| 1 |
/* Copyright (c) 1991 Regents of the University of California */
| 2 |
| 3 |
#ifndef lint
| 4 |
static char SCCSid[] = "$SunId$ LBL";
| 5 |
#endif
| 6 |
| 7 |
| 8 |
* Compute Glare Index given by program name or -t option:
| 9 |
| 10 |
* guth_dgr - Guth discomfort glare rating
| 11 |
* guth_vcp - Guth visual comfort probability
| 12 |
* cie_cgi - CIE Glare Index (1983, due to Einhorn)
| 13 |
* vert_dir - Direct vertical illuminance
| 14 |
* vert_ind - Indirect vertical illuminance (from input)
| 15 |
* vert_ill - Total vertical illuminance
| 16 |
| 17 |
* 12 April 1991 Greg Ward EPFL
| 18 |
| 19 |
| 20 |
#include "standard.h"
| 21 |
#include "view.h"
| 22 |
| 23 |
extern double erfc();
| 24 |
| 25 |
double posindex();
| 26 |
| 27 |
double direct(), guth_dgr(), guth_vcp(), cie_cgi(),
| 28 |
indirect(), total();
| 29 |
| 30 |
struct named_func {
| 31 |
char *name;
| 32 |
double (*func)();
| 33 |
char *descrip;
| 34 |
} all_funcs[] = {
| 35 |
{"guth_vcp", guth_vcp, "Guth Visual Comfort Probability"},
| 36 |
{"cie_cgi", cie_cgi, "CIE Glare Index (Einhorn)"},
| 37 |
{"guth_dgr", guth_dgr, "Guth Disability Glare Rating"},
| 38 |
{"vert_dir", direct, "Direct Vertical Illuminance"},
| 39 |
{"vert_ill", total, "Total Vertical Illuminance"},
| 40 |
{"vert_ind", indirect, "Indirect Vertical Illuminance"},
| 41 |
{NULL}
| 42 |
| 43 |
| 44 |
struct glare_src {
| 45 |
FVECT dir; /* source direction */
| 46 |
double dom; /* solid angle */
| 47 |
double lum; /* average luminance */
| 48 |
struct glare_src *next;
| 49 |
} *all_srcs = NULL;
| 50 |
| 51 |
struct glare_dir {
| 52 |
double ang; /* angle (in radians) */
| 53 |
double indirect; /* indirect illuminance */
| 54 |
struct glare_dir *next;
| 55 |
} *all_dirs = NULL;
| 56 |
| 57 |
#define newp(type) (type *)malloc(sizeof(type))
| 58 |
| 59 |
char *progname;
| 60 |
int print_header = 1;
| 61 |
| 62 |
VIEW midview = STDVIEW;
| 63 |
| 64 |
int wrongformat = 0;
| 65 |
| 66 |
| 67 |
main(argc, argv)
| 68 |
int argc;
| 69 |
char *argv[];
| 70 |
| 71 |
extern char *rindex();
| 72 |
struct named_func *funp;
| 73 |
char *progtail;
| 74 |
int i;
| 75 |
/* get program name */
| 76 |
progname = argv[0];
| 77 |
progtail = rindex(progname, '/'); /* final component */
| 78 |
if (progtail == NULL)
| 79 |
progtail = progname;
| 80 |
else
| 81 |
progtail++;
| 82 |
/* get options */
| 83 |
for (i = 1; i < argc && argv[i][0] == '-'; i++)
| 84 |
switch (argv[i][1]) {
| 85 |
case 't':
| 86 |
progtail = argv[++i];
| 87 |
break;
| 88 |
case 'h':
| 89 |
print_header = 0;
| 90 |
break;
| 91 |
default:
| 92 |
goto userr;
| 93 |
| 94 |
if (i < argc-1)
| 95 |
goto userr;
| 96 |
if (i == argc-1) /* open file */
| 97 |
if (freopen(argv[i], "r", stdin) == NULL) {
| 98 |
perror(argv[i]);
| 99 |
exit(1);
| 100 |
| 101 |
/* find and run calculation */
| 102 |
for (funp = all_funcs; funp->name != NULL; funp++)
| 103 |
if (!strcmp(funp->name, progtail)) {
| 104 |
init();
| 105 |
read_input();
| 106 |
if (print_header) {
| 107 |
printargs(i, argv, stdout);
| 108 |
putchar('\n');
| 109 |
| 110 |
print_values(funp->func);
| 111 |
exit(0); /* we're done */
| 112 |
| 113 |
/* invalid function */
| 114 |
userr:
| 115 |
fprintf(stderr, "Usage: %s -t type [-h] [input]\n", progname);
| 116 |
fprintf(stderr, "\twhere 'type' is one of the following:\n");
| 117 |
| 118 |
fprintf(stderr, "\t%12s\t%s\n", funp->name, funp->descrip);
| 119 |
exit(1);
| 120 |
| 121 |
| 122 |
| 123 |
headline(s) /* get line from header */
| 124 |
char *s;
| 125 |
| 126 |
char fmt[32];
| 127 |
| 128 |
