root/Development/ray/src/util/glarendx.c
Revision: 2.7
Committed: Sat Feb 22 02:07:30 2003 UTC (22 years, 10 months ago) by greg
Changes since 2.6: +1 -4 lines
5 * Compute Glare Index given by program name or -t option:
6 *
7 * dgi - Daylight Glare Index
8 * brs_gi - Building Research Station Glare Index (Petherbridge
9 * & Hopkinson)
10 * ugr - Unified Glare Rating System (Fischer)
11 * guth_dgr - Guth discomfort glare rating
12 * guth_vcp - Guth visual comfort probability
13 * cie_cgi - CIE Glare Index (1983, due to Einhorn)
14 * vert_dir - Direct vertical illuminance
15 * vert_ind - Indirect vertical illuminance (from input)
16 * vert_ill - Total vertical illuminance
17 *
18 * 12 April 1991 Greg Ward EPFL
19 * 19 April 1993 R. Compagnon EPFL (added dgi, brs_gi, ugr)
20 */
21
22 #include "standard.h"
23 #include "view.h"
24
25
26 double posindex();
27
28 double direct(), guth_dgr(), guth_vcp(), cie_cgi(),
29 indirect(), total(), dgi(), brs_gi(), ugr();
30
31 struct named_func {
32 char *name;
33 double (*func)();
34 char *descrip;
35 } all_funcs[] = {
36 {"dgi", dgi, "Daylight Glare Index"},
37 {"brs_gi", brs_gi, "BRS Glare Index"},
38 {"ugr", ugr, "Unified Glare Rating"},
39 {"guth_vcp", guth_vcp, "Guth Visual Comfort Probability"},
40 {"cie_cgi", cie_cgi, "CIE Glare Index (Einhorn)"},
41 {"guth_dgr", guth_dgr, "Guth Disability Glare Rating"},
42 {"vert_dir", direct, "Direct Vertical Illuminance"},
43 {"vert_ill", total, "Total Vertical Illuminance"},
44 {"vert_ind", indirect, "Indirect Vertical Illuminance"},
45 {NULL}
46 };
47
48 struct glare_src {
49 FVECT dir; /* source direction */
50 double dom; /* solid angle */
51 double lum; /* average luminance */
52 struct glare_src *next;
53 } *all_srcs = NULL;
54
55 struct glare_dir {
56 double ang; /* angle (in radians) */
57 double indirect; /* indirect illuminance */
58 struct glare_dir *next;
59 } *all_dirs = NULL;
60
61 #define newp(type) (type *)malloc(sizeof(type))
62
63 char *progname;
64 int print_header = 1;
65
66 VIEW midview = STDVIEW;
67
68 int wrongformat = 0;
69
70
71 main(argc, argv)
72 int argc;
73 char *argv[];
74 {
75 extern char *rindex();
76 struct named_func *funp;
77 char *progtail;
78 int i;
79 /* get program name */
80 progname = argv[0];
81 progtail = rindex(progname, '/'); /* final component */
82 if (progtail == NULL)
83 progtail = progname;
84 else
85 progtail++;
86 /* get options */
87 for (i = 1; i < argc && argv[i][0] == '-'; i++)
88 switch (argv[i][1]) {
89 case 't':
90 progtail = argv[++i];
91 break;
92 case 'h':
93 print_header = 0;
94 break;
95 default:
96 goto userr;
97 }
98 if (i < argc-1)
99 goto userr;
100 if (i == argc-1) /* open file */
101 if (freopen(argv[i], "r", stdin) == NULL) {
102 perror(argv[i]);
103 exit(1);
104 }
105 /* find and run calculation */
106 for (funp = all_funcs; funp->name != NULL; funp++)
107 if (!strcmp(funp->name, progtail)) {
108 init();
109 read_input();
110 if (print_header) {
111 printargs(i, argv, stdout);
112 putchar('\n');
113 }
114 print_values(funp->func);
115 exit(0); /* we're done */
116 }
117 /* invalid function */
118 userr:
119 fprintf(stderr, "Usage: %s -t type [-h] [input]\n", progname);
120 fprintf(stderr, "\twhere 'type' is one of the following:\n");
121 for (funp = all_funcs; funp->name != NULL; funp++)
122 fprintf(stderr, "\t%12s\t%s\n", funp->name, funp->descrip);
