root/radiance/ray/src/util/glarendx.c
Revision: 1.8
Committed: Thu May 2 13:17:41 1991 UTC (33 years, 1 month ago) by greg
Changes since 1.7: +30 -4 lines
added CGI (Einhorn) formula
1 /* Copyright (c) 1991 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Compute Glare Index given by program name:
9 *
10 * guth_dgr - Guth discomfort glare rating
11 * guth_vcp - Guth visual comfort probability
12 * cie_cgi - CIE Glare Index (1983)
13 *
14 * 12 April 1991 Greg Ward EPFL
15 */
16
17 #include "standard.h"
18 #include "view.h"
19
20 extern double erfc();
21
22 double posindex();
23 int headline();
24
25 double direct(), guth_dgr(), guth_vcp(), cie_cgi();
26
27 struct named_func {
28 char *name;
29 double (*func)();
30 } all_funcs[] = {
31 {"direct", direct},
32 {"guth_dgr", guth_dgr},
33 {"guth_vcp", guth_vcp},
34 {"cie_cgi", cie_cgi},
35 {NULL}
36 };
37
38 struct glare_src {
39 FVECT dir; /* source direction */
40 double dom; /* solid angle */
41 double lum; /* average luminance */
42 struct glare_src *next;
43 } *all_srcs = NULL;
44
45 struct glare_dir {
46 double ang; /* angle (in radians) */
47 double indirect; /* indirect illuminance */
48 struct glare_dir *next;
49 } *all_dirs = NULL;
50
51 #define newp(type) (type *)malloc(sizeof(type))
52
53 char *progname;
54 int print_header = 1;
55
56 VIEW midview = STDVIEW;
57
58 int wrongformat = 0;
59
60
61 main(argc, argv)
62 int argc;
63 char *argv[];
64 {
65 extern char *rindex();
66 struct named_func *funp;
67 char *progtail;
68 int i;
69 /* get program name */
70 progname = argv[0];
71 progtail = rindex(progname, '/'); /* final component */
72 if (progtail == NULL)
73 progtail = progname;
74 else
75 progtail++;
76 /* get options */
77 for (i = 1; i < argc && argv[i][0] == '-'; i++)
78 switch (argv[i][1]) {
79 case 't':
80 progtail = argv[++i];
81 break;
82 case 'h':
83 print_header = 0;
84 break;
85 default:
86 goto userr;
87 }
88 if (i < argc-1)
89 goto userr;
90 if (i == argc-1) /* open file */
91 if (freopen(argv[i], "r", stdin) == NULL) {
92 perror(argv[i]);
93 exit(1);
94 }
95 /* read header */
96 getheader(stdin, headline, NULL);
97 if (wrongformat) {
98 fprintf(stderr, "%s: bad input format\n", progname);
99 exit(1);
100 }
101 if (print_header) { /* add to header */
102 printargs(i, argv, stdout);
103 putchar('\n');
104 }
105 /* set view */
106 if (setview(&midview) != NULL) {
107 fprintf(stderr, "%s: bad view information in input\n",
108 progname);
109 exit(1);
110 }
111 /* get findglare data */
112 read_input();
113 /* find calculation */
114 for (funp = all_funcs; funp->name != NULL; funp++)
115 if (!strcmp(funp->name, progtail)) {
116 print_values(funp->func);
117 exit(0); /* we're done */
118 }
119 /* invalid function */
120 fprintf(stderr, "%s: unknown function!\n", progtail);
121 exit(1);
122 userr:
123 fprintf(stderr, "Usage: %s [-t type][-h] [input]\n", progname);
124 exit(1);
125 }
126
127
128 headline(s) /* get line from header */
129 char *s;
130 {
131 char fmt[32];
132
133 if (print_header) /* copy to output */
134 fputs(s, stdout);
135 if (!strncmp(s, VIEWSTR, VIEWSTRL))
136 sscanview(&midview, s+VIEWSTRL);
137 else if (isformat(s)) {
138 formatval(fmt, s);
139 wrongformat = strcmp(fmt, "ascii");
140 }
141 }
142
143
144 read_input() /* read glare sources from stdin */
145 {
146 #define S_SEARCH 0
147 #define S_SOURCE 1
148 #define S_DIREC 2
149 int state = S_SEARCH;
150 char buf[128];
151 register struct glare_src *gs;
152 register struct glare_dir *gd;
153
154 while (fgets(buf, sizeof(buf), stdin) != NULL)
155 switch (state) {
156 case S_SEARCH:
157 if (!strcmp(buf, "BEGIN glare source\n"))
158 state = S_SOURCE;
159 else if (!strcmp(buf, "BEGIN indirect illuminance\n"))
160 state = S_DIREC;
161 break;
162 case S_SOURCE:
163 if (!strncmp(buf, "END", 3)) {
164 state = S_SEARCH;
165 break;
166 }
167 if ((gs = newp(struct glare_src)) == NULL)
168 goto memerr;
169 if (sscanf(buf, "%lf %lf %lf %lf %lf",
170 &gs->dir[0], &gs->dir[1], &gs->dir[2],
171 &gs->dom, &gs->lum) != 5)
172 goto readerr;
173 normalize(gs->dir);
