root/radiance/ray/src/util/glarendx.c
Revision: 2.17
Committed: Tue Jun 3 21:31:51 2025 UTC (4 days, 1 hour ago) by greg
Changes since 2.16: +1 -2 lines
2 static const char RCSid[] = "$Id: glarendx.c,v 2.16 2020/07/24 16:58:16 greg Exp $";
5 * Compute Glare Index given by program name or -t option:
6 *
7 * dgi - Daylight Glare Index
8 * brs_gi - Building Research Station Glare Index (Petherbridge
9 * & Hopkinson)
10 * ugr - Unified Glare Rating System (Fischer)
11 * guth_dgr - Guth discomfort glare rating
12 * guth_vcp - Guth visual comfort probability
13 * cie_cgi - CIE Glare Index (1983, due to Einhorn)
14 * vert_dir - Direct vertical illuminance
15 * vert_ind - Indirect vertical illuminance (from input)
16 * vert_ill - Total vertical illuminance
17 *
18 * 12 April 1991 Greg Ward EPFL
19 * 19 April 1993 R. Compagnon EPFL (added dgi, brs_gi, ugr)
20 */
21
22 #include <string.h>
23
24 #include "standard.h"
25 #include "paths.h"
26 #include "view.h"
27
28
29 struct glare_src {
30 FVECT dir; /* source direction */
31 double dom; /* solid angle */
32 double lum; /* average luminance */
33 struct glare_src *next;
34 } *all_srcs = NULL;
35
36 struct glare_dir {
37 double ang; /* angle (in radians) */
38 double indirect; /* indirect illuminance */
39 struct glare_dir *next;
40 } *all_dirs = NULL;
41
42 typedef double gdfun(struct glare_dir *gd);
43
44 static gdfun dgi;
45 static gdfun brs_gi;
46 static gdfun ugr;
47 static gdfun guth_dgr;
48 static gdfun guth_vcp;
49 static gdfun cie_cgi;
50 static gdfun direct;
51 static gdfun indirect;
52 static gdfun total;
53
54 static gethfunc headline;
55 static void init(void);
56 static void read_input(void);
57 static void print_values(gdfun *func);
58 static double posindex(FVECT sd, FVECT vd, FVECT vu);
59
60
61 struct named_func {
62 char *name;
63 gdfun *func;
64 char *descrip;
65 } all_funcs[] = {
66 {"dgi", dgi, "Daylight Glare Index"},
67 {"brs_gi", brs_gi, "BRS Glare Index"},
68 {"ugr", ugr, "Unified Glare Rating"},
69 {"guth_vcp", guth_vcp, "Guth Visual Comfort Probability"},
70 {"cie_cgi", cie_cgi, "CIE Glare Index (Einhorn)"},
71 {"guth_dgr", guth_dgr, "Guth Disability Glare Rating"},
72 {"vert_dir", direct, "Direct Vertical Illuminance"},
73 {"vert_ill", total, "Total Vertical Illuminance"},
74 {"vert_ind", indirect, "Indirect Vertical Illuminance"},
75 {NULL}
76 };
77
78 #define newp(type) (type *)malloc(sizeof(type))
79
80 int print_header = 1;
81
82 VIEW midview = STDVIEW;
83
84 int wrongformat = 0;
85
86
87 int
88 main(
89 int argc,
90 char *argv[]
91 )
92 {
93 struct named_func *funp;
94 int i;
95 /* get program name */
96 progname = fixargv0(argv[0]);
97 /* get options */
98 for (i = 1; i < argc && argv[i][0] == '-'; i++)
99 switch (argv[i][1]) {
100 case 't':
101 progname = argv[++i];
102 break;
103 case 'h':
104 print_header = 0;
105 break;
106 default:
107 goto userr;
108 }
109 if (i < argc-1)
110 goto userr;
111 if (i == argc-1) /* open file */
112 if (freopen(argv[i], "r", stdin) == NULL) {
113 perror(argv[i]);
114 exit(1);
115 }
116 /* find and run calculation */
117 for (funp = all_funcs; funp->name != NULL; funp++)
118 if (!strcmp(funp->name, progname)) {
119 init();
120 read_input();
121 if (print_header) {
122 printargs(i, argv, stdout);
123 putchar('\n');
124 }
125 print_values(funp->func);
126 exit(0); /* we're done */
127 }
128 /* invalid function */
129 userr:
130 fprintf(stderr, "Usage: %s -t type [-h] [input]\n", progname);
131 fprintf(stderr, "\twhere 'type' is one of the following:\n");
132 for (funp = all_funcs; funp->name != NULL; funp++)
133 fprintf(stderr, "\t%12s\t%s\n", funp->name, funp->descrip);
