root/radiance/ray/src/util/glarendx.c
Revision: 2.6
Committed: Tue Oct 27 08:47:17 1998 UTC (26 years, 8 months ago) by gwlarson
1 /* Copyright (c) 1991 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Compute Glare Index given by program name or -t option:
9 *
10 * dgi - Daylight Glare Index
11 * brs_gi - Building Research Station Glare Index (Petherbridge
12 * & Hopkinson)
13 * ugr - Unified Glare Rating System (Fischer)
14 * guth_dgr - Guth discomfort glare rating
15 * guth_vcp - Guth visual comfort probability
16 * cie_cgi - CIE Glare Index (1983, due to Einhorn)
17 * vert_dir - Direct vertical illuminance
18 * vert_ind - Indirect vertical illuminance (from input)
19 * vert_ill - Total vertical illuminance
20 *
21 * 12 April 1991 Greg Ward EPFL
22 * 19 April 1993 R. Compagnon EPFL (added dgi, brs_gi, ugr)
23 */
24
25 #include "standard.h"
26 #include "view.h"
27
28
29 double posindex();
30
31 double direct(), guth_dgr(), guth_vcp(), cie_cgi(),
32 indirect(), total(), dgi(), brs_gi(), ugr();
33
34 struct named_func {
35 char *name;
36 double (*func)();
37 char *descrip;
38 } all_funcs[] = {
39 {"dgi", dgi, "Daylight Glare Index"},
40 {"brs_gi", brs_gi, "BRS Glare Index"},
41 {"ugr", ugr, "Unified Glare Rating"},
42 {"guth_vcp", guth_vcp, "Guth Visual Comfort Probability"},
43 {"cie_cgi", cie_cgi, "CIE Glare Index (Einhorn)"},
44 {"guth_dgr", guth_dgr, "Guth Disability Glare Rating"},
45 {"vert_dir", direct, "Direct Vertical Illuminance"},
46 {"vert_ill", total, "Total Vertical Illuminance"},
47 {"vert_ind", indirect, "Indirect Vertical Illuminance"},
48 {NULL}
49 };
50
51 struct glare_src {
52 FVECT dir; /* source direction */
53 double dom; /* solid angle */
54 double lum; /* average luminance */
55 struct glare_src *next;
56 } *all_srcs = NULL;
57
58 struct glare_dir {
59 double ang; /* angle (in radians) */
60 double indirect; /* indirect illuminance */
61 struct glare_dir *next;
62 } *all_dirs = NULL;
63
64 #define newp(type) (type *)malloc(sizeof(type))
65
66 char *progname;
67 int print_header = 1;
68
69 VIEW midview = STDVIEW;
70
71 int wrongformat = 0;
72
73
74 main(argc, argv)
75 int argc;
76 char *argv[];
77 {
78 extern char *rindex();
79 struct named_func *funp;
80 char *progtail;
81 int i;
82 /* get program name */
83 progname = argv[0];
84 progtail = rindex(progname, '/'); /* final component */
85 if (progtail == NULL)
86 progtail = progname;
87 else
88 progtail++;
89 /* get options */
90 for (i = 1; i < argc && argv[i][0] == '-'; i++)
91 switch (argv[i][1]) {
92 case 't':
93 progtail = argv[++i];
94 break;
95 case 'h':
96 print_header = 0;
97 break;
98 default:
99 goto userr;
100 }
101 if (i < argc-1)
102 goto userr;
103 if (i == argc-1) /* open file */
104 if (freopen(argv[i], "r", stdin) == NULL) {
105 perror(argv[i]);
106 exit(1);
107 }
108 /* find and run calculation */
109 for (funp = all_funcs; funp->name != NULL; funp++)
110 if (!strcmp(funp->name, progtail)) {
111 init();
112 read_input();
113 if (print_header) {
114 printargs(i, argv, stdout);
115 putchar('\n');
116 }
117 print_values(funp->func);
118 exit(0); /* we're done */
119 }
120 /* invalid function */
121 userr:
122 fprintf(stderr, "Usage: %s -t type [-h] [input]\n", progname);
123 fprintf(stderr, "\twhere 'type' is one of the following:\n");
124 for (funp = all_funcs; funp->name != NULL; funp++)