if (print_header) /* copy to output */
| 129 |
fputs(s, stdout);
| 130 |
if (!strncmp(s, VIEWSTR, VIEWSTRL))
| 131 |
sscanview(&midview, s+VIEWSTRL);
| 132 |
else if (isformat(s)) {
| 133 |
formatval(fmt, s);
| 134 |
wrongformat = strcmp(fmt, "ascii");
| 135 |
| 136 |
| 137 |
| 138 |
| 139 |
init() /* initialize calculation */
| 140 |
| 141 |
/* read header */
| 142 |
getheader(stdin, headline, NULL);
| 143 |
if (wrongformat) {
| 144 |
fprintf(stderr, "%s: bad input format\n", progname);
| 145 |
exit(1);
| 146 |
| 147 |
/* set view */
| 148 |
if (setview(&midview) != NULL) {
| 149 |
fprintf(stderr, "%s: bad view information in input\n",
| 150 |
progname);
| 151 |
exit(1);
| 152 |
| 153 |
| 154 |
| 155 |
| 156 |
read_input() /* read glare sources from stdin */
| 157 |
| 158 |
#define S_SEARCH 0
| 159 |
#define S_SOURCE 1
| 160 |
#define S_DIREC 2
| 161 |
int state = S_SEARCH;
| 162 |
char buf[128];
| 163 |
register struct glare_src *gs;
| 164 |
register struct glare_dir *gd;
| 165 |
| 166 |
while (fgets(buf, sizeof(buf), stdin) != NULL)
| 167 |
switch (state) {
| 168 |
case S_SEARCH:
| 169 |
if (!strcmp(buf, "BEGIN glare source\n"))
| 170 |
state = S_SOURCE;
| 171 |
else if (!strcmp(buf, "BEGIN indirect illuminance\n"))
| 172 |
state = S_DIREC;
| 173 |
break;
| 174 |
case S_SOURCE:
| 175 |
if (!strncmp(buf, "END", 3)) {
| 176 |
state = S_SEARCH;
| 177 |
break;
| 178 |
| 179 |
if ((gs = newp(struct glare_src)) == NULL)
| 180 |
goto memerr;
| 181 |
if (sscanf(buf, "%lf %lf %lf %lf %lf",
| 182 |
&gs->dir[0], &gs->dir[1], &gs->dir[2],
| 183 |
&gs->dom, &gs->lum) != 5)
| 184 |
goto readerr;
| 185 |
normalize(gs->dir);
| 186 |
gs->next = all_srcs;
| 187 |
all_srcs = gs;
| 188 |
break;
| 189 |
case S_DIREC:
| 190 |
| 191 |
state = S_SEARCH;
| 192 |
break;
| 193 |
| 194 |
if ((gd = newp(struct glare_dir)) == NULL)
| 195 |
goto memerr;
| 196 |
if (sscanf(buf, "%lf %lf",
| 197 |
&gd->ang, &gd->indirect) != 2)
| 198 |
goto readerr;
| 199 |
gd->ang *= PI/180.0; /* convert to radians */
| 200 |
gd->next = all_dirs;
| 201 |
all_dirs = gd;
| 202 |
break;
| 203 |
| 204 |
return;
| 205 |
memerr:
| 206 |
perror(progname);
| 207 |
exit(1);
| 208 |
readerr:
| 209 |
fprintf(stderr, "%s: read error on input\n", progname);
| 210 |
exit(1);
| 211 |
#undef S_SEARCH
| 212 |
#undef S_SOURCE
| 213 |
#undef S_DIREC
| 214 |
| 215 |
| 216 |
| 217 |
print_values(funp) /* print out calculations */
| 218 |
double (*funp)();
| 219 |
| 220 |
| 221 |
| 222 |
for (gd = all_dirs; gd != NULL; gd = gd->next)
| 223 |
printf("%f\t%f\n", gd->ang*(180.0/PI), (*funp)(gd));
| 224 |
| 225 |
| 226 |
| 227 |
double
| 228 |
direct(gd) /* compute direct vertical illuminance */
| 229 |
| 230 |
| 231 |
FVECT mydir;
| 232 |
double d, dval;
| 233 |
| 234 |
| 235 |
spinvector(mydir, midview.vdir, midview.vup, gd->ang);
| 236 |
dval = 0.0;
| 237 |
for (gs = all_srcs; gs != NULL; gs = gs->next) {
| 238 |
d = DOT(mydir,gs->dir);
| 239 |
if (d > FTINY)
| 240 |
dval += d * gs->dom * gs->lum;
| 241 |
| 242 |
return(dval);
| 243 |
| 244 |
| 245 |
| 246 |
double
| 247 |
indirect(gd) /* return indirect vertical illuminance */
| 248 |
| 249 |
| 250 |
return(gd->indirect);
| 251 |
| 252 |
| 253 |
| 254 |
double
| 255 |
total(gd) /* return total vertical illuminance */
| 256 |
| 257 |
| 258 |
return(direct(gd)+gd->indirect);
| 259 |
| 260 |
| 261 |
| 262 |
| 263 |
* posindex - compute glare position index from:
| 264 |
| 265 |
* Source Direction
| 266 |
* View Direction
| 267 |
* View Up Direction
| 268 |
| 269 |
* All vectors are assumed to be normalized.