134 exit(1);
135 }
136
137
138 static int
139 headline( /* get line from header */
140 char *s,
141 void *p
142 )
143 {
144 char fmt[MAXFMTLEN];
145
146 if (print_header) /* copy to output */
147 fputs(s, stdout);
148 if (isview(s))
149 sscanview(&midview, s);
150 else if (isformat(s)) {
151 formatval(fmt, s);
152 wrongformat = strcmp(fmt, "ascii");
153 }
154 return(0);
155 }
156
157
158 static void
159 init(void) /* initialize calculation */
160 {
161 char *err;
162 /* read header */
163 getheader(stdin, headline, NULL);
164 if (wrongformat) {
165 fprintf(stderr, "%s: bad input format\n", progname);
166 exit(1);
167 }
168 /* set view */
169 if ((err = setview(&midview)) != NULL) {
170 fprintf(stderr, "%s: %s\n",
171 progname, err);
172 exit(1);
173 }
174 if (fabs(DOT(midview.vdir, midview.vup)) > 1e-4) {
175 fprintf(stderr,
176 "%s: Input view direction not perpendicular to up vector\n",
177 progname);
178 exit(1);
179 }
180 }
181
182
183 static void
184 read_input(void) /* read glare sources from stdin */
185 {
186 #define S_SEARCH 0
187 #define S_SOURCE 1
188 #define S_DIREC 2
189 int state = S_SEARCH;
190 char buf[128];
191 struct glare_src *gs;
192 struct glare_dir *gd;
193
194 while (fgets(buf, sizeof(buf), stdin) != NULL)
195 switch (state) {
196 case S_SEARCH:
197 if (!strcmp(buf, "BEGIN glare source\n"))
198 state = S_SOURCE;
199 else if (!strcmp(buf, "BEGIN indirect illuminance\n"))
200 state = S_DIREC;
201 break;
202 case S_SOURCE:
203 if (!strncmp(buf, "END", 3)) {
204 state = S_SEARCH;
205 break;
206 }
207 if ((gs = newp(struct glare_src)) == NULL)
208 goto memerr;
209 if (sscanf(buf, FVFORMAT, &gs->dir[0], &gs->dir[1],
210 &gs->dir[2]) != 3 ||
211 sscanf(sskip2(buf, 3), "%lf %lf",
212 &gs->dom, &gs->lum) != 2)
213 goto readerr;
214 normalize(gs->dir);
215 gs->next = all_srcs;
216 all_srcs = gs;
217 break;
218 case S_DIREC:
219 if (!strncmp(buf, "END", 3)) {
220 state = S_SEARCH;
221 break;
222 }
223 if ((gd = newp(struct glare_dir)) == NULL)
224 goto memerr;
225 if (sscanf(buf, "%lf %lf",
226 &gd->ang, &gd->indirect) != 2)
227 goto readerr;
228 gd->ang *= PI/180.0; /* convert to radians */
229 gd->next = all_dirs;
230 all_dirs = gd;
231 break;
232 }
233 return;
234 memerr:
235 perror(progname);
236 exit(1);
237 readerr:
238 fprintf(stderr, "%s: read error on input\n", progname);
239 exit(1);
240 #undef S_SEARCH
241 #undef S_SOURCE
242 #undef S_DIREC
243 }
244
245
246 static void
247 print_values( /* print out calculations */
248 gdfun *func
249 )
250 {
251 struct glare_dir *gd;
252
253 for (gd = all_dirs; gd != NULL; gd = gd->next)
254 printf("%f\t%f\n", gd->ang*(180.0/PI), (*func)(gd));
255 }
256
257
258 static double
259 direct( /* compute direct vertical illuminance */
260 struct glare_dir *gd
261 )
262 {
263 FVECT mydir;
264 double d, dval;
265 struct glare_src *gs;
266
267 spinvector(mydir, midview.vdir, midview.vup, gd->ang);
268 dval = 0.0;
269 for (gs = all_srcs; gs != NULL; gs = gs->next) {
270 d = DOT(mydir,gs->dir);
271 if (d > FTINY)
272 dval += d * gs->dom * gs->lum;
273 }
274 return(dval);
275 }
276
277
278 static double
279 indirect( /* return indirect vertical illuminance */
280 struct glare_dir *gd
281 )
282 {
283 return(gd->indirect);
284 }
285
286
287 static double
288 total( /* return total vertical illuminance */
289 struct glare_dir *gd
290 )
291 {
292 return(direct(gd)+gd->indirect);
293 }
294
295
296 /*
297 * posindex - compute glare position index from:
298 *
299 * Source Direction
300 * View Direction
301 * View Up Direction
302 *
303 * All vectors are assumed to be normalized.