125 fprintf(stderr, "\t%12s\t%s\n", funp->name, funp->descrip);
126 exit(1);
127 }
128
129
130 int
131 headline(s) /* get line from header */
132 char *s;
133 {
134 char fmt[32];
135
136 if (print_header) /* copy to output */
137 fputs(s, stdout);
138 if (isview(s))
139 sscanview(&midview, s);
140 else if (isformat(s)) {
141 formatval(fmt, s);
142 wrongformat = strcmp(fmt, "ascii");
143 }
144 return(0);
145 }
146
147
148 init() /* initialize calculation */
149 {
150 /* read header */
151 getheader(stdin, headline, NULL);
152 if (wrongformat) {
153 fprintf(stderr, "%s: bad input format\n", progname);
154 exit(1);
155 }
156 /* set view */
157 if (setview(&midview) != NULL) {
158 fprintf(stderr, "%s: bad view information in input\n",
159 progname);
160 exit(1);
161 }
162 }
163
164
165 read_input() /* read glare sources from stdin */
166 {
167 #define S_SEARCH 0
168 #define S_SOURCE 1
169 #define S_DIREC 2
170 int state = S_SEARCH;
171 char buf[128];
172 register struct glare_src *gs;
173 register struct glare_dir *gd;
174
175 while (fgets(buf, sizeof(buf), stdin) != NULL)
176 switch (state) {
177 case S_SEARCH:
178 if (!strcmp(buf, "BEGIN glare source\n"))
179 state = S_SOURCE;
180 else if (!strcmp(buf, "BEGIN indirect illuminance\n"))
181 state = S_DIREC;
182 break;
183 case S_SOURCE:
184 if (!strncmp(buf, "END", 3)) {
185 state = S_SEARCH;
186 break;
187 }
188 if ((gs = newp(struct glare_src)) == NULL)
189 goto memerr;
190 if (sscanf(buf, "%lf %lf %lf %lf %lf",
191 &gs->dir[0], &gs->dir[1], &gs->dir[2],
192 &gs->dom, &gs->lum) != 5)
193 goto readerr;
194 normalize(gs->dir);
195 gs->next = all_srcs;
196 all_srcs = gs;
197 break;
198 case S_DIREC:
199 if (!strncmp(buf, "END", 3)) {
200 state = S_SEARCH;
201 break;
202 }
203 if ((gd = newp(struct glare_dir)) == NULL)
204 goto memerr;
205 if (sscanf(buf, "%lf %lf",
206 &gd->ang, &gd->indirect) != 2)
207 goto readerr;
208 gd->ang *= PI/180.0; /* convert to radians */
209 gd->next = all_dirs;
210 all_dirs = gd;
211 break;
212 }
213 return;
214 memerr:
215 perror(progname);
216 exit(1);
217 readerr:
218 fprintf(stderr, "%s: read error on input\n", progname);
219 exit(1);
220 #undef S_SEARCH
221 #undef S_SOURCE
222 #undef S_DIREC
223 }
224
225
226 print_values(funp) /* print out calculations */
227 double (*funp)();
228 {
229 register struct glare_dir *gd;
230
231 for (gd = all_dirs; gd != NULL; gd = gd->next)
232 printf("%f\t%f\n", gd->ang*(180.0/PI), (*funp)(gd));
233 }
234
235
236 double
237 direct(gd) /* compute direct vertical illuminance */
238 struct glare_dir *gd;
239 {
240 FVECT mydir;
241 double d, dval;
242 register struct glare_src *gs;
243
244 spinvector(mydir, midview.vdir, midview.vup, gd->ang);
245 dval = 0.0;
246 for (gs = all_srcs; gs != NULL; gs = gs->next) {
247 d = DOT(mydir,gs->dir);
248 if (d > FTINY)
249 dval += d * gs->dom * gs->lum;
250 }
251 return(dval);
252 }
253
254
255 double
256 indirect(gd) /* return indirect vertical illuminance */
257 struct glare_dir *gd;
258 {
259 return(gd->indirect);
260 }
261
262
263 double
264 total(gd) /* return total vertical illuminance */
265 struct glare_dir *gd;
266 {
267 return(direct(gd)+gd->indirect);
268 }
269
270
271 /*
272 * posindex - compute glare position index from:
273 *
274 * Source Direction
275 * View Direction
276 * View Up Direction
277 *
278 * All vectors are assumed to be normalized.
