--- ray/src/util/glarendx.c 2004/01/02 12:48:36 2.10 +++ ray/src/util/glarendx.c 2020/02/17 19:35:24 2.15 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: glarendx.c,v 2.10 2004/01/02 12:48:36 schorsch Exp $"; +static const char RCSid[] = "$Id: glarendx.c,v 2.15 2020/02/17 19:35:24 greg Exp $"; #endif /* * Compute Glare Index given by program name or -t option: @@ -147,7 +147,7 @@ headline( /* get line from header */ void *p ) { - char fmt[32]; + char fmt[MAXFMTLEN]; if (print_header) /* copy to output */ fputs(s, stdout); @@ -164,6 +164,7 @@ headline( /* get line from header */ static void init(void) /* initialize calculation */ { + char *err; /* read header */ getheader(stdin, headline, NULL); if (wrongformat) { @@ -171,8 +172,14 @@ init(void) /* initialize calculation */ exit(1); } /* set view */ - if (setview(&midview) != NULL) { - fprintf(stderr, "%s: bad view information in input\n", + if ((err = setview(&midview)) != NULL) { + fprintf(stderr, "%s: %s\n", + progname, err); + exit(1); + } + if (fabs(DOT(midview.vdir, midview.vup)) > 1e-4) { + fprintf(stderr, + "%s: Input view direction not perpendicular to up vector\n", progname); exit(1); } @@ -187,8 +194,8 @@ read_input(void) /* read glare sources from stdin */ #define S_DIREC 2 int state = S_SEARCH; char buf[128]; - register struct glare_src *gs; - register struct glare_dir *gd; + struct glare_src *gs; + struct glare_dir *gd; while (fgets(buf, sizeof(buf), stdin) != NULL) switch (state) { @@ -205,9 +212,10 @@ read_input(void) /* read glare sources from stdin */ } if ((gs = newp(struct glare_src)) == NULL) goto memerr; - if (sscanf(buf, "%lf %lf %lf %lf %lf", - &gs->dir[0], &gs->dir[1], &gs->dir[2], - &gs->dom, &gs->lum) != 5) + if (sscanf(buf, FVFORMAT, &gs->dir[0], &gs->dir[1], + &gs->dir[2]) != 3 || + sscanf(sskip2(buf, 3), "%lf %lf", + &gs->dom, &gs->lum) != 2) goto readerr; normalize(gs->dir); gs->next = all_srcs; @@ -246,7 +254,7 @@ print_values( /* print out calculations */ gdfun *func ) { - register struct glare_dir *gd; + struct glare_dir *gd; for (gd = all_dirs; gd != NULL; gd = gd->next) printf("%f\t%f\n", gd->ang*(180.0/PI), (*func)(gd)); @@ -260,7 +268,7 @@ direct( /* compute direct vertical illuminance */ { FVECT mydir; double d, dval; - register struct glare_src *gs; + struct glare_src *gs; spinvector(mydir, midview.vdir, midview.vup, gd->ang); dval = 0.0; @@ -318,14 +326,11 @@ posindex( /* compute position index */ d = DOT(sd,vd); if (d <= 0.0) return(-1.0); - if (d >= 1.0) + if (d >= 1.0-FTINY) return(1.0); sigma = acos(d) * (180./PI); d = fabs(DOT(sd,vu)/sqrt(1.0-d*d)); - if (d >= 1.0) - tau = 0.0; - else - tau = acos(d) * (180./PI); + tau = Acos(d) * (180./PI); return( exp( sigma*( (35.2 - tau*.31889 - 1.22*exp(-.22222*tau))*1e-3 + sigma*(21. + tau*(.26667 + tau*-.002963))*1e-5 ) ) ); @@ -337,19 +342,21 @@ dgi( /* compute Daylight Glare Index */ struct glare_dir *gd ) { - register struct glare_src *gs; + struct glare_src *gs; FVECT mydir,testdir[7],vhor; double r,posn,omega,p[7],sum; - int i,n; + int i; spinvector(mydir, midview.vdir, midview.vup, gd->ang); - sum = 0.0; n = 0; + sum = 0.0; for (gs = all_srcs; gs != NULL; gs = gs->next) { /* compute 1/p^2 weighted solid angle of the source */ - r = sqrt(1 - pow(1.-gs->dom/2./PI,2.)); + r = 1. - gs->dom*(.5/PI); + r = sqrt(1. - r*r); fcross(vhor,gs->dir,midview.vup); - normalize(vhor); + if (normalize(vhor) == 0.) + continue; VCOPY(testdir[0],gs->dir); fvsum(testdir[1],gs->dir,vhor,r); fvsum(testdir[2],gs->dir,vhor,0.5*r); @@ -360,26 +367,26 @@ dgi( /* compute Daylight Glare Index */ fvsum(testdir[6],testdir[4],midview.vup,0.866*r); fvsum(testdir[4],testdir[4],midview.vup,-0.866*r); for (i = 0; i < 7; i++) { - normalize(testdir[i]); + p[i] = 0.0; + if (normalize(testdir[i]) == 0.) + continue; posn = posindex(testdir[i],mydir,midview.vup); - if (posn <= FTINY) - p[i] = 0.0; - else + if (posn > FTINY) p[i] = 1./(posn*posn); } - r = 1-gs->dom/2./PI; + r = 1. - gs->dom*(.5/PI); omega = gs->dom*p[0]; - omega += (r*PI*(1+1/r/r)-2*PI)*(-p[0]+(p[1]+p[2])*0.5); - omega += (2*PI-r*PI*(1+1/r/r))*(-p[0]-0.1667*(p[1]+p[3]) + omega += (r*PI*(1.+1./(r*r))-2.*PI)*(-p[0]+(p[1]+p[2])*0.5); + omega += (2.*PI-r*PI*(1.+1./(r*r)))*(-p[0]-0.1667*(p[1]+p[3]) +0.3334*(p[2]+p[4]+p[5]+p[6])); - + if (omega <= 0.) + continue; sum += pow(gs->lum,1.6) * pow(omega,0.8) / - (gd->indirect/PI + 0.07*sqrt(gs->dom)*gs->lum); - n++; + (gd->indirect*(1./PI) + 0.07*sqrt(gs->dom)*gs->lum); } - if (n == 0) + if (sum <= FTINY) return(0.0); - return( 10*log10(0.478*sum) ); + return( 10.*log10(0.478*sum) ); } @@ -388,7 +395,7 @@ brs_gi( /* compute BRS Glare Index */ struct glare_dir *gd ) { - register struct glare_src *gs; + struct glare_src *gs; FVECT mydir; double p; double sum; @@ -403,7 +410,7 @@ brs_gi( /* compute BRS Glare Index */ } if (sum <= FTINY) return(0.0); - sum /= gd->indirect/PI; + sum *= PI/gd->indirect; return(10*log10(0.478*sum)); } @@ -414,7 +421,7 @@ guth_dgr( /* compute Guth discomfort glare rating */ ) { #define q(w) (20.4*w+1.52*pow(w,.2)-.075) - register struct glare_src *gs; + struct glare_src *gs; FVECT mydir; double p; double sum; @@ -467,7 +474,7 @@ cie_cgi( /* compute CIE Glare Index */ struct glare_dir *gd ) { - register struct glare_src *gs; + struct glare_src *gs; FVECT mydir; double dillum; double p; @@ -493,7 +500,7 @@ ugr( /* compute Unified Glare Rating */ struct glare_dir *gd ) { - register struct glare_src *gs; + struct glare_src *gs; FVECT mydir; double p; double sum;
