root/radiance/ray/src/util/glarendx.c
Revision: 2.15
Committed: Mon Feb 17 19:35:24 2020 UTC (4 years, 4 months ago) by greg
Minor improvement to last change
2 static const char RCSid[] = "$Id: glarendx.c,v 2.14 2020/02/17 19:19:45 greg Exp $";
5 * Compute Glare Index given by program name or -t option:
6 *
7 * dgi - Daylight Glare Index
8 * brs_gi - Building Research Station Glare Index (Petherbridge
9 * & Hopkinson)
10 * ugr - Unified Glare Rating System (Fischer)
11 * guth_dgr - Guth discomfort glare rating
12 * guth_vcp - Guth visual comfort probability
13 * cie_cgi - CIE Glare Index (1983, due to Einhorn)
14 * vert_dir - Direct vertical illuminance
15 * vert_ind - Indirect vertical illuminance (from input)
16 * vert_ill - Total vertical illuminance
17 *
18 * 12 April 1991 Greg Ward EPFL
19 * 19 April 1993 R. Compagnon EPFL (added dgi, brs_gi, ugr)
20 */
21
22 #include <string.h>
23
24 #include "standard.h"
25 #include "view.h"
26
27
28 struct glare_src {
29 FVECT dir; /* source direction */
30 double dom; /* solid angle */
31 double lum; /* average luminance */
32 struct glare_src *next;
33 } *all_srcs = NULL;
34
35 struct glare_dir {
36 double ang; /* angle (in radians) */
37 double indirect; /* indirect illuminance */
38 struct glare_dir *next;
39 } *all_dirs = NULL;
40
41 typedef double gdfun(struct glare_dir *gd);
42
43 static gdfun dgi;
44 static gdfun brs_gi;
45 static gdfun ugr;
46 static gdfun guth_dgr;
47 static gdfun guth_vcp;
48 static gdfun cie_cgi;
49 static gdfun direct;
50 static gdfun indirect;
51 static gdfun total;
52
53 static gethfunc headline;
54 static void init(void);
55 static void read_input(void);
56 static void print_values(gdfun *func);
57 static double posindex(FVECT sd, FVECT vd, FVECT vu);
58
59
60 struct named_func {
61 char *name;
62 gdfun *func;
63 char *descrip;
64 } all_funcs[] = {
65 {"dgi", dgi, "Daylight Glare Index"},
66 {"brs_gi", brs_gi, "BRS Glare Index"},
67 {"ugr", ugr, "Unified Glare Rating"},
68 {"guth_vcp", guth_vcp, "Guth Visual Comfort Probability"},
69 {"cie_cgi", cie_cgi, "CIE Glare Index (Einhorn)"},
70 {"guth_dgr", guth_dgr, "Guth Disability Glare Rating"},
71 {"vert_dir", direct, "Direct Vertical Illuminance"},
72 {"vert_ill", total, "Total Vertical Illuminance"},
73 {"vert_ind", indirect, "Indirect Vertical Illuminance"},
74 {NULL}
75 };
76
77 #define newp(type) (type *)malloc(sizeof(type))
78
79 char *progname;
80 int print_header = 1;
81
82 VIEW midview = STDVIEW;
83
84 int wrongformat = 0;
85
86
87 int
88 main(
89 int argc,
90 char *argv[]
91 )
92 {
93 struct named_func *funp;
94 char *progtail;
95 int i;
96 /* get program name */
97 progname = argv[0];
98 progtail = strrchr(progname, '/'); /* final component */
99 if (progtail == NULL)
100 progtail = progname;
101 else
102 progtail++;
103 /* get options */
104 for (i = 1; i < argc && argv[i][0] == '-'; i++)
105 switch (argv[i][1]) {
106 case 't':
107 progtail = argv[++i];
108 break;
109 case 'h':
110 print_header = 0;
111 break;
112 default:
113 goto userr;
114 }
115 if (i < argc-1)
116 goto userr;
117 if (i == argc-1) /* open file */
118 if (freopen(argv[i], "r", stdin) == NULL) {
119 perror(argv[i]);
120 exit(1);
121 }
122 /* find and run calculation */
123 for (funp = all_funcs; funp->name != NULL; funp++)
124 if (!strcmp(funp->name, progtail)) {
125 init();
126 read_input();
127 if (print_header) {
128 printargs(i, argv, stdout);
129 putchar('\n');
130 }
131 print_values(funp->func);
132 exit(0); /* we're done */
133 }
134 /* invalid function */
135 userr:
136 fprintf(stderr, "Usage: %s -t type [-h] [input]\n", progname);
137 fprintf(stderr, "\twhere 'type' is one of the following:\n");