279 * This function is an implementation of the method proposed by
280 * Robert Levin in his 1975 JIES article.
281 * This calculation presumes the view direction and up vectors perpendicular.
282 * We return a value less than zero for improper positions.
283 */
284
285 double
286 posindex(sd, vd, vu) /* compute position index */
287 FVECT sd, vd, vu;
288 {
289 double sigma, tau;
290 double d;
291
292 d = DOT(sd,vd);
293 if (d <= 0.0)
294 return(-1.0);
295 if (d >= 1.0)
296 return(1.0);
297 sigma = acos(d) * (180./PI);
298 d = fabs(DOT(sd,vu)/sqrt(1.0-d*d));
299 if (d >= 1.0)
300 tau = 0.0;
301 else
302 tau = acos(d) * (180./PI);
303 return( exp( sigma*( (35.2 - tau*.31889 - 1.22*exp(-.22222*tau))*1e-3
304 + sigma*(21. + tau*(.26667 + tau*-.002963))*1e-5 )
305 ) );
306 }
307
308
309 double
310 dgi(gd) /* compute Daylight Glare Index */
311 struct glare_dir *gd;
312 {
313 register struct glare_src *gs;
314 FVECT mydir,testdir[7],vhor;
315 double r,omega,p[7],sum;
316 int i,n;
317
318 spinvector(mydir, midview.vdir, midview.vup, gd->ang);
319 sum = 0.0; n = 0;
320 for (gs = all_srcs; gs != NULL; gs = gs->next) {
321
322 /* compute 1/p^2 weighted solid angle of the source */
323 r = sqrt(1 - pow(1.-gs->dom/2./PI,2.));
324 fcross(vhor,gs->dir,midview.vup);
325 normalize(vhor);
326 VCOPY(testdir[0],gs->dir);
327 fvsum(testdir[1],gs->dir,vhor,r);
328 fvsum(testdir[2],gs->dir,vhor,0.5*r);
329 fvsum(testdir[5],testdir[2],midview.vup,-0.866*r);
330 fvsum(testdir[2],testdir[2],midview.vup,0.866*r);
331 fvsum(testdir[3],gs->dir,vhor,-r);
332 fvsum(testdir[4],gs->dir,vhor,-0.5*r);
333 fvsum(testdir[6],testdir[4],midview.vup,0.866*r);
334 fvsum(testdir[4],testdir[4],midview.vup,-0.866*r);
335 for (i = 0; i < 7; i++) {
336 normalize(testdir[i]);
337 p[i] = pow(posindex(testdir[i],mydir,midview.vup),-2.0);
338 if (p[i] <= FTINY) p[i] = 0.0;
339 }
340 r = 1-gs->dom/2./PI;
341 omega = gs->dom*p[0];
342 omega += (r*PI*(1+1/r/r)-2*PI)*(-p[0]+(p[1]+p[2])*0.5);
343 omega += (2*PI-r*PI*(1+1/r/r))*(-p[0]-0.1667*(p[1]+p[3])
344 +0.3334*(p[2]+p[4]+p[5]+p[6]));
345
346 sum += pow(gs->lum,1.6) * pow(omega,0.8) /
347 (gd->indirect/PI + 0.07*sqrt(gs->dom)*gs->lum);
348 n++;
349 }
350 if (n == 0)
351 return(0.0);
352 return( 10*log10(0.478*sum) );
353 }
354
355
356 double
357 brs_gi(gd) /* compute BRS Glare Index */
358 struct glare_dir *gd;
359 {
360 register struct glare_src *gs;
361 FVECT mydir;
362 double p;
363 double sum;
364
365 spinvector(mydir, midview.vdir, midview.vup, gd->ang);
366 sum = 0.0;
367 for (gs = all_srcs; gs != NULL; gs = gs->next) {