123 exit(1);
124 }
125
126
127 int
128 headline(s) /* get line from header */
129 char *s;
130 {
131 char fmt[32];
132
133 if (print_header) /* copy to output */
134 fputs(s, stdout);
135 if (isview(s))
136 sscanview(&midview, s);
137 else if (isformat(s)) {
138 formatval(fmt, s);
139 wrongformat = strcmp(fmt, "ascii");
140 }
141 return(0);
142 }
143
144
145 init() /* initialize calculation */
146 {
147 /* read header */
148 getheader(stdin, headline, NULL);
149 if (wrongformat) {
150 fprintf(stderr, "%s: bad input format\n", progname);
151 exit(1);
152 }
153 /* set view */
154 if (setview(&midview) != NULL) {
155 fprintf(stderr, "%s: bad view information in input\n",
156 progname);
157 exit(1);
158 }
159 }
160
161
162 read_input() /* read glare sources from stdin */
163 {
164 #define S_SEARCH 0
165 #define S_SOURCE 1
166 #define S_DIREC 2
167 int state = S_SEARCH;
168 char buf[128];
169 register struct glare_src *gs;
170 register struct glare_dir *gd;
171
172 while (fgets(buf, sizeof(buf), stdin) != NULL)
173 switch (state) {
174 case S_SEARCH:
175 if (!strcmp(buf, "BEGIN glare source\n"))
176 state = S_SOURCE;
177 else if (!strcmp(buf, "BEGIN indirect illuminance\n"))
178 state = S_DIREC;
179 break;
180 case S_SOURCE:
181 if (!strncmp(buf, "END", 3)) {
182 state = S_SEARCH;
183 break;
184 }
185 if ((gs = newp(struct glare_src)) == NULL)
186 goto memerr;
187 if (sscanf(buf, "%lf %lf %lf %lf %lf",
188 &gs->dir[0], &gs->dir[1], &gs->dir[2],
189 &gs->dom, &gs->lum) != 5)
190 goto readerr;
191 normalize(gs->dir);
192 gs->next = all_srcs;
193 all_srcs = gs;
194 break;
195 case S_DIREC:
196 if (!strncmp(buf, "END", 3)) {
197 state = S_SEARCH;
198 break;
199 }
200 if ((gd = newp(struct glare_dir)) == NULL)
201 goto memerr;
202 if (sscanf(buf, "%lf %lf",
203 &gd->ang, &gd->indirect) != 2)
204 goto readerr;
205 gd->ang *= PI/180.0; /* convert to radians */
206 gd->next = all_dirs;
207 all_dirs = gd;
208 break;
209 }
210 return;
211 memerr:
212 perror(progname);
213 exit(1);
214 readerr:
215 fprintf(stderr, "%s: read error on input\n", progname);
216 exit(1);
217 #undef S_SEARCH
218 #undef S_SOURCE
219 #undef S_DIREC
220 }
221
222
223 print_values(funp) /* print out calculations */
224 double (*funp)();
225 {
226 register struct glare_dir *gd;
227
228 for (gd = all_dirs; gd != NULL; gd = gd->next)
229 printf("%f\t%f\n", gd->ang*(180.0/PI), (*funp)(gd));
230 }
231
232
233 double
234 direct(gd) /* compute direct vertical illuminance */
235 struct glare_dir *gd;
236 {
237 FVECT mydir;
238 double d, dval;
239 register struct glare_src *gs;
240
241 spinvector(mydir, midview.vdir, midview.vup, gd->ang);
242 dval = 0.0;
243 for (gs = all_srcs; gs != NULL; gs = gs->next) {
244 d = DOT(mydir,gs->dir);
245 if (d > FTINY)
246 dval += d * gs->dom * gs->lum;
247 }
248 return(dval);
249 }
250
251
252 double
253 indirect(gd) /* return indirect vertical illuminance */
254 struct glare_dir *gd;
255 {
256 return(gd->indirect);
257 }
258
259
260 double
261 total(gd) /* return total vertical illuminance */
262 struct glare_dir *gd;
263 {
264 return(direct(gd)+gd->indirect);
265 }
266
267
268 /*
269 * posindex - compute glare position index from:
270 *
271 * Source Direction
272 * View Direction
273 * View Up Direction
274 *
275 * All vectors are assumed to be normalized.
