( /* compute BRS Glare Index */
| 389 |
| 390 |
| 391 |
| 392 |
| 393 |
FVECT mydir;
| 394 |
double p;
| 395 |
double sum;
| 396 |
| 397 |
| 398 |
sum = 0.0;
| 399 |
| 400 |
p = posindex(gs->dir, mydir, midview.vup);
| 401 |
if (p <= FTINY)
| 402 |
continue;
| 403 |
sum += pow(gs->lum/p,1.6) * pow(gs->dom,0.8);
| 404 |
| 405 |
if (sum <= FTINY)
| 406 |
return(0.0);
| 407 |
sum *= PI/gd->indirect;
| 408 |
return(10*log10(0.478*sum));
| 409 |
| 410 |
| 411 |
| 412 |
static double
| 413 |
guth_dgr( /* compute Guth discomfort glare rating */
| 414 |
| 415 |
| 416 |
| 417 |
#define q(w) (20.4*w+1.52*pow(w,.2)-.075)
| 418 |
| 419 |
FVECT mydir;
| 420 |
double p;
| 421 |
double sum;
| 422 |
double wtot, brsum;
| 423 |
int n;
| 424 |
| 425 |
| 426 |
sum = wtot = brsum = 0.0; n = 0;
| 427 |
| 428 |
| 429 |
if (p <= FTINY)
| 430 |
continue;
| 431 |
sum += gs->lum * q(gs->dom) / p;
| 432 |
brsum += gs->lum * gs->dom;
| 433 |
wtot += gs->dom;
| 434 |
n++;
| 435 |
| 436 |
if (n == 0)
| 437 |
return(0.0);
| 438 |
return( pow(.5*sum/pow((brsum+(5.-wtot)*gd->indirect/PI)/5.,.44),
| 439 |
pow((double)n, -.0914) ) );
| 440 |
#undef q
| 441 |
| 442 |
| 443 |
| 444 |
#ifndef M_SQRT2
| 445 |
#define M_SQRT2 1.41421356237309504880
| 446 |
#endif
| 447 |
| 448 |
#define norm_integral(z) (1.-.5*erfc((z)/M_SQRT2))
| 449 |
| 450 |
| 451 |
static double
| 452 |
guth_vcp( /* compute Guth visual comfort probability */
| 453 |
| 454 |
| 455 |
| 456 |
extern double erfc();
| 457 |
double dgr;
| 458 |
| 459 |
dgr = guth_dgr(gd);
| 460 |
if (dgr <= FTINY)
| 461 |
return(100.0);
| 462 |
return(100.*norm_integral(6.374-1.3227*log(dgr)));
| 463 |
| 464 |
| 465 |
| 466 |
static double
| 467 |
cie_cgi( /* compute CIE Glare Index */
| 468 |
| 469 |
| 470 |
| 471 |
| 472 |
FVECT mydir;
| 473 |
double dillum;
| 474 |
double p;
| 475 |
double sum;
| 476 |
| 477 |
| 478 |
sum = 0.0;
| 479 |
| 480 |
| 481 |
if (p <= FTINY)
| 482 |
continue;
| 483 |
sum += gs->lum*gs->lum * gs->dom / (p*p);
| 484 |
| 485 |
if (sum <= FTINY)
| 486 |
return(0.0);
| 487 |
dillum = direct(gd);
| 488 |
return(8.*log10(2.*sum*(1.+dillum/500.)/(dillum+gd->indirect)));
| 489 |
| 490 |
| 491 |
| 492 |
static double
| 493 |
ugr( /* compute Unified Glare Rating */
| 494 |
| 495 |
| 496 |
| 497 |
| 498 |
FVECT mydir;
| 499 |
double p;
| 500 |
double sum;
| 501 |
| 502 |
| 503 |
sum = 0.0;
| 504 |
| 505 |
| 506 |
if (p <= FTINY)
| 507 |
continue;
| 508 |
| 509 |
| 510 |
if (sum <= FTINY)
| 511 |
return(0.0);
| 512 |
return(8.*log10(0.25*sum*PI/gd->indirect));
| 513 |
