root/radiance/ray/src/util/glarendx.c
Tue Jun 3 21:31:51 2025 UTC (2 days, 23 hours ago) by greg
Changes since 2.16: +1 -2 lines
Diff to previous 2.16 , to selected 2.9
Fri Jul 24 16:58:16 2020 UTC (4 years, 10 months ago) by greg
CVS Tags: rad5R3, rad5R4
Changes since 2.15: +5 -10 lines
Diff to previous 2.15 , to selected 2.9
Hopeful fix to Windows test issues
Mon Feb 17 19:35:24 2020 UTC (5 years, 3 months ago) by greg
Minor improvement to last change
Mon Feb 17 19:19:45 2020 UTC (5 years, 3 months ago) by greg
Changes since 2.13: +31 -25 lines
Hopeful fix to dgi calculation issues
Thu Aug 2 18:33:50 2018 UTC (6 years, 10 months ago) by greg
Mon Apr 2 16:45:41 2018 UTC (7 years, 2 months ago) by greg
Fixed issue with reading data in glarendx
Fri Apr 11 20:27:23 2014 UTC (11 years, 1 month ago) by greg
Changes since 2.10: +14 -13 lines
Made reading of vectors more consistent with FVFORMAT macro
Fri Jan 2 12:48:36 2004 UTC (21 years, 5 months ago) by schorsch
Changes since 2.9: +143 -109 lines
Wed Nov 19 16:21:28 2003 UTC (21 years, 6 months ago) by greg
Changes since 2.8: +7 -4 lines
Mon Jun 30 14:59:13 2003 UTC (21 years, 11 months ago) by schorsch
Changes since 2.7: +4 -3 lines
Sat Feb 22 02:07:30 2003 UTC (22 years, 3 months ago) by greg
Changes since 2.6: +1 -4 lines
Tue Oct 27 08:47:17 1998 UTC (26 years, 7 months ago) by gwlarson
Sun Jun 4 10:58:38 1995 UTC (30 years ago) by greg
Changes since 2.4: +1 -3 lines
changed location of erfc() declaration
Thu Mar 24 11:06:59 1994 UTC (31 years, 2 months ago) by greg
Changes since 2.3: +150 -51 lines
Raphael added dgi, brs_gi, and ugr index calculations
Thu Nov 19 09:59:08 1992 UTC (32 years, 6 months ago) by greg
added additional protection against acos() domain error
Tue Apr 28 09:11:00 1992 UTC (33 years, 1 month ago) by greg
changed call to sscanview
Tue Nov 12 17:19:11 1991 UTC (33 years, 7 months ago) by greg
Diff to previous 1.9 , to selected 2.9
Thu May 2 14:00:58 1991 UTC (34 years, 1 month ago) by greg
Changes since 1.8: +59 -31 lines
Diff to previous 1.8 , to selected 2.9
improved error reporting
Thu May 2 13:17:41 1991 UTC (34 years, 1 month ago) by greg
Changes since 1.7: +30 -4 lines
Diff to previous 1.7 , to selected 2.9
added CGI (Einhorn) formula
Mon Apr 29 08:31:23 1991 UTC (34 years, 1 month ago) by greg
Changes since 1.6: +9 -2 lines
Diff to previous 1.6 , to selected 2.9
minor bug fixes
Mon Apr 22 10:11:21 1991 UTC (34 years, 1 month ago) by greg
Diff to previous 1.5 , to selected 2.9
ASCII -> ascii
Mon Apr 22 10:07:36 1991 UTC (34 years, 1 month ago) by greg
Changes since 1.4: +8 -1 lines
Diff to previous 1.4 , to selected 2.9
made posindex() a little more robust
Thu Apr 18 15:18:20 1991 UTC (34 years, 1 month ago) by greg
Changes since 1.3: +15 -2 lines
Diff to previous 1.3 , to selected 2.9
Wed Apr 17 11:55:03 1991 UTC (34 years, 1 month ago) by greg
Changes since 1.2: +6 -3 lines
Diff to previous 1.2 , to selected 2.9
corrected calculation of Guth F (average field luminance)
Wed Apr 17 08:21:41 1991 UTC (34 years, 1 month ago) by greg
Changes since 1.1: +9 -8 lines
Diff to previous 1.1 , to selected 2.9
fixed spelling of "Guth" and added normalization to vectors
Tue Apr 16 16:40:22 1991 UTC (34 years, 1 month ago) by greg
Diff to selected 2.9