| 270 |
* This function is an implementation of the method proposed by
| 271 |
* Robert Levin in his 1975 JIES article.
| 272 |
* This calculation presumes the view direction and up vectors perpendicular.
| 273 |
* We return a value less than zero for improper positions.
| 274 |
| 275 |
| 276 |
double
| 277 |
posindex(sd, vd, vu) /* compute position index */
| 278 |
FVECT sd, vd, vu;
| 279 |
| 280 |
double sigma, tau;
| 281 |
double d;
| 282 |
| 283 |
d = DOT(sd,vd);
| 284 |
if (d <= 0.0)
| 285 |
return(-1.0);
| 286 |
if (d >= 1.0)
| 287 |
return(1.0);
| 288 |
sigma = acos(d) * (180./PI);
| 289 |
d = DOT(sd,vu)/sqrt(1.0-d*d);
| 290 |
if (d >= 1.0)
| 291 |
tau = 0.0;
| 292 |
else
| 293 |
tau = acos(d) * (180./PI);
| 294 |
return( exp( sigma*( (35.2 - tau*.31889 - 1.22*exp(-.22222*tau))*1e-3
| 295 |
+ sigma*(21. + tau*(.26667 + tau*-.002963))*1e-5 )
| 296 |
| 297 |
| 298 |
| 299 |
| 300 |
double
| 301 |
guth_dgr(gd) /* compute Guth discomfort glare rating */
| 302 |
| 303 |
| 304 |
#define q(w) (20.4*w+1.52*pow(w,.2)-.075)
| 305 |
| 306 |
FVECT mydir;
| 307 |
double p;
| 308 |
double sum;
| 309 |
double wtot, brsum;
| 310 |
int n;
| 311 |
| 312 |
| 313 |
sum = wtot = brsum = 0.0; n = 0;
| 314 |
| 315 |
p = posindex(gs->dir, mydir, midview.vup);
| 316 |
if (p <= FTINY)
| 317 |
continue;
| 318 |
sum += gs->lum * q(gs->dom) / p;
| 319 |
brsum += gs->lum * gs->dom;
| 320 |
wtot += gs->dom;
| 321 |
n++;
| 322 |
| 323 |
if (n == 0)
| 324 |
return(0.0);
| 325 |
| 326 |
return( pow(.5*sum/pow((brsum+(5.-wtot)*gd->indirect/PI)/5.,.44),
| 327 |
pow((double)n, -.0914) ) );
| 328 |
#undef q
| 329 |
| 330 |
| 331 |
| 332 |
extern double erf(), erfc();
| 333 |
| 334 |
#ifndef M_SQRT2
| 335 |
#define M_SQRT2 1.41421356237309504880
| 336 |
#endif
| 337 |
| 338 |
#define norm_integral(z) (1.-.5*erfc((z)/M_SQRT2))
| 339 |
| 340 |
| 341 |
double
| 342 |
guth_vcp(gd) /* compute Guth visual comfort probability */
| 343 |
| 344 |
| 345 |
double dgr;
| 346 |
| 347 |
dgr = guth_dgr(gd);
| 348 |
if (dgr <= FTINY)
| 349 |
return(100.0);
| 350 |
return(100.*norm_integral(6.374-1.3227*log(dgr)));
| 351 |
| 352 |
| 353 |
| 354 |
double
| 355 |
cie_cgi(gd) /* compute CIE Glare Index */
| 356 |
| 357 |
| 358 |
| 359 |
FVECT mydir;
| 360 |
double dillum;
| 361 |
double p;
| 362 |
double sum;
| 363 |
| 364 |
| 365 |
sum = 0.0;
| 366 |
| 367 |
| 368 |
if (p <= FTINY)
| 369 |
continue;
| 370 |
sum += gs->lum*gs->lum * gs->dom / (p*p);
| 371 |
| 372 |
if (sum <= FTINY)
| 373 |
return(0.0);
| 374 |
dillum = direct(gd);
| 375 |
return(8.*log10(2.*sum*(1.+dillum/500.)/(dillum+gd->indirect)));
| 376 |
