--- ray/src/util/glarendx.c 1991/04/18 15:18:20 1.4 +++ ray/src/util/glarendx.c 2004/01/02 12:48:36 2.10 @@ -1,38 +1,30 @@ -/* Copyright (c) 1991 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: glarendx.c,v 2.10 2004/01/02 12:48:36 schorsch Exp $"; #endif - /* - * Compute Glare Index given by program name: + * Compute Glare Index given by program name or -t option: * + * dgi - Daylight Glare Index + * brs_gi - Building Research Station Glare Index (Petherbridge + * & Hopkinson) + * ugr - Unified Glare Rating System (Fischer) * guth_dgr - Guth discomfort glare rating * guth_vcp - Guth visual comfort probability + * cie_cgi - CIE Glare Index (1983, due to Einhorn) + * vert_dir - Direct vertical illuminance + * vert_ind - Indirect vertical illuminance (from input) + * vert_ill - Total vertical illuminance * * 12 April 1991 Greg Ward EPFL + * 19 April 1993 R. Compagnon EPFL (added dgi, brs_gi, ugr) */ +#include + #include "standard.h" #include "view.h" -extern double erfc(); -double posindex(); -int headline(); - -double direct(), guth_dgr(), guth_vcp(); - -struct named_func { - char *name; - double (*func)(); -} all_funcs[] = { - {"direct", direct}, - {"guth_dgr", guth_dgr}, - {"guth_vcp", guth_vcp}, - {NULL} -}; - struct glare_src { FVECT dir; /* source direction */ double dom; /* solid angle */ @@ -46,6 +38,42 @@ struct glare_dir { struct glare_dir *next; } *all_dirs = NULL; +typedef double gdfun(struct glare_dir *gd); + +static gdfun dgi; +static gdfun brs_gi; +static gdfun ugr; +static gdfun guth_dgr; +static gdfun guth_vcp; +static gdfun cie_cgi; +static gdfun direct; +static gdfun indirect; +static gdfun total; + +static gethfunc headline; +static void init(void); +static void read_input(void); +static void print_values(gdfun *func); +static double posindex(FVECT sd, FVECT vd, FVECT vu); + + +struct named_func { + char *name; + gdfun *func; + char *descrip; +} all_funcs[] = { + {"dgi", dgi, "Daylight Glare Index"}, + {"brs_gi", brs_gi, "BRS Glare Index"}, + {"ugr", ugr, "Unified Glare Rating"}, + {"guth_vcp", guth_vcp, "Guth Visual Comfort Probability"}, + {"cie_cgi", cie_cgi, "CIE Glare Index (Einhorn)"}, + {"guth_dgr", guth_dgr, "Guth Disability Glare Rating"}, + {"vert_dir", direct, "Direct Vertical Illuminance"}, + {"vert_ill", total, "Total Vertical Illuminance"}, + {"vert_ind", indirect, "Indirect Vertical Illuminance"}, + {NULL} +}; + #define newp(type) (type *)malloc(sizeof(type)) char *progname; @@ -56,17 +84,18 @@ VIEW midview = STDVIEW; int wrongformat = 0; -main(argc, argv) -int argc; -char *argv[]; +int +main( + int argc, + char *argv[] +) { - extern char *rindex(); struct named_func *funp; char *progtail; int i; /* get program name */ progname = argv[0]; - progtail = rindex(progname, '/'); /* final component */ + progtail = strrchr(progname, '/'); /* final component */ if (progtail == NULL) progtail = progname; else @@ -90,57 +119,69 @@ char *argv[]; perror(argv[i]); exit(1); } - /* read header */ - getheader(stdin, headline, NULL); - if (wrongformat) { - fprintf(stderr, "%s: bad input format\n", progname); - exit(1); - } - if (print_header) { /* add to header */ - printargs(i, argv, stdout); - putchar('\n'); - } - /* set view */ - if (setview(&midview) != NULL) { - fprintf(stderr, "%s: bad view information in input\n", - progname); - exit(1); - } - /* get findglare data */ - read_input(); - /* find calculation */ + /* find and run calculation */ for (funp = all_funcs; funp->name != NULL; funp++) if (!strcmp(funp->name, progtail)) { + init(); + read_input(); + if (print_header) { + printargs(i, argv, stdout); + putchar('\n'); + } print_values(funp->func); exit(0); /* we're done */ } /* invalid function */ - fprintf(stderr, "%s: unknown function!