root/radiance/ray/src/util/glarendx.c
Revision: 1.6
Committed: Mon Apr 22 10:11:21 1991 UTC (34 years ago) by greg
ASCII -> ascii
1 /* Copyright (c) 1991 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Compute Glare Index given by program name:
9 *
10 * guth_dgr - Guth discomfort glare rating
11 * guth_vcp - Guth visual comfort probability
12 *
13 * 12 April 1991 Greg Ward EPFL
14 */
15
16 #include "standard.h"
17 #include "view.h"
18
19 extern double erfc();
20
21 double posindex();
22 int headline();
23
24 double direct(), guth_dgr(), guth_vcp();
25
26 struct named_func {
27 char *name;
28 double (*func)();
29 } all_funcs[] = {
30 {"direct", direct},
31 {"guth_dgr", guth_dgr},
32 {"guth_vcp", guth_vcp},
33 {NULL}
34 };
35
36 struct glare_src {
37 FVECT dir; /* source direction */
38 double dom; /* solid angle */
39 double lum; /* average luminance */
40 struct glare_src *next;
41 } *all_srcs = NULL;
42
43 struct glare_dir {
44 double ang; /* angle (in radians) */
45 double indirect; /* indirect illuminance */
46 struct glare_dir *next;
47 } *all_dirs = NULL;
48
49 #define newp(type) (type *)malloc(sizeof(type))
50
51 char *progname;
52 int print_header = 1;
53
54 VIEW midview = STDVIEW;
55
56 int wrongformat = 0;
57
58
59 main(argc, argv)
60 int argc;
61 char *argv[];
62 {
63 extern char *rindex();
64 struct named_func *funp;
65 char *progtail;
66 int i;
67 /* get program name */
68 progname = argv[0];
69 progtail = rindex(progname, '/'); /* final component */
70 if (progtail == NULL)
71 progtail = progname;
72 else
73 progtail++;
74 /* get options */
75 for (i = 1; i < argc && argv[i][0] == '-'; i++)
76 switch (argv[i][1]) {
77 case 't':
78 progtail = argv[++i];
79 break;
80 case 'h':
81 print_header = 0;
82 break;
83 default:
84 goto userr;
85 }
86 if (i < argc-1)
87 goto userr;
88 if (i == argc-1) /* open file */
89 if (freopen(argv[i], "r", stdin) == NULL) {
90 perror(argv[i]);
91 exit(1);
92 }
93 /* read header */
94 getheader(stdin, headline, NULL);
95 if (wrongformat) {
96 fprintf(stderr, "%s: bad input format\n", progname);
97 exit(1);
98 }
99 if (print_header) { /* add to header */
100 printargs(i, argv, stdout);
101 putchar('\n');
102 }
103 /* set view */
104 if (setview(&midview) != NULL) {
105 fprintf(stderr, "%s: bad view information in input\n",
106 progname);
107 exit(1);
108 }
109 /* get findglare data */
110 read_input();
111 /* find calculation */
112 for (funp = all_funcs; funp->name != NULL; funp++)
113 if (!strcmp(funp->name, progtail)) {
114 print_values(funp->func);
115 exit(0); /* we're done */
116 }
117 /* invalid function */
118 fprintf(stderr, "%s: unknown function!\n", progtail);
119 exit(1);
120 userr:
121 fprintf(stderr, "Usage: %s [-t type][-h] [input]\n", progname);
122 exit(1);
123 }
124
125
126 headline(s) /* get line from header */
127 char *s;
128 {
129 char fmt[32];
130
131 if (print_header) /* copy to output */
132 fputs(s, stdout);
133 if (!strncmp(s, VIEWSTR, VIEWSTRL))
134 sscanview(&midview, s+VIEWSTRL);
135 else if (isformat(s)) {
136 formatval(fmt, s);
137 wrongformat = strcmp(fmt, "ascii");
138 }
139 }
140
141
142 read_input() /* read glare sources from stdin */
143 {
144 #define S_SEARCH 0
145 #define S_SOURCE 1
146 #define S_DIREC 2
147 int state = S_SEARCH;
148 char buf[128];
149 register struct glare_src *gs;
150 register struct glare_dir *gd;
151
152 while (fgets(buf, sizeof(buf), stdin) != NULL)
153 switch (state) {
154 case S_SEARCH:
155 if (!strcmp(buf, "BEGIN glare source\n"))
156 state = S_SOURCE;
157 else if (!strcmp(buf, "BEGIN indirect illuminance\n"))
158 state = S_DIREC;
159 break;