138 for (funp = all_funcs; funp->name != NULL; funp++)
139 fprintf(stderr, "\t%12s\t%s\n", funp->name, funp->descrip);
140 exit(1);
141 }
142
143
144 static int
145 headline( /* get line from header */
146 char *s,
147 void *p
148 )
149 {
150 char fmt[MAXFMTLEN];
151
152 if (print_header) /* copy to output */
153 fputs(s, stdout);
154 if (isview(s))
155 sscanview(&midview, s);
156 else if (isformat(s)) {
157 formatval(fmt, s);
158 wrongformat = strcmp(fmt, "ascii");
159 }
160 return(0);
161 }
162
163
164 static void
165 init(void) /* initialize calculation */
166 {
167 char *err;
168 /* read header */
169 getheader(stdin, headline, NULL);
170 if (wrongformat) {
171 fprintf(stderr, "%s: bad input format\n", progname);
172 exit(1);
173 }
174 /* set view */
175 if ((err = setview(&midview)) != NULL) {
176 fprintf(stderr, "%s: %s\n",
177 progname, err);
178 exit(1);
179 }
180 if (fabs(DOT(midview.vdir, midview.vup)) > 1e-4) {
181 fprintf(stderr,
182 "%s: Input view direction not perpendicular to up vector\n",
183 progname);
184 exit(1);
185 }
186 }
187
188
189 static void
190 read_input(void) /* read glare sources from stdin */
191 {
192 #define S_SEARCH 0
193 #define S_SOURCE 1
194 #define S_DIREC 2
195 int state = S_SEARCH;
196 char buf[128];
197 struct glare_src *gs;
198 struct glare_dir *gd;
199
200 while (fgets(buf, sizeof(buf), stdin) != NULL)
201 switch (state) {
202 case S_SEARCH:
203 if (!strcmp(buf, "BEGIN glare source\n"))
204 state = S_SOURCE;
205 else if (!strcmp(buf, "BEGIN indirect illuminance\n"))
206 state = S_DIREC;
207 break;
208 case S_SOURCE:
209 if (!strncmp(buf, "END", 3)) {
210 state = S_SEARCH;
211 break;
212 }
213 if ((gs = newp(struct glare_src)) == NULL)
214 goto memerr;
215 if (sscanf(buf, FVFORMAT, &gs->dir[0], &gs->dir[1],
216 &gs->dir[2]) != 3 ||
217 sscanf(sskip2(buf, 3), "%lf %lf",
218 &gs->dom, &gs->lum) != 2)
219 goto readerr;
220 normalize(gs->dir);
221 gs->next = all_srcs;
222 all_srcs = gs;
223 break;
224 case S_DIREC:
225 if (!strncmp(buf, "END", 3)) {
226 state = S_SEARCH;
227 break;
228 }
229 if ((gd = newp(struct glare_dir)) == NULL)
230 goto memerr;
231 if (sscanf(buf, "%lf %lf",
232 &gd->ang, &gd->indirect) != 2)
233 goto readerr;
234 gd->ang *= PI/180.0; /* convert to radians */
235 gd->next = all_dirs;
236 all_dirs = gd;
237 break;
238 }
239 return;
240 memerr:
241 perror(progname);
242 exit(1);
243 readerr:
244 fprintf(stderr, "%s: read error on input\n", progname);
245 exit(1);
246 #undef S_SEARCH
247 #undef S_SOURCE
248 #undef S_DIREC
249 }
250
251
252 static void
253 print_values( /* print out calculations */
254 gdfun *func
255 )
256 {
257 struct glare_dir *gd;
258
259 for (gd = all_dirs; gd != NULL; gd = gd->next)
260 printf("%f\t%f\n", gd->ang*(180.0/PI), (*func)(gd));
261 }
262
263
264 static double
265 direct( /* compute direct vertical illuminance */
266 struct glare_dir *gd
267 )
268 {
269 FVECT mydir;
270 double d, dval;
271 struct glare_src *gs;
272
273 spinvector(mydir, midview.vdir, midview.vup, gd->ang);
274 dval = 0.0;
275 for (gs = all_srcs; gs != NULL; gs = gs->next) {
276 d = DOT(mydir,gs->dir);
277 if (d > FTINY)
278 dval += d * gs->dom * gs->lum;
279 }
280 return(dval);
281 }
282
283
284 static double
285 indirect( /* return indirect vertical illuminance */
286 struct glare_dir *gd
287 )
288 {
289 return(gd->indirect);
290 }
291
292
293 static double
294 total( /* return total vertical illuminance */
295 struct glare_dir *gd
296 )
297 {
298 return(direct(gd)+gd->indirect);
299 }
300
301
302 /*
303 * posindex - compute glare position index from:
304 *
305 * Source Direction
306 * View Direction
307 * View Up Direction
308 *
309 * All vectors are assumed to be normalized.