\n", progtail); - exit(1); userr: - fprintf(stderr, "Usage: %s [-t type][-h] [input]\n", progname); + fprintf(stderr, "Usage: %s -t type [-h] [input]\n", progname); + fprintf(stderr, "\twhere 'type' is one of the following:\n"); + for (funp = all_funcs; funp->name != NULL; funp++) + fprintf(stderr, "\t%12s\t%s\n", funp->name, funp->descrip); exit(1); } -headline(s) /* get line from header */ -char *s; +static int +headline( /* get line from header */ + char *s, + void *p +) { char fmt[32]; if (print_header) /* copy to output */ fputs(s, stdout); - if (!strncmp(s, VIEWSTR, VIEWSTRL)) - sscanview(&midview, s+VIEWSTRL); + if (isview(s)) + sscanview(&midview, s); else if (isformat(s)) { formatval(fmt, s); - wrongformat = strcmp(fmt, "ASCII"); + wrongformat = strcmp(fmt, "ascii"); } + return(0); } -read_input() /* read glare sources from stdin */ +static void +init(void) /* initialize calculation */ { + /* read header */ + getheader(stdin, headline, NULL); + if (wrongformat) { + fprintf(stderr, "%s: bad input format\n", progname); + exit(1); + } + /* set view */ + if (setview(&midview) != NULL) { + fprintf(stderr, "%s: bad view information in input\n", + progname); + exit(1); + } +} + + +static void +read_input(void) /* read glare sources from stdin */ +{ #define S_SEARCH 0 #define S_SOURCE 1 #define S_DIREC 2 @@ -200,19 +241,22 @@ readerr: } -print_values(funp) /* print out calculations */ -double (*funp)(); +static void +print_values( /* print out calculations */ + gdfun *func +) { register struct glare_dir *gd; for (gd = all_dirs; gd != NULL; gd = gd->next) - printf("%f\t%f\n", gd->ang*(180.0/PI), (*funp)(gd)); + printf("%f\t%f\n", gd->ang*(180.0/PI), (*func)(gd)); } -double -direct(gd) /* compute direct illuminance */ -struct glare_dir *gd; +static double +direct( /* compute direct vertical illuminance */ + struct glare_dir *gd +) { FVECT mydir; double d, dval; @@ -229,6 +273,24 @@ struct glare_dir *gd; } +static double +indirect( /* return indirect vertical illuminance */ + struct glare_dir *gd +) +{ + return(gd->indirect); +} + + +static double +total( /* return total vertical illuminance */ + struct glare_dir *gd +) +{ + return(direct(gd)+gd->indirect); +} + + /* * posindex - compute glare position index from: * @@ -239,12 +301,16 @@ struct glare_dir *gd; * All vectors are assumed to be normalized. * This function is an implementation of the method proposed by * Robert Levin in his 1975 JIES article. + * This calculation presumes the view direction and up vectors perpendicular. * We return a value less than zero for improper positions. */ -double -posindex(sd, vd, vu) /* compute position index */ -FVECT sd, vd, vu; +static double +posindex( /* compute position index */ + FVECT sd, + FVECT vd, + FVECT vu +) { double sigma, tau; double d; @@ -252,28 +318,113 @@ FVECT sd, vd, vu; d = DOT(sd,vd); if (d <= 0.0) return(-1.0); + if (d >= 1.0) + return(1.0); sigma = acos(d) * (180./PI); - tau = acos(DOT(sd,vu)/sqrt(1.0-d*d)) * (180./PI); + d = fabs(DOT(sd,vu)/sqrt(1.0-d*d)); + if (d >= 1.0) + tau = 0.0; + else + tau = acos(d) * (180./PI); return( exp( sigma*( (35.2 - tau*.31889 - 1.22*exp(-.22222*tau))*1e-3 + sigma*(21. + tau*(.26667 + tau*-.002963))*1e-5 ) ) ); } -double -guth_dgr(gd) /* compute Guth discomfort glare rating */ -struct glare_dir *gd; +static double +dgi( /* compute Daylight Glare Index */ + struct glare_dir *gd +) { + register struct glare_src *gs; + FVECT mydir,testdir[7],vhor; + double r,posn,omega,p[7],sum; + int i,n; + + spinvector(mydir, midview.vdir, midview.vup, gd->ang); + sum = 0.0; n = 0; + for (gs = all_srcs; gs != NULL; gs = gs->next) { + + /* compute 1/p^2 weighted solid angle of the source */ + r = sqrt(1 - pow(1.