160 case S_SOURCE:
161 if (!strncmp(buf, "END", 3)) {
162 state = S_SEARCH;
163 break;
164 }
165 if ((gs = newp(struct glare_src)) == NULL)
166 goto memerr;
167 if (sscanf(buf, "%lf %lf %lf %lf %lf",
168 &gs->dir[0], &gs->dir[1], &gs->dir[2],
169 &gs->dom, &gs->lum) != 5)
170 goto readerr;
171 normalize(gs->dir);
172 gs->next = all_srcs;
173 all_srcs = gs;
174 break;
175 case S_DIREC:
176 if (!strncmp(buf, "END", 3)) {
177 state = S_SEARCH;
178 break;
179 }
180 if ((gd = newp(struct glare_dir)) == NULL)
181 goto memerr;
182 if (sscanf(buf, "%lf %lf",
183 &gd->ang, &gd->indirect) != 2)
184 goto readerr;
185 gd->ang *= PI/180.0; /* convert to radians */
186 gd->next = all_dirs;
187 all_dirs = gd;
188 break;
189 }
190 return;
191 memerr:
192 perror(progname);
193 exit(1);
194 readerr:
195 fprintf(stderr, "%s: read error on input\n", progname);
196 exit(1);
197 #undef S_SEARCH
198 #undef S_SOURCE
199 #undef S_DIREC
200 }
201
202
203 print_values(funp) /* print out calculations */
204 double (*funp)();
205 {
206 register struct glare_dir *gd;
207
208 for (gd = all_dirs; gd != NULL; gd = gd->next)
209 printf("%f\t%f\n", gd->ang*(180.0/PI), (*funp)(gd));
210 }
211
212
213 double
214 direct(gd) /* compute direct illuminance */
215 struct glare_dir *gd;
216 {
217 FVECT mydir;
218 double d, dval;
219 register struct glare_src *gs;
220
221 spinvector(mydir, midview.vdir, midview.vup, gd->ang);
222 dval = 0.0;
223 for (gs = all_srcs; gs != NULL; gs = gs->next) {
224 d = DOT(mydir,gs->dir);
225 if (d > FTINY)
226 dval += d * gs->dom * gs->lum;
227 }
228 return(dval);
229 }
230
231
232 /*
233 * posindex - compute glare position index from:
234 *
235 * Source Direction
236 * View Direction
237 * View Up Direction
238 *
239 * All vectors are assumed to be normalized.
240 * This function is an implementation of the method proposed by
241 * Robert Levin in his 1975 JIES article.
242 * This calculation presumes the view direction and up vectors perpendicular.
243 * We return a value less than zero for improper positions.
244 */
245
246 double
247 posindex(sd, vd, vu) /* compute position index */
248 FVECT sd, vd, vu;
249 {
250 double sigma, tau;
251 double d;
252
253 d = DOT(sd,vd);
254 if (d <= 0.0)
255 return(-1.0);
256 if (d >= 1.0)
257 return(1.0);
258 sigma = acos(d) * (180./PI);
259 d = DOT(sd,vu)/sqrt(1.0-d*d);
260 if (d >= 1.0)
261 tau = 0.0;
262 else
263 tau = acos(d) * (180./PI);
264 return( exp( sigma*( (35.2 - tau*.31889 - 1.22*exp(-.22222*tau))*1e-3
265 + sigma*(21. + tau*(.26667 + tau*-.002963))*1e-5 )
266 ) );
267 }
268
269
270 double
271 guth_dgr(gd) /* compute Guth discomfort glare rating */
272 struct glare_dir *gd;
273 {
274 #define q(w) (20.4*w+1.52*pow(w,.2)-.075)
275 register struct glare_src *gs;
276 double p;
277 double sum;
278 double wtot, brsum;
279 int n;
280
281 sum = wtot = brsum = 0.0; n = 0;
282 for (gs = all_srcs; gs != NULL; gs = gs->next) {
283 p = posindex(gs->dir, midview.vdir, midview.vup);
284 if (p <= FTINY)
285 continue;
286 sum += gs->lum * q(gs->dom) / p;
287 brsum += gs->lum * gs->dom;
288 wtot += gs->dom;
289 n++;
290 }
291 if (n == 0)
292 return(0.0);
293 else
294 return( pow(
295 .5*sum/pow((brsum+(5.-wtot)*gd->indirect/PI)/5.,.44),
296 pow((double)n, -.0914) ) );
297 #undef q
298 }
299
300
301 extern double erf(), erfc();
302
303 #ifndef M_SQRT2
304 #define M_SQRT2 1.41421356237309504880
305 #endif
306
307 #define norm_integral(z) (1.-.5*erfc((z)/M_SQRT2))
308
309
310 double
311 guth_vcp(gd) /* compute Guth visual comfort probability */
312 struct glare_dir *gd;
313 {
314 return(100.*norm_integral(6.374-1.3227*log(guth_dgr(gd))));
315 }
