root/Development/ray/src/util/glarendx.c
Revision: 2.5
Committed: Sun Jun 4 10:58:38 1995 UTC (30 years, 7 months ago) by greg
Changes since 2.4: +1 -3 lines
changed location of erfc() declaration
1 /* Copyright (c) 1991 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Compute Glare Index given by program name or -t option:
9 *
10 * dgi - Daylight Glare Index
11 * brs_gi - Building Research Station Glare Index (Petherbridge
12 * & Hopkinson)
13 * ugr - Unified Glare Rating System (Fischer)
14 * guth_dgr - Guth discomfort glare rating
15 * guth_vcp - Guth visual comfort probability
16 * cie_cgi - CIE Glare Index (1983, due to Einhorn)
17 * vert_dir - Direct vertical illuminance
18 * vert_ind - Indirect vertical illuminance (from input)
19 * vert_ill - Total vertical illuminance
20 *
21 * 12 April 1991 Greg Ward EPFL
22 * 19 April 1993 R. Compagnon EPFL (added dgi, brs_gi, ugr)
23 */
24
25 #include "standard.h"
26 #include "view.h"
27
28
29 double posindex();
30
31 double direct(), guth_dgr(), guth_vcp(), cie_cgi(),
32 indirect(), total(), dgi(), brs_gi(), ugr();
33
34 struct named_func {
35 char *name;
36 double (*func)();
37 char *descrip;
38 } all_funcs[] = {
39 {"dgi", dgi, "Daylight Glare Index"},
40 {"brs_gi", brs_gi, "BRS Glare Index"},
41 {"ugr", ugr, "Unified Glare Rating"},
42 {"guth_vcp", guth_vcp, "Guth Visual Comfort Probability"},
43 {"cie_cgi", cie_cgi, "CIE Glare Index (Einhorn)"},
44 {"guth_dgr", guth_dgr, "Guth Disability Glare Rating"},
45 {"vert_dir", direct, "Direct Vertical Illuminance"},
46 {"vert_ill", total, "Total Vertical Illuminance"},
47 {"vert_ind", indirect, "Indirect Vertical Illuminance"},
48 {NULL}
49 };
50
51 struct glare_src {
52 FVECT dir; /* source direction */
53 double dom; /* solid angle */
54 double lum; /* average luminance */
55 struct glare_src *next;
56 } *all_srcs = NULL;
57
58 struct glare_dir {
59 double ang; /* angle (in radians) */
60 double indirect; /* indirect illuminance */
61 struct glare_dir *next;
62 } *all_dirs = NULL;
63
64 #define newp(type) (type *)malloc(sizeof(type))
65
66 char *progname;
67 int print_header = 1;
68
69 VIEW midview = STDVIEW;
70
71 int wrongformat = 0;
72
73
74 main(argc, argv)
75 int argc;
76 char *argv[];
77 {
78 extern char *rindex();
79 struct named_func *funp;
80 char *progtail;
81 int i;
82 /* get program name */
83 progname = argv[0];
84 progtail = rindex(progname, '/'); /* final component */
85 if (progtail == NULL)
86 progtail = progname;
87 else
88 progtail++;
89 /* get options */
90 for (i = 1; i < argc && argv[i][0] == '-'; i++)
91 switch (argv[i][1]) {
92 case 't':
93 progtail = argv[++i];
94 break;
95 case 'h':
96 print_header = 0;
97 break;
98 default:
99 goto userr;
100 }
101 if (i < argc-1)
102 goto userr;
103 if (i == argc-1) /* open file */
104 if (freopen(argv[i], "r", stdin) == NULL) {
105 perror(argv[i]);
106 exit(1);
107 }
108 /* find and run calculation */
109 for (funp = all_funcs; funp->name != NULL; funp++)
110 if (!strcmp(funp->name, progtail)) {
111 init();
112 read_input();
113 if (print_header) {
114 printargs(i, argv, stdout);
115 putchar('\n');
116 }
117 print_values(funp->func);
118 exit(0); /* we're done */
119 }
120 /* invalid function */
121 userr:
122 fprintf(stderr, "Usage: %s -t type [-h] [input]\n", progname);
123 fprintf(stderr, "\twhere 'type' is one of the following:\n");