-gs->dom/2./PI,2.)); + fcross(vhor,gs->dir,midview.vup); + normalize(vhor); + VCOPY(testdir[0],gs->dir); + fvsum(testdir[1],gs->dir,vhor,r); + fvsum(testdir[2],gs->dir,vhor,0.5*r); + fvsum(testdir[5],testdir[2],midview.vup,-0.866*r); + fvsum(testdir[2],testdir[2],midview.vup,0.866*r); + fvsum(testdir[3],gs->dir,vhor,-r); + fvsum(testdir[4],gs->dir,vhor,-0.5*r); + fvsum(testdir[6],testdir[4],midview.vup,0.866*r); + fvsum(testdir[4],testdir[4],midview.vup,-0.866*r); + for (i = 0; i < 7; i++) { + normalize(testdir[i]); + posn = posindex(testdir[i],mydir,midview.vup); + if (posn <= FTINY) + p[i] = 0.0; + else + p[i] = 1./(posn*posn); + } + r = 1-gs->dom/2./PI; + omega = gs->dom*p[0]; + omega += (r*PI*(1+1/r/r)-2*PI)*(-p[0]+(p[1]+p[2])*0.5); + omega += (2*PI-r*PI*(1+1/r/r))*(-p[0]-0.1667*(p[1]+p[3]) + +0.3334*(p[2]+p[4]+p[5]+p[6])); + + sum += pow(gs->lum,1.6) * pow(omega,0.8) / + (gd->indirect/PI + 0.07*sqrt(gs->dom)*gs->lum); + n++; + } + if (n == 0) + return(0.0); + return( 10*log10(0.478*sum) ); +} + + +static double +brs_gi( /* compute BRS Glare Index */ + struct glare_dir *gd +) +{ + register struct glare_src *gs; + FVECT mydir; + double p; + double sum; + + spinvector(mydir, midview.vdir, midview.vup, gd->ang); + sum = 0.0; + for (gs = all_srcs; gs != NULL; gs = gs->next) { + p = posindex(gs->dir, mydir, midview.vup); + if (p <= FTINY) + continue; + sum += pow(gs->lum/p,1.6) * pow(gs->dom,0.8); + } + if (sum <= FTINY) + return(0.0); + sum /= gd->indirect/PI; + return(10*log10(0.478*sum)); +} + + +static double +guth_dgr( /* compute Guth discomfort glare rating */ + struct glare_dir *gd +) +{ #define q(w) (20.4*w+1.52*pow(w,.2)-.075) register struct glare_src *gs; + FVECT mydir; double p; double sum; double wtot, brsum; int n; + spinvector(mydir, midview.vdir, midview.vup, gd->ang); sum = wtot = brsum = 0.0; n = 0; for (gs = all_srcs; gs != NULL; gs = gs->next) { - p = posindex(gs->dir, midview.vdir, midview.vup); + p = posindex(gs->dir, mydir, midview.vup); if (p <= FTINY) continue; sum += gs->lum * q(gs->dom) / p; @@ -283,16 +434,12 @@ struct glare_dir *gd; } if (n == 0) return(0.0); - else - return( pow( - .5*sum/pow((brsum+(5.-wtot)*gd->indirect/PI)/5.,.44), + return( pow(.5*sum/pow((brsum+(5.-wtot)*gd->indirect/PI)/5.,.44), pow((double)n, -.0914) ) ); #undef q } -extern double erf(), erfc(); - #ifndef M_SQRT2 #define M_SQRT2 1.41421356237309504880 #endif @@ -300,9 +447,66 @@ extern double erf(), erfc(); #define norm_integral(z) (1.-.5*erfc((z)/M_SQRT2)) -double -guth_vcp(gd) /* compute Guth visual comfort probability */ -struct glare_dir *gd; +static double +guth_vcp( /* compute Guth visual comfort probability */ + struct glare_dir *gd +) { - return(100.*norm_integral(6.374-1.3227*log(guth_dgr(gd)))); + extern double erfc(); + double dgr; + + dgr = guth_dgr(gd); + if (dgr <= FTINY) + return(100.0); + return(100.*norm_integral(6.374-1.3227*log(dgr))); +} + + +static double +cie_cgi( /* compute CIE Glare Index */ + struct glare_dir *gd +) +{ + register struct glare_src *gs; + FVECT mydir; + double dillum; + double p; + double sum; + + spinvector(mydir, midview.vdir, midview.vup, gd->ang); + sum = 0.0; + for (gs = all_srcs; gs != NULL; gs = gs->next) { + p = posindex(gs->dir, mydir, midview.vup); + if (p <= FTINY) + continue; + sum += gs->lum*gs->lum * gs->dom / (p*p); + } + if (sum <= FTINY) + return(0.0); + dillum = direct(gd); + return(8.*log10(2.*sum*(1.+dillum/500.)/(dillum+gd->indirect))); +} + + +static double +ugr( /* compute Unified Glare Rating */ + struct glare_dir *gd +) +{ + register struct glare_src *gs; + FVECT mydir; + double p; + double sum; + + spinvector(mydir, midview.vdir, midview.vup, gd->ang); + sum = 0.0; + for (gs = all_srcs; gs != NULL; gs = gs->next) { + p = posindex(gs->dir, mydir, midview.vup); + if (p <= FTINY) + continue; + sum += gs->lum*gs->lum * gs->dom / (p*p); + } + if (sum <= FTINY) + return(0.0); + return(8.*log10(0.25*sum*PI/gd->indirect)); }
