--- ray/src/util/glarendx.c 1991/04/16 16:40:22 1.1 +++ ray/src/util/glarendx.c 1991/04/22 10:11:21 1.6 @@ -7,8 +7,8 @@ static char SCCSid[] = "$SunId$ LBL"; /* * Compute Glare Index given by program name: * - * gnuth_dgr - Gnuth discomfort glare rating - * gnuth_vcp - Gnuth visual comfort probability + * guth_dgr - Guth discomfort glare rating + * guth_vcp - Guth visual comfort probability * * 12 April 1991 Greg Ward EPFL */ @@ -21,15 +21,15 @@ extern double erfc(); double posindex(); int headline(); -double direct(), gnuth_dgr(), gnuth_vcp(); +double direct(), guth_dgr(), guth_vcp(); struct named_func { char *name; double (*func)(); } all_funcs[] = { {"direct", direct}, - {"gnuth_dgr", gnuth_dgr}, - {"gnuth_vcp", gnuth_vcp}, + {"guth_dgr", guth_dgr}, + {"guth_vcp", guth_vcp}, {NULL} }; @@ -53,7 +53,9 @@ int print_header = 1; VIEW midview = STDVIEW; +int wrongformat = 0; + main(argc, argv) int argc; char *argv[]; @@ -89,14 +91,19 @@ char *argv[]; exit(1); } /* read header */ - getheader(stdin, headline); + getheader(stdin, headline, NULL); + if (wrongformat) { + fprintf(stderr, "%s: bad input format\n", progname); + exit(1); + } if (print_header) { /* add to header */ printargs(i, argv, stdout); putchar('\n'); } /* set view */ if (setview(&midview) != NULL) { - fprintf(stderr, "%s: bad view information in input\n"); + fprintf(stderr, "%s: bad view information in input\n", + progname); exit(1); } /* get findglare data */ @@ -119,10 +126,16 @@ userr: headline(s) /* get line from header */ char *s; { + char fmt[32]; + if (print_header) /* copy to output */ fputs(s, stdout); if (!strncmp(s, VIEWSTR, VIEWSTRL)) sscanview(&midview, s+VIEWSTRL); + else if (isformat(s)) { + formatval(fmt, s); + wrongformat = strcmp(fmt, "ascii"); + } } @@ -155,6 +168,7 @@ read_input() /* read glare sources from stdin */ &gs->dir[0], &gs->dir[1], &gs->dir[2], &gs->dom, &gs->lum) != 5) goto readerr; + normalize(gs->dir); gs->next = all_srcs; all_srcs = gs; break; @@ -225,6 +239,7 @@ struct glare_dir *gd; * All vectors are assumed to be normalized. * This function is an implementation of the method proposed by * Robert Levin in his 1975 JIES article. + * This calculation presumes the view direction and up vectors perpendicular. * We return a value less than zero for improper positions. */ @@ -238,8 +253,14 @@ FVECT sd, vd, vu; d = DOT(sd,vd); if (d <= 0.0) return(-1.0); + if (d >= 1.0) + return(1.0); sigma = acos(d) * (180./PI); - tau = acos(DOT(sd,vu)/sqrt(1.0-d*d)) * (180./PI); + d = DOT(sd,vu)/sqrt(1.0-d*d); + if (d >= 1.0) + tau = 0.0; + else + tau = acos(d) * (180./PI); return( exp( sigma*( (35.2 - tau*.31889 - 1.22*exp(-.22222*tau))*1e-3 + sigma*(21. + tau*(.26667 + tau*-.002963))*1e-5 ) ) ); @@ -247,28 +268,31 @@ FVECT sd, vd, vu; double -gnuth_dgr(gd) /* compute Gnuth discomfort glare rating */ +guth_dgr(gd) /* compute Guth discomfort glare rating */ struct glare_dir *gd; { #define q(w) (20.4*w+1.52*pow(w,.2)-.075) register struct glare_src *gs; double p; double sum; + double wtot, brsum; int n; - sum = 0.0; n = 0; + sum = wtot = brsum = 0.0; n = 0; for (gs = all_srcs; gs != NULL; gs = gs->next) { p = posindex(gs->dir, midview.vdir, midview.vup); if (p <= FTINY) continue; sum += gs->lum * q(gs->dom) / p; + brsum += gs->lum * gs->dom; + wtot += gs->dom; n++; } if (n == 0) return(0.0); else return( pow( - .5*sum/pow(direct(gd)+gd->indirect,.44), + .5*sum/pow((brsum+(5.-wtot)*gd->indirect/PI)/5.,.44), pow((double)n, -.0914) ) ); #undef q } @@ -284,8 +308,8 @@ extern double erf(), erfc(); double -gnuth_vcp(gd) /* compute Gnuth visual comfort probability */ +guth_vcp(gd) /* compute Guth visual comfort probability */ struct glare_dir *gd; { - return(100.*norm_integral(-6.374+1.3227*log(gnuth_dgr(gd)))); + return(100.*norm_integral(6.374-1.3227*log(guth_dgr(gd)))); }