124 for (funp = all_funcs; funp->name != NULL; funp++)
125 fprintf(stderr, "\t%12s\t%s\n", funp->name, funp->descrip);
126 exit(1);
127 }
128
129
130 headline(s) /* get line from header */
131 char *s;
132 {
133 char fmt[32];
134
135 if (print_header) /* copy to output */
136 fputs(s, stdout);
137 if (isview(s))
138 sscanview(&midview, s);
139 else if (isformat(s)) {
140 formatval(fmt, s);
141 wrongformat = strcmp(fmt, "ascii");
142 }
143 }
144
145
146 init() /* initialize calculation */
147 {
148 /* read header */
149 getheader(stdin, headline, NULL);
150 if (wrongformat) {
151 fprintf(stderr, "%s: bad input format\n", progname);
152 exit(1);
153 }
154 /* set view */
155 if (setview(&midview) != NULL) {
156 fprintf(stderr, "%s: bad view information in input\n",
157 progname);
158 exit(1);
159 }
160 }
161
162
163 read_input() /* read glare sources from stdin */
164 {
165 #define S_SEARCH 0
166 #define S_SOURCE 1
167 #define S_DIREC 2
168 int state = S_SEARCH;
169 char buf[128];
170 register struct glare_src *gs;
171 register struct glare_dir *gd;
172
173 while (fgets(buf, sizeof(buf), stdin) != NULL)
174 switch (state) {
175 case S_SEARCH:
176 if (!strcmp(buf, "BEGIN glare source\n"))
177 state = S_SOURCE;
178 else if (!strcmp(buf, "BEGIN indirect illuminance\n"))
179 state = S_DIREC;
180 break;
181 case S_SOURCE:
182 if (!strncmp(buf, "END", 3)) {
183 state = S_SEARCH;
184 break;
185 }
186 if ((gs = newp(struct glare_src)) == NULL)
187 goto memerr;
188 if (sscanf(buf, "%lf %lf %lf %lf %lf",
189 &gs->dir[0], &gs->dir[1], &gs->dir[2],
190 &gs->dom, &gs->lum) != 5)
191 goto readerr;
192 normalize(gs->dir);
193 gs->next = all_srcs;
194 all_srcs = gs;
195 break;
196 case S_DIREC:
197 if (!strncmp(buf, "END", 3)) {
198 state = S_SEARCH;
199 break;
200 }
201 if ((gd = newp(struct glare_dir)) == NULL)
202 goto memerr;
203 if (sscanf(buf, "%lf %lf",
204 &gd->ang, &gd->indirect) != 2)
205 goto readerr;
206 gd->ang *= PI/180.0; /* convert to radians */
207 gd->next = all_dirs;
208 all_dirs = gd;
209 break;
210 }
211 return;
212 memerr:
213 perror(progname);
214 exit(1);
215 readerr:
216 fprintf(stderr, "%s: read error on input\n", progname);
217 exit(1);
218 #undef S_SEARCH
219 #undef S_SOURCE
220 #undef S_DIREC
221 }
222
223
224 print_values(funp) /* print out calculations */
225 double (*funp)();
226 {
227 register struct glare_dir *gd;
228
229 for (gd = all_dirs; gd != NULL; gd = gd->next)
230 printf("%f\t%f\n", gd->ang*(180.0/PI), (*funp)(gd));
231 }
232
233
234 double
235 direct(gd) /* compute direct vertical illuminance */
236 struct glare_dir *gd;
237 {
238 FVECT mydir;
239 double d, dval;
240 register struct glare_src *gs;
241
242 spinvector(mydir, midview.vdir, midview.vup, gd->ang);
243 dval = 0.0;
244 for (gs = all_srcs; gs != NULL; gs = gs->next) {
245 d = DOT(mydir,gs->dir);
246 if (d > FTINY)
247 dval += d * gs->dom * gs->lum;
248 }
249 return(dval);
250 }
251
252
253 double
254 indirect(gd) /* return indirect vertical illuminance */
255 struct glare_dir *gd;
256 {
257 return(gd->indirect);
258 }
259
260
261 double
262 total(gd) /* return total vertical illuminance */
263 struct glare_dir *gd;
264 {
265 return(direct(gd)+gd->indirect);
266 }
267
268
269 /*
270 * posindex - compute glare position index from:
271 *
272 * Source Direction
273 * View Direction
274 * View Up Direction
275 *
276 * All vectors are assumed to be normalized.