276 * This function is an implementation of the method proposed by
277 * Robert Levin in his 1975 JIES article.
278 * This calculation presumes the view direction and up vectors perpendicular.
279 * We return a value less than zero for improper positions.
280 */
281
282 double
283 posindex(sd, vd, vu) /* compute position index */
284 FVECT sd, vd, vu;
285 {
286 double sigma, tau;
287 double d;
288
289 d = DOT(sd,vd);
290 if (d <= 0.0)
291 return(-1.0);
292 if (d >= 1.0)
293 return(1.0);
294 sigma = acos(d) * (180./PI);
295 d = fabs(DOT(sd,vu)/sqrt(1.0-d*d));
296 if (d >= 1.0)
297 tau = 0.0;
298 else
299 tau = acos(d) * (180./PI);
300 return( exp( sigma*( (35.2 - tau*.31889 - 1.22*exp(-.22222*tau))*1e-3
301 + sigma*(21. + tau*(.26667 + tau*-.002963))*1e-5 )
302 ) );
303 }
304
305
306 double
307 dgi(gd) /* compute Daylight Glare Index */
308 struct glare_dir *gd;
309 {
310 register struct glare_src *gs;
311 FVECT mydir,testdir[7],vhor;
312 double r,omega,p[7],sum;
313 int i,n;
314
315 spinvector(mydir, midview.vdir, midview.vup, gd->ang);
316 sum = 0.0; n = 0;
317 for (gs = all_srcs; gs != NULL; gs = gs->next) {
318
319 /* compute 1/p^2 weighted solid angle of the source */
320 r = sqrt(1 - pow(1.-gs->dom/2./PI,2.));
321 fcross(vhor,gs->dir,midview.vup);
322 normalize(vhor);
323 VCOPY(testdir[0],gs->dir);
324 fvsum(testdir[1],gs->dir,vhor,r);
325 fvsum(testdir[2],gs->dir,vhor,0.5*r);
326 fvsum(testdir[5],testdir[2],midview.vup,-0.866*r);
327 fvsum(testdir[2],testdir[2],midview.vup,0.866*r);
328 fvsum(testdir[3],gs->dir,vhor,-r);
329 fvsum(testdir[4],gs->dir,vhor,-0.5*r);
330 fvsum(testdir[6],testdir[4],midview.vup,0.866*r);
331 fvsum(testdir[4],testdir[4],midview.vup,-0.866*r);
332 for (i = 0; i < 7; i++) {
333 normalize(testdir[i]);
334 p[i] = pow(posindex(testdir[i],mydir,midview.vup),-2.0);
335 if (p[i] <= FTINY) p[i] = 0.0;
336 }
337 r = 1-gs->dom/2./PI;
338 omega = gs->dom*p[0];
339 omega += (r*PI*(1+1/r/r)-2*PI)*(-p[0]+(p[1]+p[2])*0.5);
340 omega += (2*PI-r*PI*(1+1/r/r))*(-p[0]-0.1667*(p[1]+p[3])
341 +0.3334*(p[2]+p[4]+p[5]+p[6]));
342
343 sum += pow(gs->lum,1.6) * pow(omega,0.8) /
344 (gd->indirect/PI + 0.07*sqrt(gs->dom)*gs->lum);
345 n++;
346 }
347 if (n == 0)
348 return(0.0);
349 return( 10*log10(0.478*sum) );
350 }
351
352
353 double
354 brs_gi(gd) /* compute BRS Glare Index */
355 struct glare_dir *gd;
356 {
357 register struct glare_src *gs;
358 FVECT mydir;
359 double p;
360 double sum;
361
362 spinvector(mydir, midview.vdir, midview.vup, gd->ang);
363 sum = 0.0;
364 for (gs = all_srcs; gs != NULL; gs = gs->next) {