174 gs->next = all_srcs;
175 all_srcs = gs;
176 break;
177 case S_DIREC:
178 if (!strncmp(buf, "END", 3)) {
179 state = S_SEARCH;
180 break;
181 }
182 if ((gd = newp(struct glare_dir)) == NULL)
183 goto memerr;
184 if (sscanf(buf, "%lf %lf",
185 &gd->ang, &gd->indirect) != 2)
186 goto readerr;
187 gd->ang *= PI/180.0; /* convert to radians */
188 gd->next = all_dirs;
189 all_dirs = gd;
190 break;
191 }
192 return;
193 memerr:
194 perror(progname);
195 exit(1);
196 readerr:
197 fprintf(stderr, "%s: read error on input\n", progname);
198 exit(1);
199 #undef S_SEARCH
200 #undef S_SOURCE
201 #undef S_DIREC
202 }
203
204
205 print_values(funp) /* print out calculations */
206 double (*funp)();
207 {
208 register struct glare_dir *gd;
209
210 for (gd = all_dirs; gd != NULL; gd = gd->next)
211 printf("%f\t%f\n", gd->ang*(180.0/PI), (*funp)(gd));
212 }
213
214
215 double
216 direct(gd) /* compute direct illuminance */
217 struct glare_dir *gd;
218 {
219 FVECT mydir;
220 double d, dval;
221 register struct glare_src *gs;
222
223 spinvector(mydir, midview.vdir, midview.vup, gd->ang);
224 dval = 0.0;
225 for (gs = all_srcs; gs != NULL; gs = gs->next) {
226 d = DOT(mydir,gs->dir);
227 if (d > FTINY)
228 dval += d * gs->dom * gs->lum;
229 }
230 return(dval);
231 }
232
233
234 /*
235 * posindex - compute glare position index from:
236 *
237 * Source Direction
238 * View Direction
239 * View Up Direction
240 *
241 * All vectors are assumed to be normalized.
242 * This function is an implementation of the method proposed by
243 * Robert Levin in his 1975 JIES article.
244 * This calculation presumes the view direction and up vectors perpendicular.
245 * We return a value less than zero for improper positions.
246 */
247
248 double
249 posindex(sd, vd, vu) /* compute position index */
250 FVECT sd, vd, vu;
251 {
252 double sigma, tau;
253 double d;
254
255 d = DOT(sd,vd);
256 if (d <= 0.0)
257 return(-1.0);
258 if (d >= 1.0)
259 return(1.0);
260 sigma = acos(d) * (180./PI);
261 d = DOT(sd,vu)/sqrt(1.0-d*d);
262 if (d >= 1.0)
263 tau = 0.0;
264 else
265 tau = acos(d) * (180./PI);
266 return( exp( sigma*( (35.2 - tau*.31889 - 1.22*exp(-.22222*tau))*1e-3
267 + sigma*(21. + tau*(.26667 + tau*-.002963))*1e-5 )
268 ) );
269 }
270
271
272 double
273 guth_dgr(gd) /* compute Guth discomfort glare rating */
274 struct glare_dir *gd;
275 {
276 #define q(w) (20.4*w+1.52*pow(w,.2)-.075)
277 register struct glare_src *gs;
278 FVECT mydir;
279 double p;
280 double sum;
281 double wtot, brsum;
282 int n;
283
284 spinvector(mydir, midview.vdir, midview.vup, gd->ang);
285 sum = wtot = brsum = 0.0; n = 0;
286 for (gs = all_srcs; gs != NULL; gs = gs->next) {
287 p = posindex(gs->dir, mydir, midview.vup);
288 if (p <= FTINY)
289 continue;
290 sum += gs->lum * q(gs->dom) / p;
291 brsum += gs->lum * gs->dom;
292 wtot += gs->dom;
293 n++;
294 }
295 if (n == 0)
296 return(0.0);
297
298 return( pow(.5*sum/pow((brsum+(5.-wtot)*gd->indirect/PI)/5.,.44),
299 pow((double)n, -.0914) ) );
300 #undef q
301 }
302
303
304 extern double erf(), erfc();
305
306 #ifndef M_SQRT2
307 #define M_SQRT2 1.41421356237309504880
308 #endif
309
310 #define norm_integral(z) (1.-.5*erfc((z)/M_SQRT2))
311
312
313 double
314 guth_vcp(gd) /* compute Guth visual comfort probability */
315 struct glare_dir *gd;
316 {
317 double dgr;
318
319 dgr = guth_dgr(gd);
320 if (dgr <= FTINY)
321 return(100.0);
322 return(100.*norm_integral(6.374-1.3227*log(dgr)));
323 }
324
325
326 double
327 cie_cgi(gd) /* compute CIE Glare Index */
328 struct glare_dir *gd;
329 {
330 register struct glare_src *gs;
331 FVECT mydir;
332 double dillum;
333 double p;
334 double sum;
335
336 spinvector(mydir, midview.vdir, midview.vup, gd->ang);
337 sum = 0.0;
338 for (gs = all_srcs; gs != NULL; gs = gs->next) {
339 p = posindex(gs->dir, mydir, midview.vup);
340 if (p <= FTINY)
341 continue;
342 sum += gs->lum*gs->lum * gs->dom / (p*p);
343 }
344 if (sum <= FTINY)
345 return(0.0);
346 dillum = direct(gd);
347 return(8.*log10(2.*sum*(1.+dillum/500.)/(dillum+gd->indirect)));
348 }