277 * This function is an implementation of the method proposed by
278 * Robert Levin in his 1975 JIES article.
279 * This calculation presumes the view direction and up vectors perpendicular.
280 * We return a value less than zero for improper positions.
281 */
282
283 double
284 posindex(sd, vd, vu) /* compute position index */
285 FVECT sd, vd, vu;
286 {
287 double sigma, tau;
288 double d;
289
290 d = DOT(sd,vd);
291 if (d <= 0.0)
292 return(-1.0);
293 if (d >= 1.0)
294 return(1.0);
295 sigma = acos(d) * (180./PI);
296 d = fabs(DOT(sd,vu)/sqrt(1.0-d*d));
297 if (d >= 1.0)
298 tau = 0.0;
299 else
300 tau = acos(d) * (180./PI);
301 return( exp( sigma*( (35.2 - tau*.31889 - 1.22*exp(-.22222*tau))*1e-3
302 + sigma*(21. + tau*(.26667 + tau*-.002963))*1e-5 )
303 ) );
304 }
305
306
307 double
308 dgi(gd) /* compute Daylight Glare Index */
309 struct glare_dir *gd;
310 {
311 register struct glare_src *gs;
312 FVECT mydir,testdir[7],vhor;
313 double r,omega,p[7],sum;
314 int i,n;
315
316 spinvector(mydir, midview.vdir, midview.vup, gd->ang);
317 sum = 0.0; n = 0;
318 for (gs = all_srcs; gs != NULL; gs = gs->next) {
319
320 /* compute 1/p^2 weighted solid angle of the source */
321 r = sqrt(1 - pow(1.-gs->dom/2./PI,2.));
322 fcross(vhor,gs->dir,midview.vup);
323 normalize(vhor);
324 VCOPY(testdir[0],gs->dir);
325 fvsum(testdir[1],gs->dir,vhor,r);
326 fvsum(testdir[2],gs->dir,vhor,0.5*r);
327 fvsum(testdir[5],testdir[2],midview.vup,-0.866*r);
328 fvsum(testdir[2],testdir[2],midview.vup,0.866*r);
329 fvsum(testdir[3],gs->dir,vhor,-r);
330 fvsum(testdir[4],gs->dir,vhor,-0.5*r);
331 fvsum(testdir[6],testdir[4],midview.vup,0.866*r);
332 fvsum(testdir[4],testdir[4],midview.vup,-0.866*r);
333 for (i = 0; i < 7; i++) {
334 normalize(testdir[i]);
335 p[i] = pow(posindex(testdir[i],mydir,midview.vup),-2.0);
336 if (p[i] <= FTINY) p[i] = 0.0;
337 }
338 r = 1-gs->dom/2./PI;
339 omega = gs->dom*p[0];
340 omega += (r*PI*(1+1/r/r)-2*PI)*(-p[0]+(p[1]+p[2])*0.5);
341 omega += (2*PI-r*PI*(1+1/r/r))*(-p[0]-0.1667*(p[1]+p[3])
342 +0.3334*(p[2]+p[4]+p[5]+p[6]));
343
344 sum += pow(gs->lum,1.6) * pow(omega,0.8) /
345 (gd->indirect/PI + 0.07*sqrt(gs->dom)*gs->lum);
346 n++;
347 }
348 if (n == 0)
349 return(0.0);
350 return( 10*log10(0.478*sum) );
351 }
352
353
354 double
355 brs_gi(gd) /* compute BRS Glare Index */
356 struct glare_dir *gd;
357 {
358 register struct glare_src *gs;
359 FVECT mydir;
360 double p;
361 double sum;
362
363 spinvector(mydir, midview.vdir, midview.vup, gd->ang);
364 sum = 0.0;
365 for (gs = all_srcs; gs != NULL; gs = gs->next) {