310 * This function is an implementation of the method proposed by
311 * Robert Levin in his 1975 JIES article.
312 * This calculation presumes the view direction and up vectors perpendicular.
313 * We return a value less than zero for improper positions.
314 */
315
316 static double
317 posindex( /* compute position index */
318 FVECT sd,
319 FVECT vd,
320 FVECT vu
321 )
322 {
323 double sigma, tau;
324 double d;
325
326 d = DOT(sd,vd);
327 if (d <= 0.0)
328 return(-1.0);
329 if (d >= 1.0-FTINY)
330 return(1.0);
331 sigma = acos(d) * (180./PI);
332 d = fabs(DOT(sd,vu)/sqrt(1.0-d*d));
333 tau = Acos(d) * (180./PI);
334 return( exp( sigma*( (35.2 - tau*.31889 - 1.22*exp(-.22222*tau))*1e-3
335 + sigma*(21. + tau*(.26667 + tau*-.002963))*1e-5 )
336 ) );
337 }
338
339
340 static double
341 dgi( /* compute Daylight Glare Index */
342 struct glare_dir *gd
343 )
344 {
345 struct glare_src *gs;
346 FVECT mydir,testdir[7],vhor;
347 double r,posn,omega,p[7],sum;
348 int i;
349
350 spinvector(mydir, midview.vdir, midview.vup, gd->ang);
351 sum = 0.0;
352 for (gs = all_srcs; gs != NULL; gs = gs->next) {
353
354 /* compute 1/p^2 weighted solid angle of the source */
355 r = 1. - gs->dom*(.5/PI);
356 r = sqrt(1. - r*r);
357 fcross(vhor,gs->dir,midview.vup);
358 if (normalize(vhor) == 0.)
359 continue;
360 VCOPY(testdir[0],gs->dir);
361 fvsum(testdir[1],gs->dir,vhor,r);
362 fvsum(testdir[2],gs->dir,vhor,0.5*r);
363 fvsum(testdir[5],testdir[2],midview.vup,-0.866*r);
364 fvsum(testdir[2],testdir[2],midview.vup,0.866*r);
365 fvsum(testdir[3],gs->dir,vhor,-r);
366 fvsum(testdir[4],gs->dir,vhor,-0.5*r);
367 fvsum(testdir[6],testdir[4],midview.vup,0.866*r);
368 fvsum(testdir[4],testdir[4],midview.vup,-0.866*r);
369 for (i = 0; i < 7; i++) {
370 p[i] = 0.0;
371 if (normalize(testdir[i]) == 0.)
372 continue;
373 posn = posindex(testdir[i],mydir,midview.vup);
374 if (posn > FTINY)
375 p[i] = 1./(posn*posn);
376 }
377 r = 1. - gs->dom*(.5/PI);
378 omega = gs->dom*p[0];
379 omega += (r*PI*(1.+1./(r*r))-2.*PI)*(-p[0]+(p[1]+p[2])*0.5);
380 omega += (2.*PI-r*PI*(1.+1./(r*r)))*(-p[0]-0.1667*(p[1]+p[3])
381 +0.3334*(p[2]+p[4]+p[5]+p[6]));
382 if (omega <= 0.)