365 p = posindex(gs->dir, mydir, midview.vup);
366 if (p <= FTINY)
367 continue;
368 sum += pow(gs->lum/p,1.6) * pow(gs->dom,0.8);
369 }
370 if (sum <= FTINY)
371 return(0.0);
372 sum /= gd->indirect/PI;
373 return(10*log10(0.478*sum));
374 }
375
376
377 double
378 guth_dgr(gd) /* compute Guth discomfort glare rating */
379 struct glare_dir *gd;
380 {
381 #define q(w) (20.4*w+1.52*pow(w,.2)-.075)
382 register struct glare_src *gs;
383 FVECT mydir;
384 double p;
385 double sum;
386 double wtot, brsum;
387 int n;
388
389 spinvector(mydir, midview.vdir, midview.vup, gd->ang);
390 sum = wtot = brsum = 0.0; n = 0;
391 for (gs = all_srcs; gs != NULL; gs = gs->next) {
392 p = posindex(gs->dir, mydir, midview.vup);
393 if (p <= FTINY)
394 continue;
395 sum += gs->lum * q(gs->dom) / p;
396 brsum += gs->lum * gs->dom;
397 wtot += gs->dom;
398 n++;
399 }
400 if (n == 0)
401 return(0.0);
402 return( pow(.5*sum/pow((brsum+(5.-wtot)*gd->indirect/PI)/5.,.44),
403 pow((double)n, -.0914) ) );
404 #undef q
405 }
406
407
408 #ifndef M_SQRT2
409 #define M_SQRT2 1.41421356237309504880
410 #endif
411
412 #define norm_integral(z) (1.-.5*erfc((z)/M_SQRT2))
413
414
415 double
416 guth_vcp(gd) /* compute Guth visual comfort probability */
417 struct glare_dir *gd;
418 {
419 extern double erfc();
420 double dgr;
421
422 dgr = guth_dgr(gd);
423 if (dgr <= FTINY)
424 return(100.0);
425 return(100.*norm_integral(6.374-1.3227*log(dgr)));
426 }
427
428
429 double
430 cie_cgi(gd) /* compute CIE Glare Index */
431 struct glare_dir *gd;
432 {
433 register struct glare_src *gs;
434 FVECT mydir;
435 double dillum;
436 double p;
437 double sum;
438
439 spinvector(mydir, midview.vdir, midview.vup, gd->ang);
440 sum = 0.0;
441 for (gs = all_srcs; gs != NULL; gs = gs->next) {
442 p = posindex(gs->dir, mydir, midview.vup);
443 if (p <= FTINY)
444 continue;
445 sum += gs->lum*gs->lum * gs->dom / (p*p);
446 }
447 if (sum <= FTINY)
448 return(0.0);
449 dillum = direct(gd);
450 return(8.*log10(2.*sum*(1.+dillum/500.)/(dillum+gd->indirect)));
451 }
452
453
454 double
455 ugr(gd) /* compute Unified Glare Rating */
456 struct glare_dir *gd;
457 {
458 register struct glare_src *gs;
459 FVECT mydir;
460 double p;
461 double sum;
462
463 spinvector(mydir, midview.vdir, midview.vup, gd->ang);
464 sum = 0.0;
465 for (gs = all_srcs; gs != NULL; gs = gs->next) {
466 p = posindex(gs->dir, mydir, midview.vup);
467 if (p <= FTINY)
468 continue;
469 sum += gs->lum*gs->lum * gs->dom / (p*p);
470 }
471 if (sum <= FTINY)
472 return(0.0);
473 return(8.*log10(0.25*sum*PI/gd->indirect));
474 }