366 p = posindex(gs->dir, mydir, midview.vup);
367 if (p <= FTINY)
368 continue;
369 sum += pow(gs->lum/p,1.6) * pow(gs->dom,0.8);
370 }
371 if (sum <= FTINY)
372 return(0.0);
373 sum /= gd->indirect/PI;
374 return(10*log10(0.478*sum));
375 }
376
377
378 double
379 guth_dgr(gd) /* compute Guth discomfort glare rating */
380 struct glare_dir *gd;
381 {
382 #define q(w) (20.4*w+1.52*pow(w,.2)-.075)
383 register struct glare_src *gs;
384 FVECT mydir;
385 double p;
386 double sum;
387 double wtot, brsum;
388 int n;
389
390 spinvector(mydir, midview.vdir, midview.vup, gd->ang);
391 sum = wtot = brsum = 0.0; n = 0;
392 for (gs = all_srcs; gs != NULL; gs = gs->next) {
393 p = posindex(gs->dir, mydir, midview.vup);
394 if (p <= FTINY)
395 continue;
396 sum += gs->lum * q(gs->dom) / p;
397 brsum += gs->lum * gs->dom;
398 wtot += gs->dom;
399 n++;
400 }
401 if (n == 0)
402 return(0.0);
403 return( pow(.5*sum/pow((brsum+(5.-wtot)*gd->indirect/PI)/5.,.44),
404 pow((double)n, -.0914) ) );
405 #undef q
406 }
407
408
409 #ifndef M_SQRT2
410 #define M_SQRT2 1.41421356237309504880
411 #endif
412
413 #define norm_integral(z) (1.-.5*erfc((z)/M_SQRT2))
414
415
416 double
417 guth_vcp(gd) /* compute Guth visual comfort probability */
418 struct glare_dir *gd;
419 {
420 extern double erfc();
421 double dgr;
422
423 dgr = guth_dgr(gd);
424 if (dgr <= FTINY)
425 return(100.0);
426 return(100.*norm_integral(6.374-1.3227*log(dgr)));
427 }
428
429
430 double
431 cie_cgi(gd) /* compute CIE Glare Index */
432 struct glare_dir *gd;
433 {
434 register struct glare_src *gs;
435 FVECT mydir;
436 double dillum;
437 double p;
438 double sum;
439
440 spinvector(mydir, midview.vdir, midview.vup, gd->ang);
441 sum = 0.0;
442 for (gs = all_srcs; gs != NULL; gs = gs->next) {
443 p = posindex(gs->dir, mydir, midview.vup);
444 if (p <= FTINY)
445 continue;
446 sum += gs->lum*gs->lum * gs->dom / (p*p);
447 }
448 if (sum <= FTINY)
449 return(0.0);
450 dillum = direct(gd);
451 return(8.*log10(2.*sum*(1.+dillum/500.)/(dillum+gd->indirect)));
452 }
453
454
455 double
456 ugr(gd) /* compute Unified Glare Rating */
457 struct glare_dir *gd;
458 {
459 register struct glare_src *gs;
460 FVECT mydir;
461 double p;
462 double sum;
463
464 spinvector(mydir, midview.vdir, midview.vup, gd->ang);
465 sum = 0.0;
466 for (gs = all_srcs; gs != NULL; gs = gs->next) {
467 p = posindex(gs->dir, mydir, midview.vup);
468 if (p <= FTINY)
469 continue;
470 sum += gs->lum*gs->lum * gs->dom / (p*p);
471 }
472 if (sum <= FTINY)
473 return(0.0);
474 return(8.*log10(0.25*sum*PI/gd->indirect));
475 }