383 continue;
384 sum += pow(gs->lum,1.6) * pow(omega,0.8) /
385 (gd->indirect*(1./PI) + 0.07*sqrt(gs->dom)*gs->lum);
386 }
387 if (sum <= FTINY)
388 return(0.0);
389 return( 10.*log10(0.478*sum) );
390 }
391
392
393 static double
394 brs_gi( /* compute BRS Glare Index */
395 struct glare_dir *gd
396 )
397 {
398 struct glare_src *gs;
399 FVECT mydir;
400 double p;
401 double sum;
402
403 spinvector(mydir, midview.vdir, midview.vup, gd->ang);
404 sum = 0.0;
405 for (gs = all_srcs; gs != NULL; gs = gs->next) {
406 p = posindex(gs->dir, mydir, midview.vup);
407 if (p <= FTINY)
408 continue;
409 sum += pow(gs->lum/p,1.6) * pow(gs->dom,0.8);
410 }
411 if (sum <= FTINY)
412 return(0.0);
413 sum *= PI/gd->indirect;
414 return(10*log10(0.478*sum));
415 }
416
417
418 static double
419 guth_dgr( /* compute Guth discomfort glare rating */
420 struct glare_dir *gd
421 )
422 {
423 #define q(w) (20.4*w+1.52*pow(w,.2)-.075)
424 struct glare_src *gs;
425 FVECT mydir;
426 double p;
427 double sum;
428 double wtot, brsum;
429 int n;
430
431 spinvector(mydir, midview.vdir, midview.vup, gd->ang);
432 sum = wtot = brsum = 0.0; n = 0;
433 for (gs = all_srcs; gs != NULL; gs = gs->next) {
434 p = posindex(gs->dir, mydir, midview.vup);
435 if (p <= FTINY)
436 continue;
437 sum += gs->lum * q(gs->dom) / p;
438 brsum += gs->lum * gs->dom;
439 wtot += gs->dom;
440 n++;
441 }
442 if (n == 0)
443 return(0.0);
444 return( pow(.5*sum/pow((brsum+(5.-wtot)*gd->indirect/PI)/5.,.44),
445 pow((double)n, -.0914) ) );
446 #undef q
447 }
448
449
450 #ifndef M_SQRT2
451 #define M_SQRT2 1.41421356237309504880
452 #endif
453
454 #define norm_integral(z) (1.-.5*erfc((z)/M_SQRT2))
455
456
457 static double
458 guth_vcp( /* compute Guth visual comfort probability */
459 struct glare_dir *gd
460 )
461 {
462 extern double erfc();
463 double dgr;
464
465 dgr = guth_dgr(gd);
466 if (dgr <= FTINY)
467 return(100.0);
468 return(100.*norm_integral(6.374-1.3227*log(dgr)));
469 }
470
471
472 static double
473 cie_cgi( /* compute CIE Glare Index */
474 struct glare_dir *gd
475 )
476 {
477 struct glare_src *gs;
478 FVECT mydir;
479 double dillum;
480 double p;
481 double sum;
482
483 spinvector(mydir, midview.vdir, midview.vup, gd->ang);
484 sum = 0.0;
485 for (gs = all_srcs; gs != NULL; gs = gs->next) {
486 p = posindex(gs->dir, mydir, midview.vup);
487 if (p <= FTINY)
488 continue;
489 sum += gs->lum*gs->lum * gs->dom / (p*p);
490 }
491 if (sum <= FTINY)
492 return(0.0);
493 dillum = direct(gd);
494 return(8.*log10(2.*sum*(1.+dillum/500.)/(dillum+gd->indirect)));
495 }
496
497
498 static double
499 ugr( /* compute Unified Glare Rating */
500 struct glare_dir *gd
501 )
502 {
503 struct glare_src *gs;
504 FVECT mydir;
505 double p;
506 double sum;
507
508 spinvector(mydir, midview.vdir, midview.vup, gd->ang);
509 sum = 0.0;
510 for (gs = all_srcs; gs != NULL; gs = gs->next) {
511 p = posindex(gs->dir, mydir, midview.vup);
512 if (p <= FTINY)
513 continue;
514 sum += gs->lum*gs->lum * gs->dom / (p*p);
515 }
516 if (sum <= FTINY)
517 return(0.0);
518 return(8.*log10(0.25*sum*PI/gd->indirect));
519 }