304 * This function is an implementation of the method proposed by
305 * Robert Levin in his 1975 JIES article.
306 * This calculation presumes the view direction and up vectors perpendicular.
307 * We return a value less than zero for improper positions.
308 */
309
310 static double
311 posindex( /* compute position index */
312 FVECT sd,
313 FVECT vd,
314 FVECT vu
315 )
316 {
317 double sigma, tau;
318 double d;
319
320 d = DOT(sd,vd);
321 if (d <= 0.0)
322 return(-1.0);
323 if (d >= 1.0-FTINY)
324 return(1.0);
325 sigma = acos(d) * (180./PI);
326 d = fabs(DOT(sd,vu)/sqrt(1.0-d*d));
327 tau = Acos(d) * (180./PI);
328 return( exp( sigma*( (35.2 - tau*.31889 - 1.22*exp(-.22222*tau))*1e-3
329 + sigma*(21. + tau*(.26667 + tau*-.002963))*1e-5 )
330 ) );
331 }
332
333
334 static double
335 dgi( /* compute Daylight Glare Index */
336 struct glare_dir *gd
337 )
338 {
339 struct glare_src *gs;
340 FVECT mydir,testdir[7],vhor;
341 double r,posn,omega,p[7],sum;
342 int i;
343
344 spinvector(mydir, midview.vdir, midview.vup, gd->ang);
345 sum = 0.0;
346 for (gs = all_srcs; gs != NULL; gs = gs->next) {
347
348 /* compute 1/p^2 weighted solid angle of the source */
349 r = 1. - gs->dom*(.5/PI);
350 r = sqrt(1. - r*r);
351 fcross(vhor,gs->dir,midview.vup);
352 if (normalize(vhor) == 0.)
353 continue;
354 VCOPY(testdir[0],gs->dir);
355 fvsum(testdir[1],gs->dir,vhor,r);
356 fvsum(testdir[2],gs->dir,vhor,0.5*r);
357 fvsum(testdir[5],testdir[2],midview.vup,-0.866*r);
358 fvsum(testdir[2],testdir[2],midview.vup,0.866*r);
359 fvsum(testdir[3],gs->dir,vhor,-r);
360 fvsum(testdir[4],gs->dir,vhor,-0.5*r);
361 fvsum(testdir[6],testdir[4],midview.vup,0.866*r);
362 fvsum(testdir[4],testdir[4],midview.vup,-0.866*r);
363 for (i = 0; i < 7; i++) {
364 p[i] = 0.0;
365 if (normalize(testdir[i]) == 0.)
366 continue;
367 posn = posindex(testdir[i],mydir,midview.vup);
368 if (posn > FTINY)
369 p[i] = 1./(posn*posn);
370 }
371 r = 1. - gs->dom*(.5/PI);
372 omega = gs->dom*p[0];
373 omega += (r*PI*(1.+1./(r*r))-2.*PI)*(-p[0]+(p[1]+p[2])*0.5);
374 omega += (2.*PI-r*PI*(1.+1./(r*r)))*(-p[0]-0.1667*(p[1]+p[3])
375 +0.3334*(p[2]+p[4]+p[5]+p[6]));
376 if (omega <= 0.)