368 p = posindex(gs->dir, mydir, midview.vup);
369 if (p <= FTINY)
370 continue;
371 sum += pow(gs->lum/p,1.6) * pow(gs->dom,0.8);
372 }
373 if (sum <= FTINY)
374 return(0.0);
375 sum /= gd->indirect/PI;
376 return(10*log10(0.478*sum));
377 }
378
379
380 double
381 guth_dgr(gd) /* compute Guth discomfort glare rating */
382 struct glare_dir *gd;
383 {
384 #define q(w) (20.4*w+1.52*pow(w,.2)-.075)
385 register struct glare_src *gs;
386 FVECT mydir;
387 double p;
388 double sum;
389 double wtot, brsum;
390 int n;
391
392 spinvector(mydir, midview.vdir, midview.vup, gd->ang);
393 sum = wtot = brsum = 0.0; n = 0;
394 for (gs = all_srcs; gs != NULL; gs = gs->next) {
395 p = posindex(gs->dir, mydir, midview.vup);
396 if (p <= FTINY)
397 continue;
398 sum += gs->lum * q(gs->dom) / p;
399 brsum += gs->lum * gs->dom;
400 wtot += gs->dom;
401 n++;
402 }
403 if (n == 0)
404 return(0.0);
405 return( pow(.5*sum/pow((brsum+(5.-wtot)*gd->indirect/PI)/5.,.44),
406 pow((double)n, -.0914) ) );
407 #undef q
408 }
409
410
411 #ifndef M_SQRT2
412 #define M_SQRT2 1.41421356237309504880
413 #endif
414
415 #define norm_integral(z) (1.-.5*erfc((z)/M_SQRT2))
416
417
418 double
419 guth_vcp(gd) /* compute Guth visual comfort probability */
420 struct glare_dir *gd;
421 {
422 extern double erfc();
423 double dgr;
424
425 dgr = guth_dgr(gd);
426 if (dgr <= FTINY)
427 return(100.0);
428 return(100.*norm_integral(6.374-1.3227*log(dgr)));
429 }
430
431
432 double
433 cie_cgi(gd) /* compute CIE Glare Index */
434 struct glare_dir *gd;
435 {
436 register struct glare_src *gs;
437 FVECT mydir;
438 double dillum;
439 double p;
440 double sum;
441
442 spinvector(mydir, midview.vdir, midview.vup, gd->ang);
443 sum = 0.0;
444 for (gs = all_srcs; gs != NULL; gs = gs->next) {
445 p = posindex(gs->dir, mydir, midview.vup);
446 if (p <= FTINY)
447 continue;
448 sum += gs->lum*gs->lum * gs->dom / (p*p);
449 }
450 if (sum <= FTINY)
451 return(0.0);
452 dillum = direct(gd);
453 return(8.*log10(2.*sum*(1.+dillum/500.)/(dillum+gd->indirect)));
454 }
455
456
457 double
458 ugr(gd) /* compute Unified Glare Rating */
459 struct glare_dir *gd;
460 {
461 register struct glare_src *gs;
462 FVECT mydir;
463 double p;
464 double sum;
465
466 spinvector(mydir, midview.vdir, midview.vup, gd->ang);
467 sum = 0.0;
468 for (gs = all_srcs; gs != NULL; gs = gs->next) {
469 p = posindex(gs->dir, mydir, midview.vup);
470 if (p <= FTINY)
471 continue;
472 sum += gs->lum*gs->lum * gs->dom / (p*p);
473 }
474 if (sum <= FTINY)
475 return(0.0);
476 return(8.*log10(0.25*sum*PI/gd->indirect));
477 }