377 continue;
378 sum += pow(gs->lum,1.6) * pow(omega,0.8) /
379 (gd->indirect*(1./PI) + 0.07*sqrt(gs->dom)*gs->lum);
380 }
381 if (sum <= FTINY)
382 return(0.0);
383 return( 10.*log10(0.478*sum) );
384 }
385
386
387 static double
388 brs_gi( /* compute BRS Glare Index */
389 struct glare_dir *gd
390 )
391 {
392 struct glare_src *gs;
393 FVECT mydir;
394 double p;
395 double sum;
396
397 spinvector(mydir, midview.vdir, midview.vup, gd->ang);
398 sum = 0.0;
399 for (gs = all_srcs; gs != NULL; gs = gs->next) {
400 p = posindex(gs->dir, mydir, midview.vup);
401 if (p <= FTINY)
402 continue;
403 sum += pow(gs->lum/p,1.6) * pow(gs->dom,0.8);
404 }
405 if (sum <= FTINY)
406 return(0.0);
407 sum *= PI/gd->indirect;
408 return(10*log10(0.478*sum));
409 }
410
411
412 static double
413 guth_dgr( /* compute Guth discomfort glare rating */
414 struct glare_dir *gd
415 )
416 {
417 #define q(w) (20.4*w+1.52*pow(w,.2)-.075)
418 struct glare_src *gs;
419 FVECT mydir;
420 double p;
421 double sum;
422 double wtot, brsum;
423 int n;
424
425 spinvector(mydir, midview.vdir, midview.vup, gd->ang);
426 sum = wtot = brsum = 0.0; n = 0;
427 for (gs = all_srcs; gs != NULL; gs = gs->next) {
428 p = posindex(gs->dir, mydir, midview.vup);
429 if (p <= FTINY)
430 continue;
431 sum += gs->lum * q(gs->dom) / p;
432 brsum += gs->lum * gs->dom;
433 wtot += gs->dom;
434 n++;
435 }
436 if (n == 0)
437 return(0.0);
438 return( pow(.5*sum/pow((brsum+(5.-wtot)*gd->indirect/PI)/5.,.44),
439 pow((double)n, -.0914) ) );
440 #undef q
441 }
442
443
444 #ifndef M_SQRT2
445 #define M_SQRT2 1.41421356237309504880
446 #endif
447
448 #define norm_integral(z) (1.-.5*erfc((z)/M_SQRT2))
449
450
451 static double
452 guth_vcp( /* compute Guth visual comfort probability */
453 struct glare_dir *gd
454 )
455 {
456 extern double erfc();
457 double dgr;
458
459 dgr = guth_dgr(gd);
460 if (dgr <= FTINY)
461 return(100.0);
462 return(100.*norm_integral(6.374-1.3227*log(dgr)));
463 }
464
465
466 static double
467 cie_cgi( /* compute CIE Glare Index */
468 struct glare_dir *gd
469 )
470 {
471 struct glare_src *gs;
472 FVECT mydir;
473 double dillum;
474 double p;
475 double sum;
476
477 spinvector(mydir, midview.vdir, midview.vup, gd->ang);
478 sum = 0.0;
479 for (gs = all_srcs; gs != NULL; gs = gs->next) {
480 p = posindex(gs->dir, mydir, midview.vup);
481 if (p <= FTINY)
482 continue;
483 sum += gs->lum*gs->lum * gs->dom / (p*p);
484 }
485 if (sum <= FTINY)
486 return(0.0);
487 dillum = direct(gd);
488 return(8.*log10(2.*sum*(1.+dillum/500.)/(dillum+gd->indirect)));
489 }
490
491
492 static double
493 ugr( /* compute Unified Glare Rating */
494 struct glare_dir *gd
495 )
496 {
497 struct glare_src *gs;
498 FVECT mydir;
499 double p;
500 double sum;
501
502 spinvector(mydir, midview.vdir, midview.vup, gd->ang);
503 sum = 0.0;
504 for (gs = all_srcs; gs != NULL; gs = gs->next) {
505 p = posindex(gs->dir, mydir, midview.vup);
506 if (p <= FTINY)
507 continue;
508 sum += gs->lum*gs->lum * gs->dom / (p*p);
509 }
510 if (sum <= FTINY)
511 return(0.0);
512 return(8.*log10(0.25*sum*PI/gd->indirect));
513 }
